TI CCS IDE轻松玩转MSP430
824|9
 楼主| szt1993 发表于 2023-2-23 17:17 | 显示全部楼层 |阅读模式
#申请原创#@21小跑堂
MSP430系列MCU下载驱动库的话肯定涉及驱动库的使用,下面咱们一起以MSP430 DriverLib for MSP430FR2xx_4xx Devices的驱动库为例给大家详细说明一下TI IDE CCS如何查阅相关的文档!
打开ccs后点击View界面,弹出相关试图菜单,其中Resource Exerplorer和Resource Exerplorer Offline就是搜索资源窗口,第一个是在线资源第二个是离线资源!
在在线资源下面的MSP430Ware (3.80.14.01)选择Libraries就会出现关于MSP430的相关文件
在Libraries库文件下选择Driver Library驱动库文件,驱动文件分MCU进行存放,选择需要的MCU进行查阅
驱动库文件下游各种驱动示例,以GPIO为例讲解一下:
点击GPIO会弹出相关的GPIO的相关案例程序,选择需要的查看API函数以及使用过程,里面讲解的很详细,里面的驱动库也比较齐全,唯一的缺点是相关讲解说明是英文的。
  1. /* --COPYRIGHT--,BSD
  2. * Copyright (c) 2017, Texas Instruments Incorporated
  3. * All rights reserved.
  4. *
  5. * Redistribution and use in source and binary forms, with or without
  6. * modification, are permitted provided that the following conditions
  7. * are met:
  8. *
  9. * *  Redistributions of source code must retain the above copyright
  10. *    notice, this list of conditions and the following disclaimer.
  11. *
  12. * *  Redistributions in binary form must reproduce the above copyright
  13. *    notice, this list of conditions and the following disclaimer in the
  14. *    documentation and/or other materials provided with the distribution.
  15. *
  16. * *  Neither the name of Texas Instruments Incorporated nor the names of
  17. *    its contributors may be used to endorse or promote products derived
  18. *    from this software without specific prior written permission.
  19. *
  20. * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  21. * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
  22. * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
  23. * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
  24. * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
  25. * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
  26. * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
  27. * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
  28. * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
  29. * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
  30. * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  31. * --/COPYRIGHT--*/
  32. //******************************************************************************
  33. //   Write a Word to Port A (Port1+Port2)
  34. //
  35. //   Writes a Word(FFFFh) to Port A and stays in LPM4
  36. //   ACLK = 32.768kHz, MCLK = SMCLK = default DCO
  37. //
  38. //  Tested On: MSP430FR4133
  39. //             -----------------
  40. //         /|\|                 |
  41. //          | |                 |
  42. //          --|RST          PA.x|-->HI
  43. //            |                 |
  44. //            |                 |
  45. //
  46. //
  47. //   This example uses the following peripherals and I/O signals.  You must
  48. //   review these and change as needed for your own board:
  49. //   - GPIO Port peripheral
  50. //
  51. //   This example uses the following interrupt handlers.  To use this example
  52. //   in your own application you must add these interrupt handlers to your
  53. //   vector table.
  54. //   - None.
  55. //******************************************************************************
  56. #include "driverlib.h"
  57. void main (void)
  58. {
  59.     //Stop WDT
  60.     WDT_A_hold(WDT_A_BASE);
  61.     //PA.x output
  62.     GPIO_setAsOutputPin(
  63.         GPIO_PORT_PA,
  64.         GPIO_PIN0 + GPIO_PIN1 + GPIO_PIN2 + GPIO_PIN3 +
  65.         GPIO_PIN4 + GPIO_PIN5 + GPIO_PIN6 + GPIO_PIN7 +
  66.         GPIO_PIN8 + GPIO_PIN9 + GPIO_PIN10 + GPIO_PIN11 +
  67.         GPIO_PIN12 + GPIO_PIN13 + GPIO_PIN14 + GPIO_PIN15
  68.         );
  69.     //Set all PA pins HI
  70.     GPIO_setOutputHighOnPin(
  71.         GPIO_PORT_PA,
  72.         GPIO_PIN0 + GPIO_PIN1 + GPIO_PIN2 + GPIO_PIN3 +
  73.         GPIO_PIN4 + GPIO_PIN5 + GPIO_PIN6 + GPIO_PIN7 +
  74.         GPIO_PIN8 + GPIO_PIN9 + GPIO_PIN10 + GPIO_PIN11 +
  75.         GPIO_PIN12 + GPIO_PIN13 + GPIO_PIN14 + GPIO_PIN15
  76.         );
  77.     PMM_unlockLPM5();
  78.     //Enter LPM4 w/interrupts enabled
  79.     __bis_SR_register(LPM4_bits + GIE);
  80.     //For debugger
  81.     __no_operation();
  82. }
整体的一个TI CCS 软件相关资料的查阅基本就是在线查找即可,非常方便快捷,对于新手来说也非常友好,只不过需要深入学习一下!
最后咱们说一下在线资源和离线资源的对比情况。
在线资源列表如下图:
离线资源列表如下图:
在线资源与离线资源对比总结如下:
1、离线资源就是下载的MSP430 Ware资源包含库、设备等
2、在线资源不仅包含MSP430的资源还包含其他的MCU资源、Hardware kits and boards等资源,种类更齐全
3、在线资源实时更新,所有库文件状态会有所变化
个人建议使用在线资源进行相关文档的查阅学习!
评分
参与人数 1威望 +10 收起 理由
xyz549040622 + 10 很给力!
查看全部评分
xyz549040622 发表于 2023-2-25 22:39 | 显示全部楼层
个人认为,TI的Resource  Explorer的是业界做的相当好的东西了,非常方便。
 楼主| szt1993 发表于 2023-2-28 10:26 | 显示全部楼层
确实,我感觉也是集成度非常高,而且运行还挺流畅
minzisc 发表于 2023-3-18 12:17 | 显示全部楼层
图形化开发单片机是趋势了。
abotomson 发表于 2023-3-18 13:56 | 显示全部楼层
CCS 这个软件还是非常不错的 。性能给力。
hilahope 发表于 2023-3-18 14:41 | 显示全部楼层
直接iar开发吧。
wangdezhi 发表于 2023-3-18 15:14 | 显示全部楼层
现在CCS的版本到哪里了
pentruman 发表于 2023-3-18 15:57 | 显示全部楼层
CCS IDE安装文件太大了。
gygp 发表于 2023-3-18 16:37 | 显示全部楼层
msp430好久没有用过了,感觉都非常陌生了。
zwsam 发表于 2023-3-24 21:44 | 显示全部楼层
