#ifndef HC32L17XA_H_ #define HC32L17XA_H_ #ifdef __cplusplus extern "C" { #endif #include "core_cm0plus.h" #include "system_hc32l17x.h" #include <stdint.h> #pragma region RCC //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR0; //---控制寄存器1 00 __IO uint32_t CR1; //---控制寄存器2 04 __IO uint32_t CR2; //---控制寄存器3 08 __IO uint32_t RCH; //---RCH控制寄存器 0C __IO uint32_t XTH; //---XTH控制寄存器 10 __IO uint32_t RCL; //---RCL控制寄存器 14 __IO uint32_t XTL; //---XTL置位清零寄存器 18 __IO uint32_t RSTSR; //---复位标识 1C __IO uint32_t PERENR0; //---外设时钟使能寄存器1 20 __IO uint32_t PERENR1; //---外设时钟使能寄存器2 24 __IO uint32_t PERRSTR0; //---外设时钟复位寄存器1 28 __IO uint32_t PERRSTR1; //---外设时钟复位寄存器2 2C uint32_t RESERVED[3]; //---保留 30 34 38 __IO uint32_t PLL; //---PLL控制寄存器 3C } RCC_TypeDef; //===>>>系统控制寄存器0的的功能 #define RCC_CR0_WAKEUP_BYRCH_POS 15 #define RCC_CR0_WAKEUP_BYRCH_MASK (0x01UL<<RCC_CR0_WAKEUP_BYRCH_POS) #define RCC_CR0_WAKEUP_BYRCH RCC_CR0_WAKEUP_BYRCH_MASK //===PCLK的时钟来源选择 #define RCC_CR0_PCLK_PRS_POS 11 #define RCC_CR0_PCLK_PRS_MASK (0x03UL<<RCC_CR0_PCLK_PRS_POS) #define RCC_CR0_PCLK_PRS RCC_CR0_PCLK_PRS_MASK //===PCLK的时钟分频数 #define RCC_CR0_PCLK_PRS_1 (0x00UL<<RCC_CR0_PCLK_PRS_POS) #define RCC_CR0_PCLK_PRS_2 (0x01UL<<RCC_CR0_PCLK_PRS_POS) #define RCC_CR0_PCLK_PRS_4 (0x02UL<<RCC_CR0_PCLK_PRS_POS) #define RCC_CR0_PCLK_PRS_8 (0x03UL<<RCC_CR0_PCLK_PRS_POS) //===HCLK的时钟来源选择 #define RCC_CR0_HCLK_PRS_POS 8 #define RCC_CR0_HCLK_PRS_MASK (0x07UL<<RCC_CR0_HCLK_PRS_POS) #define RCC_CR0_HCLK_PRS RCC_CR0_HCLK_PRS_MASK //===HCLK的时钟分频数 #define RCC_CR0_HCLK_PRS_1 (0x00UL<<RCC_CR0_HCLK_PRS_POS) #define RCC_CR0_HCLK_PRS_2 (0x01UL<<RCC_CR0_HCLK_PRS_POS) #define RCC_CR0_HCLK_PRS_4 (0x02UL<<RCC_CR0_HCLK_PRS_POS) #define RCC_CR0_HCLK_PRS_8 (0x03UL<<RCC_CR0_HCLK_PRS_POS) #define RCC_CR0_HCLK_PRS_16 (0x04UL<<RCC_CR0_HCLK_PRS_POS) #define RCC_CR0_HCLK_PRS_32 (0x05UL<<RCC_CR0_HCLK_PRS_POS) #define RCC_CR0_HCLK_PRS_64 (0x06UL<<RCC_CR0_HCLK_PRS_POS) #define RCC_CR0_HCLK_PRS_128 (0x07UL<<RCC_CR0_HCLK_PRS_POS) //===系统时钟的来源的时钟来源选择 #define RCC_CR0_CLKSW_POS 5 #define RCC_CR0_CLKSW_MASK (0x07UL<<RCC_CR0_CLKSW_POS) #define RCC_CR0_CLKSW RCC_CR0_CLKSW_MASK #define RCC_CR0_CLKSW_RCH (0x00UL<<RCC_CR0_CLKSW_POS) #define RCC_CR0_CLKSW_XTH (0x01UL<<RCC_CR0_CLKSW_POS) #define RCC_CR0_CLKSW_RCL (0x02UL<<RCC_CR0_CLKSW_POS) #define RCC_CR0_CLKSW_XTL (0x03UL<<RCC_CR0_CLKSW_POS) #define RCC_CR0_CLKSW_PLL (0x04UL<<RCC_CR0_CLKSW_POS) //===PLL使能控制 #define RCC_CR0_PLLEN_POS 4 #define RCC_CR0_PLLEN_MASK (0x01UL<<RCC_CR0_PLLEN_POS) #define RCC_CR0_PLLEN RCC_CR0_PLLEN_MASK //===XTL使能控制 #define RCC_CR0_XTLEN_POS 3 #define RCC_CR0_XTLEN_MASK (0x01UL<<RCC_CR0_XTLEN_POS) #define RCC_CR0_XTLEN RCC_CR0_XTLEN_MASK //===RCL使能控制 #define RCC_CR0_RCLEN_POS 2 #define RCC_CR0_RCLEN_MASK (0x01UL<<RCC_CR0_RCLEN_POS) #define RCC_CR0_RCLEN RCC_CR0_RCLEN_MASK //===XTH使能控制 #define RCC_CR0_XTHEN_POS 1 #define RCC_CR0_XTHEN_MASK (0x01UL<<RCC_CR0_XTHEN_POS) #define RCC_CR0_XTHEN RCC_CR0_XTHEN_MASK //===RCH使能控制 #define RCC_CR0_RCHEN_POS 0 #define RCC_CR0_RCHEN_MASK (0x01UL<<RCC_CR0_RCHEN_POS) #define RCC_CR0_RCHEN RCC_CR0_RCHEN_MASK //===<<<系统控制寄存器0的功能 //===>>>系统控制寄存器1的的功能 //===RTC高速补偿时钟使能控制 #define RCC_CR1_RTC_FREQ_ADJ_POS 9 #define RCC_CR1_RTC_FREQ_ADJ_MASK (0x07UL<<RCC_CR1_RTC_FREQ_ADJ_POS) #define RCC_CR1_RTC_FREQ_ADJ RCC_CR1_RTC_FREQ_ADJ_MASK #define RCC_CR1_RTC_FREQ_ADJ_4M (0x00UL<<RCC_CR1_RTC_FREQ_ADJ_POS) #define RCC_CR1_RTC_FREQ_ADJ_6M (0x01UL<<RCC_CR1_RTC_FREQ_ADJ_POS) #define RCC_CR1_RTC_FREQ_ADJ_8M (0x02UL<<RCC_CR1_RTC_FREQ_ADJ_POS) #define RCC_CR1_RTC_FREQ_ADJ_12M (0x03UL<<RCC_CR1_RTC_FREQ_ADJ_POS) #define RCC_CR1_RTC_FREQ_ADJ_16M (0x04UL<<RCC_CR1_RTC_FREQ_ADJ_POS) #define RCC_CR1_RTC_FREQ_ADJ_20M (0x05UL<<RCC_CR1_RTC_FREQ_ADJ_POS) #define RCC_CR1_RTC_FREQ_ADJ_24M (0x06UL<<RCC_CR1_RTC_FREQ_ADJ_POS) #define RCC_CR1_RTC_FREQ_ADJ_32M (0x07UL<<RCC_CR1_RTC_FREQ_ADJ_POS) //===SWD端口功能 #define RCC_CR1_SWD_AF_POS 8 #define RCC_CR1_SWD_AF_MASK (0x01UL<<RCC_CR1_SWD_AF_POS) #define RCC_CR1_SWD_AF RCC_CR1_SWD_AF_MASK //===锁定功能 #define RCC_CR1_LOCK_UP_POS 6 #define RCC_CR1_LOCK_UP_MASK (0x01UL<<RCC_CR1_LOCK_UP_POS) #define RCC_CR1_LOCK_UP RCC_CR1_LOCK_UP_MASK //===RTC低功耗模式 #define RCC_CR1_RTC_LPW_POS 5 #define RCC_CR1_RTC_LPW_MASK (0x01UL<<RCC_CR1_RTC_LPW_POS) #define RCC_CR1_RTC_LPW RCC_CR1_RTC_LPW_MASK //===RTC低功耗模式 #define RCC_CR1_XTL_ON_POS 3 #define RCC_CR1_XTL_ON_MASK (0x01UL<<RCC_CR1_XTL_ON_POS) #define RCC_CR1_XTL_ON RCC_CR1_XTL_ON_MASK //===外部XTL时钟输入控制 #define RCC_CR1_EXTL_EN_POS 2 #define RCC_CR1_EXTL_EN_MASK (0x01UL<<RCC_CR1_EXTL_EN_POS) #define RCC_CR1_EXTL_EN RCC_CR1_EXTL_EN_MASK //===外部XTH时钟输入控制 #define RCC_CR1_EXTH_EN_POS 1 #define RCC_CR1_EXTH_EN_MASK (0x01UL<<RCC_CR1_EXTH_EN_POS) #define RCC_CR1_EXTH_EN RCC_CR1_EXTH_EN_MASK //===<<<系统控制寄存器1的功能 //===>>>系统控制寄存器2的的功能 //===<<<系统控制寄存器2的功能 //===>>>RCH控制寄存器的的功能 #define RCC_RCH_STABLE_POS 11 #define RCC_RCH_STABLE_MASK (0x01UL<<RCC_RCH_STABLE_POS) #define RCC_RCH_STABLE RCC_RCH_STABLE_MASK #define RCC_RCH_TRIM_POS 0 #define RCC_RCH_TRIM_MASK (0x3FFUL<<RCC_RCH_TRIM_POS) #define RCC_RCH_TRIM RCC_RCH_TRIM_MASK //===内置频率的校准值 #ifndef USE_SIMULATOR #define RCC_RCH_TRIM_4M (*((volatile uint16_t*) (0x00100C08ul))) #define RCC_RCH_TRIM_8M (*((volatile uint16_t*) (0x00100C06ul))) #define RCC_RCH_TRIM_16M (*((volatile uint16_t*) (0x00100C04ul))) #define RCC_RCH_TRIM_22M12 (*((volatile uint16_t*) (0x00100C02ul))) #define RCC_RCH_TRIM_24M (*((volatile uint16_t*) (0x00100C00ul))) #else #define RCC_RCH_TRIM_4M (0x100) #define RCC_RCH_TRIM_8M (0x100) #define RCC_RCH_TRIM_16M (0x100) #define RCC_RCH_TRIM_22M12 (0x100) #define RCC_RCH_TRIM_24M (0x100) #endif //===<<<RCH控制寄存器的的功能 //===>>>XTH控制寄存器的的功能 #define RCC_XTH_STABLE_POS 6 #define RCC_XTH_STABLE_MASK (0x01UL<<RCC_XTH_STABLE_POS) #define RCC_XTH_STABLE RCC_XTH_STABLE_MASK #define RCC_XTH_STARTUP_POS 4 #define RCC_XTH_STARTUP_MASK (0x03UL<<RCC_XTH_STARTUP_POS) #define RCC_XTH_STARTUP RCC_XTH_STARTUP_MASK #define RCC_XTH_STARTUP_256_CLK (0x00UL<<RCC_XTH_STARTUP_POS) #define RCC_XTH_STARTUP_1024_CLK (0x01UL<<RCC_XTH_STARTUP_POS) #define RCC_XTH_STARTUP_4096_CLK (0x02UL<<RCC_XTH_STARTUP_POS) #define RCC_XTH_STARTUP_16384_CLK (0x03UL<<RCC_XTH_STARTUP_POS) #define RCC_XTH_FREQ_POS 2 #define RCC_XTH_FREQ_MASK (0x03UL<<RCC_XTH_FREQ_POS) #define RCC_XTH_FREQ RCC_XTH_FREQ_MASK #define RCC_XTH_FREQ_24M_32M (0x03UL<<RCC_XTH_FREQ_POS) #define RCC_XTH_FREQ_16M_24M (0x02UL<<RCC_XTH_FREQ_POS) #define RCC_XTH_FREQ_8M_16M (0x01UL<<RCC_XTH_FREQ_POS) #define RCC_XTH_FREQ_4M_8M (0x00UL<<RCC_XTH_FREQ_POS) #define RCC_XTH_DRIVER_POS 0 #define RCC_XTH_DRIVER_MASK (0x03UL<<RCC_XTH_DRIVER_POS) #define RCC_XTH_DRIVER RCC_XTH_DRIVER_MASK #define RCC_XTH_DRIVER_HIGH (0x03UL<<RCC_XTH_DRIVER_POS) #define RCC_XTH_DRIVER_NORMAL (0x02UL<<RCC_XTH_DRIVER_POS) #define RCC_XTH_DRIVER_LOW (0x01UL<<RCC_XTH_DRIVER_POS) #define RCC_XTH_DRIVER_VERY_LOW (0x00UL<<RCC_XTH_DRIVER_POS) //===<<<XTH控制寄存器的的功能 //===>>>RCL控制寄存器的的功能 #define RCC_RCL_STABLE_POS 12 #define RCC_RCL_STABLE_MASK (0x01UL<<RCC_RCL_STABLE_POS) #define RCC_RCL_STABLE RCC_RCL_STABLE_MASK #define RCC_RCL_STARTUP_POS 10 #define RCC_RCL_STARTUP_MASK (0x03UL<<RCC_RCL_STARTUP_POS) #define RCC_RCL_STARTUP RCC_RCL_STARTUP_MASK #define RCC_RCL_STARTUP_256_CLK (0x03UL<<RCC_RCL_STARTUP_POS) #define RCC_RCL_STARTUP_64_CLK (0x02UL<<RCC_RCL_STARTUP_POS) #define RCC_RCL_STARTUP_16_CLK (0x01UL<<RCC_RCL_STARTUP_POS) #define RCC_RCL_STARTUP_4_CLK (0x00UL<<RCC_RCL_STARTUP_POS) #define RCC_RCL_TRIM_POS 0 #define RCC_RCL_TRIM_MASK (0x1FFUL<<RCC_RCL_TRIM_POS) #define RCC_RCL_TRIM RCC_RCL_TRIM_MASK //===内置RCL频率的校准值 #ifndef USE_SIMULATOR #define RCC_RCL_TRIM_38K4 (*((volatile uint16_t*) (0x00100C20ul))) #define RCC_RCL_TRIM_32K768 (*((volatile uint16_t*) (0x00100C22ul))) #else #define RCC_RCL_TRIM_38K4 (0x100) #define RCC_RCL_TRIM_32K768 (0x100) #endif //===<<<RCL控制寄存器的的功能 //===>>>XTL控制寄存器的的功能 #define RCC_XTL_STABLE_POS 6 #define RCC_XTL_STABLE_MASK (0x01UL<<RCC_XTL_STABLE_POS) #define RCC_XTL_STABLE RCC_XTL_STABLE_MASK #define RCC_XTL_STARTUP_POS 4 #define RCC_XTL_STARTUP_MASK (0x03UL<<RCC_XTL_STARTUP_POS) #define RCC_XTL_STARTUP RCC_XTL_STARTUP_MASK #define RCC_XTL_STARTUP_256_CLK (0x00UL<<RCC_XTL_STARTUP_POS) #define RCC_XTL_STARTUP_1024_CLK (0x01UL<<RCC_XTL_STARTUP_POS) #define RCC_XTL_STARTUP_4096_CLK (0x02UL<<RCC_XTL_STARTUP_POS) #define RCC_XTL_STARTUP_16384_CLK (0x03UL<<RCC_XTL_STARTUP_POS) #define RCC_XTL_AMP_POS 2 #define RCC_XTL_AMP_MASK (0x03UL<<RCC_XTL_AMP_POS) #define RCC_XTL_AMP RCC_XTL_AMP_MASK #define RCC_XTL_AMP_VERY_HIGH (0x03UL<<RCC_XTL_AMP_POS) #define RCC_XTL_AMP_HIGH (0x02UL<<RCC_XTL_AMP_POS) #define RCC_XTL_AMP_NORMAL (0x01UL<<RCC_XTL_AMP_POS) #define RCC_XTL_AMP_LOW (0x00UL<<RCC_XTL_AMP_POS) #define RCC_XTL_DRIVER_POS 0 #define RCC_XTL_DRIVER_MASK (0x03UL<<RCC_XTL_DRIVER_POS) #define RCC_XTL_DRIVER RCC_XTL_DRIVER_MASK #define RCC_XTL_DRIVER_VERY_HIGH (0x03UL<<RCC_XTL_DRIVER_POS) #define RCC_XTL_DRIVER_HIGH (0x02UL<<RCC_XTL_DRIVER_POS) #define RCC_XTL_DRIVER_NORMAL (0x01UL<<RCC_XTL_DRIVER_POS) #define RCC_XTL_DRIVER_LOW (0x00UL<<RCC_XTL_DRIVER_POS) //===<<<XTL控制寄存器的的功能 //===>>>复位标识寄存器的功能 #define RCC_RSTSR_RST_POS 7 #define RCC_RSTSR_RST_MASK (0x01UL<<RCC_RSTSR_RST_POS) #define RCC_RSTSR_RST RCC_RSTSR_RST_MASK #define RCC_RSTSR_SYSREQ_POS 6 #define RCC_RSTSR_SYSREQ_MASK (0x01UL<<RCC_RSTSR_SYSREQ_POS) #define RCC_RSTSR_SYSREQ RCC_RSTSR_SYSREQ_MASK #define RCC_RSTSR_LOCKUP_POS 5 #define RCC_RSTSR_LOCKUP_MASK (0x01UL<<RCC_RSTSR_LOCKUP_POS) #define RCC_RSTSR_LOCKUP RCC_RSTSR_LOCKUP_MASK #define RCC_RSTSR_PCA_POS 4 #define RCC_RSTSR_PCA_MASK (0x01UL<<RCC_RSTSR_PCA_POS) #define RCC_RSTSR_PCA RCC_RSTSR_PCA_MASK #define RCC_RSTSR_WDT_POS 3 #define RCC_RSTSR_WDT_MASK (0x01UL<<RCC_RSTSR_WDT_POS) #define RCC_RSTSR_WDT RCC_RSTSR_WDT_MASK #define RCC_RSTSR_LVD_POS 2 #define RCC_RSTSR_LVD_MASK (0x01UL<<RCC_RSTSR_LVD_POS) #define RCC_RSTSR_LVD RCC_RSTSR_LVD_MASK #define RCC_RSTSR_PORVCAP_POS 1 #define RCC_RSTSR_PORVCAP_MASK (0x01UL<<RCC_RSTSR_PORVCAP_POS) #define RCC_RSTSR_PORVCAP RCC_RSTSR_PORVCAP_MASK #define RCC_RSTSR_PORVCC_POS 0 #define RCC_RSTSR_PORVCC_MASK (0x01UL<<RCC_RSTSR_PORVCC_POS) #define RCC_RSTSR_PORVCC RCC_RSTSR_PORVCC_MASK //===<<<复位标识寄存器的功能 //===>>>外围模块时钟控制寄存器0的功能 #define RCC_PER0ENR_UART0EN_POS 0 #define RCC_PER0ENR_UART0EN_MASK (0x01UL<<RCC_PER0ENR_UART0EN_POS) #define RCC_PER0ENR_UART0EN RCC_PER0ENR_UART0EN_MASK #define RCC_PER0ENR_UART1EN_POS 1 #define RCC_PER0ENR_UART1EN_MASK (0x01UL<<RCC_PER0ENR_UART1EN_POS) #define RCC_PER0ENR_UART1EN RCC_PER0ENR_UART1EN_MASK #define RCC_PER0ENR_LPUART0EN_POS 2 #define RCC_PER0ENR_LPUART0EN_MASK (0x01UL<<RCC_PER0ENR_LPUART0EN_POS) #define RCC_PER0ENR_LPUART0EN RCC_PER0ENR_LPUART0EN_MASK #define RCC_PER0ENR_LPUART1EN_POS 3 #define RCC_PER0ENR_LPUART1EN_MASK (0x01UL<<RCC_PER0ENR_LPUART1EN_POS) #define RCC_PER0ENR_LPUART1EN RCC_PER0ENR_LPUART1EN_MASK #define RCC_PER0ENR_I2C0EN_POS 4 #define RCC_PER0ENR_I2C0EN_MASK (0x01UL<<RCC_PER0ENR_I2C0EN_POS) #define RCC_PER0ENR_I2C0EN RCC_PER0ENR_I2C0EN_MASK #define RCC_PER0ENR_I2C1EN_POS 5 #define RCC_PER0ENR_I2C1EN_MASK (0x01UL<<RCC_PER0ENR_I2C1EN_POS) #define RCC_PER0ENR_I2C1EN RCC_PER0ENR_I2C1EN_MASK #define RCC_PER0ENR_SPI0EN_POS 6 #define RCC_PER0ENR_SPI0EN_MASK (0x01UL<<RCC_PER0ENR_SPI0EN_POS) #define RCC_PER0ENR_SPI0EN RCC_PER0ENR_SPI0EN_MASK #define RCC_PER0ENR_SPI1EN_POS 7 #define RCC_PER0ENR_SPI1EN_MASK (0x01UL<<RCC_PER0ENR_SPI1EN_POS) #define RCC_PER0ENR_SPI1EN RCC_PER0ENR_SPI1EN_MASK #define RCC_PER0ENR_TIM0EN_POS 8 #define RCC_PER0ENR_TIM0EN_MASK (0x01UL<<RCC_PER0ENR_TIM0EN_POS) #define RCC_PER0ENR_TIM0EN RCC_PER0ENR_TIM0EN_MASK #define RCC_PER0ENR_TIM1EN_POS 8 #define RCC_PER0ENR_TIM1EN_MASK (0x01UL<<RCC_PER0ENR_TIM1EN_POS) #define RCC_PER0ENR_TIM1EN RCC_PER0ENR_TIM1EN_MASK #define RCC_PER0ENR_TIM2EN_POS 8 #define RCC_PER0ENR_TIM2EN_MASK (0x01UL<<RCC_PER0ENR_TIM2EN_POS) #define RCC_PER0ENR_TIM2EN RCC_PER0ENR_TIM2EN_MASK #define RCC_PER0ENR_LPTIM0EN_POS 9 #define RCC_PER0ENR_LPTIM0EN_MASK (0x01UL<<RCC_PER0ENR_LPTIM0EN_POS) #define RCC_PER0ENR_LPTIM0EN RCC_PER0ENR_LPTIM0EN_MASK #define RCC_PER0ENR_TIM4EN_POS 10 #define RCC_PER0ENR_TIM4EN_MASK (0x01UL<<RCC_PER0ENR_TIM4EN_POS) #define RCC_PER0ENR_TIM4EN RCC_PER0ENR_TIM4EN_MASK #define RCC_PER0ENR_TIM5EN_POS 10 #define RCC_PER0ENR_TIM5EN_MASK (0x01UL<<RCC_PER0ENR_TIM5EN_POS) #define RCC_PER0ENR_TIM5EN RCC_PER0ENR_TIM5EN_MASK #define RCC_PER0ENR_TIM6EN_POS 10 #define RCC_PER0ENR_TIM6EN_MASK (0x01UL<<RCC_PER0ENR_TIM6EN_POS) #define RCC_PER0ENR_TIM6EN RCC_PER0ENR_TIM6EN_MASK #define RCC_PER0ENR_TIM3EN_POS 11 #define RCC_PER0ENR_TIM3EN_MASK (0x01UL<<RCC_PER0ENR_TIM3EN_POS) #define RCC_PER0ENR_TIM3EN RCC_PER0ENR_TIM3EN_MASK #define RCC_PER0ENR_OPAEN_POS 13 #define RCC_PER0ENR_OPAEN_MASK (0x01UL<<RCC_PER0ENR_OPAEN_POS) #define RCC_PER0ENR_OPAEN RCC_PER0ENR_OPAEN_MASK #define RCC_PER0ENR_PCAEN_POS 14 #define RCC_PER0ENR_PCAEN_MASK (0x01UL<<RCC_PER0ENR_PCAEN_POS) #define RCC_PER0ENR_PCAEN RCC_PER0ENR_PCAEN_MASK #define RCC_PER0ENR_WDTEN_POS 15 #define RCC_PER0ENR_WDTEN_MASK (0x01UL<<RCC_PER0ENR_WDTEN_POS) #define RCC_PER0ENR_WDTEN RCC_PER0ENR_WDTEN_MASK #define RCC_PER0ENR_ADCEN_POS 16 #define RCC_PER0ENR_ADCEN_MASK (0x01UL<<RCC_PER0ENR_ADCEN_POS) #define RCC_PER0ENR_ADCEN RCC_PER0ENR_ADCEN_MASK #define RCC_PER0ENR_VCEN_POS 17 #define RCC_PER0ENR_VCEN_MASK (0x01UL<<RCC_PER0ENR_VCEN_POS) #define RCC_PER0ENR_VCEN RCC_PER0ENR_VCEN_MASK #define RCC_PER0ENR_RNGEN_POS 18 #define RCC_PER0ENR_RNGEN_MASK (0x01UL<<RCC_PER0ENR_RNGEN_POS) #define RCC_PER0ENR_RNGEN RCC_PER0ENR_RNGEN_MASK #define RCC_PER0ENR_PCNTEN_POS 19 #define RCC_PER0ENR_PCNTEN_MASK (0x01UL<<RCC_PER0ENR_PCNTEN_POS) #define RCC_PER0ENR_PCNTEN RCC_PER0ENR_PCNTEN_MASK #define RCC_PER0ENR_RTCEN_POS 20 #define RCC_PER0ENR_RTCEN_MASK (0x01UL<<RCC_PER0ENR_RTCEN_POS) #define RCC_PER0ENR_RTCEN RCC_PER0ENR_RTCEN_MASK #define RCC_PER0ENR_TRIMEN_POS 21 #define RCC_PER0ENR_TRIMEN_MASK (0x01UL<<RCC_PER0ENR_TRIMEN_POS) #define RCC_PER0ENR_TRIMEN RCC_PER0ENR_TRIMEN_MASK #define RCC_PER0ENR_LCDEN_POS 22 #define RCC_PER0ENR_LCDEN_MASK (0x01UL<<RCC_PER0ENR_LCDEN_POS) #define RCC_PER0ENR_LCDEN RCC_PER0ENR_LCDEN_MASK #define RCC_PER0ENR_TICKEN_POS 24 #define RCC_PER0ENR_TICKEN_MASK (0x01UL<<RCC_PER0ENR_TICKEN_POS) #define RCC_PER0ENR_TICKEN RCC_PER0ENR_TICKEN_MASK #define RCC_PER0ENR_SWDEN_POS 25 #define RCC_PER0ENR_SWDEN_MASK (0x01UL<<RCC_PER0ENR_SWDEN_POS) #define RCC_PER0ENR_SWDEN RCC_PER0ENR_SWDEN_MASK #define RCC_PER0ENR_CRCEN_POS 26 #define RCC_PER0ENR_CRCEN_MASK (0x01UL<<RCC_PER0ENR_CRCEN_POS) #define RCC_PER0ENR_CRCEN RCC_PER0ENR_CRCEN_MASK #define RCC_PER0ENR_AESEN_POS 27 #define RCC_PER0ENR_AESEN_MASK (0x01UL<<RCC_PER0ENR_AESEN_POS) #define RCC_PER0ENR_AESEN RCC_PER0ENR_AESEN_MASK #define RCC_PER0ENR_GPIOEN_POS 28 #define RCC_PER0ENR_GPIOEN_MASK (0x01UL<<RCC_PER0ENR_GPIOEN_POS) #define RCC_PER0ENR_GPIOEN RCC_PER0ENR_GPIOEN_MASK #define RCC_PER0ENR_DMAEN_POS 29 #define RCC_PER0ENR_DMAEN_MASK (0x01UL<<RCC_PER0ENR_DMAEN_POS) #define RCC_PER0ENR_DMAEN RCC_PER0ENR_DMAEN_MASK #define RCC_PER0ENR_FLASHEN_POS 31 #define RCC_PER0ENR_FLASHEN_MASK (0x01UL<<RCC_PER0ENR_FLASHEN_POS) #define RCC_PER0ENR_FLASHEN RCC_PER0ENR_FLASHEN_MASK //===<<<外围模块时钟控制寄存器0的功能 //===>>>外围模块时钟控制寄存器1的功能 #define RCC_PER1ENR_DACEN_POS 3 #define RCC_PER1ENR_DACEN_MASK (0x01UL<<RCC_PER1ENR_DACEN_POS) #define RCC_PER1ENR_DACEN RCC_PER1ENR_DACEN_MASK #define RCC_PER1ENR_LPTIM1EN_POS 4 #define RCC_PER1ENR_LPTIM1EN_MASK (0x01UL<<RCC_PER1ENR_LPTIM1EN_POS) #define RCC_PER1ENR_LPTIM1EN RCC_PER1ENR_LPTIM1EN_POS #define RCC_PER1ENR_UART2EN_POS 8 #define RCC_PER1ENR_UART2EN_MASK (0x01UL<<RCC_PER1ENR_UART2EN_POS) #define RCC_PER1ENR_UART2EN RCC_PER1ENR_UART2EN_MASK #define RCC_PER1ENR_UART3EN_POS 9 #define RCC_PER1ENR_UART3EN_MASK (0x01UL<<RCC_PER1ENR_UART3EN_POS) #define RCC_PER1ENR_UART3EN RCC_PER1ENR_UART3EN_MASK //===<<<外围模块时钟控制寄存器1的功能 // //===>>>外围模块时钟复位寄存器0的功能 #define RCC_PER0RSTR_UART0RST_POS 0 #define RCC_PER0RSTR_UART0RST_MASK (0x01UL<<RCC_PER0RSTR_UART0RST_POS) #define RCC_PER0RSTR_UART0RST RCC_PER0RSTR_UART0RST_MASK #define RCC_PER0RSTR_UART1RST_POS 1 #define RCC_PER0RSTR_UART1RST_MASK (0x01UL<<RCC_PER0RSTR_UART1RST_POS) #define RCC_PER0RSTR_UART1RST RCC_PER0RSTR_UART1RST_MASK #define RCC_PER0RSTR_LPUART0RST_POS 2 #define RCC_PER0RSTR_LPUART0RST_MASK (0x01UL<<RCC_PER0RSTR_LPUART0RST_POS) #define RCC_PER0RSTR_LPUART0RST RCC_PER0RSTR_LPUART0RST_MASK #define RCC_PER0RSTR_LPUART1RST_POS 3 #define RCC_PER0RSTR_LPUART1RST_MASK (0x01UL<<RCC_PER0RSTR_LPUART1RST_POS) #define RCC_PER0RSTR_LPUART1RST RCC_PER0RSTR_LPUART1RST_MASK #define RCC_PER0RSTR_I2C0RST_POS 4 #define RCC_PER0RSTR_I2C0RST_MASK (0x01UL<<RCC_PER0RSTR_I2C0RST_POS) #define RCC_PER0RSTR_I2C0RST RCC_PER0RSTR_I2C0RST_MASK #define RCC_PER0RSTR_I2C1RST_POS 5 #define RCC_PER0RSTR_I2C1RST_MASK (0x01UL<<RCC_PER0RSTR_I2C1RST_POS) #define RCC_PER0RSTR_I2C1RST RCC_PER0RSTR_I2C1RST_MASK #define RCC_PER0RSTR_SPI0RST_POS 6 #define RCC_PER0RSTR_SPI0RST_MASK (0x01UL<<RCC_PER0RSTR_SPI0RST_POS) #define RCC_PER0RSTR_SPI0RST RCC_PER0RSTR_SPI0RST_MASK #define RCC_PER0RSTR_SPI1RST_POS 7 #define RCC_PER0RSTR_SPI1RST_MASK (0x01UL<<RCC_PER0RSTR_SPI1RST_POS) #define RCC_PER0RSTR_SPI1RST RCC_PER0RSTR_SPI1RST_MASK #define RCC_PER0RSTR_TIM0RST_POS 8 #define RCC_PER0RSTR_TIM0RST_MASK (0x01UL<<RCC_PER0RSTR_TIM0RST_POS) #define RCC_PER0RSTR_TIM0RST RCC_PER0RSTR_TIM0RST_MASK #define RCC_PER0RSTR_TIM1RST_POS 8 #define RCC_PER0RSTR_TIM1RST_MASK (0x01UL<<RCC_PER0RSTR_TIM1RST_POS) #define RCC_PER0RSTR_TIM1RST RCC_PER0RSTR_TIM1RST_MASK #define RCC_PER0RSTR_TIM2RST_POS 8 #define RCC_PER0RSTR_TIM2RST_MASK (0x01UL<<RCC_PER0RSTR_TIM2RST_POS) #define RCC_PER0RSTR_TIM2RST RCC_PER0RSTR_TIM2RST_MASK #define RCC_PER0RSTR_LPTIM0RST_POS 9 #define RCC_PER0RSTR_LPTIM0RST_MASK (0x01UL<<RCC_PER0RSTR_LPTIM0RST_POS) #define RCC_PER0RSTR_LPTIM0RST RCC_PER0RSTR_LPTIM0RST_MASK #define RCC_PER0RSTR_TIM4RST_POS 10 #define RCC_PER0RSTR_TIM4RST_MASK (0x01UL<<RCC_PER0RSTR_TIM4RST_POS) #define RCC_PER0RSTR_TIM4RST RCC_PER0RSTR_TIM4RST_MASK #define RCC_PER0RSTR_TIM5RST_POS 10 #define RCC_PER0RSTR_TIM5RST_MASK (0x01UL<<RCC_PER0RSTR_TIM5RST_POS) #define RCC_PER0RSTR_TIM5RST RCC_PER0RSTR_TIM5RST_MASK #define RCC_PER0RSTR_TIM6RST_POS 10 #define RCC_PER0RSTR_TIM6RST_MASK (0x01UL<<RCC_PER0RSTR_TIM6RST_POS) #define RCC_PER0RSTR_TIM6RST RCC_PER0RSTR_TIM6RST_MASK #define RCC_PER0RSTR_TIM3RST_POS 11 #define RCC_PER0RSTR_TIM3RST_MASK (0x01UL<<RCC_PER0RSTR_TIM3RST_POS) #define RCC_PER0RSTR_TIM3RST RCC_PER0RSTR_TIM3RST_MASK #define RCC_PER0RSTR_OPARST_POS 13 #define RCC_PER0RSTR_OPARST_MASK (0x01UL<<RCC_PER0RSTR_OPARST_POS) #define RCC_PER0RSTR_OPARST RCC_PER0RSTR_OPARST_MASK #define RCC_PER0RSTR_PCARST_POS 14 #define RCC_PER0RSTR_PCARST_MASK (0x01UL<<RCC_PER0RSTR_PCARST_POS) #define RCC_PER0RSTR_PCARST RCC_PER0RSTR_PCARST_MASK #define RCC_PER0RSTR_ADCRST_POS 16 #define RCC_PER0RSTR_ADCRST_MASK (0x01UL<<RCC_PER0RSTR_ADCRST_POS) #define RCC_PER0RSTR_ADCRST RCC_PER0RSTR_ADCRST_MASK #define RCC_PER0RSTR_VCRST_POS 17 #define RCC_PER0RSTR_VCRST_MASK (0x01UL<<RCC_PER0RSTR_VCRST_POS) #define RCC_PER0RSTR_VCRST RCC_PER0RSTR_VCRST_MASK #define RCC_PER0RSTR_RNGRST_POS 18 #define RCC_PER0RSTR_RNGRST_MASK (0x01UL<<RCC_PER0RSTR_RNGRST_POS) #define RCC_PER0RSTR_RNGRST RCC_PER0RSTR_RNGRST_MASK #define RCC_PER0RSTR_PCNTRST_POS 19 #define RCC_PER0RSTR_PCNTRST_MASK (0x01UL<<RCC_PER0RSTR_PCNTRST_POS) #define RCC_PER0RSTR_PCNTRST RCC_PER0RSTR_PCNTRST_MASK #define RCC_PER0RSTR_RTCRST_POS 20 #define RCC_PER0RSTR_RTCRST_MASK (0x01UL<<RCC_PER0RSTR_RTCRST_POS) #define RCC_PER0RSTR_RTCRST RCC_PER0RSTR_RTCRST_MASK #define RCC_PER0RSTR_TRIMRST_POS 21 #define RCC_PER0RSTR_TRIMRST_MASK (0x01UL<<RCC_PER0RSTR_TRIMRST_POS) #define RCC_PER0RSTR_TRIMRST RCC_PER0RSTR_TRIMRST_MASK #define RCC_PER0RSTR_LCDRST_POS 22 #define RCC_PER0RSTR_LCDRST_MASK (0x01UL<<RCC_PER0RSTR_LCDRST_POS) #define RCC_PER0RSTR_LCDRST RCC_PER0RSTR_LCDRST_MASK #define RCC_PER0RSTR_TICKRST_POS 24 #define RCC_PER0RSTR_TICKRST_MASK (0x01UL<<RCC_PER0RSTR_TICKRST_POS) #define RCC_PER0RSTR_TICKRST RCC_PER0RSTR_TICKRST_MASK #define RCC_PER0RSTR_SWDRST_POS 25 #define RCC_PER0RSTR_SWDRST_MASK (0x01UL<<RCC_PER0RSTR_SWDRST_POS) #define RCC_PER0RSTR_SWDRST RCC_PER0RSTR_SWDRST_MASK #define RCC_PER0RSTR_CRCRST_POS 26 #define RCC_PER0RSTR_CRCRST_MASK (0x01UL<<RCC_PER0RSTR_CRCRST_POS) #define RCC_PER0RSTR_CRCRST RCC_PER0RSTR_CRCRST_MASK #define RCC_PER0RSTR_AESRST_POS 27 #define RCC_PER0RSTR_AESRST_MASK (0x01UL<<RCC_PER0RSTR_AESRST_POS) #define RCC_PER0RSTR_AESRST RCC_PER0RSTR_AESRST_MASK #define RCC_PER0RSTR_GPIORST_POS 28 #define RCC_PER0RSTR_GPIORST_MASK (0x01UL<<RCC_PER0RSTR_GPIORST_POS) #define RCC_PER0RSTR_GPIORST RCC_PER0RSTR_GPIORST_MASK #define RCC_PER0RSTR_DMARST_POS 29 #define RCC_PER0RSTR_DMARST_MASK (0x01UL<<RCC_PER0RSTR_DMARST_POS) #define RCC_PER0RSTR_DMARST RCC_PER0RSTR_DMARST_MASK #define RCC_PER0RSTR_ALL (uint32_t)0xFFFFFFFFU //===<<<外围模块时钟复位寄存器0的功能 //===>>>外围模块时钟控制寄存器1的功能 #define RCC_PER1RSTR_DACRST_POS 3 #define RCC_PER1RSTR_DACRST_MASK (0x01UL<<RCC_PER1RSTR_DACRST_POS) #define RCC_PER1RSTR_DACRST RCC_PER1RSTR_DACRST_MASK #define RCC_PER1RSTR_LPTIM1RST_POS 4 #define RCC_PER1RSTR_LPTIM1RST_MASK (0x01UL<<RCC_PER1RSTR_LPTIM1RST_POS) #define RCC_PER1RSTR_LPTIM1RST RCC_PER1RSTR_LPTIM1RST_POS #define RCC_PER1RSTR_UART2RST_POS 8 #define RCC_PER1RSTR_UART2RST_MASK (0x01UL<<RCC_PER1RSTR_UART2RST_POS) #define RCC_PER1RSTR_UART2RST RCC_PER1RSTR_UART2RST_MASK #define RCC_PER1RSTR_UART3RST_POS 9 #define RCC_PER1RSTR_UART3RST_MASK (0x01UL<<RCC_PER1RSTR_UART3RST_POS) #define RCC_PER1RSTR_UART3RST RCC_PER1RSTR_UART3RST_MASK #define RCC_PER1RSTR_ALL (uint32_t)0xFFFFFFFFU //===<<<外围模块时钟控制寄存器1的功能 //===>>>XTL控制寄存器的的功能 #define RCC_PLL_STABLE_POS 18 #define RCC_PLL_STABLE_MASK (0x01UL<<RCC_PLL_STABLE_POS) #define RCC_PLL_STABLE RCC_PLL_STABLE_MASK #define RCC_PLL_STARTUP_POS 15 #define RCC_PLL_STARTUP_MASK (0x07UL<<RCC_PLL_STARTUP_POS) #define RCC_PLL_STARTUP RCC_PLL_STARTUP_MASK #define RCC_PLL_STARTUP_128_CLK (0x00UL<<RCC_PLL_STARTUP_POS) #define RCC_PLL_STARTUP_256_CLK (0x01UL<<RCC_PLL_STARTUP_POS) #define RCC_PLL_STARTUP_512_CLK (0x02UL<<RCC_PLL_STARTUP_POS) #define RCC_PLL_STARTUP_1024_CLK (0x03UL<<RCC_PLL_STARTUP_POS) #define RCC_PLL_STARTUP_2048_CLK (0x04UL<<RCC_PLL_STARTUP_POS) #define RCC_PLL_STARTUP_4096_CLK (0x05UL<<RCC_PLL_STARTUP_POS) #define RCC_PLL_STARTUP_8192_CLK (0x06UL<<RCC_PLL_STARTUP_POS) #define RCC_PLL_STARTUP_16384_CLK (0x07UL<<RCC_PLL_STARTUP_POS) //===PLL输入频率 #define RCC_PLL_IN_FREQ_POS 13 #define RCC_PLL_IN_FREQ_MASK (0x03UL<<RCC_PLL_IN_FREQ_POS) #define RCC_PLL_IN_FREQ RCC_PLL_IN_FREQ_MASK #define RCC_PLL_IN_FREQ_20M_24M (0x03UL<<RCC_PLL_IN_FREQ_POS) #define RCC_PLL_IN_FREQ_12M_20M (0x02UL<<RCC_PLL_IN_FREQ_POS) #define RCC_PLL_IN_FREQ_6M_12M (0x01UL<<RCC_PLL_IN_FREQ_POS) #define RCC_PLL_IN_FREQ_4M_6M (0x00UL<<RCC_PLL_IN_FREQ_POS) //===PLL倍频 #define RCC_PLL_DIVN_POS 5 #define RCC_PLL_DIVN_MASK (0x0FUL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN RCC_PLL_DIVN_MASK #define RCC_PLL_DIVN_2 (0x02UL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN_3 (0x03UL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN_4 (0x04UL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN_5 (0x05UL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN_6 (0x06UL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN_7 (0x07UL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN_8 (0x08UL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN_9 (0x09UL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN_10 (0x0AUL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN_11 (0x0BUL<<RCC_PLL_DIVN_POS) #define RCC_PLL_DIVN_12 (0x0CUL<<RCC_PLL_DIVN_POS) //===PLL输出频率 #define RCC_PLL_OUT_FREQ_POS 2 #define RCC_PLL_OUT_FREQ_MASK (0x07UL<<RCC_PLL_OUT_FREQ_POS) #define RCC_PLL_OUT_FREQ RCC_PLL_OUT_FREQ_MASK #define RCC_PLL_OUT_FREQ_8M_12M (0x00UL<<RCC_PLL_OUT_FREQ_POS) #define RCC_PLL_OUT_FREQ_12M_18M (0x01UL<<RCC_PLL_OUT_FREQ_POS) #define RCC_PLL_OUT_FREQ_18M_24M (0x02UL<<RCC_PLL_OUT_FREQ_POS) #define RCC_PLL_OUT_FREQ_24M_36M (0x03UL<<RCC_PLL_OUT_FREQ_POS) #define RCC_PLL_OUT_FREQ_36M_48M (0x04UL<<RCC_PLL_OUT_FREQ_POS) //===输入时钟选择 #define RCC_PLL_REF_POS 0 #define RCC_PLL_REF_MASK (0x07UL<<RCC_PLL_REF_POS) #define RCC_PLL_REF RCC_PLL_REF_MASK #define RCC_PLL_REF_XTH (0x00UL<<RCC_PLL_REF_POS) #define RCC_PLL_REF_BYPASS (0x01UL<<RCC_PLL_REF_POS) #define RCC_PLL_REF_RCH (0x03UL<<RCC_PLL_REF_POS) //===<<<XTL控制寄存器的的功能 #pragma endregion #pragma region GPIO //===端口复用功能配置寄存器 typedef struct { __IO uint32_t SEL[16]; //---端口选择功能 /* __IO uint32_t SEL01; //---端口选择功能 __IO uint32_t SEL02; //---端口选择功能 __IO uint32_t SEL03; //---端口选择功能 __IO uint32_t SEL04; //---端口选择功能 __IO uint32_t SEL05; //---端口选择功能 __IO uint32_t SEL06; //---端口选择功能 __IO uint32_t SEL07; //---端口选择功能 __IO uint32_t SEL08; //---端口选择功能 __IO uint32_t SEL09; //---端口选择功能 __IO uint32_t SEL10; //---端口选择功能 __IO uint32_t SEL11; //---端口选择功能 __IO uint32_t SEL12; //---端口选择功能 __IO uint32_t SEL13; //---端口选择功能 __IO uint32_t SEL14; //---端口选择功能 __IO uint32_t SEL15; //---端口选择功能 */ } GPIO_AF_TypeDef; //===端口通用功能配置寄存器 typedef struct { __IO uint32_t DIR; //---配置输入输出模式模式 00 __IO uint32_t IDR; //---输入数据寄存器 04 __IO uint32_t ODR; //---输出数据寄存器 08 __IO uint32_t ADS; //---数模配置寄存器 0c __IO uint32_t BSET; //---置位寄存器 10 __IO uint32_t BCLR; //---清零寄存器 14 __IO uint32_t BSETCLR; //---置位清零寄存器 18 __IO uint32_t DRIVER; //---驱动能力寄存器 1c __IO uint32_t PU; //---上拉使能寄存器 20 __IO uint32_t PD; //---下拉使能寄存器 24 uint32_t RESERVED; //---保留字节 __IO uint32_t OD; //---开漏输出寄存器 2c } GPIO_TypeDef; //===端口辅助功能配置寄存器 typedef struct { __IO uint32_t CTRL1; //---端口辅助功能配置寄存器1 04 __IO uint32_t CTRL2; //---端口辅助功能配置寄存器1 08 __IO uint32_t TIMGS; //---端口辅助定时器门控选择 0c __IO uint32_t TIMES; //---端口辅助定时器ETR控选择 10 __IO uint32_t TIMCPS; //---端口辅助定时器输入捕获选择 14 __IO uint32_t PCAS; //---端口辅助PCA捕获选择 18 __IO uint32_t PCNTS; //---端口辅助PCNT脉冲输入选择 1c } GPIO_Sub_TypeDef; #define GPIO_AF_CTRL1_IR_POS 14 #define GPIO_AF_CTRL1_IR_MASK (0x01UL<<GPIO_AF_CTRL1_IR_POS) #define GPIO_AF_CTRL1_IR GPIO_AF_CTRL1_IR_MASK #define GPIO_AF_CTRL1_HCLK_EN_POS 13 #define GPIO_AF_CTRL1_HCLK_EN_MASK (0x01UL<<GPIO_AF_CTRL1_HCLK_EN_POS) #define GPIO_AF_CTRL1_HCLK_EN GPIO_AF_CTRL1_HCLK_EN_MASK #define GPIO_AF_CTRL1_PCLK_EN_POS 13 #define GPIO_AF_CTRL1_PCLK_EN_MASK (0x01UL<<GPIO_AF_CTRL1_PCLK_EN_POS) #define GPIO_AF_CTRL1_PCLK_EN