[PCB制造工艺] IPQ5018/QCN6102/QCN6122/WIFI6/INDUSTRIAL WIFI ROUTER/WALLYS
411|0
 楼主| wallysj 发表于 2023-4-4 15:33 | 显示全部楼层 |阅读模式
Unleash next-level network performance with IPQ5018 and QCN6102
The combination of Wallys' Routerboard DR5018 and QCN6102 can provide a powerful and versatile networking solution for businesses and individuals alike.
Wallys' Routerboard DR5018 is a high-performance router that features a powerful 1.8GHz dual-core CPU RAM IPQ5018, and dual-band Wi-Fi, making it an excellent choice for handling demanding networking tasks. It also includes multiple Gigabit Ethernet ports, allowing for easy integration with other devices on the network.
The QCN6102, on the other hand, is a high-speed network switch that provides up to 10Gbps of bandwidth per port, making it an ideal choice for high-bandwidth applications such as video streaming, large file transfers, and online gaming. It is a 2x2 MIMO (Multiple Input Multiple Output) LTE modem, which means it supports two antennas for both receiving and transmitting data.It also supports multiple VLANs, allowing for easy segmentation of the network and enhanced security.
Together, these two devices can provide a powerful and versatile networking solution that can meet the needs of a wide range of businesses and individuals. Whether you're looking to build a high-speed home network or a robust corporate infrastructure, the combination of Wallys' Routerboard DR5018 and QCN6102 can help you achieve your goals.In addition, this is also the cheapest wifi 6 combination.
