具体看下面完整的初始化代码:
- //配置串口1
- void USART1_Config()
- GPIO_InitTypeDef GPIO_InitStructure;
- USART_InitTypeDef USART_InitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
- //配置发送引脚
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- //发送引脚设置为推挽复用
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- //配置接收引脚
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- //接收引脚设置为浮空输入
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- //波特率
- USART_InitStructure.USART_BaudRate = 9600;
- //数据长度
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- //停止位
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- //校验位
- USART_InitStructure.USART_Parity = USART_Parity_No;
- //流控制
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- //打开发送和接收模式
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- //初始化串口1
- USART_Init(USART1, &USART_InitStructure);
- //USART1->SR寄存器复位后TC位为1,在此清零
- USART_ClearFlag(USART1, USART_FLAG_TC);
- //串口1使能
- USART_Cmd(USART1, ENABLE);
- //使能后串口发送一个空闲帧,等待空闲帧发送完毕后将TC标记位清零
- while(USART_GetFlagStatus(USART1, USART_FLAG_TC) != SET);
- //否则开启TC中断后会马上中断
- //配置中断优先级
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- 注意:初始化时不要随意打开TXE中断,
- 因为只要TX-DR寄存器为空,TX和TXE都会马上被置位而立即会产生中断
- //清除接收中断标记
- USART_ClearITPendingBit(USART1, USART_IT_RXNE);
- //清除发送完成中断标记
- USART_ClearITPendingBit(USART1, USART_IT_TC);
- //打开串口1发送完中断
- USART_ITConfig(USART1, USART_IT_TC, ENABLE);
- //打开串口1接收中断 两个中断不能在一个函数中同时打开!!!太坑了T_T
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
