2410eboot遇到问题求解
2224|1
 楼主| redglass 发表于 2008-4-24 19:29 | 显示全部楼层 |阅读模式
boot, ST, TE, AD, dc
调试2410的wince遇到问题。下面的代码是eboot中打开mmu的代码,但是mmu打开后bl main就跳到了空的地址,之前到bl之前运行都是对的,小弟对于mmu不是太了解,有没有那位高手能帮我分析一下,不胜感激,最后付了OEMAddressTable
其中
PHYBASE     EQU 0x30000000  ; physical start
PTs     EQU 0x31E00000
GWMMUINIT
                ; Compute physical address of the OEMAddressTable.
20      add     r11, pc, #SDATA - (. + 8)
        ldr     r10, =PTs                ; (r10) = 1st level page table
        ; Setup 1st level page table (using section descriptor)
        ; Fill in first level page table entries to create "un-mapped" regions
        ; from the contents of the MemoryMap array.
        ;   (r11) = ptr to MemoryMap array
        add     r10, r10, #0x2000       ; (r10) = ptr to 1st PTE for "unmapped space"
        mov     r0, #0x0E               ; (r0) = PTE for 0: 1MB cachable bufferable
        orr     r0, r0, #0x400          ; set kernel r/w permission
25      mov     r1, r11                 ; (r1) = ptr to MemoryMap array
30      ldr     r2, [r1], #4            ; (r2) = virtual address to map Bank at
        ldr     r3, [r1], #4            ; (r3) = physical address to map from
        ldr     r4, [r1], #4            ; (r4) = num MB to map
        cmp     r4, #0                  ; End of table?
        beq     %f40
        ldr     r5, =0x1FF00000
        and     r2, r2, r5              ; VA needs 512MB, 1MB aligned.
        ldr     r5, =0xFFF00000
        and     r3, r3, r5              ; PA needs 4GB, 1MB aligned.
        add     r2, r10, r2, LSR #18
        add     r0, r0, r3              ; (r0) = PTE for next physical page
35      str     r0, [r2], #4
        add     r0, r0, #0x00100000     ; (r0) = PTE for next physical page
        sub     r4, r4, #1              ; Decrement number of MB left
        cmp     r4, #0
        bne     %b35                    ; Map next MB
        bic     r0, r0, #0xF0000000     ; Clear Section Base Address Field
        bic     r0, r0, #0x0FF00000     ; Clear Section Base Address Field
        b       %b30                    ; Get next element
40      tst     r0, #8
        bic     r0, r0, #0x0C           ; clear cachable & bufferable bits in PTE
        add     r10, r10, #0x0800       ; (r10) = ptr to 1st PTE for "unmapped uncached space"
        bne     %b25                    ; go setup PTEs for uncached space
        sub     r10, r10, #0x3000       ; (r10) = restore address of 1st level page table
        ; Setup mmu to map (VA == 0) to (PA == 0x30000000).
        ldr     r0, =PTs                ; PTE entry for VA = 0
        ldr     r1, =0x3000040E         ; uncache/unbuffer/rw, PA base == 0x30000000
        str     r1, [r0]
        ; uncached area.
        add     r0, r0, #0x0800         ; PTE entry for VA = 0x0200.0000 , uncached
        ldr     r1, =0x30000402         ; uncache/unbuffer/rw, base == 0x30000000
        str     r1, [r0]
        ; Comment:
        ; The following loop is to direct map RAM VA == PA. i.e.
        ;   VA == 0x30XXXXXX => PA == 0x30XXXXXX for S3C2400
        ; Fill in 8 entries to have a direct mapping for DRAM
        ldr     r10, =PTs               ; restore address of 1st level page table
        ldr     r0,  =PHYBASE
        add     r10, r10, #(0x3000 / 4) ; (r10) = ptr to 1st PTE for 0x30000000
        add     r0, r0, #0x1E           ; 1MB cachable bufferable
        mov     r1, #0
        mov     r3, #64
45      mov     r2, r1                  ; (r2) = virtual address to map Bank at
        cmp     r2, #0x20000000:SHR:BANK_SHIFT
        add     r2, r10, r2, LSL #BANK_SHIFT-18
        strlo   r0, [r2]
        subs    r3, r3, #1
        add     r1, r1, #1
        bgt     %b45
        ldr     r10, =PTs               ; (r10) = restore address of 1st level page table
        ; The page tables and exception vectors are setup.
        ; Initialize the MMU and turn it on.
        mov     r1, #1
        mcr     p15, 0, r1, c3, c0, 0   ; setup access to domain 0
        mcr     p15, 0, r10, c2, c0, 0
        mcr     p15, 0, r0, c8, c7, 0   ; flush I+D TLBs
        mov     r1, #0x0071             ; Enable: MMU
        orr     r1, r1, #0x0004         ; Enable the cache
        ldr     r0, =VirtualStart
        cmp     r0, #0                  ; make sure no stall on "mov pc,r0" below
        mcr     p15, 0, r1, c1, c0, 0
        mov     pc, r0                  ;  & jump to new virtual address
        nop
        ; MMU & caches now enabled.
        ;   (r10) = physcial address of 1st level page table
VirtualStart
        mov     sp, #0x8C000000
        add     sp, sp, #0x30000        ; arbitrary initial super-page stack pointer
        ldr     r0, = 0x91600054
        ldr     r1, = 0x80
        str     r1, [r0]
        bl        Main
    LTORG
SDATA DATA
    DCD 0x80000000, 0x02000000, 30  ; 30 MB SROM(SRAM/ROM) BANK 0
    DCD 0x82000000, 0x08000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 1
    DCD 0x84000000, 0x10000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 2
    DCD 0x86000000, 0x18000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 3
    DCD 0x88000000, 0x20000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 4
    DCD 0x8A000000, 0x28000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 5
    DCD 0x8C000000, 0x30000000, 64  ; 64 MB DRAM BANK 0,1
    DCD 0x90800000, 0x48000000,  1  ; Memory control register
    DCD 0x90900000, 0x49000000,  1  ; USB Host register
    DCD 0x90A00000, 0x4A000000,  1  ; Interrupt Control register
    DCD 0x90B00000, 0x4B000000,  1  ; DMA control register
    DCD 0x90C00000, 0x4C000000,  1  ; Clock & Power register
    DCD 0x90D00000, 0x4D000000,  1  ; LCD control register
    DCD 0x90E00000, 0x4E000000,  1  ; NAND flash control register
    DCD 0x91000000, 0x50000000,  1  ; UART control register
    DCD 0x91100000, 0x51000000,  1  ; PWM timer register
    DCD 0x91200000, 0x52000000,  1  ; USB device register
    DCD 0x91300000, 0x53000000,  1  ; Watchdog Timer register
    DCD 0x91400000, 0x54000000,  1  ; IIC control register
    DCD 0x91500000, 0x55000000,  1  ; IIS control register
    DCD 0x91600000, 0x56000000,  1  ; I/O Port register
    DCD 0x91700000, 0x57000000,  1  ; RTC control register
    DCD 0x91800000, 0x58000000,  1  ; A/D convert register
    DCD 0x91900000, 0x59000000,  1  ; SPI register
    DCD 0x91A00000, 0x5A000000,  1  ; SD Interface register
    DCD 0x92000000, 0x00000000,  2  ;  2 MB SROM(SRAM/ROM) BANK 0
    DCD 0x00000000, 0x00000000,  0  ; End of Table (MB MUST BE ZERO!)
      ALIGN
