GD32F303RCT6 CAN 125k 波特率以上没法工作
1649|5
 楼主| cc6379103 发表于 2023-5-5 11:58 | 显示全部楼层 |阅读模式
CAN 配置125k 及一下都可正常收发 125k 以上CAN无法收发数据请大佬帮忙看下
void CAN0_Config(u16 CAN_BAUDRATE)
    can_parameter_struct            can_parameter;
    can_filter_parameter_struct     can_filter;
    can_struct_para_init(CAN_INIT_STRUCT, &can_parameter);
    can_struct_para_init(CAN_FILTER_STRUCT, &can_filter);
    /* initialize CAN register */
    can_deinit(CAN0);
    /* initialize CAN parameters */
    can_parameter.time_triggered = DISABLE;
    can_parameter.auto_bus_off_recovery = ENABLE;
    can_parameter.auto_wake_up = DISABLE;
    can_parameter.auto_retrans = ENABLE;
    can_parameter.rec_fifo_overwrite = DISABLE;
    can_parameter.trans_fifo_order = DISABLE;
    can_parameter.working_mode = CAN_NORMAL_MODE;
    can_parameter.resync_jump_width = CAN_BT_SJW_1TQ;
//    can_parameter.time_segment_1 = CAN_BT_BS1_8TQ;
//    can_parameter.time_segment_2 = CAN_BT_BS2_1TQ;
    /* 1MBps */
    if (CAN_BAUDRATE == 1000)     //AHB1 主频60M / 1000
        can_parameter.prescaler = 6;
    /* 500KBps */
    else if (CAN_BAUDRATE == 500) //AHB1 主频60M / 500
        can_parameter.prescaler = 12;
    /* 250KBps */
    else if (CAN_BAUDRATE == 250) //AHB1 主频60M / 250
        can_parameter.prescaler = 24;
    /* 125KBps */
    else if (CAN_BAUDRATE == 125) //AHB1 主频60M / (SJW+BS1+BS2)/ prescaler
        can_parameter.prescaler = 48;
    /* 100KBps */
    else if (CAN_BAUDRATE == 100) //AHB1 主频60M / 100
        can_parameter.prescaler = 60;
    /* 50KBps */
    else if (CAN_BAUDRATE == 50)
        can_parameter.prescaler = 120;
    /* 20KBps */
    else if (CAN_BAUDRATE == 20)
        can_parameter.prescaler = 300;
    /* initialize CAN */
    can_init(CAN0, &can_parameter);
    /* initialize filter */
    can_filter.filter_number = 0;
    can_filter.filter_mode = CAN_FILTERMODE_MASK;
    can_filter.filter_bits = CAN_FILTERBITS_32BIT;
    can_filter.filter_list_high = 0x0000;
    can_filter.filter_list_low = 0x0000;
    can_filter.filter_mask_high = 0x0000;
    can_filter.filter_mask_low = 0x0000;
    can_filter.filter_fifo_number = CAN_FIFO1;
    can_filter.filter_enable = ENABLE;
    can_filter_init(&can_filter);
369122197 发表于 2023-5-5 12:23 | 显示全部楼层
303RCT6用户还挺多
elephant00 发表于 2024-2-7 16:33 | 显示全部楼层
时钟配置有误
两只袜子 发表于 2024-2-7 16:34 | 显示全部楼层
可能是总线负载
jcky001 发表于 2024-2-7 16:34 | 显示全部楼层
确保您连接的CAN收发器(如果有的话)支持您设置的波特率。有些收发器可能不支持非常高的波特率。
cr315 发表于 2024-2-7 16:35 | 显示全部楼层
中断和DMA通道是否已正确配置并且没有冲突。
