| USB库函数里有些地方判断CID寄存器的bit8位,1或0执行不同操作,请问这位代表什么意思?参考手册上没有介绍
 1、if ((USBx->CID & (0x1U << 8)) != 0U)  {    if (cfg.speed == USBH_FSLS_SPEED)    {      /* Force Device Enumeration to FS/LS mode only */      USBx_HOST->HCFG |= USB_OTG_HCFG_FSLSS;    }    else    {      /* Set default Max speed support */      USBx_HOST->HCFG &= ~(USB_OTG_HCFG_FSLSS);    }  }  else  {    /* Set default Max speed support */    USBx_HOST->HCFG &= ~(USB_OTG_HCFG_FSLSS);  }2、if ((USBx->CID & (0x1U << 8)) != 0U)  {    /* set Rx FIFO size */    USBx->GRXFSIZ  = 0x200U;    USBx->DIEPTXF0_HNPTXFSIZ = (uint32_t)(((0x100U << 16) & USB_OTG_NPTXFD) | 0x200U);    USBx->HPTXFSIZ = (uint32_t)(((0xE0U << 16) & USB_OTG_HPTXFSIZ_PTXFD) | 0x300U);  }  else  {    /* set Rx FIFO size */    USBx->GRXFSIZ  = 0x80U;    USBx->DIEPTXF0_HNPTXFSIZ = (uint32_t)(((0x60U << 16) & USB_OTG_NPTXFD) | 0x80U);    USBx->HPTXFSIZ = (uint32_t)(((0x40U << 16)& USB_OTG_HPTXFSIZ_PTXFD) | 0xE0U);  }3、if ((USBx->CID & (0x1U << 8)) != 0U)        {          USBx_HC((uint32_t)ch_num)->HCINTMSK |= USB_OTG_HCINTMSK_NYET |                                                 USB_OTG_HCINTMSK_ACKM;        }4、if (((USBx->CID & (0x1U << 8)) != 0U) && (hc->speed == USBH_HS_SPEED))//CID bit8 host  {    /* in DMA mode host Core automatically issues ping  in case of NYET/NAK */    if ((dma == 1U) && ((hc->ep_type == EP_TYPE_CTRL) || (hc->ep_type == EP_TYPE_BULK)))    {      USBx_HC((uint32_t)ch_num)->HCINTMSK &= ~(USB_OTG_HCINTMSK_NYET |                                               USB_OTG_HCINTMSK_ACKM |                                               USB_OTG_HCINTMSK_NAKM);    }    if ((dma == 0U) && (hc->do_ping == 1U))    {      (void)USB_DoPing(USBx, hc->ch_num);      return HAL_OK;    }  }
 复制代码
