mm32f0010开发板 I2c读写Eeprom例程卡死
1167|0
Fay1011|  楼主 | 2023-2-9 14:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
运行 EEPROM_Read(0x00, gRxData, 8);会卡死,什么也不输出
例程代码如下
main.c:
s32 main(void)
    CONSOLE_Init(115200);
    DELAY_Init();
    I2C_WR_EepromInit();
    I2C_WR_EepromTest();
    while(1);
i2c.c:
void EEPROM_Read(u8 sub, u8* ptr, u16 len)
    do {
        //read data
        EEPROM_ReadPacket(sub, ptr, len);
        //till I2C is not work
        while(gEeprom.busy);
    } while(!gEeprom.ack);
void I2C_WR_EepromTest(void)
    u32 cnt;
    //Write 16 bytes from buffer0[128] to 0x10 of EEPROM
    EEPROM_Write(0x00, gTxData, 8);
    DELAY_Ms(1);
    for(cnt = 0; cnt < 8 ; cnt ++)
        printf("TX data%d is: %x \r\n", cnt, gTxData[cnt]);
    //Read 16 bytes from 0x10 of EEPROM to buffer1[128]
    for(cnt = 0; cnt < 8; cnt++) {
        printf("RX data%d is  : %x \r\n", cnt, gRxData[cnt]);
    printf("i2c1 polling test over\r\n");
