C++:记录一个错误 undefined reference to `vtable for
265|2
keer_zu|  楼主 | 2023-2-28 10:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
class AppStateListener
        :public ldra_class_1000030000 /* 75 */
  public :
  virtual ~AppStateListener () = default ;
     * [url=home.php?mod=space&uid=247401]@brief[/url] request the app starts to serve, such as start threads, apply for some resource
     * @param none
     * @param none
     * [url=home.php?mod=space&uid=266161]@return[/url] 0 indicates success
  virtual uint8_t onStart () = 0 ;
     * @brief request the app stops to serve, such as stop threads, release resource
     * @param none
     * @param none
     * @return 0 indicates success
  virtual uint8_t onStop () = 0 ;
     * @brief notify of SM changed state
     * @param fg function group
     * @param state current changed state of the fg
  virtual uint8_t
                  onStateChanged ( FG_TYPE fg , FG_STATE state )
#if defined(LDRA_dummy_global) || defined(LDRA_dummy_1_1)
   int ievent_handler_1zzqqzz
= event_handler_1zzqqzz        (       1 ) ; /* 37 */
    event_handler_1zzqqzz        (       2  ) ; /* 48 */
    return
    0 ;
#else
; /* end of prototype alternative */
#endif /* endof dummy_ */
出错:
undefined reference to `vtable for AppStateListener'
keer_zu|  楼主 | 2023-2-28 10:27 | 只看该作者
之前的原始形式:
class AppStateListener {
public:
    virtual ~AppStateListener() = default;
     * @brief request the app starts to serve, such as start threads, apply for some resource
     * @param none
     * @param none
    virtual uint8_t onStart() = 0;
     * @param none
     * @param none
    virtual uint8_t onStop() = 0;
    virtual uint8_t onStateChanged(FG_TYPE fg, FG_STATE state){return 0;};
不会报错
keer_zu|  楼主 | 2023-2-28 10:44 | 只看该作者
对比发现导致的原因是:
没有宏定义的时候,下面代码就是没有函数体的:
 virtual uint8_t
    return
    0 ;
#else
1455
