我前段时间买了个SPI接口的网口模块,有STM32F103例程,初始化如下:
- GPIO_InitTypeDef GPIO_InitStructure;
- SPI_InitTypeDef SPI_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_SPI1 | RCC_APB2Periph_AFIO, ENABLE);
- /* 初始化SCK、MISO、MOSI引脚 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- GPIO_SetBits(GPIOA,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
- /* 初始化CS引脚 */
- GPIO_InitStructure.GPIO_Pin = W5500_SCS;
- GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
- GPIO_Init(W5500_SCS_PORT, &GPIO_InitStructure);
- GPIO_SetBits(W5500_SCS_PORT, W5500_SCS);
- /* 初始化配置STM32 SPI1 */
- SPI_InitStructure.SPI_Direction=SPI_Direction_2Lines_FullDuplex; //SPI设置为双线双向全双工
- SPI_InitStructure.SPI_Mode=SPI_Mode_Master; //设置为主SPI
- SPI_InitStructure.SPI_DataSize=SPI_DataSize_8b; //SPI发送接收8位帧结构
- SPI_InitStructure.SPI_CPOL=SPI_CPOL_Low; //时钟悬空低
- SPI_InitStructure.SPI_CPHA=SPI_CPHA_1Edge; //数据捕获于第1个时钟沿
- SPI_InitStructure.SPI_NSS=SPI_NSS_Soft; //NSS由外部管脚管理
- SPI_InitStructure.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_2; //波特率预分频值为2
- SPI_InitStructure.SPI_FirstBit=SPI_FirstBit_MSB; //数据传输从MSB位开始
- SPI_InitStructure.SPI_CRCPolynomial=7; //CRC多项式为7
- SPI_Init(SPI1,&SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPI1寄存器
- SPI_Cmd(SPI1,ENABLE); //STM32使能SPI1
用STM32CubeMX生成的STM32F303的SPI代码如下:
- static void MX_SPI4_Init(void)
- /* USER CODE BEGIN SPI4_Init 0 */
- /* USER CODE END SPI4_Init 0 */
- /* USER CODE BEGIN SPI4_Init 1 */
- /* USER CODE END SPI4_Init 1 */
- /* SPI4 parameter configuration*/
- hspi4.Instance = SPI4;
- hspi4.Init.Mode = SPI_MODE_MASTER;
- hspi4.Init.Direction = SPI_DIRECTION_2LINES;
- hspi4.Init.DataSize = SPI_DATASIZE_8BIT;
- hspi4.Init.CLKPolarity = SPI_POLARITY_LOW;
- hspi4.Init.CLKPhase = SPI_PHASE_1EDGE;
- hspi4.Init.NSS = SPI_NSS_SOFT;
- hspi4.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
- hspi4.Init.FirstBit = SPI_FIRSTBIT_MSB;
- hspi4.Init.TIMode = SPI_TIMODE_DISABLE;
- hspi4.Init.CRCCalculation = SPI_CRCCALCULATION_ENABLE;
- hspi4.Init.CRCPolynomial = 7;
- hspi4.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
- hspi4.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
- if (HAL_SPI_Init(&hspi4) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN SPI4_Init 2 */
- /* USER CODE END SPI4_Init 2 */
- static void MX_GPIO_Init(void)
- GPIO_InitTypeDef GPIO_InitStruct = {0};
- /* USER CODE BEGIN MX_GPIO_Init_1 */
- /* USER CODE END MX_GPIO_Init_1 */
- __HAL_RCC_SPI4_CLK_ENABLE();
- /* GPIO Ports Clock Enable */
- __HAL_RCC_GPIOE_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- __HAL_RCC_GPIOB_CLK_ENABLE();
- __HAL_RCC_GPIOD_CLK_ENABLE();
- /*Configure GPIO pin Output Level */
- HAL_GPIO_WritePin(RST_GPIO_Port, RST_Pin, GPIO_PIN_SET);
- HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_SET);
- /*Configure GPIO pin : RST_Pin */
- GPIO_InitStruct.Pin = RST_Pin;
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
- HAL_GPIO_Init(RST_GPIO_Port, &GPIO_InitStruct);
- /*Configure GPIO pin : CS_Pin */
- GPIO_InitStruct.Pin = CS_Pin;
- HAL_GPIO_Init(CS_GPIO_Port, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = LED_Pin;
- HAL_GPIO_Init(LED_GPIO_Port, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = GPIO_PIN_2 |GPIO_PIN_5 | GPIO_PIN_6;
- GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
- HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
- // GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_5|GPIO_PIN_6;
- // GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- // GPIO_InitStruct.Pull = GPIO_NOPULL;
- // GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
- // HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
- /* USER CODE BEGIN MX_GPIO_Init_2 */
- /* USER CODE END MX_GPIO_Init_2 */
大神看看,初始化有没有错误?谢谢!
