vxworks 代码错误,谢谢!
3058|0
 楼主| at91rm9200 发表于 2007-12-13 09:19 | 显示全部楼层 |阅读模式
LOCAL AT91S_MciDeviceFeatures            MCI_Device_Features;
LOCAL  AT91S_MciDeviceDesc            MCI_Device_Desc;
LOCAL AT91S_MciDevice *                pMCI_Device=0;
/* SDCard Device Descriptor Structure Definition */
typedef struct    _AT91S_MciDeviceDesc
    volatile unsigned int    state;
    unsigned int            SDCard_bus_width;
} AT91S_MciDeviceDesc, *AT91PS_MciDeviceDesc;
/* MMC & SDCard Structure Device Features       */
typedef struct    _AT91S_MciDeviceFeatures
    unsigned int    Card_Inserted;                /* (0=AT91C_CARD_REMOVED) (1=AT91C_MMC_CARD_INSERTED) (2=AT91C_SD_CARD_INSERTED)*/
    unsigned int     Relative_Card_Address;        /* RCA*/
    unsigned int     Max_Read_DataBlock_Length;    /* 2^(READ_BL_LEN) in CSD */
    unsigned int     Max_Write_DataBlock_Length;    /* 2^(WRITE_BL_LEN) in CSD*/
    unsigned int    Read_Partial;                /* READ_BL_PARTIAL*/
    unsigned int    Write_Partial;                /* WRITE_BL_PARTIAL*/
    unsigned int    Erase_Block_Enable;            /* ERASE_BLK_EN*/
    unsigned int    Read_Block_Misalignment;    /* READ_BLK_MISALIGN*/
    unsigned int    Write_Block_Misalignment;    /* WRITE_BLK_MISALIGN*/
    unsigned int    Sector_Size;                /* SECTOR_SIZE*/
    unsigned int    Memory_Capacity;            /* Size in bits of the device*/
}    AT91S_MciDeviceFeatures, *AT91PS_MciDeviceFeatures ;
/* MCI Device Structure Definition                */
    BLK_DEV blkDev;
    int drive;
        int blkOffset    ;
    AT91PS_MciDeviceDesc             pMCI_DeviceDesc;    /* MCI device descriptor*/
    AT91PS_MciDeviceFeatures        pMCI_DeviceFeatures;/* Pointer on a MCI device features array  */
}AT91S_MciDevice, *AT91PS_MciDevice;
void AT91F_CfgDevice(AT91PS_MciDevice pmmcDev)
    /* Init Device Structure*/
    MCI_Device_Features.Relative_Card_Address         = 0;
    MCI_Device_Features.Card_Inserted                 = AT91C_CARD_REMOVED;
    MCI_Device_Features.Max_Read_DataBlock_Length    = 0;
    MCI_Device_Features.Max_Write_DataBlock_Length     = 0;
    MCI_Device_Features.Read_Partial                 = 0;
    MCI_Device_Features.Write_Partial                 = 0;
    MCI_Device_Features.Erase_Block_Enable             = 0;
    MCI_Device_Features.Sector_Size                 = 0;
    MCI_Device_Features.Memory_Capacity             = 0;
    MCI_Device_Desc.state                            = AT91C_MCI_IDLE;
    MCI_Device_Desc.SDCard_bus_width                = AT91C_MCI_SCDBUS;
    /* Init AT91S_DataFlash Global Structure, by default AT45DB choosen !!!*/
    pmmcDev->pMCI_DeviceDesc         = &MCI_Device_Desc;
    pmmcDev->pMCI_DeviceFeatures     = &MCI_Device_Features;
void mmcDevCreate(void)
    AT91PS_MciDevice pmmcDev;
    if ((pmmcDev = (AT91PS_MciDevice )calloc(sizeof (AT91PS_MciDevice), 1)) == NULL)
    return (NULL);
     pMCI_Device = pmmcDev;
     AT91F_CfgDevice(pmmcDev);
上面代码中,执行到
系统出错,提示信息如下:
Data abort
Exception address: 0x20013fe8
Current Processor Status Register: 0x20000013
trcStack aborted: error in top frame
shell restarted.
请问,这边可以直接给指针赋值?谢谢!
