STM32 有时候会不断进入中断,解决方法如下
- 1.串口初始化配置时,需要打开ORE 溢出中断,如下红色代码所示
- void Usart_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- USART_InitTypeDef USART_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); // 开启串口时钟
- GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_1);
- GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_1);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- USART_InitStructure.USART_BaudRate = 57600; // 配置波特率为115200
- USART_InitStructure.USART_StopBits = USART_WordLength_8b; // 配置数据长度为8
- USART_InitStructure.USART_StopBits = USART_StopBits_1; //设置停止位
- USART_InitStructure.USART_Parity = USART_Parity_No; // 配置奇偶校验为NONE
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; // 配置硬件流为NONE
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; // 打开Rx接收和Tx发送功能
- USART_Init(USART1,&USART_InitStructure); // 配置
- USART_Cmd(USART1,ENABLE);
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; // 选择中断通道
- NVIC_InitStructure.NVIC_IRQChannelPriority = 2; // 抢断优先1
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; // 使能中断
- NVIC_Init(&NVIC_InitStructure);
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); // 打开中断
- USART_ITConfig(USART1, USART_IT_ORE, ENABLE); // 打开中断