GPIO_AF_CTRL1_PCLK_EN_MASK #define GPIO_AF_CTRL1_HCLK_SEL_POS 10 #define GPIO_AF_CTRL1_HCLK_SEL_MASK (0x03UL<<GPIO_AF_CTRL1_HCLK_SEL_POS) #define GPIO_AF_CTRL1_HCLK_SEL GPIO_AF_CTRL1_HCLK_SEL_MASK #define GPIO_AF_CTRL1_HCLK_PRS_1 (0x00UL<<GPIO_AF_CTRL1_HCLK_SEL_POS) #define GPIO_AF_CTRL1_HCLK_PRS_2 (0x01UL<<GPIO_AF_CTRL1_HCLK_SEL_POS) #define GPIO_AF_CTRL1_HCLK_PRS_4 (0x02UL<<GPIO_AF_CTRL1_HCLK_SEL_POS) #define GPIO_AF_CTRL1_HCLK_PRS_8 (0x03UL<<GPIO_AF_CTRL1_HCLK_SEL_POS) #define GPIO_AF_CTRL1_PCLK_SEL_POS 8 #define GPIO_AF_CTRL1_PCLK_SEL_MASK (0x03UL<<GPIO_AF_CTRL1_PCLK_SEL_POS) #define GPIO_AF_CTRL1_PCLK_SEL GPIO_AF_CTRL1_PCLK_SEL_MASK #define GPIO_AF_CTRL1_PCLK_PRS_1 (0x00UL<<GPIO_AF_CTRL1_PCLK_SEL_POS) #define GPIO_AF_CTRL1_PCLK_PRS_2 (0x01UL<<GPIO_AF_CTRL1_PCLK_SEL_POS) #define GPIO_AF_CTRL1_PCLK_PRS_4 (0x02UL<<GPIO_AF_CTRL1_PCLK_SEL_POS) #define GPIO_AF_CTRL1_PCLK_PRS_8 (0x03UL<<GPIO_AF_CTRL1_PCLK_SEL_POS) #define GPIO_AF_CTRL1_SPI0_SS_POS 4 #define GPIO_AF_CTRL1_SPI0_SS_MASK (0x0FUL<<GPIO_AF_CTRL1_SPI0_SS_POS) #define GPIO_AF_CTRL1_SPI0_SS GPIO_AF_CTRL1_SPI0_SS_MASK #define GPIO_AF_CTRL1_EXT_CLK_POS 0 #define GPIO_AF_CTRL1_EXT_CLK_MASK (0x0FUL<<GPIO_AF_CTRL1_EXT_CLK_POS) #define GPIO_AF_CTRL1_EXT_CLK GPIO_AF_CTRL1_EXT_CLK_MASK #define GPIO_AF_CTRL2_AHB_POS 15 #define GPIO_AF_CTRL2_AHB_MASK (0x01UL<<GPIO_AF_CTRL2_AHB_POS) #define GPIO_AF_CTRL2_AHB GPIO_AF_CTRL2_AHB_MASK #define GPIO_AF_CTRL2_TCLK_DIV_POS 6 #define GPIO_AF_CTRL2_TCLK_DIV_MASK (0x03UL<<GPIO_AF_CTRL2_TCLK_DIV_POS) #define GPIO_AF_CTRL2_TCLK_DIV GPIO_AF_CTRL2_TCLK_DIV_MASK #define GPIO_AF_CTRL2_TCLK_SEL_POS 4 #define GPIO_AF_CTRL2_TCLK_SEL_MASK (0x03UL<<GPIO_AF_CTRL2_TCLK_SEL_POS) #define GPIO_AF_CTRL2_TCLK_SEL GPIO_AF_CTRL2_TCLK_SEL_MASK #define GPIO_AF_CTRL2_SPI1_SS_POS 0 #define GPIO_AF_CTRL2_SPI1_SS_MASK (0x0FUL<<GPIO_AF_CTRL2_SPI1_SS_POS) #define GPIO_AF_CTRL2_SPI1_SS GPIO_AF_CTRL2_SPI1_SS_MASK //===端口定时器门控选择 #define GPIO_AF_TIMGS_LPTIM0_POS 12 #define GPIO_AF_TIMGS_LPTIM0_MASK (0x07UL<<GPIO_AF_TIMGS_LPTIM0_POS) #define GPIO_AF_TIMGS_LPTIM0 GPIO_AF_TIMGS_LPTIM0_MASK #define GPIO_AF_TIMGS_TIM3_POS 9 #define GPIO_AF_TIMGS_TIM3_MASK (0x07UL<<GPIO_AF_TIMGS_TIM3_POS) #define GPIO_AF_TIMGS_TIM3 GPIO_AF_TIMGS_TIM3_MASK #define GPIO_AF_TIMGS_TIM2_POS 6 #define GPIO_AF_TIMGS_TIM2_MASK (0x07UL<<GPIO_AF_TIMGS_TIM2_POS) #define GPIO_AF_TIMGS_TIM2 GPIO_AF_TIMGS_TIM2_MASK #define GPIO_AF_TIMGS_TIM1_POS 3 #define GPIO_AF_TIMGS_TIM1_MASK (0x07UL<<GPIO_AF_TIMGS_TIM1_POS) #define GPIO_AF_TIMGS_TIM1 GPIO_AF_TIMGS_TIM1_MASK #define GPIO_AF_TIMGS_TIM0_POS 0 #define GPIO_AF_TIMGS_TIM0_MASK (0x07UL<<GPIO_AF_TIMGS_TIM0_POS) #define GPIO_AF_TIMGS_TIM0 GPIO_AF_TIMGS_TIM0_MASK //===定时器ETR输入选择 #define GPIO_AF_TIMES_LPTIM0_POS 12 #define GPIO_AF_TIMES_LPTIM0_MASK (0x07UL<<GPIO_AF_TIMES_LPTIM0_POS) #define GPIO_AF_TIMES_LPTIM0 GPIO_AF_TIMES_LPTIM0_MASK #define GPIO_AF_TIMES_TIM3_POS 9 #define GPIO_AF_TIMES_TIM3_MASK (0x07UL<<GPIO_AF_TIMES_TIM3_POS) #define GPIO_AF_TIMES_TIM3 GPIO_AF_TIMES_TIM3_MASK #define GPIO_AF_TIMES_TIM2_POS 6 #define GPIO_AF_TIMES_TIM2_MASK (0x07UL<<GPIO_AF_TIMES_TIM2_POS) #define GPIO_AF_TIMES_TIM2 GPIO_AF_TIMES_TIM2_MASK #define GPIO_AF_TIMES_TIM1_POS 3 #define GPIO_AF_TIMES_TIM1_MASK (0x07UL<<GPIO_AF_TIMES_TIM1_POS) #define GPIO_AF_TIMES_TIM1 GPIO_AF_TIMES_TIM1_MASK #define GPIO_AF_TIMES_TIM0_POS 0 #define GPIO_AF_TIMES_TIM0_MASK (0x07UL<<GPIO_AF_TIMES_TIM0_POS) #define GPIO_AF_TIMES_TIM0 GPIO_AF_TIMES_TIM0_MASK //===输入捕捉通道选择 #define GPIO_AF_TIMCPS_TIM3_CH0B_POS 12 #define GPIO_AF_TIMCPS_TIM3_CH0B_MASK (0x07UL<<GPIO_AF_TIMCPS_TIM3_CH0B_POS) #define GPIO_AF_TIMCPS_TIM3_CH0B GPIO_AF_TIMCPS_TIM3_CH0B_MASK #define GPIO_AF_TIMCPS_TIM3_CH0A_POS 9 #define GPIO_AF_TIMCPS_TIM3_CH0A_MASK (0x07UL<<GPIO_AF_TIMCPS_TIM3_CH0A_POS) #define GPIO_AF_TIMCPS_TIM3_CH0A GPIO_AF_TIMCPS_TIM3_CH0A_MASK #define GPIO_AF_TIMCPS_TIM2_CH0A_POS 6 #define GPIO_AF_TIMCPS_TIM2_CH0A_MASK (0x07UL<<GPIO_AF_TIMCPS_TIM2_CH0A_POS) #define GPIO_AF_TIMCPS_TIM2_CH0A GPIO_AF_TIMCPS_TIM2_CH0A_MASK #define GPIO_AF_TIMCPS_TIM1_CH0A_POS 3 #define GPIO_AF_TIMCPS_TIM1_CH0A_MASK (0x07UL<<GPIO_AF_TIMCPS_TIM1_CH0A_POS) #define GPIO_AF_TIMCPS_TIM1_CH0A GPIO_AF_TIMCPS_TIM1_CH0A_MASK #define GPIO_AF_TIMCPS_TIM0_CH0A_POS 0 #define GPIO_AF_TIMCPS_TIM0_CH0A_MASK (0x07UL<<GPIO_AF_TIMCPS_TIM0_CH0A_POS) #define GPIO_AF_TIMCPS_TIM0_CH0A GPIO_AF_TIMCPS_TIM0_CH0A_MASK //===PCA捕获选择 #define GPIO_AF_PCAS_LPTIM1_ETR_POS 9 #define GPIO_AF_PCAS_LPTIM1_ETR_MASK (0x07UL<<GPIO_AF_PCAS_LPTIM1_ETR_POS) #define GPIO_AF_PCAS_LPTIM1_ETR GPIO_AF_PCAS_LPTIM1_ETR_MASK #define GPIO_AF_PCAS_LPTIM1_GATE_POS 6 #define GPIO_AF_PCAS_LPTIM1_GATE_MASK (0x07UL<<GPIO_AF_PCAS_LPTIM1_GATE_POS) #define GPIO_AF_PCAS_LPTIM1_GATE GPIO_AF_PCAS_LPTIM1_GATE_MASK #define GPIO_AF_PCAS_PCA_EC1_POS 3 #define GPIO_AF_PCAS_PCA_EC1_MASK (0x07UL<<GPIO_AF_PCAS_PCA_EC1_POS) #define GPIO_AF_PCAS_PCA_EC1 GPIO_AF_PCAS_PCA_EC1_MASK #define GPIO_AF_PCAS_PCA_CH0_POS 0 #define GPIO_AF_PCAS_PCA_CH0_MASK (0x07UL<<GPIO_AF_PCAS_PCA_CH0_POS) #define GPIO_AF_PCAS_PCA_CH0 GPIO_AF_PCAS_PCA_CH0_MASK //===PCNT输入选择 #define GPIO_AF_PCNTS_PCNT_S1_POS 2 #define GPIO_AF_PCNTS_PCNT_S1_MASK (0x03UL<<GPIO_AF_PCNTS_PCNT_S1_POS) #define GPIO_AF_PCNTS_PCNT_S1 GPIO_AF_PCNTS_PCNT_S1_MASK #define GPIO_AF_PCNTS_PCNT_S0_POS 0 #define GPIO_AF_PCNTS_PCNT_S0_MASK (0x03UL<<GPIO_AF_PCNTS_PCNT_S0_POS) #define GPIO_AF_PCNTS_PCNT_S0 GPIO_AF_PCNTS_PCNT_S0_MASK #pragma endregion //===外部中断 #pragma region EXTI //===端口通用功能配置寄存器 typedef struct { __IO uint32_t HIE; //---高电平中断使能 130 __IO uint32_t LIE; //---低电平中断使能 134 __IO uint32_t RIE; //---上升沿中断使能 138 __IO uint32_t FIE; //---下降沿中断使能 13c uint32_t RESERVED1[48]; //---保留字节 __IO uint32_t SR; //---中断状态 200 uint32_t RESERVED2[3]; //---保留字节 __IO uint32_t CSR; //---清除中断状态 210 } EXIT_TypeDef; #define EXIT_PIN_0_POS 0 #define EXIT_PIN_0_MASK (0x01UL<<EXIT_PIN_0_POS) #define EXIT_PIN_0 EXIT_PIN_0_MASK #define EXIT_PIN_1_POS 1 #define EXIT_PIN_1_MASK (0x01UL<<EXIT_PIN_1_POS) #define EXIT_PIN_1 EXIT_PIN_1_MASK #define EXIT_PIN_2_POS 2 #define EXIT_PIN_2_MASK (0x01UL<<EXIT_PIN_2_POS) #define EXIT_PIN_2 EXIT_PIN_2 #define EXIT_PIN_3_POS 3 #define EXIT_PIN_3_MASK (0x01UL<<EXIT_PIN_3_POS) #define EXIT_PIN_3 EXIT_PIN_3_MASK #define EXIT_PIN_4_POS 4 #define EXIT_PIN_4_MASK (0x01UL<<EXIT_PIN_4_POS) #define EXIT_PIN_4 EXIT_PIN_4_MASK #define EXIT_PIN_5_POS 5 #define EXIT_PIN_5_MASK (0x01UL<<EXIT_PIN_5_POS) #define EXIT_PIN_5 EXIT_PIN_5_MASK #define EXIT_PIN_6_POS 6 #define EXIT_PIN_6_MASK (0x01UL<<EXIT_PIN_6_POS) #define EXIT_PIN_6 EXIT_PIN_6_MASK #define EXIT_PIN_7_POS 7 #define EXIT_PIN_7_MASK (0x01UL<<EXIT_PIN_7_POS) #define EXIT_PIN_7 EXIT_PIN_7_MASK #define EXIT_PIN_8_POS 8 #define EXIT_PIN_8_MASK (0x01UL<<EXIT_PIN_8_POS) #define EXIT_PIN_8 EXIT_PIN_8_MASK #define EXIT_PIN_9_POS 9 #define EXIT_PIN_9_MASK (0x01UL<<EXIT_PIN_9_POS) #define EXIT_PIN_9 EXIT_PIN_9_MASK #define EXIT_PIN_10_POS 10 #define EXIT_PIN_10_MASK (0x01UL<<EXIT_PIN_10_POS) #define EXIT_PIN_10 EXIT_PIN_10_MASK #define EXIT_PIN_11_POS 11 #define EXIT_PIN_11_MASK (0x01UL<<EXIT_PIN_11_POS) #define EXIT_PIN_11 EXIT_PIN_11_MASK #define EXIT_PIN_12_POS 12 #define EXIT_PIN_12_MASK (0x01UL<<EXIT_PIN_12_POS) #define EXIT_PIN_12 EXIT_PIN_12_MASK #define EXIT_PIN_13_POS 13 #define EXIT_PIN_13_MASK (0x01UL<<EXIT_PIN_13_POS) #define EXIT_PIN_13 EXIT_PIN_13_MASK #define EXIT_PIN_14_POS 14 #define EXIT_PIN_14_MASK (0x01UL<<EXIT_PIN_14_POS) #define EXIT_PIN_14 EXIT_PIN_14_MASK #define EXIT_PIN_15_POS 15 #define EXIT_PIN_15_MASK (0x01UL<<EXIT_PIN_15_POS) #define EXIT_PIN_15 EXIT_PIN_15_MASK #pragma endregion #pragma region CRC //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR; //---控制寄存器 __IO uint32_t DR; //---数据寄存器 04 uint32_t RESERVED[30]; //---保留字节 __IO uint32_t IDR; //---输入数据寄存器 80 } CRC_TypeDef; //===CRC编码格式,CRC16或者CRC32 #define CRC_CR_ENCODE_POS 0 #define CRC_CR_ENCODE_MASK (0x01U<<CRC_CR_ENCODE_POS) #define CRC_CR_ENCODE CRC_CR_ENCODE_MASK //===CRC校验结果 #define CRC_CR_FLAG_POS 1 #define CRC_CR_FLAG_MASK (0x01U<<CRC_CR_FLAG_POS) #define CRC_CR_FLAG CRC_CR_FLAG_MASK //===CRC16编码 #define CRC_CR_CRC16 0 //===CRC32编码 #define CRC_CR_CRC32 1 //===CRC校验错误 #define CRC_CR_FLAG_ERR 0 //===CRC校验成功 #define CRC_CR_FLAG_OK 1 #pragma endregion #pragma region I2C //===端口通用功能配置寄存器 typedef struct { __IO uint32_t TMRUN; //---时钟寄存器1 __IO uint32_t TM; //---时钟寄存器2 __IO uint32_t CR; //---控制寄存器 __IO uint32_t DR; //---数据寄存器 __IO uint32_t ADDR; //---地址寄存器 __IO uint32_t SR; //---状态寄存器 } I2C_TypeDef; #define I2C_TMRUN_TME_POS 0 #define I2C_TMRUN_TME_MASK (0x01U<<I2C_TMRUN_TME_POS) #define I2C_TMRUN_TME I2C_TMRUN_TME_MASK #define I2C_TM_POS 0 #define I2C_TM_MASK (0xFFU<<I2C_TM_POS) #define I2C_TM I2C_TM_MASK #define I2C_CR_EN_POS 6 #define I2C_CR_EN_MASK (0x01U<<I2C_CR_EN_POS) #define I2C_CR_EN I2C_CR_EN_MASK #define I2C_CR_START_POS 5 #define I2C_CR_START_MASK (0x01U<<I2C_CR_START_POS) #define I2C_CR_START I2C_CR_START_MASK #define I2C_CR_STOP_POS 4 #define I2C_CR_STOP_MASK (0x01U<<I2C_CR_STOP_POS) #define I2C_CR_STOP I2C_CR_STOP_MASK #define I2C_CR_IE_FLAG_POS 3 #define I2C_CR_IE_FLAG_MASK (0x01U<<I2C_CR_IE_FLAG_POS) #define I2C_CR_IE_FLAG I2C_CR_IE_FLAG_MASK #define I2C_CR_ACK_POS 2 #define I2C_CR_ACK_MASK (0x01U<<I2C_CR_ACK_POS) #define I2C_CR_ACK I2C_CR_ACK_MASK #define I2C_CR_FILTER_POS 0 #define I2C_CR_FILTER_MASK (0x01U<<I2C_CR_FILTER_POS) #define I2C_CR_FILTER I2C_CR_FILTER_MASK #define I2C_DATA_POS 0 #define I2C_DATA_MASK (0xFFU<<I2C_DATA_POS) #define I2C_DATA I2C_DATA_MASK #define I2C_ADDR_SLAVE_POS 1 #define I2C_ADDR_SLAVE_MASK (0x7FU<<I2C_ADDR_SLAVE_POS) #define I2C_ADDR_SLAVE I2C_ADDR_SLAVE_MASK #define I2C_ADDR_GC_POS 0 #define I2C_ADDR_GC_MASK (0x01U<<I2C_ADDR_GC_POS) #define I2C_ADDR_GC I2C_ADDR_GC_MASK #define I2C_STATE_POS 0 #define I2C_STATE_MASK (0xFFU<<I2C_STATE_POS) #define I2C_STATE I2C_STATE_MASK #define I2C_STATE_M_START 0X08 #define I2C_STATE_M_RESTART 0X10 #define I2C_STATE_M_ERR 0X38 #define I2C_STATE_MT_ADDR_ACK 0X18 #define I2C_STATE_MT_ADDR_NACK 0X20 #define I2C_STATE_MT_DATA_ACK 0X28 #define I2C_STATE_MT_DATA_NACK 0X30 #define I2C_STATE_MR_ADDR_ACK 0X40 #define I2C_STATE_MR_ADDR_NACK 0X48 #define I2C_STATE_MR_DATA_ACK 0X50 #define I2C_STATE_MR_DATA_NACK 0X58 #define I2C_STATE_STATIC_ADDR 0XA0 #define I2C_STATE_SR_ADDR_ACK 0X60 #define I2C_STATE_SR_ADDR_ERR_ACK 0X68 #define I2C_STATE_SR_DATA_ACK 0X80 #define I2C_STATE_SR_DATA_NACK 0X88 #define I2C_STATE_ST_ADDR_ACK 0XA8 #define I2C_STATE_ST_ADDR_ERR_ACK 0XB0 #define I2C_STATE_ST_DATA_ACK 0XB8 #define I2C_STATE_ST_DATA_NACK 0XC0 #define I2C_STATE_ST_DATA_LOAD_ACK 0XC8 #define I2C_STATE_GC_ADDR_ACK 0X70 #define I2C_STATE_GC_ADDR_ERR_ACK 0X78 #define I2C_STATE_GC_DATA_ACK 0X78 #define I2C_STATE_GC_DATA_NACK 0X98 #define I2C_STATE_NONE 0XF8 #define I2C_STATE_ERR 0X00 #pragma endregion #pragma region SPI //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR; //---配置寄存器1 00 __IO uint32_t SSN; //---片选配置寄存器 04 __IO uint32_t SR; //---状态寄存器 08 __IO uint32_t DR; //---数据寄存器 0C __IO uint32_t CR2; //---配置寄存器2 10 __IO uint32_t CSR; //---状态清除寄存器 14 } SPI_TypeDef; #define SPI_CR_BAUDRATE_SPR2_POS 7 #define SPI_CR_BAUDRATE_SPR2_MASK (0x01U<<SPI_CR_BAUDRATE_SPR2_POS) #define SPI_CR_BAUDRATE_SPR2 SPI_CR_BAUDRATE_SPR2_MASK #define SPI_CR_EN_POS 6 #define SPI_CR_EN_MASK (0x01U<<SPI_CR_EN_POS) #define SPI_CR_EN SPI_CR_EN_MASK #define SPI_CR_MODE_POS 4 #define SPI_CR_MODE_MASK (0x01U<<SPI_CR_MODE_POS) #define SPI_CR_MODE SPI_CR_MODE_MASK #define SPI_CR_MODE_MASTER SPI_CR_MODE #define SPI_CR_MODE_SLAVE (~SPI_CR_MODE) #define SPI_CR_CPOL_POS 3 #define SPI_CR_CPOL_MASK (0x01U<<SPI_CR_CPOL_POS) #define SPI_CR_CPOL SPI_CR_CPOL_MASK #define SPI_CR_CPOL_LOW (~SPI_CR_CPOL) #define SPI_CR_CPOL_HIGH (SPI_CR_CPOL) #define SPI_CR_CPHA_POS 2 #define SPI_CR_CPHA_MASK (0x01U<<SPI_CR_CPHA_POS) #define SPI_CR_CPHA SPI_CR_CPHA_MASK #define SPI_CR_CPHA_1EDGE (~SPI_CR_CPHA) #define SPI_CR_CPHA_2EDGE (SPI_CR_CPHA) #define SPI_CR_BAUDRATE_SPR1_POS 1 #define SPI_CR_BAUDRATE_SPR1_MASK (0x01U<<SPI_CR_BAUDRATE_SPR1_POS) #define SPI_CR_BAUDRATE_SPR1 SPI_CR_BAUDRATE_SPR1_MASK #define SPI_CR_BAUDRATE_SPR0_POS 0 #define SPI_CR_BAUDRATE_SPR0_MASK (0x01U<<SPI_CR_BAUDRATE_SPR0_POS) #define SPI_CR_BAUDRATE_SPR0 SPI_CR_BAUDRATE_SPR0_MASK #define SPI_CR_BAUDRATE_SPR (SPI_CR_BAUDRATE_SPR0|SPI_CR_BAUDRATE_SPR1|SPI_CR_BAUDRATE_SPR2) #define SPI_CR_SCK_PRE_2 ((0x00U<<SPI_CR_BAUDRATE_SPR2_POS)|(0x00U<<SPI_CR_BAUDRATE_SPR1_POS)|(0x00U<<SPI_CR_BAUDRATE_SPR0_POS)) #define SPI_CR_SCK_PRE_4 ((0x00U<<SPI_CR_BAUDRATE_SPR2_POS)|(0x00U<<SPI_CR_BAUDRATE_SPR1_POS)|(0x01U<<SPI_CR_BAUDRATE_SPR0_POS)) #define SPI_CR_SCK_PRE_8 ((0x00U<<SPI_CR_BAUDRATE_SPR2_POS)|(0x01U<<SPI_CR_BAUDRATE_SPR1_POS)|(0x00U<<SPI_CR_BAUDRATE_SPR0_POS)) #define SPI_CR_SCK_PRE_16 ((0x00U<<SPI_CR_BAUDRATE_SPR2_POS)|(0x01U<<SPI_CR_BAUDRATE_SPR1_POS)|(0x01U<<SPI_CR_BAUDRATE_SPR0_POS)) #define SPI_CR_SCK_PRE_32 ((0x01U<<SPI_CR_BAUDRATE_SPR2_POS)|(0x00U<<SPI_CR_BAUDRATE_SPR1_POS)|(0x00U<<SPI_CR_BAUDRATE_SPR0_POS)) #define SPI_CR_SCK_PRE_64 ((0x01U<<SPI_CR_BAUDRATE_SPR2_POS)|(0x00U<<SPI_CR_BAUDRATE_SPR1_POS)|(0x01U<<SPI_CR_BAUDRATE_SPR0_POS)) #define SPI_CR_SCK_PRE_128 ((0x01U<<SPI_CR_BAUDRATE_SPR2_POS)|(0x01U<<SPI_CR_BAUDRATE_SPR1_POS)|(0x00U<<SPI_CR_BAUDRATE_SPR0_POS)) #define SPI_SSN_SSN_POS 0 #define SPI_SSN_SSN_MASK (0x01U<<SPI_SSN_SSN_POS) #define SPI_SSN_SSN SPI_SSN_SSN_MASK #define SPI_SR_SPIF_POS 7 #define SPI_SR_SPIF_MASK (0x01U<<SPI_SR_SPIF_POS) #define SPI_SR_SPIF SPI_SR_SPIF_MASK #define SPI_SR_SSERR_POS 5 #define SPI_SR_SSERR_MASK (0x01U<<SPI_SR_SSERR_POS) #define SPI_SR_SSERR SPI_SR_SSERR_MASK #define SPI_SR_MDF_POS 4 #define SPI_SR_MDF_MASK (0x01U<<SPI_SR_MDF_POS) #define SPI_SR_MDF SPI_SR_MDF_MASK #define SPI_SR_BUSY_POS 3 #define SPI_SR_BUSY_MASK (0x01U<<SPI_SR_BUSY_POS) #define SPI_SR_BUSY SPI_SR_BUSY_MASK #define SPI_SR_TXE_POS 2 #define SPI_SR_TXE_MASK (0x01U<<SPI_SR_TXE_POS) #define SPI_SR_TXE SPI_SR_TXE_MASK #define SPI_SR_RXNE_POS 1 #define SPI_SR_RXNE_MASK (0x01U<<SPI_SR_RXNE_POS) #define SPI_SR_RXNE SPI_SR_RXNE_MASK #define SPI_DR_POS 0 #define SPI_DR_MASK (0xFFUL<<SPI_DR_POS) #define SPI_DR SPI_DR_MASK #define SPI_CR2_RXNEIE_POS 6 #define SPI_CR2_RXNEIE_MASK (0x01U<<SPI_CR2_RXNEIE_POS) #define SPI_CR2_RXNEIE SPI_CR2_RXNEIE_MASK #define SPI_CR2_TXEIE_POS 5 #define SPI_CR2_TXEIE_MASK (0x01U<<SPI_CR2_TXEIE_POS) #define SPI_CR2_TXEIE SPI_CR2_TXEIE_MASK #define SPI_CR2_DMATXEN_POS 4 #define SPI_CR2_DMATXEN_MASK (0x01U<<SPI_CR2_DMATXEN_POS) #define SPI_CR2_DMATXEN SPI_CR2_DMATXEN_MASK #define SPI_CR2_DMARXEN_POS 3 #define SPI_CR2_DMARXEN_MASK (0x01U<<SPI_CR2_DMARXEN_POS) #define SPI_CR2_DMARXEN SPI_CR2_DMARXEN_MASK #define SPI_CR2_IE_POS 2 #define SPI_CR2_IE_MASK (0x01U<<SPI_CR2_IE_POS) #define SPI_CR2_IE SPI_CR2_IE_MASK #define SPI_CSR_IE_POS 0 #define SPI_CSR_IE_MASK (0x01U<<SPI_CSR_IE_POS) #define SPI_CSR_IE SPI_CSR_IE_MASK #pragma endregion #pragma region USART //===端口通用功能配置寄存器 typedef struct { __IO uint32_t SBUF; //---数据寄存器 __IO uint32_t SCON; //---控制寄存器 __IO uint32_t SADDR; //---地址寄存器寄存器 __IO uint32_t SADEN; //---地址寄存器寄存器 __IO uint32_t SR; //---状态寄存器 __IO uint32_t CSR; //---状态清除寄存器 __IO uint32_t SCNT; //---波特率寄存器 } USART_TypeDef; //===>>>USART控制寄存器的的功能 //===单线半双工模式使能位 #define USART_SCON_HDSEL_POS 22 #define USART_SCON_HDSEL_MASK (0x01U<<USART_SCON_HDSEL_POS) #define USART_SCON_HDSEL USART_SCON_HDSEL_MASK //===帧错误中断使能位 #define USART_SCON_FEIE_POS 21 #define USART_SCON_FEIE_MASK (0x01U<<USART_SCON_FEIE_POS) #define USART_SCON_FEIE USART_SCON_FEIE_MASK //===CTS信号翻转中断使能位 #define USART_SCON_CTSIE_POS 20 #define USART_SCON_CTSIE_MASK (0x01U<<USART_SCON_CTSIE_POS) #define USART_SCON_CTSIE USART_SCON_CTSIE_MASK //===硬件流控制使能位 #define USART_SCON_CTSEN_POS 19 #define USART_SCON_CTSEN_MASK (0x01U<<USART_SCON_CTSEN_POS) #define USART_SCON_CTSEN USART_SCON_CTSEN_MASK //===硬件流控制使能位 #define USART_SCON_RTSEN_POS 18 #define USART_SCON_RTSEN_MASK (0x01U<<USART_SCON_RTSEN_POS) #define USART_SCON_RTSEN USART_SCON_RTSEN_MASK //===DMA使能位 #define USART_SCON_DMATXEN_POS 17 #define USART_SCON_DMATXEN_MASK (0x01U<<USART_SCON_DMATXEN_POS) #define USART_SCON_DMATXEN USART_SCON_DMATXEN_MASK //===DMA使能位 #define USART_SCON_DMARXEN_POS 16 #define USART_SCON_DMARXEN_MASK (0x01U<<USART_SCON_DMARXEN_POS) #define USART_SCON_DMARXEN USART_SCON_DMARXEN_MASK //===停止位 #define USART_SCON_STOPBIT_POS 14 #define USART_SCON_STOPBIT_MASK (0x03U<<USART_SCON_STOPBIT_POS) #define USART_SCON_STOPBIT USART_SCON_STOPBIT_MASK #define USART_SCON_STOPBIT_1BIT (0x00U<<USART_SCON_STOPBIT_POS) #define USART_SCON_STOPBIT_1BIT5 (0x01U<<USART_SCON_STOPBIT_POS) #define USART_SCON_STOPBIT_2BIT (0x02U<<USART_SCON_STOPBIT_POS) //===奇偶校验错误中断使能位 #define USART_SCON_PEIE_POS 13 #define USART_SCON_PEIE_MASK (0x01U<<USART_SCON_PEIE_POS) #define USART_SCON_PEIE USART_SCON_PEIE_MASK //===采样分频 #define USART_SCON_OVER_POS 9 #define USART_SCON_OVER_MASK (0x01U<<USART_SCON_OVER_POS) #define USART_SCON_OVER USART_SCON_OVER_MASK #define USART_SCON_OVER1_16 (0x00U<<USART_SCON_OVER_POS) #define USART_SCON_OVER1_8 (0x01U<<USART_SCON_OVER_POS) #define USART_SCON_OVER2_32 (0x00U<<USART_SCON_OVER_POS) #define USART_SCON_OVER2_16 (0x01U<<USART_SCON_OVER_POS) //===发送空中断使能位 #define USART_SCON_TXEIE_POS 8 #define USART_SCON_TXEIE_MASK (0x01U<<USART_SCON_TXEIE_POS) #define USART_SCON_TXEIE USART_SCON_TXEIE_MASK //===工作模式 #define USART_SCON_SM_POS 6 #define USART_SCON_SM_MASK (0x03U<<USART_SCON_SM_POS) #define USART_SCON_SM USART_SCON_SM_MASK #define USART_SCON_SM_MODE0 (0x00U<<USART_SCON_SM_POS) #define USART_SCON_SM_MODE1 (0x01U<<USART_SCON_SM_POS) #define USART_SCON_SM_MODE2 (0x02U<<USART_SCON_SM_POS) #define USART_SCON_SM_MODE3 (0x03U<<USART_SCON_SM_POS) //===多机通讯地址自动识别使能位 #define USART_SCON_ADRDET_POS 5 #define USART_SCON_ADRDET_MASK (0x01U<<USART_SCON_ADRDET_POS) #define USART_SCON_ADRDET USART_SCON_ADRDET_MASK //===收发模式控制 #define USART_SCON_REN_POS 4 #define USART_SCON_REN_MASK (0x01U<<USART_SCON_REN_POS) #define USART_SCON_REN USART_SCON_REN_MASK #define USART_SCON_REN_TX (0x00U<<USART_SCON_REN_POS) #define USART_SCON_REN_RX (0x01U<<USART_SCON_REN_POS) #define USART_SCON_REN_TX_RX (0x01U<<USART_SCON_REN_POS) //===BIT8数据控制位 #define USART_SCON_B8CONT_POS 2 #define USART_SCON_B8CONT_MASK (0x03U<<USART_SCON_B8CONT_POS) #define USART_SCON_B8CONT USART_SCON_B8CONT_MASK #define USART_SCON_B8CONT_B8SBUF (0x00U<<USART_SCON_B8CONT_POS) #define USART_SCON_B8CONT_EVEN (0x01U<<USART_SCON_B8CONT_POS) #define USART_SCON_B8CONT_ODD (0x02U<<USART_SCON_B8CONT_POS) #define USART_SCON_B8CONT_NONE (0x03U<<USART_SCON_B8CONT_POS) //===发送完成中断使能位 #define USART_SCON_TCIE_POS 1 #define USART_SCON_TCIE_MASK (0x01U<<USART_SCON_TCIE_POS) #define USART_SCON_TCIE USART_SCON_TCIE_MASK //===接收完成中断使能位 #define USART_SCON_RCIE_POS 0 #define USART_SCON_RCIE_MASK (0x01U<<USART_SCON_RCIE_POS) #define USART_SCON_RCIE USART_SCON_RCIE_MASK //===<<<USART控制寄存器的的功能 //===>>>USART标志寄存器的的功能 //===CTS信号标志位 #define USART_SR_CTS_POS 6 #define USART_SR_CTS_MASK (0x01U<<USART_SR_CTS_POS) #define USART_SR_CTS USART_SR_CTS_MASK //===CTS中断标志位 #define USART_SR_CTSIF_POS 5 #define USART_SR_CTSIF_MASK (0x01U<<USART_SR_CTSIF_POS) #define USART_SR_CTSIF USART_SR_CTSIF_MASK //===PE奇偶校验错误中断标志位 #define USART_SR_PE_POS 4 #define USART_SR_PE_MASK (0x01U<<USART_SR_PE_POS) #define USART_SR_PE USART_SR_PE_MASK //===发送寄存器空中断标志位 #define USART_SR_TXE_POS 3 #define USART_SR_TXE_MASK (0x01U<<USART_SR_TXE_POS) #define USART_SR_TXE USART_SR_TXE_MASK //===帧错误中断标志位 #define USART_SR_FE_POS 2 #define USART_SR_FE_MASK (0x01U<<USART_SR_FE_POS) #define USART_SR_FE USART_SR_FE_MASK //===发送寄存器空中断标志位 #define USART_SR_TC_POS 1 #define USART_SR_TC_MASK (0x01U<<USART_SR_TC_POS) #define USART_SR_TC USART_SR_TC_MASK //===发送寄存器空中断标志位 #define USART_SR_RC_POS 0 #define USART_SR_RC_MASK (0x01U<<USART_SR_RC_POS) #define USART_SR_RC USART_SR_RC_MASK //===<<<USART标志寄存器的的功能 //===>>>USART标志清楚寄存器的的功能 //===CTS中断标志位 #define USART_CSR_CTSIF_POS 5 #define USART_CSR_CTSIF_MASK (0x01U<<USART_CSR_CTSIF_POS) #define USART_CSR_CTSIF USART_CSR_CTSIF_MASK //===PE奇偶校验错误中断标志位 #define USART_CSR_PE_POS 4 #define USART_CSR_PE_MASK (0x01U<<USART_CSR_PE_POS) #define USART_CSR_PE USART_CSR_PE_MASK //===帧错误中断标志位 #define USART_CSR_FE_POS 2 #define USART_CSR_FE_MASK (0x01U<<USART_CSR_FE_POS) #define USART_CSR_FE USART_CSR_FE_MASK //===发送寄存器空中断标志位 #define USART_CSR_TC_POS 1 #define USART_CSR_TC_MASK (0x01U<<USART_CSR_TC_POS) #define USART_CSR_TC USART_CSR_TC_MASK //===发送寄存器空中断标志位 #define USART_CSR_RC_POS 0 #define USART_CSR_RC_MASK (0x01U<<USART_CSR_RC_POS) #define USART_CSR_RC USART_CSR_RC_MASK //===<<<USART标志清楚寄存器的的功能 #pragma endregion #pragma region LPUSART //===端口通用功能配置寄存器 typedef struct { __IO uint32_t SBUF; //---数据寄存器 __IO uint32_t SCON; //---控制寄存器 __IO uint32_t SADDR; //---地址寄存器寄存器 __IO uint32_t SADEN; //---地址寄存器寄存器 __IO uint32_t SR; //---状态寄存器 __IO uint32_t CSR; //---状态清除寄存器 __IO uint32_t SCNT; //---波特率寄存器 } LPUSART_TypeDef; //===>>>LPUSART控制寄存器的的功能 //===单线半双工模式使能位 #define LPUSART_SCON_HDSEL_POS 22 #define LPUSART_SCON_HDSEL_MASK (0x01U<<LPUSART_SCON_HDSEL_POS) #define LPUSART_SCON_HDSEL LPUSART_SCON_HDSEL_MASK //===帧错误中断使能位 #define LPUSART_SCON_FEIE_POS 21 #define LPUSART_SCON_FEIE_MASK (0x01U<<LPUSART_SCON_FEIE_POS) #define LPUSART_SCON_FEIE LPUSART_SCON_FEIE_MASK //===CTS信号翻转中断使能位 #define LPUSART_SCON_CTSIE_POS 20 #define LPUSART_SCON_CTSIE_MASK (0x01U<<LPUSART_SCON_CTSIE_POS) #define LPUSART_SCON_CTSIE LPUSART_SCON_CTSIE_MASK //===硬件流控制使能位 #define LPUSART_SCON_CTSEN_POS 19 #define LPUSART_SCON_CTSEN_MASK (0x01U<<LPUSART_SCON_CTSEN_POS) #define LPUSART_SCON_CTSEN LPUSART_SCON_CTSEN_MASK //===硬件流控制使能位 #define LPUSART_SCON_RTSEN_POS 18 #define LPUSART_SCON_RTSEN_MASK (0x01U<<LPUSART_SCON_RTSEN_POS) #define LPUSART_SCON_RTSEN LPUSART_SCON_RTSEN_MASK //===DMA使能位 #define LPUSART_SCON_DMATXEN_POS 17 #define LPUSART_SCON_DMATXEN_MASK (0x01U<<LPUSART_SCON_DMATXEN_POS) #define LPUSART_SCON_DMATXEN LPUSART_SCON_DMATXEN_MASK //===DMA使能位 #define LPUSART_SCON_DMARXEN_POS 16 #define LPUSART_SCON_DMARXEN_MASK (0x01U<<LPUSART_SCON_DMARXEN_POS) #define LPUSART_SCON_DMARXEN LPUSART_SCON_DMARXEN_MASK //===停止位 #define LPUSART_SCON_STOPBIT_POS 14 #define LPUSART_SCON_STOPBIT_MASK (0x03U<<LPUSART_SCON_STOPBIT_POS) #define LPUSART_SCON_STOPBIT LPUSART_SCON_STOPBIT_MASK #define LPUSART_SCON_STOPBIT_1BIT (0x00U<<LPUSART_SCON_STOPBIT_POS) #define LPUSART_SCON_STOPBIT_1BIT5 (0x01U<<LPUSART_SCON_STOPBIT_POS) #define LPUSART_SCON_STOPBIT_2BIT (0x02U<<LPUSART_SCON_STOPBIT_POS) //===奇偶校验错误中断使能位 #define LPUSART_SCON_PEIE_POS 13 #define LPUSART_SCON_PEIE_MASK (0x01U<<LPUSART_SCON_PEIE_POS) #define LPUSART_SCON_PEIE LPUSART_SCON_PEIE_MASK //===传输时钟选择为 #define LPUSART_SCON_SCLK_POS 11 #define LPUSART_SCON_SCLK_MASK (0x03U<<LPUSART_SCON_SCLK_POS) #define LPUSART_SCON_SCLK LPUSART_SCON_SCLK_MASK #define LPUSART_SCON_SCLK_PCLK (0x00U<<LPUSART_SCON_SCLK_POS) #define LPUSART_SCON_SCLK_XTL (0x02U<<LPUSART_SCON_SCLK_POS) #define LPUSART_SCON_SCLK_RCL (0x03U<<LPUSART_SCON_SCLK_POS) //===采样分频 #define LPUSART_SCON_OVER_POS 9 #define LPUSART_SCON_OVER_MASK (0x03U<<LPUSART_SCON_OVER_POS) #define LPUSART_SCON_OVER LPUSART_SCON_OVER_MASK #define LPUSART_SCON_OVER1_16 (0x00U<<LPUSART_SCON_OVER_POS) #define LPUSART_SCON_OVER1_8 (0x01U<<LPUSART_SCON_OVER_POS) #define LPUSART_SCON_OVER1_4 (0x02U<<LPUSART_SCON_OVER_POS) #define LPUSART_SCON_OVER2_32 (0x00U<<LPUSART_SCON_OVER_POS) #define LPUSART_SCON_OVER2_16 (0x01U<<LPUSART_SCON_OVER_POS) #define LPUSART_SCON_OVER2_8 (0x02U<<LPUSART_SCON_OVER_POS) //===发送空中断使能位 #define LPUSART_SCON_TXEIE_POS 8 #define LPUSART_SCON_TXEIE_MASK (0x01U<<LPUSART_SCON_TXEIE_POS) #define LPUSART_SCON_TXEIE LPUSART_SCON_TXEIE_MASK //===工作模式 #define LPUSART_SCON_SM_POS 6 #define LPUSART_SCON_SM_MASK (0x03U<<LPUSART_SCON_SM_POS) #define LPUSART_SCON_SM LPUSART_SCON_SM_MASK #define LPUSART_SCON_SM_MODE0 (0x00U<<LPUSART_SCON_SM_POS) #define LPUSART_SCON_SM_MODE1 (0x01U<<LPUSART_SCON_SM_POS) #define LPUSART_SCON_SM_MODE2 (0x02U<<LPUSART_SCON_SM_POS) #define LPUSART_SCON_SM_MODE3 (0x03U<<LPUSART_SCON_SM_POS) //===多机通讯地址自动识别使能位 #define LPUSART_SCON_ADRDET_POS 5 #define LPUSART_SCON_ADRDET_MASK (0x01U<<LPUSART_SCON_ADRDET_POS) #define LPUSART_SCON_ADRDET LPUSART_SCON_ADRDET_MASK //===收发模式控制 #define LPUSART_SCON_REN_POS 4 #define LPUSART_SCON_REN_MASK (0x01U<<LPUSART_SCON_REN_POS) #define LPUSART_SCON_REN LPUSART_SCON_REN_MASK #define LPUSART_SCON_REN_TX (0x00U<<LPUSART_SCON_REN_POS) #define LPUSART_SCON_REN_RX (0x01U<<LPUSART_SCON_REN_POS) #define LPUSART_SCON_REN_TX_RX (0x01U<<LPUSART_SCON_REN_POS) //===BIT8数据控制位 #define LPUSART_SCON_B8CONT_POS 2 #define LPUSART_SCON_B8CONT_MASK (0x03U<<LPUSART_SCON_B8CONT_POS) #define LPUSART_SCON_B8CONT LPUSART_SCON_B8CONT_MASK #define LPUSART_SCON_B8CONT_B8SBUF (0x00U<<LPUSART_SCON_B8CONT_POS) #define LPUSART_SCON_B8CONT_EVEN (0x01U<<LPUSART_SCON_B8CONT_POS) #define LPUSART_SCON_B8CONT_ODD (0x02U<<LPUSART_SCON_B8CONT_POS) #define LPUSART_SCON_B8CONT_NONE (0x03U<<LPUSART_SCON_B8CONT_POS) //===发送完成中断使能位 #define LPUSART_SCON_TCIE_POS 1 #define LPUSART_SCON_TCIE_MASK (0x01U<<LPUSART_SCON_TCIE_POS) #define LPUSART_SCON_TCIE LPUSART_SCON_TCIE_MASK //===接收完成中断使能位 #define LPUSART_SCON_RCIE_POS 0 #define LPUSART_SCON_RCIE_MASK (0x01U<<LPUSART_SCON_RCIE_POS) #define LPUSART_SCON_RCIE LPUSART_SCON_RCIE_MASK //===<<<LPUSART控制寄存器的的功能 //===>>>LPUSART标志寄存器的的功能 //===CTS信号标志位 #define LPUSART_SR_CTS_POS 6 #define LPUSART_SR_CTS_MASK (0x01U<<LPUSART_SR_CTS_POS) #define LPUSART_SR_CTS LPUSART_SR_CTS_MASK //===CTS中断标志位 #define LPUSART_SR_CTSIF_POS 5 #define LPUSART_SR_CTSIF_MASK (0x01U<<LPUSART_SR_CTSIF_POS) #define LPUSART_SR_CTSIF LPUSART_SR_CTSIF_MASK //===PE奇偶校验错误中断标志位 #define LPUSART_SR_PE_POS 4 #define LPUSART_SR_PE_MASK (0x01U<<LPUSART_SR_PE_POS) #define LPUSART_SR_PE LPUSART_SR_PE_MASK //===发送寄存器空中断标志位 #define LPUSART_SR_TXE_POS 3 #define LPUSART_SR_TXE_MASK (0x01U<<LPUSART_SR_TXE_POS) #define LPUSART_SR_TXE LPUSART_SR_TXE_MASK //===帧错误中断标志位 #define LPUSART_SR_FE_POS 2 #define LPUSART_SR_FE_MASK (0x01U<<LPUSART_SR_FE_POS) #define LPUSART_SR_FE LPUSART_SR_FE_MASK //===发送寄存器空中断标志位 #define LPUSART_SR_TC_POS 1 #define LPUSART_SR_TC_MASK (0x01U<<LPUSART_SR_TC_POS) #define LPUSART_SR_TC LPUSART_SR_TC_MASK //===发送寄存器空中断标志位 #define LPUSART_SR_RC_POS 0 #define LPUSART_SR_RC_MASK (0x01U<<LPUSART_SR_RC_POS) #define LPUSART_SR_RC LPUSART_SR_RC_MASK //===<<<LPUSART标志寄存器的的功能 //===>>>LPUSART标志清楚寄存器的的功能 //===CTS中断标志位 #define LPUSART_CSR_CTSIF_POS 5 #define LPUSART_CSR_CTSIF_MASK (0x01U<<LPUSART_CSR_CTSIF_POS) #define LPUSART_CSR_CTSIF LPUSART_CSR_CTSIF_MASK //===PE奇偶校验错误中断标志位 #define LPUSART_CSR_PE_POS 4 #define LPUSART_CSR_PE_MASK (0x01U<<LPUSART_CSR_PE_POS) #define LPUSART_CSR_PE LPUSART_CSR_PE_MASK //===帧错误中断标志位 #define LPUSART_CSR_FE_POS 2 #define LPUSART_CSR_FE_MASK (0x01U<<LPUSART_CSR_FE_POS) #define LPUSART_CSR_FE LPUSART_CSR_FE_MASK //===发送寄存器空中断标志位 #define LPUSART_CSR_TC_POS 1 #define LPUSART_CSR_TC_MASK (0x01U<<LPUSART_CSR_TC_POS) #define LPUSART_CSR_TC LPUSART_CSR_TC_MASK //===发送寄存器空中断标志位 #define LPUSART_CSR_RC_POS 0 #define LPUSART_CSR_RC_MASK (0x01U<<LPUSART_CSR_RC_POS) #define LPUSART_CSR_RC LPUSART_CSR_RC_MASK //===<<<LPUSART标志清楚寄存器的的功能 #pragma endregion #pragma region FLASH //===FLASH寄存器 typedef struct { __IO uint32_t TNVS; //---时间参数 __IO uint32_t TPGS; //---时间参数 __IO uint32_t TPROG; //---地址寄存器寄存器 __IO uint32_t TSERASE; //---地址寄存器寄存器 __IO uint32_t TMERASE; //---状态寄存器 __IO uint32_t TPRCV; //---状态清除寄存器 __IO uint32_t TSRCV; //---状态清除寄存器 __IO uint32_t TMRCV; //---状态清除寄存器 __IO uint32_t CR; //---状态清除寄存器 __IO uint32_t SR; //---状态清除寄存器 __IO uint32_t CSR; //---状态清除寄存器 __IO uint32_t BYPASS; //---状态清除寄存器 __IO uint32_t SLOCK0; //---状态清除寄存器 __IO uint32_t SLOCK1; //---状态清除寄存器 uint32_t RESERVED[2]; //---保留字节 __IO uint32_t SLOCK2; //---状态清除寄存器 __IO uint32_t SLOCK3; //---状态清除寄存器 } FLASH_TypeDef; //====TNVS #define FLASH_TNVS_POS 0 #define FLASH_TNVS_MASK (0x1FFUL<<FLASH_TNVS_POS) #define FLASH_TNVS FLASH_TNVS_MASK //===TPGS #define FLASH_TPGS_POS 0 #define FLASH_TPGS_MASK (0x1FFUL<<FLASH_TPGS_POS) #define FLASH_TPGS FLASH_TPGS_MASK //===TPRGOS #define FLASH_TPRGOS_POS 0 #define FLASH_TPRGOS_MASK (0x1FFUL<<FLASH_TPRGOS_POS) #define FLASH_TPRGOS FLASH_TPRGOS_MASK //===TSERASE #define FLASH_TSERASE_POS 0 #define FLASH_TSERASE_MASK (0x1FFFFUL<<FLASH_TSERASE_POS) #define FLASH_TSERASE FLASH_TSERASE_MASK //===TMERASE #define FLASH_TMERASE_POS 0 #define FLASH_TMERASE_MASK (0x1FFFFFUL<<FLASH_TMERASE_POS) #define FLASH_TMERASE FLASH_TMERASE_MASK //===TPRCV #define FLASH_TPRCV_POS 0 #define FLASH_TPRCV_MASK (0xFFFUL<<FLASH_TPRCV_POS) #define FLASH_TPRCV FLASH_TPRCV_MASK //===TSRCV #define FLASH_TSRCV_POS 0 #define FLASH_TSRCV_MASK (0xFFFUL<<FLASH_TSRCV_POS) #define FLASH_TSRCV FLASH_TSRCV_MASK //===TMRCV #define FLASH_TMRCV_POS 0 #define FLASH_TMRCV_MASK (0x3FFFUL<<FLASH_TMRCV_POS) #define FLASH_TMRCV FLASH_TMRCV_MASK //===>>>FLASH_CR寄存器 #define FLASH_CR_DPSTN_EN_POS 9 #define FLASH_CR_DPSTN_EN_MASK (0x1UL<<FLASH_CR_DPSTN_EN_POS) #define FLASH_CR_DPSTN_EN FLASH_CR_DPSTN_EN_MASK #define FLASH_CR_IE_ADDR_POS 6 #define FLASH_CR_IE_ADDR_MASK (0x1UL<<FLASH_CR_IE_ADDR_POS) #define FLASH_CR_IE_ADDR FLASH_CR_IE_ADDR_MASK #define FLASH_CR_IE_PC_POS 5 #define FLASH_CR_IE_PC_MASK (0x1UL<<FLASH_CR_IE_PC_POS) #define FLASH_CR_IE_PC FLASH_CR_IE_PC_MASK #define FLASH_CR_BUSY_POS 4 #define FLASH_CR_BUSY_MASK (0x1UL<<FLASH_CR_BUSY_POS) #define FLASH_CR_BUSY FLASH_CR_BUSY_MASK #define FLASH_CR_WAIT_POS 2 #define FLASH_CR_WAIT_MASK (0x3UL<<FLASH_CR_WAIT_POS) #define FLASH_CR_WAIT FLASH_CR_WAIT_MASK #define FLASH_CR_WAIT_0 (0x0UL<<FLASH_CR_WAIT_POS) #define FLASH_CR_WAIT_1 (0x0UL<<FLASH_CR_WAIT_POS) #define FLASH_CR_WAIT_2 (0x1UL<<FLASH_CR_WAIT_POS) #define FLASH_CR_WAIT_3 (0x2UL<<FLASH_CR_WAIT_POS) #define FLASH_CR_OP_POS 0 #define FLASH_CR_OP_MASK (0x3UL<<FLASH_CR_OP_POS) #define FLASH_CR_OP FLASH_CR_OP_MASK #define FLASH_CR_OP_READ (0x0UL<<FLASH_CR_OP_POS) #define FLASH_CR_OP_PROGRAM (0x1UL<<FLASH_CR_OP_POS) #define FLASH_CR_OP_SECTOR_ERASE (0x2UL<<FLASH_CR_OP_POS) #define FLASH_CR_OP_CHIP_ERASE (0x3UL<<FLASH_CR_OP_POS) //===<<<FLASH_CR寄存器 #define FLASH_SR_IE_ADDR_POS 1 #define FLASH_SR_IE_ADDR_MASK (0x1UL<<FLASH_SR_IE_ADDR_POS) #define FLASH_SR_IE_ADDR FLASH_SR_IE_ADDR_MASK #define FLASH_SR_IE_PC_POS 0 #define FLASH_SR_IE_PC_MASK (0x1UL<<FLASH_SR_IE_PC_POS) #define FLASH_SR_IE_PC FLASH_SR_IE_PC_MASK #define FLASH_CSR_IE_ADDR_POS 1 #define FLASH_CSR_IE_ADDR_MASK (0x1UL<<FLASH_CSR_IE_ADDR_POS) #define FLASH_CSR_IE_ADDR FLASH_CSR_IE_ADDR_MASK #define FLASH_CSR_IE_PC_POS 0 #define FLASH_CSR_IE_PC_MASK (0x1UL<<FLASH_CSR_IE_PC_POS) #define FLASH_CSR_IE_PC FLASH_CSR_IE_PC_MASK #define FLASH_BYPASS_POS 0 #define FLASH_BYPASS_MASK (0xFFFFUL<<FLASH_BYPASS_POS) #define FLASH_BYPASS FLASH_BYPASS_MASK #pragma endregion #pragma region RAM //==RAM寄存器 typedef struct { __IO uint32_t CR; //---控制寄存器 __IO uint32_t ERR; //---出错地址寄存器 __IO uint32_t SR; //---状态寄存器 __IO uint32_t CSR; //---状态清除寄存器 } RAM_TypeDef; //===RAM校验报警中断使能信号 #define RAM_CR_IE_POS 1 #define RAM_CR_IE_MASK (0x01UL<<RAM_CR_IE_POS) #define RAM_CR_IE RAM_CR_IE_MASK //===RAM校验出错地址 #define RAM_ERR_ADDR_POS 0 #define RAM_ERR_ADDR_MASK (0x3FFFUL<<RAM_ERR_ADDR_POS) #define RAM_ERR_ADDR RAM_ERR_ADDR_MASK //===RAM错误中断标志 #define RAM_SR_ERR_POS 0 #define RAM_SR_ERR_MASK (0x01UL<<RAM_SR_ERR_POS) #define RAM_SR_ERR RAM_SR_ERR_MASK //===RAM错误中断标志清除 #define RAM_CSR_ERR_POS 0 #define RAM_CSR_ERR_MASK (0x01UL<<RAM_CSR_ERR_POS) #define RAM_CSR_ERR RAM_CSR_ERR_MASK #pragma endregion #pragma region RNG //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR; //---控制寄存器 __IO uint32_t MODE; //---模式寄存器 uint32_t RESERVED; //---保留字节 __IO uint32_t DR1; //---数据寄存器1 __IO uint32_t DR2; //---数据寄存器2 } RNG_TypeDef; //===随机数状态 #define RNG_CR_RUN_POS 1 #define RNG_CR_RUN_MASK (0x01UL<<RNG_CR_RUN_POS) #define RNG_CR_RUN RNG_CR_RUN_MASK //===使能RNG #define RNG_CR_EN_POS 0 #define RNG_CR_EN_MASK (0x01UL<<RNG_CR_EN_POS) #define RNG_CR_EN RNG_CR_EN_MASK //===随机数反馈移位次数 #define RNG_MODE_CNT_POS 2 #define RNG_MODE_CNT_MASK (0x07UL<<RNG_MODE_CNT_POS) #define RNG_MODE_CNT RNG_MODE_CNT_MASK #define RNG_MODE_CNT_NONE (0x00UL<<RNG_MODE_CNT_POS) #define RNG_MODE_CNT_8 (0x01UL<<RNG_MODE_CNT_POS) #define RNG_MODE_CNT_16 (0x02UL<<RNG_MODE_CNT_POS) #define RNG_MODE_CNT_32 (0x03UL<<RNG_MODE_CNT_POS) #define RNG_MODE_CNT_64 (0x04UL<<RNG_MODE_CNT_POS) #define RNG_MODE_CNT_128 (0x05UL<<RNG_MODE_CNT_POS) #define RNG_MODE_CNT_256 (0x06UL<<RNG_MODE_CNT_POS) //===异或运算 #define RNG_MODE_FDBK_POS 1 #define RNG_MODE_FDBK_MASK (0x01UL<<RNG_MODE_FDBK_POS) #define RNG_MODE_FDBK RNG_MODE_FDBK_MASK //===产生真随机数,还是伪随机数 #define RNG_MODE_LOAD_POS 0 #define RNG_MODE_LOAD_MASK (0x01UL<<RNG_MODE_LOAD_POS) #define RNG_MODE_LOAD RNG_MODE_LOAD_MASK #pragma endregion #pragma region RTC //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR0; //---控制寄存器0 __IO uint32_t CR1; //---控制寄存器1 __IO uint32_t SEC; //---秒计数寄存器 __IO uint32_t MIN; //---分计数寄存器 __IO uint32_t HOUR; //---十计数寄存器 __IO uint32_t WEEKDAY; //---周计数寄存器 __IO uint32_t DAY; //---日计数寄存器 __IO uint32_t MONTH; //---月计数寄存器 __IO uint32_t YEAR; //---年计数寄存器 __IO uint32_t ALMMIN; //---分闹钟寄存器 __IO uint32_t ALMHOUR; //---时闹钟寄存器 __IO uint32_t ALMWEEKDAY; //---周闹钟寄存器 __IO uint32_t COMPEM; //---时钟误差补偿寄存器 __IO uint32_t ALMSEC; //---秒闹钟寄存器 } RTC_TypeDef; //===控制寄存器0的配置 #define RTC_CR0_PRDSEL_POS 14 #define RTC_CR0_PRDSEL_MASK (0x01UL<<RTC_CR0_PRDSEL_POS) #define RTC_CR0_PRDSEL RTC_CR0_PRDSEL_MASK #define RTC_CR0_PRDX_POS 8 #define RTC_CR0_PRDX_MASK (0x3FUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX RTC_CR0_PRDX_MASK #define RTC_CR0_PRDX_SEC_0P5 (0x00UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_1 (0x01UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_1P5 (0x02UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_2 (0x03UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_2P5 (0x04UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_3 (0x05UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_3P5 (0x06UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_4 (0x07UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_4P5 (0x08UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_5 (0x09UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_5P5 (0x0AUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_6 (0x0BUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_6P5 (0x0CUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_7 (0x0DUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_7P5 (0x0EUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_8 (0x0FUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_8P5 (0x10UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_9 (0x11UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_9P5 (0x12UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_10 (0x13UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_10P5 (0x14UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_11 (0x15UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_11P5 (0x16UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_12 (0x17UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_12P5 (0x18UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_13 (0x19UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_13P5 (0x1AUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_14 (0x1BUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_14P5 (0x1CUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_15 (0x1DUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_15P5 (0x1EUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_16 (0x1FUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_16P5 (0x20UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_17 (0x21UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_17P5 (0x22UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_18 (0x23UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_18P5 (0x24UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_19 (0x25UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_19P5 (0x26UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_20 (0x27UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_20P5 (0x28UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_21 (0x29UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_21P5 (0x2AUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_22 (0x2BUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_22P5 (0x2CUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_23 (0x2DUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_23P5 (0x2EUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_24 (0x2FUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_24P5 (0x30UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_25 (0x31UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_25P5 (0x32UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_26 (0x33UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_26P5 (0x34UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_27 (0x35UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_27P5 (0x36UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_28 (0x37UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_28P5 (0x38UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_29 (0x39UL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_29P5 (0x3AUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_30 (0x3BUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_30P5 (0x3CUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_31 (0x3DUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_31P5 (0x3EUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_PRDX_SEC_32 (0x3FUL<<RTC_CR0_PRDX_POS) #define RTC_CR0_START_POS 7 #define RTC_CR0_START_MASK (0x01UL<<RTC_CR0_START_POS) #define RTC_CR0_START RTC_CR0_START_MASK #define RTC_CR0_1HZSEL_POS 6 #define RTC_CR0_1HZSEL_MASK (0x01UL<<RTC_CR0_1HZSEL_POS) #define RTC_CR0_1HZSEL RTC_CR0_1HZSEL_MASK #define RTC_CR0_1HZEN_POS 5 #define RTC_CR0_1HZEN_MASK (0x01UL<<RTC_CR0_1HZEN_POS) #define RTC_CR0_1HZEN RTC_CR0_1HZEN_MASK #define RTC_CR0_AMPM_POS 3 #define RTC_CR0_AMPM_MASK (0x01UL<<RTC_CR0_AMPM_POS) #define RTC_CR0_AMPM RTC_CR0_AMPM_MASK #define RTC_CR0_AM (0x01UL<<RTC_CR0_AMPM_POS) #define RTC_CR0_PM (0x00UL<<RTC_CR0_AMPM_POS) #define RTC_CR0_PRDS_POS 0 #define RTC_CR0_PRDS_MASK (0x3UL<<RTC_CR0_PRDS_POS) #define RTC_CR0_PRDS RTC_CR0_PRDS_MASK #define RTC_CR0_PRDS_NONE (0x00UL<<RTC_CR0_PRDS_POS) #define RTC_CR0_PRDS_SEC_0P5 (0x01UL<<RTC_CR0_PRDS_POS) #define RTC_CR0_PRDS_SEC_1 (0x02UL<<RTC_CR0_PRDS_POS) #define RTC_CR0_PRDS_MIN_1 (0x03UL<<RTC_CR0_PRDS_POS) #define RTC_CR0_PRDS_HOUR_1 (0x04UL<<RTC_CR0_PRDS_POS) #define RTC_CR0_PRDS_DAY_1 (0x05UL<<RTC_CR0_PRDS_POS) #define RTC_CR0_PRDS_MON_1 (0x06UL<<RTC_CR0_PRDS_POS) //===控制寄存器1的配置 #define RTC_CR1_CKSEL_POS 8 #define RTC_CR1_CKSEL_MASK (0x07UL<<RTC_CR1_CKSEL_POS) #define RTC_CR1_CKSEL RTC_CR1_CKSEL_MASK #define RTC_CR1_CKSEL_XTL (0x00UL<<RTC_CR1_CKSEL_POS) #define RTC_CR1_CKSEL_RCL (0x02UL<<RTC_CR1_CKSEL_POS) #define RTC_CR1_CKSEL_XTH_PRE128 (0x04UL<<RTC_CR1_CKSEL_POS) #define RTC_CR1_CKSEL_XTH_PRE256 (0x05UL<<RTC_CR1_CKSEL_POS) #define RTC_CR1_CKSEL_XTH_PRE512 (0x06UL<<RTC_CR1_CKSEL_POS) #define RTC_CR1_CKSEL_XTH_PRE1024 (0x07UL<<RTC_CR1_CKSEL_POS) #define RTC_CR1_ALMEN_POS 7 #define RTC_CR1_ALMEN_MASK (0x01UL<<RTC_CR1_ALMEN_POS) #define RTC_CR1_ALMEN RTC_CR1_ALMEN_MASK //===闹钟中断使能位 #define RTC_CR1_ALMIE_POS 6 #define RTC_CR1_ALMIE_MASK (0x01UL<<RTC_CR1_ALMIE_POS) #define RTC_CR1_ALMIE RTC_CR1_ALMIE_MASK //===闹钟中断标志 #define RTC_CR1_ALMF_POS 4 #define RTC_CR1_ALMF_MASK (0x01UL<<RTC_CR1_ALMF_POS) #define RTC_CR1_ALMF RTC_CR1_ALMF_MASK //===周期中断标志 #define RTC_CR1_PRDF_POS 3 #define RTC_CR1_PRDF_MASK (0x01UL<<RTC_CR1_PRDF_POS) #define RTC_CR1_PRDF RTC_CR1_PRDF_MASK //===技术模式标志 #define RTC_CR1_WAITF_POS 1 #define RTC_CR1_WAITF_MASK (0x01UL<<RTC_CR1_WAITF_POS) #define RTC_CR1_WAITF RTC_CR1_WAITF_MASK //===计数模式 #define RTC_CR1_WAIT_POS 0 #define RTC_CR1_WAIT_MASK (0x01UL<<RTC_CR1_WAIT_POS) #define RTC_CR1_WAIT RTC_CR1_WAIT_MASK #pragma endregion #pragma region TIM //===普通定时器 typedef struct { __IO uint32_t ARR; //---重载寄存器 00 __IO uint32_t CNT; //---16位模式计数寄存器 04 __IO uint32_t CNT32; //---32位模式计数寄存器 08 __IO uint32_t MCR; //---控制寄存器 0C __IO uint32_t SR; //---中断标志 10 __IO uint32_t CSR; //---中断标志清除 14 __IO uint32_t MSCR; //---主从模式控制 18 __IO uint32_t FLTR; //---滤波控制 1C __IO uint32_t ADTR; //---ADC触发控制 20 __IO uint32_t CRCH0_CR0; //---比较单元0控制寄存器 24 __IO uint32_t CRCH1; //---比较单元1控制寄存器 28 __IO uint32_t CRCH2; //---比较单元2控制寄存器 2C __IO uint32_t DTR; //---死区寄存器 30 __IO uint32_t RCR; //---重复计数寄存器 34 __IO uint32_t ARRDM; //---控制寄存器1 38 __IO uint32_t CCR0A; //---比较0A寄存器 3C __IO uint32_t CCR0B; //---比较0B寄存器 40 __IO uint32_t CCR1A; //---比较1A寄存器 44 __IO uint32_t CCR1B; //---比较1B寄存器 48 __IO uint32_t CCR2A; //---比较2A寄存器 4C __IO uint32_t CCR2B; //---比较2B寄存器 50 } TIM_TypeDef; //===工作模式 #define TIM_MCR_MODE_POS 12 #define TIM_MCR_MODE_MASK (0x03UL<<TIM_MCR_MODE_POS) #define TIM_MCR_MODE TIM_MCR_MODE_MASK #define TIM_MCR_MODE_TIM0 (0x00UL<<TIM_MCR_MODE_POS) #define TIM_MCR_MODE_PWC (0x01UL<<TIM_MCR_MODE_POS) #define TIM_MCR_MODE_SAWTOOTH (0x02UL<<TIM_MCR_MODE_POS) #define TIM_MCR_MODE_TRIANGLE (0x03UL<<TIM_MCR_MODE_POS) #define TIM_MCR_PRS_POS 4 #define TIM_MCR_PRS_MASK (0x07U<<TIM_MCR_PRS_POS) #define TIM_MCR_PRS TIM_MCR_PRS_MASK #define TIM_MCR_PRS_1 (0x00U<<TIM_MCR_PRS_POS) #define TIM_MCR_PRS_2 (0x01U<<TIM_MCR_PRS_POS) #define TIM_MCR_PRS_4 (0x02U<<TIM_MCR_PRS_POS) #define TIM_MCR_PRS_8 (0x03U<<TIM_MCR_PRS_POS) #define TIM_MCR_PRS_16 (0x04U<<TIM_MCR_PRS_POS) #define TIM_MCR_PRS_32 (0x05U<<TIM_MCR_PRS_POS) #define TIM_MCR_PRS_64 (0x06U<<TIM_MCR_PRS_POS) #define TIM_MCR_PRS_256 (0x07U<<TIM_MCR_PRS_POS) #define TIM_MCR_CT_POS 2 #define TIM_MCR_CT_MASK (0x01U<<TIM_MCR_CT_POS) #define TIM_MCR_CT TIM_MCR_CT_MASK #define TIM_MCR_EN_POS 0 #define TIM_MCR_EN_MASK (0x01U<<TIM_MCR_EN_POS) #define TIM_MCR_EN TIM_MCR_EN_MASK #pragma region TIM_M0 //===普通定时器 typedef struct { __IO uint32_t ARR; //---重载寄存器 00 __IO uint32_t CNT; //---16位模式计数寄存器 04 __IO uint32_t CNT32; //---32位模式计数寄存器 08 __IO uint32_t M0CR; //---控制寄存器 0C __IO uint32_t SR; //---中断标志 10 __IO uint32_t CSR; //---中断标志清除 14 uint32_t RESERVED[6]; //---保留字节 __IO uint32_t DTR; //---死区寄存器 30 } TIM_M0_TypeDef; #define TIM_M0_ARR_ARR_POS 0 #define TIM_M0_ARR_ARR_MASK (0xFFFFUL<<TIM_M0_ARR_ARR_POS) #define TIM_M0_ARR_ARR TIM_M0_ARR_ARR_MASK #define TIM_M0_CNT_CNT_POS 0 #define TIM_M0_CNT_CNT_MASK (0xFFFFUL<<TIM_M0_CNT_CNT_POS) #define TIM_M0_CNT_CNT TIM_M0_CNT_CNT_MASK #define TIM_M0_CNT_CNT32_POS 0 #define TIM_M0_CNT_CNT32_MASK (0xFFFFFFFFUL<<TIM_M0_CNT_CNT32_POS) #define TIM_M0_CNT_CNT32 TIM_M0_CNT_CNT32_MASK //===控制寄存器 #define TIM_M0_M0CR_MODE_POS 12 #define TIM_M0_M0CR_MODE_MASK (0x03U<<TIM_M0_M0CR_MODE_POS) #define TIM_M0_M0CR_MODE TIM_M0_M0CR_MODE_MASK #define TIM_M0_M0CR_IE_POS 10 #define TIM_M0_M0CR_IE_MASK (0x01U<<TIM_M0_M0CR_IE_POS) #define TIM_M0_M0CR_IE TIM_M0_M0CR_IE_MASK #define TIM_M0_M0CR_GATEP_POS 9 #define TIM_M0_M0CR_GATEP_MASK (0x01U<<TIM_M0_M0CR_GATEP_POS) #define TIM_M0_M0CR_GATEP TIM_M0_M0CR_GATEP_MASK #define TIM_M0_M0CR_GATEN_POS 8 #define TIM_M0_M0CR_GATEN_MASK (0x01U<<TIM_M0_M0CR_GATEN_POS) #define TIM_M0_M0CR_GATEN TIM_M0_M0CR_GATEN_MASK #define TIM_M0_M0CR_PRS_POS 4 #define TIM_M0_M0CR_PRS_MASK (0x07U<<TIM_M0_M0CR_PRS_POS) #define TIM_M0_M0CR_PRS TIM_M0_M0CR_PRS_MASK #define TIM_M0_M0CR_PRS_1 (0x00U<<TIM_M0_M0CR_PRS_POS) #define TIM_M0_M0CR_PRS_2 (0x01U<<TIM_M0_M0CR_PRS_POS) #define TIM_M0_M0CR_PRS_4 (0x02U<<TIM_M0_M0CR_PRS_POS) #define TIM_M0_M0CR_PRS_8 (0x03U<<TIM_M0_M0CR_PRS_POS) #define TIM_M0_M0CR_PRS_16 (0x04U<<TIM_M0_M0CR_PRS_POS) #define TIM_M0_M0CR_PRS_32 (0x05U<<TIM_M0_M0CR_PRS_POS) #define TIM_M0_M0CR_PRS_64 (0x06U<<TIM_M0_M0CR_PRS_POS) #define TIM_M0_M0CR_PRS_256 (0x07U<<TIM_M0_M0CR_PRS_POS) #define TIM_M0_M0CR_TOGEN_POS 3 #define TIM_M0_M0CR_TOGEN_MASK (0x01U<<TIM_M0_M0CR_TOGEN_POS) #define TIM_M0_M0CR_TOGEN TIM_M0_M0CR_TOGEN_MASK #define TIM_M0_M0CR_CT_POS 2 #define TIM_M0_M0CR_CT_MASK (0x01U<<TIM_M0_M0CR_CT_POS) #define TIM_M0_M0CR_CT TIM_M0_M0CR_CT_MASK #define TIM_M0_M0CR_MD_POS 1 #define TIM_M0_M0CR_MD_MASK (0x01U<<TIM_M0_M0CR_MD_POS) #define TIM_M0_M0CR_MD TIM_M0_M0CR_MD_MASK #define TIM_M0_M0CR_EN_POS 0 #define TIM_M0_M0CR_EN_MASK (0x01U<<TIM_M0_M0CR_EN_POS) #define TIM_M0_M0CR_EN TIM_M0_M0CR_EN_MASK //===标志寄存器 #define TIM_M0_SR_IE_POS 0 #define TIM_M0_SR_IE_MASK (0x01U<<TIM_M0_SR_IE_POS) #define TIM_M0_SR_IE TIM_M0_SR_IE_MASK //===清楚标志寄存器 #define TIM_M0_CSR_IE_POS 0 #define TIM_M0_CSR_IE_MASK (0x01U<<TIM_M0_CSR_IE_POS) #define TIM_M0_CSR_IE TIM_M0_CSR_IE_MASK //===死区控制寄存器 #define TIM_M0_DTR_MOE_POS 12 #define TIM_M0_DTR_MOE_MASK (0x01U<<TIM_M0_DTR_MOE_POS) #define TIM_M0_DTR_MOE TIM_M0_DTR_MOE_MASK #pragma endregion #pragma region TIM_M1 //===普通定时器 typedef struct { uint32_t RESERVED1; //---保留字节 00 __IO uint32_t CNT; //---16位模式计数寄存器 04 uint32_t RESERVED2; //---保留字节 08 __IO uint32_t M1CR; //---控制寄存器 0C __IO uint32_t SR; //---中断标志 10 __IO uint32_t CSR; //---中断标志清除 14 __IO uint32_t DTR; //---死区寄存器 30 __IO uint32_t MSCR; //---主从模式控制 18 __IO uint32_t FLTR; //---滤波控制 1C uint32_t RESERVED3; //---保留字节 20 __IO uint32_t CR0; //---比较单元0控制寄存器 24 uint32_t RESERVED4[5]; //---保留字节 __IO uint32_t CCR0A; //---比较0A寄存器 3C } TIM_M1_TypeDef; //===控制寄存器 #define TIM_M1_CR_TRIG_POS 14 #define TIM_M1_CR_TRIG_MASK (0x03U<<TIM_M1_CR_TRIG_POS) #define TIM_M1_CR_TRIG TIM_M1_CR_TRIG_MASK #define TIM_M1_CR_MODE_POS 12 #define TIM_M1_CR_MODE_MASK (0x03U<<TIM_M1_CR_MODE_POS) #define TIM_M1_CR_MODE TIM_M1_CR_MODE_MASK #define TIM_M1_CR_IE_POS 10 #define TIM_M1_CR_IE_MASK (0x01U<<TIM_M1_CR_IE_POS) #define TIM_M1_CR_IE TIM_M1_CR_IE_MASK #define TIM_M1_CR_EDG_POS 8 #define TIM_M1_CR_EDG_MASK (0x03U<<TIM_M1_CR_EDG_POS) #define TIM_M1_CR_EDG TIM_M1_CR_EDG_MASK #define TIM_M1_CR_PRS_POS 4 #define TIM_M1_CR_PRS_MASK (0x07U<<TIM_M1_CR_PRS_POS) #define TIM_M1_CR_PRS TIM_M1_CR_PRS_MASK #define TIM_M1_CR_TOGEN_POS 3 #define TIM_M1_CR_TOGEN_MASK (0x01U<<TIM_M1_CR_TOGEN_POS) #define TIM_M1_CR_TOGEN TIM_M1_CR_TOGEN_MASK #define TIM_M1_CR_CT_POS 2 #define TIM_M1_CR_CT_MASK (0x01U<<TIM_M1_CR_CT_POS) #define TIM_M1_CR_CT TIM_M1_CR_CT_MASK #define TIM_M1_CR_EN_POS 0 #define TIM_M1_CR_EN_MASK (0x01U<<TIM_M1_CR_EN_POS) #define TIM_M1_CR_EN TIM_M1_CR_EN_MASK //===标志寄存器 #define TIM_M1_SR_CAE_POS 2 #define TIM_M1_SR_CAE_MASK (0x01U<<TIM_M1_SR_CAE_POS) #define TIM_M1_SR_CAE TIM_M1_SR_CAE_MASK #define TIM_M1_SR_IE_POS 0 #define TIM_M1_SR_IE_MASK (0x01U<<TIM_M1_SR_IE_POS) #define TIM_M1_SR_IE TIM_M1_SR_IE_MASK //===清楚标志寄存器 #define TIM_M1_CSR_CAE_POS 2 #define TIM_M1_CSR_CAE_MASK (0x01U<<TIM_M1_CSR_CAE_POS) #define TIM_M1_CSR_CAE TIM_M1_CSR_CAE_MASK #define TIM_M1_CSR_IE_POS 0 #define TIM_M1_CSR_IE_MASK (0x01U<<TIM_M1_CSR_IE_POS) #define TIM_M1_CSR_IE TIM_M1_CSR_IE_MASK //===主从模式控制寄存器 #define TIM_M1_MSCR_IB_POS 12 #define TIM_M1_MSCR_IB_MASK (0x01U<<TIM_M1_MSCR_IB_POS) #define TIM_M1_MSCR_IB TIM_M1_MSCR_IB_MASK #define TIM_M1_MSCR_IA_POS 11 #define TIM_M1_MSCR_IA_MASK (0x01U<<TIM_M1_MSCR_IA_POS) #define TIM_M1_MSCR_IA TIM_M1_MSCR_IA_MASK #define TIM_M1_MSCR_TRIG_POS 5 #define TIM_M1_MSCR_TRIG_MASK (0x07U<<TIM_M1_MSCR_TRIG_POS) #define TIM_M1_MSCR_TRIG TIM_M1_MSCR_TRIG_MASK //===滤波控制寄存器 //===ETR输入相位 #define TIM_M1_FLTR_ETP_POS 31 #define TIM_M1_FLTR_ETP_MASK (0x01U<<TIM_M1_FLTR_ETP_POS) #define TIM_M1_FLTR_ETP TIM_M1_FLTR_ETP_MASK //===ETR滤波控制 #define TIM_M1_FLTR_ETR_POS 28 #define TIM_M1_FLTR_ETR_MASK (0x07U<<TIM_M1_FLTR_ETR_POS) #define TIM_M1_FLTR_ETR TIM_M1_FLTR_ETR_MASK //===CHB滤波控制 #define TIM_M1_FLTR_CHB_POS 4 #define TIM_M1_FLTR_CHB_MASK (0x07U<<TIM_M1_FLTR_CHB_POS) #define TIM_M1_FLTR_CHB TIM_M1_FLTR_CHB_MASK //===CHA滤波控制 #define TIM_M1_FLTR_CHA_POS 0 #define TIM_M1_FLTR_CHA_MASK (0x07U<<TIM_M1_FLTR_CHA_POS) #define TIM_M1_FLTR_CHA TIM_M1_FLTR_CHA_POS //===CR0控制寄存器 #define TIM_M1_CR0_CAE_POS 8 #define TIM_M1_CR0_CAE_MASK (0x01U<<TIM_M1_CR0_CAE_POS) #define TIM_M1_CR0_CAE TIM_M1_CR0_CAE_MASK #pragma endregion #pragma region TIM_M2 //===普通定时器 typedef struct { __IO uint32_t ARR; //---重载寄存器 00 __IO uint32_t CNT; //---16位模式计数寄存器 04 uint32_t RESERVED1; //---保留字节 08 __IO uint32_t M23CR; //---控制寄存器 0C __IO uint32_t SR; //---中断标志 10 __IO uint32_t CSR; //---中断标志清除 14 __IO uint32_t MSCR; //---主从模式控制 18 __IO uint32_t FLTR; //---滤波控制 1C __IO uint32_t ADTR; //---ADC触发控制 20 __IO uint32_t CRCH0; //---比较单元0控制寄存器 24 __IO uint32_t CRCH1; //---比较单元1控制寄存器 28 __IO uint32_t CRCH2; //---比较单元2控制寄存器 2C __IO uint32_t DTR; //---死区寄存器 30 __IO uint32_t RCR; //---重复计数寄存器 34 __IO uint32_t ARRDM; //---控制寄存器1 38 __IO uint32_t CCR0A; //---比较0A寄存器 3C __IO uint32_t CCR0B; //---比较0B寄存器 40 __IO uint32_t CCR1A; //---比较1A寄存器 44 __IO uint32_t CCR1B; //---比较1B寄存器 48 __IO uint32_t CCR2A; //---比较2A寄存器 4C __IO uint32_t CCR2B; //---比较2B寄存器 50 } TIM_M2_TypeDef; #define TIM_M2_ARR_ARR_POS 0 #define TIM_M2_ARR_ARR_MASK (0xFFFFUL<<TIM_M2_ARR_ARR_POS) #define TIM_M2_ARR_ARR TIM_M2_ARR_ARR_MASK #define TIM_M2_CNT_CNT_POS 0 #define TIM_M2_CNT_CNT_MASK (0xFFFFUL<<TIM_M2_CNT_CNT_POS) #define TIM_M2_CNT_CNT TIM_M2_CNT_CNT_MASK //===控制寄存器 #define TIM_M2_M23CR_DIR_POS 27 #define TIM_M2_M23CR_DIR_MASK (0x01UL<<TIM_M2_M23CR_DIR_POS) #define TIM_M2_M23CR_DIR TIM_M2_M23CR_DIR_MASK #define TIM_M2_M23CR_DIR_UP (0x00UL<<TIM_M2_M23CR_DIR_POS) #define TIM_M2_M23CR_DIR_DOWN (0x01UL<<TIM_M2_M23CR_DIR_POS) //===软件刹车 #define TIM_M2_M23CR_BG_POS 26 #define TIM_M2_M23CR_BG_MASK (0x01UL<<TIM_M2_M23CR_BG_POS) #define TIM_M2_M23CR_BG TIM_M2_M23CR_BG_MASK #define TIM_M2_M23CR_BG_ENABLE (0x01UL<<TIM_M2_M23CR_BG_POS) #define TIM_M2_M23CR_BG_DISABLE (0x00UL<<TIM_M2_M23CR_BG_POS) //===软件更新 #define TIM_M2_M23CR_UG_POS 25 #define TIM_M2_M23CR_UG_MASK (0x01UL<<TIM_M2_M23CR_UG_POS) #define TIM_M2_M23CR_UG TIM_M2_M23CR_UG_MASK #define TIM_M2_M23CR_UG_ENABLE (0x01UL<<TIM_M2_M23CR_UG_POS) #define TIM_M2_M23CR_UG_DISABLE (0x00UL<<TIM_M2_M23CR_UG_POS) //===软件触发 #define TIM_M2_M23CR_TG_POS 24 #define TIM_M2_M23CR_TG_MASK (0x01UL<<TIM_M2_M23CR_TG_POS) #define TIM_M2_M23CR_TG TIM_M2_M23CR_TG_MASK #define TIM_M2_M23CR_TG_ENABLE (0x01UL<<TIM_M2_M23CR_TG_POS) #define TIM_M2_M23CR_TG_DISABLE (0x00UL<<TIM_M2_M23CR_TG_POS) //===OCREF清除使能 #define TIM_M2_M23CR_OCCE_POS 23 #define TIM_M2_M23CR_OCCE_MASK (0x01UL<<TIM_M2_M23CR_OCCE_POS) #define TIM_M2_M23CR_OCCE TIM_M2_M23CR_OCCE_MASK #define TIM_M2_M23CR_OCCE_ENABLE (0x01UL<<TIM_M2_M23CR_OCCE_POS) #define TIM_M2_M23CR_OCCE_DISABLE (0x00UL<<TIM_M2_M23CR_OCCE_POS) //===A比较模式中断 #define TIM_M2_M23CR_CISA_POS 21 #define TIM_M2_M23CR_CISA_MASK (0x03UL<<TIM_M2_M23CR_CISA_POS) #define TIM_M2_M23CR_CISA TIM_M2_M23CR_CISA_MASK #define TIM_M2_M23CR_CISA_EDGE_NONE (0x00UL<<TIM_M2_M23CR_CISA_POS) #define TIM_M2_M23CR_CISA_EDGE_RISE (0x01UL<<TIM_M2_M23CR_CISA_POS) #define TIM_M2_M23CR_CISA_EDGE_FAIL (0x02UL<<TIM_M2_M23CR_CISA_POS) #define TIM_M2_M23CR_CISA_EDGE_ALL (0x03UL<<TIM_M2_M23CR_CISA_POS) //===刹车中断使能 #define TIM_M2_M23CR_BIE_POS 20 #define TIM_M2_M23CR_BIE_MASK (0x01UL<<TIM_M2_M23CR_BIE_POS) #define TIM_M2_M23CR_BIE TIM_M2_M23CR_BIE_MASK //===触发中断使能 #define TIM_M2_M23CR_TIE_POS 19 #define TIM_M2_M23CR_TIE_MASK (0x01UL<<TIM_M2_M23CR_TIE_POS) #define TIM_M2_M23CR_TIE TIM_M2_M23CR_TIE_MASK //===触发DMA中断使能 #define TIM_M2_M23CR_TDMAIE_POS 18 #define TIM_M2_M23CR_TDMAIE_MASK (0x01UL<<TIM_M2_M23CR_TDMAIE_POS) #define TIM_M2_M23CR_TDMAIE TIM_M2_M23CR_TDMAIE_MASK //===更新源 #define TIM_M2_M23CR_URS_POS 17 #define TIM_M2_M23CR_URS_MASK (0x01UL<<TIM_M2_M23CR_URS_POS) #define TIM_M2_M23CR_URS TIM_M2_M23CR_URS_MASK #define TIM_M2_M23CR_URS_ALL (0x00UL<<TIM_M2_M23CR_URS_POS) #define TIM_M2_M23CR_URS_RISE_OR_FAIL (0x00UL<<TIM_M2_M23CR_URS_POS) //===OCREF清除源选择 #define TIM_M2_M23CR_OCCS_POS 16 #define TIM_M2_M23CR_OCCS_MASK (0x01UL<<TIM_M2_M23CR_OCCS_POS) #define TIM_M2_M23CR_OCCS TIM_M2_M23CR_OCCS_MASK #define TIM_M2_M23CR_OCCS_VC (0x00UL<<TIM_M2_M23CR_OCCS_POS) #define TIM_M2_M23CR_OCCS_ETR (0x01UL<<TIM_M2_M23CR_OCCS_POS) //===PWM互补模式选择 #define TIM_M2_M23CR_CSG_POS 15 #define TIM_M2_M23CR_CSG_MASK (0x01UL<<TIM_M2_M23CR_CSG_POS) #define TIM_M2_M23CR_CSG TIM_M2_M23CR_CSG_MASK #define TIM_M2_M23CR_CSG_COMP (0x00UL<<TIM_M2_M23CR_CSG_POS) #define TIM_M2_M23CR_CSG_CAPT (0x01UL<<TIM_M2_M23CR_CSG_POS) //===触发选择 #define TIM_M2_M23CR_TRIG_POS 14 #define TIM_M2_M23CR_TRIG_MASK (0x01UL<<TIM_M2_M23CR_TRIG_POS) #define TIM_M2_M23CR_TRIG TIM_M2_M23CR_TRIG_MASK #define TIM_M2_M23CR_TRIG_CYCLE (0x00UL<<TIM_M2_M23CR_TRIG_POS) #define TIM_M2_M23CR_TRIG_SINGLE (0x01UL<<TIM_M2_M23CR_TRIG_POS) //===工作模式 #define TIM_M2_M23CR_MODE_POS 12 #define TIM_M2_M23CR_MODE_MASK (0x03UL<<TIM_M2_M23CR_MODE_POS) #define TIM_M2_M23CR_MODE TIM_M2_M23CR_MODE_MASK #define TIM_M2_M23CR_MODE_TIM0 (0x00UL<<TIM_M2_M23CR_MODE_POS) #define TIM_M2_M23CR_MODE_PWC (0x01UL<<TIM_M2_M23CR_MODE_POS) #define TIM_M2_M23CR_MODE_SAWTOOTH (0x02UL<<TIM_M2_M23CR_MODE_POS) #define TIM_M2_M23CR_MODE_TRIANGLE (0x03UL<<TIM_M2_M23CR_MODE_POS) //===更新DMA使能 #define TIM_M2_M23CR_UDMAEN_POS 11 #define TIM_M2_M23CR_UDMAEN_MASK (0x01UL<<TIM_M2_M23CR_UDMAEN_POS) #define TIM_M2_M23CR_UDMAEN TIM_M2_M23CR_UDMAEN_MASK //===更新中断使能 #define TIM_M2_M23CR_UIE_POS 10 #define TIM_M2_M23CR_UIE_MASK (0x01UL<<TIM_M2_M23CR_UIE_POS) #define TIM_M2_M23CR_UIE TIM_M2_M23CR_UIE_MASK //===下降沿捕获使能控制 #define TIM_M2_M23CR_CFG_POS 9 #define TIM_M2_M23CR_CFG_MASK (0x01UL<<TIM_M2_M23CR_CFG_POS) #define TIM_M2_M23CR_CFG TIM_M2_M23CR_CFG_MASK #define TIM_M2_M23CR_CFG_ENABLE (0x01UL<<TIM_M2_M23CR_CFG_POS) #define TIM_M2_M23CR_CFG_DISABLE (0x00UL<<TIM_M2_M23CR_CFG_POS) //===上升沿捕获使能控制 #define TIM_M2_M23CR_CRG_POS 8 #define TIM_M2_M23CR_CRG_MASK (0x01UL<<TIM_M2_M23CR_CRG_POS) #define TIM_M2_M23CR_CRG TIM_M2_M23CR_CRG_MASK #define TIM_M2_M23CR_CRG_ENABLE (0x01UL<<TIM_M2_M23CR_CRG_POS) #define TIM_M2_M23CR_CRG_DISABLE (0x00UL<<TIM_M2_M23CR_CRG_POS) //===重载缓存使能控制 #define TIM_M2_M23CR_BUFPEN_POS 7 #define TIM_M2_M23CR_BUFPEN_MASK (0x01UL<<TIM_M2_M23CR_BUFPEN_POS) #define TIM_M2_M23CR_BUFPEN TIM_M2_M23CR_BUFPEN_MASK //===时钟分频选择 #define TIM_M2_M23CR_PRS_POS 4 #define TIM_M2_M23CR_PRS_MASK (0x07UL<<TIM_M2_M23CR_PRS_POS) #define TIM_M2_M23CR_PRS TIM_M2_M23CR_PRS_MASK #define TIM_M2_M23CR_PRS_1 (0x00UL<<TIM_M2_M23CR_PRS_POS) #define TIM_M2_M23CR_PRS_2 (0x01UL<<TIM_M2_M23CR_PRS_POS) #define TIM_M2_M23CR_PRS_4 (0x02UL<<TIM_M2_M23CR_PRS_POS) #define TIM_M2_M23CR_PRS_8 (0x03UL<<TIM_M2_M23CR_PRS_POS) #define TIM_M2_M23CR_PRS_16 (0x04UL<<TIM_M2_M23CR_PRS_POS) #define TIM_M2_M23CR_PRS_32 (0x05UL<<TIM_M2_M23CR_PRS_POS) #define TIM_M2_M23CR_PRS_64 (0x06UL<<TIM_M2_M23CR_PRS_POS) #define TIM_M2_M23CR_PRS_256 (0x07UL<<TIM_M2_M23CR_PRS_POS) //===单双点比较控制 #define TIM_M2_M23CR_PWM2S_POS 3 #define TIM_M2_M23CR_PWM2S_MASK (0x01UL<<TIM_M2_M23CR_PWM2S_POS) #define TIM_M2_M23CR_PWM2S TIM_M2_M23CR_PWM2S_MASK #define TIM_M2_M23CR_PWM2S_DOUBLE (0x00UL<<TIM_M2_M23CR_PWM2S_POS) #define TIM_M2_M23CR_PWM2S_SINGLE (0x01UL<<TIM_M2_M23CR_PWM2S_POS) //===计数时钟 #define TIM_M2_M23CR_CT_POS 2 #define TIM_M2_M23CR_CT_MASK (0x01UL<<TIM_M2_M23CR_CT_POS) #define TIM_M2_M23CR_CT TIM_M2_M23CR_CT_MASK #define TIM_M2_M23CR_CT_TCLK (0x00UL<<TIM_M2_M23CR_CT_POS) #define TIM_M2_M23CR_CT_ETR (0x01UL<<TIM_M2_M23CR_CT_POS) //===PWM模式选择 #define TIM_M2_M23CR_COMP_POS 1 #define TIM_M2_M23CR_COMP_MASK (0x01UL<<TIM_M2_M23CR_COMP_POS) #define TIM_M2_M23CR_COMP TIM_M2_M23CR_COMP_MASK #define TIM_M2_M23CR_COMP_PWM_COMP (0x01UL<<TIM_M2_M23CR_COMP_POS) #define TIM_M2_M23CR_COMP_PWM_INDEP (0x00UL<<TIM_M2_M23CR_COMP_POS) //===定时器使能控制 #define TIM_M2_M23CR_EN_POS 0 #define TIM_M2_M23CR_EN_MASK (0x01U<<TIM_M2_M23CR_EN_POS) #define TIM_M2_M23CR_EN TIM_M2_M23CR_EN_MASK //===中断标志寄存器 //===触发中断标志 #define TIM_M2_SR_TIE_POS 15 #define TIM_M2_SR_TIE_MASK (0x01U<<TIM_M2_SR_TIE_POS) #define TIM_M2_SR_TIE TIM_M2_SR_TIE_MASK //===刹车中断标志 #define TIM_M2_SR_BIE_POS 14 #define TIM_M2_SR_BIE_MASK (0x01U<<TIM_M2_SR_BIE_POS) #define TIM_M2_SR_BIE TIM_M2_SR_BIE_MASK //==CH2B捕获丢数据 #define TIM_M2_SR_CH2B_ERROR_POS 13 #define TIM_M2_SR_CH2B_ERROR_MASK (0x01U<<TIM_M2_SR_CH2B_ERROR_POS) #define TIM_M2_SR_CH2B_ERROR TIM_M2_SR_CH2B_ERROR_MASK //==CH1B捕获丢数据 #define TIM_M2_SR_CH1B_ERROR_POS 12 #define TIM_M2_SR_CH1B_ERROR_MASK (0x01U<<TIM_M2_SR_CH1B_ERROR_POS) #define TIM_M2_SR_CH1B_ERROR TIM_M2_SR_CH1B_ERROR_MASK //==CH0B捕获丢数据 #define TIM_M2_SR_CH0B_ERROR_POS 11 #define TIM_M2_SR_CH0B_ERROR_MASK (0x01U<<TIM_M2_SR_CH0B_ERROR_POS) #define TIM_M2_SR_CH0B_ERROR TIM_M2_SR_CH0B_ERROR_MASK //==CH2A捕获丢数据 #define TIM_M2_SR_CH2A_ERROR_POS 10 #define TIM_M2_SR_CH2A_ERROR_MASK (0x01U<<TIM_M2_SR_CH2A_ERROR_POS) #define TIM_M2_SR_CH2A_ERROR TIM_M2_SR_CH2A_ERROR_MASK //==CH1A捕获丢数据 #define TIM_M2_SR_CH1A_ERROR_POS 9 #define TIM_M2_SR_CH1A_ERROR_MASK (0x01U<<TIM_M2_SR_CH1A_ERROR_POS) #define TIM_M2_SR_CH1A_ERROR TIM_M2_SR_CH1A_ERROR_MASK //==CH0A捕获丢数据 #define TIM_M2_SR_CH0A_ERROR_POS 8 #define TIM_M2_SR_CH0A_ERROR_MASK (0x01U<<TIM_M2_SR_CH0A_ERROR_POS) #define TIM_M2_SR_CH0A_ERROR TIM_M2_SR_CH0A_ERROR_MASK //==CH2B捕获/比较中断标志 #define TIM_M2_SR_CH2B_FLAG_POS 7 #define TIM_M2_SR_CH2B_FLAG_MASK (0x01U<<TIM_M2_SR_CH2B_FLAG_POS) #define TIM_M2_SR_CH2B_FLAG TIM_M2_SR_CH2B_FLAG_MASK //==CH1B捕获/比较中断标志 #define TIM_M2_SR_CH1B_FLAG_POS 6 #define TIM_M2_SR_CH1B_FLAG_MASK (0x01U<<TIM_M2_SR_CH1B_FLAG_POS) #define TIM_M2_SR_CH1B_FLAG TIM_M2_SR_CH1B_FLAG_MASK //==CH0B捕获/比较中断标志 #define TIM_M2_SR_CH0B_FLAG_POS 5 #define TIM_M2_SR_CH0B_FLAG_MASK (0x01U<<TIM_M2_SR_CH0B_FLAG_POS) #define TIM_M2_SR_CH0B_FLAG TIM_M2_SR_CH0B_FLAG_MASK //==CH2A捕获/比较中断标志 #define TIM_M2_SR_CH2A_FLAG_POS 4 #define TIM_M2_SR_CH2A_FLAG_MASK (0x01U<<TIM_M2_SR_CH2A_FLAG_POS) #define TIM_M2_SR_CH2A_FLAG TIM_M2_SR_CH2A_FLAG_MASK //==CH1A捕获/比较中断标志 #define TIM_M2_SR_CH1A_FLAG_POS 3 #define TIM_M2_SR_CH1A_FLAG_MASK (0x01U<<TIM_M2_SR_CH1A_FLAG_POS) #define TIM_M2_SR_CH1A_FLAG TIM_M2_SR_CH1A_FLAG_MASK //==CH0A捕获/比较中断标志 #define TIM_M2_SR_CH0A_FLAG_POS 2 #define TIM_M2_SR_CH0A_FLAG_MASK (0x01U<<TIM_M2_SR_CH0A_FLAG_POS) #define TIM_M2_SR_CH0A_FLAG TIM_M2_SR_CH0A_FLAG_MASK //===更新中断标志位 #define TIM_M2_SR_UIE_POS 0 #define TIM_M2_SR_UIE_MASK (0x01U<<TIM_M2_SR_UIE_POS) #define TIM_M2_SR_UIE TIM_M2_SR_UIE_MASK //===清楚标志寄存器 #define TIM_M2_CSR_MASK 0xFFFDUL #define TIM_M2_CSR_TIE_POS 15 #define TIM_M2_CSR_TIE_MASK (0x01U<<TIM_M2_CSR_TIE_POS) #define TIM_M2_CSR_TIE TIM_M2_CSR_TIE_MASK #define TIM_M2_CSR_BIE_POS 14 #define TIM_M2_CSR_BIE_MASK (0x01U<<TIM_M2_CSR_BIE_POS) #define TIM_M2_CSR_BIE TIM_M2_CSR_BIE_MASK #define TIM_M2_CSR_CH2B_ERROR_POS 13 #define TIM_M2_CSR_CH2B_ERROR_MASK (0x01U<<TIM_M2_CSR_CH2B_ERROR_POS) #define TIM_M2_CSR_CH2B_ERROR TIM_M2_CSR_CH2B_ERROR_MASK #define TIM_M2_CSR_CH1B_ERROR_POS 12 #define TIM_M2_CSR_CH1B_ERROR_MASK (0x01U<<TIM_M2_CSR_CH1B_ERROR_POS) #define TIM_M2_CSR_CH1B_ERROR TIM_M2_CSR_CH1B_ERROR_MASK #define TIM_M2_CSR_CH0B_ERROR_POS 11 #define TIM_M2_CSR_CH0B_ERROR_MASK (0x01U<<TIM_M2_CSR_CH0B_ERROR_POS) #define TIM_M2_CSR_CH0B_ERROR TIM_M2_CSR_CH0B_ERROR_MASK #define TIM_M2_CSR_CH2A_ERROR_POS 10 #define TIM_M2_CSR_CH2A_ERROR_MASK (0x01U<<TIM_M2_CSR_CH2A_ERROR_POS) #define TIM_M2_CSR_CH2A_ERROR TIM_M2_CSR_CH2A_ERROR_MASK #define TIM_M2_CSR_CH1A_ERROR_POS 9 #define TIM_M2_CSR_CH1A_ERROR_MASK (0x01U<<TIM_M2_CSR_CH1A_ERROR_POS) #define TIM_M2_CSR_CH1A_ERROR TIM_M2_CSR_CH1A_ERROR_MASK #define TIM_M2_CSR_CH0A_ERROR_POS 8 #define TIM_M2_CSR_CH0A_ERROR_MASK (0x01U<<TIM_M2_CSR_CH0A_ERROR_POS) #define TIM_M2_CSR_CH0A_ERROR TIM_M2_CSR_CH0A_ERROR_MASK #define TIM_M2_CSR_CH2B_FLAG_POS 7 #define TIM_M2_CSR_CH2B_FLAG_MASK (0x01U<<TIM_M2_CSR_CH2B_FLAG_POS) #define TIM_M2_CSR_CH2B_FLAG TIM_M2_CSR_CH2B_FLAG_MASK #define TIM_M2_CSR_CH1B_FLAG_POS 6 #define TIM_M2_CSR_CH1B_FLAG_MASK (0x01U<<TIM_M2_CSR_CH1B_FLAG_POS) #define TIM_M2_CSR_CH1B_FLAG TIM_M2_CSR_CH1B_FLAG_MASK #define TIM_M2_CSR_CH0B_FLAG_POS 5 #define TIM_M2_CSR_CH0B_FLAG_MASK (0x01U<<TIM_M2_CSR_CH0B_FLAG_POS) #define TIM_M2_CSR_CH0B_FLAG TIM_M2_CSR_CH0B_FLAG_MASK #define TIM_M2_CSR_CH2A_FLAG_POS 4 #define TIM_M2_CSR_CH2A_FLAG_MASK (0x01U<<TIM_M2_CSR_CH2A_FLAG_POS) #define TIM_M2_CSR_CH2A_FLAG TIM_M2_CSR_CH2A_FLAG_MASK #define TIM_M2_CSR_CH1A_FLAG_POS 3 #define TIM_M2_CSR_CH1A_FLAG_MASK (0x01U<<TIM_M2_CSR_CH1A_FLAG_POS) #define TIM_M2_CSR_CH1A_FLAG TIM_M2_CSR_CH1A_FLAG_MASK #define TIM_M2_CSR_CH0A_FLAG_POS 2 #define TIM_M2_CSR_CH0A_FLAG_MASK (0x01U<<TIM_M2_CSR_CH0A_FLAG_POS) #define TIM_M2_CSR_CH0A_FLAG TIM_M2_CSR_CH0A_FLAG_MASK #define TIM_M2_CSR_UIE_POS 0 #define TIM_M2_CSR_UIE_MASK (0x01U<<TIM_M2_CSR_UIE_POS) #define TIM_M2_CSR_UIE TIM_M2_CSR_UIE_MASK //===主从模式控制寄存器 //===CH0B输入选择 #define TIM_M2_MSCR_IB0S_POS 12 #define TIM_M2_MSCR_IB0S_MASK (0x01U<<TIM_M2_MSCR_IB0S_POS) #define TIM_M2_MSCR_IB0S TIM_M2_MSCR_IB0S_MASK //===CH0A输入选择 #define TIM_M2_MSCR_IA0S_POS 11 #define TIM_M2_MSCR_IA0S_MASK (0x01U<<TIM_M2_MSCR_IA0S_POS) #define TIM_M2_MSCR_IA0S TIM_M2_MSCR_IA0S_MASK //===从模式选择 #define TIM_M2_MSCR_SMS_POS 8 #define TIM_M2_MSCR_SMS_MASK (0x07U<<TIM_M2_MSCR_SMS_POS) #define TIM_M2_MSCR_SMS TIM_M2_MSCR_SMS_MASK #define TIM_M2_MSCR_SMS_TCLK (0x00U<<TIM_M2_MSCR_SMS_POS) #define TIM_M2_MSCR_SMS_RESET (0x01U<<TIM_M2_MSCR_SMS_POS) #define TIM_M2_MSCR_SMS_TRIG (0x02U<<TIM_M2_MSCR_SMS_POS) #define TIM_M2_MSCR_SMS_ETR (0x03U<<TIM_M2_MSCR_SMS_POS) #define TIM_M2_MSCR_SMS_ENCODE_MODE1 (0x04U<<TIM_M2_MSCR_SMS_POS) #define TIM_M2_MSCR_SMS_ENCODE_MODE2 (0x05U<<TIM_M2_MSCR_SMS_POS) #define TIM_M2_MSCR_SMS_ENCODE_MODE3 (0x06U<<TIM_M2_MSCR_SMS_POS) #define TIM_M2_MSCR_SMS_GATE (0x07U<<TIM_M2_MSCR_SMS_POS) //===触发模式选择 #define TIM_M2_MSCR_TRIG_POS 5 #define TIM_M2_MSCR_TRIG_MASK (0x07U<<TIM_M2_MSCR_TRIG_POS) #define TIM_M2_MSCR_TRIG TIM_M2_MSCR_TRIG_MASK #define TIM_M2_MSCR_TRIG_ETRP (0x00U<<TIM_M2_MSCR_TRIG_POS) #define TIM_M2_MSCR_TRIG_ITR0 (0x01U<<TIM_M2_MSCR_TRIG_POS) #define TIM_M2_MSCR_TRIG_ITR1 (0x02U<<TIM_M2_MSCR_TRIG_POS) #define TIM_M2_MSCR_TRIG_ITR2 (0x03U<<TIM_M2_MSCR_TRIG_POS) #define TIM_M2_MSCR_TRIG_ITR3 (0x04U<<TIM_M2_MSCR_TRIG_POS) #define TIM_M2_MSCR_TRIG_CH0A (0x05U<<TIM_M2_MSCR_TRIG_POS) #define TIM_M2_MSCR_TRIG_CH0AP (0x06U<<TIM_M2_MSCR_TRIG_POS) #define TIM_M2_MSCR_TRIG_CH0BP (0x07U<<TIM_M2_MSCR_TRIG_POS) //===主从模式选择 #define TIM_M2_MSCR_MSM_POS 4 #define TIM_M2_MSCR_MSM_MASK (0x07U<<TIM_M2_MSCR_MSM_POS) #define TIM_M2_MSCR_MSM TIM_M2_MSCR_MSM_MASK //===比较模式下DMA比较触发选择 #define TIM_M2_MSCR_CCDS_POS 3 #define TIM_M2_MSCR_CCDS_MASK (0x07U<<TIM_M2_MSCR_CCDS_POS) #define TIM_M2_MSCR_CCDS TIM_M2_MSCR_CCDS_MASK //===主模式输出选择 #define TIM_M2_MSCR_MMS_POS 0 #define TIM_M2_MSCR_MMS_MASK (0x07UL<<TIM_M2_MSCR_MMS_POS) #define TIM_M2_MSCR_MMS TIM_M2_MSCR_MMS_MASK #define TIM_M2_MSCR_MMS_UG (0x00U<<TIM_M2_MSCR_MMS_POS) #define TIM_M2_MSCR_MMS_EN (0x01U<<TIM_M2_MSCR_MMS_POS) #define TIM_M2_MSCR_MMS_UEV (0x02U<<TIM_M2_MSCR_MMS_POS) #define TIM_M2_MSCR_MMS_CMPSO (0x03U<<TIM_M2_MSCR_MMS_POS) #define TIM_M2_MSCR_MMS_OCREF0A (0x04U<<TIM_M2_MSCR_MMS_POS) #define TIM_M2_MSCR_MMS_OCREF1A (0x05U<<TIM_M2_MSCR_MMS_POS) #define TIM_M2_MSCR_MMS_OCREF2A (0x06U<<TIM_M2_MSCR_MMS_POS) #define TIM_M2_MSCR_MMS_OCREF0B (0x07U<<TIM_M2_MSCR_MMS_POS) //===滤波控制寄存器 //===ETR输入相位 #define TIM_M2_FLTR_ETP_POS 31 #define TIM_M2_FLTR_ETP_MASK (0x01UL<<TIM_M2_FLTR_ETP_POS) #define TIM_M2_FLTR_ETP TIM_M2_FLTR_ETP_MASK //===ETR滤波控制 #define TIM_M2_FLTR_ETR_POS 28 #define TIM_M2_FLTR_ETR_MASK (0x07UL<<TIM_M2_FLTR_ETR_POS) #define TIM_M2_FLTR_ETR TIM_M2_FLTR_ETR_MASK #define TIM_M2_FLTR_ETR_NONE (0x00U<<TIM_M2_FLTR_ETR_POS) #define TIM_M2_FLTR_ETR_PCLK_DIV1 (0x04U<<TIM_M2_FLTR_ETR_POS) #define TIM_M2_FLTR_ETR_PCLK_DIV4 (0x05U<<TIM_M2_FLTR_ETR_POS) #define TIM_M2_FLTR_ETR_PCLK_DIV16 (0x06U<<TIM_M2_FLTR_ETR_POS) #define TIM_M2_FLTR_ETR_PCLK_DIV64 (0x07U<<TIM_M2_FLTR_ETR_POS) //===刹车BK输入相位选择 #define TIM_M2_FLTR_BKP_POS 27 #define TIM_M2_FLTR_BKP_MASK (0x01U<<TIM_M2_FLTR_BKP_POS) #define TIM_M2_FLTR_BKP TIM_M2_FLTR_BKP_MASK //===刹车输入滤波控制 #define TIM_M2_FLTR_BKR_POS 24 #define TIM_M2_FLTR_BKR_MASK (0x07UL<<TIM_M2_FLTR_BKR_POS) #define TIM_M2_FLTR_BKR TIM_M2_FLTR_BKR_MASK #define TIM_M2_FLTR_BKR_NONE (0x00UL<<TIM_M2_FLTR_BKR_POS) #define TIM_M2_FLTR_BKR_PCLK_DIV1 (0x04UL<<TIM_M2_FLTR_BKR_POS) #define TIM_M2_FLTR_BKR_PCLK_DIV4 (0x05UL<<TIM_M2_FLTR_BKR_POS) #define TIM_M2_FLTR_BKR_PCLK_DIV16 (0x06UL<<TIM_M2_FLTR_BKR_POS) #define TIM_M2_FLTR_BKR_PCLK_DIV64 (0x07UL<<TIM_M2_FLTR_BKR_POS) //===CH2B比较输出相位控制 #define TIM_M2_FLTR_CCPB2_POS 23 #define TIM_M2_FLTR_CCPB2_MASK (0x01UL<<TIM_M2_FLTR_CCPB2_POS) #define TIM_M2_FLTR_CCPB2 TIM_M2_FLTR_CCPB2_MASK //==CH2B比较输出控制 #define TIM_M2_FLTR_OCMB2_POS 20 #define TIM_M2_FLTR_OCMB2_MASK (0x07UL<<TIM_M2_FLTR_OCMB2_POS) #define TIM_M2_FLTR_OCMB2 TIM_M2_FLTR_OCMB2_MASK #define TIM_M2_FLTR_OCMB2_FORCE_LOW (0x00UL<<TIM_M2_FLTR_OCMB2_POS) #define TIM_M2_FLTR_OCMB2_FORCE_HIGH (0x01UL<<TIM_M2_FLTR_OCMB2_POS) #define TIM_M2_FLTR_OCMB2_COMP_LOW (0x02UL<<TIM_M2_FLTR_OCMB2_POS) #define TIM_M2_FLTR_OCMB2_COMP_HIGH (0x03UL<<TIM_M2_FLTR_OCMB2_POS) #define TIM_M2_FLTR_OCMB2_COMP_TOGGLE (0x04UL<<TIM_M2_FLTR_OCMB2_POS) #define TIM_M2_FLTR_OCMB2_COMP_KEEP_HIGH (0x05UL<<TIM_M2_FLTR_OCMB2_POS) #define TIM_M2_FLTR_OCMB2_PWM_MODE1 (0x06UL<<TIM_M2_FLTR_OCMB2_POS) #define TIM_M2_FLTR_OCMB2_PWM_MODE2 (0x07UL<<TIM_M2_FLTR_OCMB2_POS) //==CH2B捕获输入滤波控制 #define TIM_M2_FLTR_CH2B_POS 20 #define TIM_M2_FLTR_CH2B_MASK (0x07UL<<TIM_M2_FLTR_CH2B_POS) #define TIM_M2_FLTR_CH2B TIM_M2_FLTR_CH2B_MASK #define TIM_M2_FLTR_CH2B_NONE (0x00U<<TIM_M2_FLTR_CH2B_POS) #define TIM_M2_FLTR_CH2B_PCLK_DIV1 (0x04U<<TIM_M2_FLTR_CH2B_POS) #define TIM_M2_FLTR_CH2B_PCLK_DIV4 (0x05U<<TIM_M2_FLTR_CH2B_POS) #define TIM_M2_FLTR_CH2B_PCLK_DIV16 (0x06U<<TIM_M2_FLTR_CH2B_POS) #define TIM_M2_FLTR_CH2B_PCLK_DIV64 (0x07U<<TIM_M2_FLTR_CH2B_POS) //===CH2A比较输出相位控制 #define TIM_M2_FLTR_CCPA2_POS 19 #define TIM_M2_FLTR_CCPA2_MASK (0x01UL<<TIM_M2_FLTR_CCPA2_POS) #define TIM_M2_FLTR_CCPA2 TIM_M2_FLTR_CCPA2_MASK //==CH2A比较输出控制 #define TIM_M2_FLTR_OCMA2_POS 16 #define TIM_M2_FLTR_OCMA2_MASK (0x07UL<<TIM_M2_FLTR_OCMA2_POS) #define TIM_M2_FLTR_OCMA2 TIM_M2_FLTR_OCMA2_MASK #define TIM_M2_FLTR_OCMA2_FORCE_LOW (0x00UL<<TIM_M2_FLTR_OCMA2_POS) #define TIM_M2_FLTR_OCMA2_FORCE_HIGH (0x01UL<<TIM_M2_FLTR_OCMA2_POS) #define TIM_M2_FLTR_OCMA2_COMP_LOW (0x02UL<<TIM_M2_FLTR_OCMA2_POS) #define TIM_M2_FLTR_OCMA2_COMP_HIGH (0x03UL<<TIM_M2_FLTR_OCMA2_POS) #define TIM_M2_FLTR_OCMA2_COMP_TOGGLE (0x04UL<<TIM_M2_FLTR_OCMA2_POS) #define TIM_M2_FLTR_OCMA2_COMP_KEEP_HIGH (0x05UL<<TIM_M2_FLTR_OCMA2_POS) #define TIM_M2_FLTR_OCMA2_PWM_MODE1 (0x06UL<<TIM_M2_FLTR_OCMA2_POS) #define TIM_M2_FLTR_OCMA2_PWM_MODE2 (0x07UL<<TIM_M2_FLTR_OCMA2_POS) //==CH2A捕获输入滤波控制 #define TIM_M2_FLTR_CH2A_POS 16 #define TIM_M2_FLTR_CH2A_MASK (0x07UL<<TIM_M2_FLTR_CH2A_POS) #define TIM_M2_FLTR_CH2A TIM_M2_FLTR_CH2A_MASK #define TIM_M2_FLTR_CH2A_NONE (0x00UL<<TIM_M2_FLTR_CH2A_POS) #define TIM_M2_FLTR_CH2A_PCLK_DIV1 (0x04UL<<TIM_M2_FLTR_CH2A_POS) #define TIM_M2_FLTR_CH2A_PCLK_DIV4 (0x05UL<<TIM_M2_FLTR_CH2A_POS) #define TIM_M2_FLTR_CH2A_PCLK_DIV16 (0x06UL<<TIM_M2_FLTR_CH2A_POS) #define TIM_M2_FLTR_CH2A_PCLK_DIV64 (0x07UL<<TIM_M2_FLTR_CH2A_POS) //===CH1B比较输出相位控制 #define TIM_M2_FLTR_CCPB1_POS 15 #define TIM_M2_FLTR_CCPB1_MASK (0x01UL<<TIM_M2_FLTR_CCPB1_POS) #define TIM_M2_FLTR_CCPB1 TIM_M2_FLTR_CCPB1_MASK //==CH1B比较输出控制 #define TIM_M2_FLTR_OCMB1_POS 12 #define TIM_M2_FLTR_OCMB1_MASK (0x07UL<<TIM_M2_FLTR_OCMB1_POS) #define TIM_M2_FLTR_OCMB1 TIM_M2_FLTR_OCMB1_MASK #define TIM_M2_FLTR_OCMB1_FORCE_LOW (0x00UL<<TIM_M2_FLTR_OCMB1_POS) #define TIM_M2_FLTR_OCMB1_FORCE_HIGH (0x01UL<<TIM_M2_FLTR_OCMB1_POS) #define TIM_M2_FLTR_OCMB1_COMP_LOW (0x02UL<<TIM_M2_FLTR_OCMB1_POS) #define TIM_M2_FLTR_OCMB1_COMP_HIGH (0x03UL<<TIM_M2_FLTR_OCMB1_POS) #define TIM_M2_FLTR_OCMB1_COMP_TOGGLE (0x04UL<<TIM_M2_FLTR_OCMB1_POS) #define TIM_M2_FLTR_OCMB1_COMP_KEEP_HIGH (0x05UL<<TIM_M2_FLTR_OCMB1_POS) #define TIM_M2_FLTR_OCMB1_PWM_MODE1 (0x06UL<<TIM_M2_FLTR_OCMB1_POS) #define TIM_M2_FLTR_OCMB1_PWM_MODE2 (0x07UL<<TIM_M2_FLTR_OCMB1_POS) //==CH1B捕获输入滤波控制 #define TIM_M2_FLTR_CH1B_POS 12 #define TIM_M2_FLTR_CH1B_MASK (0x07UL<<TIM_M2_FLTR_CH1B_POS) #define TIM_M2_FLTR_CH1B TIM_M2_FLTR_CH1B_MASK #define TIM_M2_FLTR_CH1B_NONE (0x00UL<<TIM_M2_FLTR_CH1B_POS) #define TIM_M2_FLTR_CH1B_PCLK_DIV1 (0x04UL<<TIM_M2_FLTR_CH1B_POS) #define TIM_M2_FLTR_CH1B_PCLK_DIV4 (0x05UL<<TIM_M2_FLTR_CH1B_POS) #define TIM_M2_FLTR_CH1B_PCLK_DIV16 (0x06UL<<TIM_M2_FLTR_CH1B_POS) #define TIM_M2_FLTR_CH1B_PCLK_DIV64 (0x07UL<<TIM_M2_FLTR_CH1B_POS) //===CH1A比较输出相位控制 #define TIM_M2_FLTR_CCPA1_POS 11 #define TIM_M2_FLTR_CCPA1_MASK (0x01UL<<TIM_M2_FLTR_CCPA1_POS) #define TIM_M2_FLTR_CCPA1 TIM_M2_FLTR_CCPA1_MASK //==CH1A比较输出控制 #define TIM_M2_FLTR_OCMA1_POS 8 #define TIM_M2_FLTR_OCMA1_MASK (0x07UL<<TIM_M2_FLTR_OCMA1_POS) #define TIM_M2_FLTR_OCMA1 TIM_M2_FLTR_OCMA1_MASK #define TIM_M2_FLTR_OCMA1_FORCE_LOW (0x00UL<<TIM_M2_FLTR_OCMA1_POS) #define TIM_M2_FLTR_OCMA1_FORCE_HIGH (0x01UL<<TIM_M2_FLTR_OCMA1_POS) #define TIM_M2_FLTR_OCMA1_COMP_LOW (0x02UL<<TIM_M2_FLTR_OCMA1_POS) #define TIM_M2_FLTR_OCMA1_COMP_HIGH (0x03UL<<TIM_M2_FLTR_OCMA1_POS) #define TIM_M2_FLTR_OCMA1_COMP_TOGGLE (0x04UL<<TIM_M2_FLTR_OCMA1_POS) #define TIM_M2_FLTR_OCMA1_COMP_KEEP_HIGH (0x05UL<<TIM_M2_FLTR_OCMA1_POS) #define TIM_M2_FLTR_OCMA1_PWM_MODE1 (0x06UL<<TIM_M2_FLTR_OCMA1_POS) #define TIM_M2_FLTR_OCMA1_PWM_MODE2 (0x07UL<<TIM_M2_FLTR_OCMA1_POS) //==CH1A捕获输入滤波控制 #define TIM_M2_FLTR_CH1A_POS 8 #define TIM_M2_FLTR_CH1A_MASK (0x07UL<<TIM_M2_FLTR_CH1A_POS) #define TIM_M2_FLTR_CH1A TIM_M2_FLTR_CH1A_MASK #define TIM_M2_FLTR_CH1A_NONE (0x00UL<<TIM_M2_FLTR_CH1A_POS) #define TIM_M2_FLTR_CH1A_PCLK_DIV1 (0x04UL<<TIM_M2_FLTR_CH1A_POS) #define TIM_M2_FLTR_CH1A_PCLK_DIV4 (0x05UL<<TIM_M2_FLTR_CH1A_POS) #define TIM_M2_FLTR_CH1A_PCLK_DIV16 (0x06UL<<TIM_M2_FLTR_CH1A_POS) #define TIM_M2_FLTR_CH1A_PCLK_DIV64 (0x07UL<<TIM_M2_FLTR_CH1A_POS) //===CH0B比较输出相位控制 #define TIM_M2_FLTR_CCPB0_POS 7 #define TIM_M2_FLTR_CCPB0_MASK (0x01UL<<TIM_M2_FLTR_CCPB0_POS) #define TIM_M2_FLTR_CCPB0 TIM_M2_FLTR_CCPB0_MASK //==CH0B捕获输入滤波控制 #define TIM_M2_FLTR_OCMB0_POS 4 #define TIM_M2_FLTR_OCMB0_MASK (0x07UL<<TIM_M2_FLTR_OCMB0_POS) #define TIM_M2_FLTR_OCMB0 TIM_M2_FLTR_OCMB0_MASK #define TIM_M2_FLTR_OCMB0_FORCE_LOW (0x00UL<<TIM_M2_FLTR_OCMB0_POS) #define TIM_M2_FLTR_OCMB0_FORCE_HIGH (0x01UL<<TIM_M2_FLTR_OCMB0_POS) #define TIM_M2_FLTR_OCMB0_COMP_LOW (0x02UL<<TIM_M2_FLTR_OCMB0_POS) #define TIM_M2_FLTR_OCMB0_COMP_HIGH (0x03UL<<TIM_M2_FLTR_OCMB0_POS) #define TIM_M2_FLTR_OCMB0_COMP_TOGGLE (0x04UL<<TIM_M2_FLTR_OCMB0_POS) #define TIM_M2_FLTR_OCMB0_COMP_KEEP_HIGH (0x05UL<<TIM_M2_FLTR_OCMB0_POS) #define TIM_M2_FLTR_OCMB0_PWM_MODE1 (0x06UL<<TIM_M2_FLTR_OCMB0_POS) #define TIM_M2_FLTR_OCMB0_PWM_MODE2 (0x07UL<<TIM_M2_FLTR_OCMB0_POS) //==CH0B捕获输入滤波控制 #define TIM_M2_FLTR_CH0B_POS 4 #define TIM_M2_FLTR_CH0B_MASK (0x07UL<<TIM_M2_FLTR_CH0B_POS) #define TIM_M2_FLTR_CH0B TIM_M2_FLTR_CH0B_MASK #define TIM_M2_FLTR_CH0B_NONE (0x00UL<<TIM_M2_FLTR_CH0B_POS) #define TIM_M2_FLTR_CH0B_PCLK_DIV1 (0x04UL<<TIM_M2_FLTR_CH0B_POS) #define TIM_M2_FLTR_CH0B_PCLK_DIV4 (0x05UL<<TIM_M2_FLTR_CH0B_POS) #define TIM_M2_FLTR_CH0B_PCLK_DIV16 (0x06UL<<TIM_M2_FLTR_CH0B_POS) #define TIM_M2_FLTR_CH0B_PCLK_DIV64 (0x07UL<<TIM_M2_FLTR_CH0B_POS) //===CH0A比较输出相位控制 #define TIM_M2_FLTR_CCPA0_POS 3 #define TIM_M2_FLTR_CCPA0_MASK (0x01UL<<TIM_M2_FLTR_CCPA0_POS) #define TIM_M2_FLTR_CCPA0 TIM_M2_FLTR_CCPA0_MASK //==CH0A比较输出控制 #define TIM_M2_FLTR_OCMA0_POS 0 #define TIM_M2_FLTR_OCMA0_MASK (0x07UL<<TIM_M2_FLTR_OCMA0_POS) #define TIM_M2_FLTR_OCMA0 TIM_M2_FLTR_OCMA0_MASK #define TIM_M2_FLTR_OCMA0_FORCE_LOW (0x00UL<<TIM_M2_FLTR_OCMA0_POS) #define TIM_M2_FLTR_OCMA0_FORCE_HIGH (0x01UL<<TIM_M2_FLTR_OCMA0_POS) #define TIM_M2_FLTR_OCMA0_COMP_LOW (0x02UL<<TIM_M2_FLTR_OCMA0_POS) #define TIM_M2_FLTR_OCMA0_COMP_HIGH (0x03UL<<TIM_M2_FLTR_OCMA0_POS) #define TIM_M2_FLTR_OCMA0_COMP_TOGGLE (0x04UL<<TIM_M2_FLTR_OCMA0_POS) #define TIM_M2_FLTR_OCMA0_COMP_KEEP_HIGH (0x05UL<<TIM_M2_FLTR_OCMA0_POS) #define TIM_M2_FLTR_OCMA0_PWM_MODE1 (0x06UL<<TIM_M2_FLTR_OCMA0_POS) #define TIM_M2_FLTR_OCMA0_PWM_MODE2 (0x07UL<<TIM_M2_FLTR_OCMA0_POS) //==CH0A捕获输入滤波控制 #define TIM_M2_FLTR_CH0A_POS 0 #define TIM_M2_FLTR_CH0A_MASK (0x07UL<<TIM_M2_FLTR_CH0A_POS) #define TIM_M2_FLTR_CH0A TIM_M2_FLTR_CH0A_MASK #define TIM_M2_FLTR_CH0A_NONE (0x00UL<<TIM_M2_FLTR_CH0A_POS) #define TIM_M2_FLTR_CH0A_PCLK_DIV1 (0x04UL<<TIM_M2_FLTR_CH0A_POS) #define TIM_M2_FLTR_CH0A_PCLK_DIV4 (0x05UL<<TIM_M2_FLTR_CH0A_POS) #define TIM_M2_FLTR_CH0A_PCLK_DIV16 (0x06UL<<TIM_M2_FLTR_CH0A_POS) #define TIM_M2_FLTR_CH0A_PCLK_DIV64 (0x07UL<<TIM_M2_FLTR_CH0A_POS) //===ADC触发控制寄存器 #define TIM_M2_ADTR_EN_POS 7 #define TIM_M2_ADTR_EN_MASK (0x01UL<<TIM_M2_ADTR_EN_POS) #define TIM_M2_ADTR_EN TIM_M2_ADTR_EN_MASK //===CH2B比较匹配触发adc #define TIM_M2_ADTR_CMB2EN_POS 6 #define TIM_M2_ADTR_CMB2EN_MASK (0x01UL<<TIM_M2_ADTR_CMB2EN_POS) #define TIM_M2_ADTR_CMB2EN TIM_M2_ADTR_CMB2EN_MASK //===CH1B比较匹配触发adc #define TIM_M2_ADTR_CMB1EN_POS 5 #define TIM_M2_ADTR_CMB1EN_MASK (0x01UL<<TIM_M2_ADTR_CMB1EN_POS) #define TIM_M2_ADTR_CMB1EN TIM_M2_ADTR_CMB1EN_MASK //===CH0B比较匹配触发adc #define TIM_M2_ADTR_CMB0EN_POS 4 #define TIM_M2_ADTR_CMB0EN_MASK (0x01UL<<TIM_M2_ADTR_CMB0EN_POS) #define TIM_M2_ADTR_CMB0EN TIM_M2_ADTR_CMB0EN_MASK //===CH2A比较匹配触发adc #define TIM_M2_ADTR_CMA2EN_POS 3 #define TIM_M2_ADTR_CMA2EN_MASK (0x01UL<<TIM_M2_ADTR_CMA2EN_POS) #define TIM_M2_ADTR_CMA2EN TIM_M2_ADTR_CMA2EN_MASK //===CH0A比较匹配触发adc #define TIM_M2_ADTR_CMA1EN_POS 2 #define TIM_M2_ADTR_CMA1EN_MASK (0x01UL<<TIM_M2_ADTR_CMA1EN_POS) #define TIM_M2_ADTR_CMA1EN TIM_M2_ADTR_CMA1EN_MASK //===CH0A比较匹配触发adc #define TIM_M2_ADTR_CMA0EN_POS 1 #define TIM_M2_ADTR_CMA0EN_MASK (0x01UL<<TIM_M2_ADTR_CMA0EN_POS) #define TIM_M2_ADTR_CMA0EN TIM_M2_ADTR_CMA0EN_MASK //===事件更新触发adc #define TIM_M2_ADTR_UEN_POS 0 #define TIM_M2_ADTR_UEN_MASK (0x01UL<<TIM_M2_ADTR_UEN_POS) #define TIM_M2_ADTR_UEN TIM_M2_ADTR_UEN_MASK //===通道0控制寄存器 //===捕获比较B软件触发 #define TIM_M2_CRCH0_CCGB_POS 15 #define TIM_M2_CRCH0_CCGB_MASK (0x01UL<<TIM_M2_CRCH0_CCGB_POS) #define TIM_M2_CRCH0_CCGB TIM_M2_CRCH0_CCGB_MASK //===捕获比较A软件触发 #define TIM_M2_CRCH0_CCGA_POS 14 #define TIM_M2_CRCH0_CCGA_MASK (0x01UL<<TIM_M2_CRCH0_CCGA_POS) #define TIM_M2_CRCH0_CCGA TIM_M2_CRCH0_CCGA_MASK //===B比较模式中断 #define TIM_M2_CRCH0_CISB_POS 13 #define TIM_M2_CRCH0_CISB_MASK (0x03UL<<TIM_M2_CRCH0_CISB_POS) #define TIM_M2_CRCH0_CISB TIM_M2_CRCH0_CISB_MASK #define TIM_M2_CRCH0_CISB_EDGE_NONE (0x00UL<<TIM_M2_CRCH0_CISB_POS) #define TIM_M2_CRCH0_CISB_EDGE_RISE (0x01UL<<TIM_M2_CRCH0_CISB_POS) #define TIM_M2_CRCH0_CISB_EDGE_FAIL (0x02UL<<TIM_M2_CRCH0_CISB_POS) #define TIM_M2_CRCH0_CISB_EDGE_ALL (0x03UL<<TIM_M2_CRCH0_CISB_POS) //===B捕获比较触发DMA使能 #define TIM_M2_CRCH0_CDMABEN_POS 11 #define TIM_M2_CRCH0_CDMABEN_MASK (0x01UL<<TIM_M2_CRCH0_CDMABEN_POS) #define TIM_M2_CRCH0_CDMABEN TIM_M2_CRCH0_CDMABEN_MASK //===A捕获比较触发DMA使能 #define TIM_M2_CRCH0_CDMAAEN_POS 10 #define TIM_M2_CRCH0_CDMAAEN_MASK (0x01UL<<TIM_M2_CRCH0_CDMAAEN_POS) #define TIM_M2_CRCH0_CDMAAEN TIM_M2_CRCH0_CDMAAEN_MASK //===B捕获比较触发中断 #define TIM_M2_CRCH0_CIEB_POS 9 #define TIM_M2_CRCH0_CIEB_MASK (0x01UL<<TIM_M2_CRCH0_CIEB_POS) #define TIM_M2_CRCH0_CIEB TIM_M2_CRCH0_CIEB_MASK //===B捕获比较触发中断 #define TIM_M2_CRCH0_CIEA_POS 8 #define TIM_M2_CRCH0_CIEA_MASK (0x01UL<<TIM_M2_CRCH0_CIEA_POS) #define TIM_M2_CRCH0_CIEA TIM_M2_CRCH0_CIEA_MASK //===比较功能,B比较缓存使能控制 #define TIM_M2_CRCH0_BUFEB_POS 7 #define TIM_M2_CRCH0_BUFEB_MASK (0x01UL<<TIM_M2_CRCH0_BUFEB_POS) #define TIM_M2_CRCH0_BUFEB TIM_M2_CRCH0_BUFEB_MASK //===比较功能,B比较缓存使能控制 #define TIM_M2_CRCH0_BUFEA_POS 6 #define TIM_M2_CRCH0_BUFEA_MASK (0x01UL<<TIM_M2_CRCH0_BUFEA_POS) #define TIM_M2_CRCH0_BUFEA TIM_M2_CRCH0_BUFEA_MASK #define TIM_M2_CRCH0_CSB_POS 5 #define TIM_M2_CRCH0_CSB_MASK (0x01UL<<TIM_M2_CRCH0_CSB_POS) #define TIM_M2_CRCH0_CSB TIM_M2_CRCH0_CSB_MASK #define TIM_M2_CRCH0_CSA_POS 4 #define TIM_M2_CRCH0_CSA_MASK (0x01UL<<TIM_M2_CRCH0_CSA_POS) #define TIM_M2_CRCH0_CSA TIM_M2_CRCH0_CSA_MASK #define TIM_M2_CRCH0_CFB_POS 3 #define TIM_M2_CRCH0_CFB_MASK (0x01UL<<TIM_M2_CRCH0_CFB_POS) #define TIM_M2_CRCH0_CFB TIM_M2_CRCH0_CFB_MASK #define TIM_M2_CRCH0_CRB_POS 2 #define TIM_M2_CRCH0_CRB_MASK (0x01UL<<TIM_M2_CRCH0_CRB_POS) #define TIM_M2_CRCH0_CRB TIM_M2_CRCH0_CRB_MASK //===B通道比较输出刹车电平控制 #define TIM_M2_CRCH0_BKSB_POS 2 #define TIM_M2_CRCH0_BKSB_MASK (0x03UL<<TIM_M2_CRCH0_BKSB_POS) #define TIM_M2_CRCH0_BKSB TIM_M2_CRCH0_BKSB_MASK #define TIM_M2_CRCH0_BKSB_HZ (0x00UL<<TIM_M2_CRCH0_BKSB_POS) #define TIM_M2_CRCH0_BKSB_NONE (0x01UL<<TIM_M2_CRCH0_BKSB_POS) #define TIM_M2_CRCH0_BKSB_LOW (0x02UL<<TIM_M2_CRCH0_BKSB_POS) #define TIM_M2_CRCH0_BKSB_HIGHT (0x03UL<<TIM_M2_CRCH0_BKSB_POS) #define TIM_M2_CRCH0_CFA_POS 1 #define TIM_M2_CRCH0_CFA_MASK (0x01UL<<TIM_M2_CRCH0_CFA_POS) #define TIM_M2_CRCH0_CFA TIM_M2_CRCH0_CFA_MASK #define TIM_M2_CRCH0_CRA_POS 0 #define TIM_M2_CRCH0_CRA_MASK (0x01UL<<TIM_M2_CRCH0_CRA_POS) #define TIM_M2_CRCH0_CRA TIM_M2_CRCH0_CRA_MASK #define TIM_M2_CRCH0_BKSA_POS 0 #define TIM_M2_CRCH0_BKSA_MASK (0x03UL<<TIM_M2_CRCH0_BKSA_POS) #define TIM_M2_CRCH0_BKSA TIM_M2_CRCH0_BKSA_MASK #define TIM_M2_CRCH0_BKSA_HZ (0x00UL<<TIM_M2_CRCH0_BKSA_POS) #define TIM_M2_CRCH0_BKSA_NONE (0x01UL<<TIM_M2_CRCH0_BKSA_POS) #define TIM_M2_CRCH0_BKSA_LOW (0x02UL<<TIM_M2_CRCH0_BKSA_POS) #define TIM_M2_CRCH0_BKSA_HIGHT (0x03UL<<TIM_M2_CRCH0_BKSA_POS) //===通道1控制寄存器 //===捕获比较B软件触发 #define TIM_M2_CRCH1_CCGB_POS 15 #define TIM_M2_CRCH1_CCGB_MASK (0x01UL<<TIM_M2_CRCH1_CCGB_POS) #define TIM_M2_CRCH1_CCGB TIM_M2_CRCH1_CCGB_MASK //===捕获比较A软件触发 #define TIM_M2_CRCH1_CCGA_POS 14 #define TIM_M2_CRCH1_CCGA_MASK (0x01UL<<TIM_M2_CRCH1_CCGA_POS) #define TIM_M2_CRCH1_CCGA TIM_M2_CRCH1_CCGA_MASK //===B比较模式中断 #define TIM_M2_CRCH1_CISB_POS 13 #define TIM_M2_CRCH1_CISB_MASK (0x03UL<<TIM_M2_CRCH1_CISB_POS) #define TIM_M2_CRCH1_CISB TIM_M2_CRCH1_CISB_MASK #define TIM_M2_CRCH1_CISB_EDGE_NONE (0x00UL<<TIM_M2_CRCH1_CISB_POS) #define TIM_M2_CRCH1_CISB_EDGE_RISE (0x01UL<<TIM_M2_CRCH1_CISB_POS) #define TIM_M2_CRCH1_CISB_EDGE_FAIL (0x02UL<<TIM_M2_CRCH1_CISB_POS) #define TIM_M2_CRCH1_CISB_EDGE_ALL (0x03UL<<TIM_M2_CRCH1_CISB_POS) //===B捕获比较触发DMA使能 #define TIM_M2_CRCH1_CDMABEN_POS 11 #define TIM_M2_CRCH1_CDMABEN_MASK (0x01UL<<TIM_M2_CRCH1_CDMABEN_POS) #define TIM_M2_CRCH1_CDMABEN TIM_M2_CRCH1_CDMABEN_MASK //===A捕获比较触发DMA使能 #define TIM_M2_CRCH1_CDMAAEN_POS 10 #define TIM_M2_CRCH1_CDMAAEN_MASK (0x01UL<<TIM_M2_CRCH1_CDMAAEN_POS) #define TIM_M2_CRCH1_CDMAAEN TIM_M2_CRCH1_CDMAAEN_MASK //===B捕获比较触发中断 #define TIM_M2_CRCH1_CIEB_POS 9 #define TIM_M2_CRCH1_CIEB_MASK (0x01UL<<TIM_M2_CRCH1_CIEB_POS) #define TIM_M2_CRCH1_CIEB TIM_M2_CRCH1_CIEB_MASK //===B捕获比较触发中断 #define TIM_M2_CRCH1_CIEA_POS 8 #define TIM_M2_CRCH1_CIEA_MASK (0x01UL<<TIM_M2_CRCH1_CIEA_POS) #define TIM_M2_CRCH1_CIEA TIM_M2_CRCH1_CIEA_MASK //===比较功能,B比较缓存使能控制 #define TIM_M2_CRCH1_BUFEB_POS 7 #define TIM_M2_CRCH1_BUFEB_MASK (0x01UL<<TIM_M2_CRCH1_BUFEB_POS) #define TIM_M2_CRCH1_BUFEB TIM_M2_CRCH1_BUFEB_MASK //===比较功能,B比较缓存使能控制 #define TIM_M2_CRCH1_BUFEA_POS 6 #define TIM_M2_CRCH1_BUFEA_MASK (0x01UL<<TIM_M2_CRCH1_BUFEA_POS) #define TIM_M2_CRCH1_BUFEA TIM_M2_CRCH1_BUFEA_MASK #define TIM_M2_CRCH1_CSB_POS 5 #define TIM_M2_CRCH1_CSB_MASK (0x01UL<<TIM_M2_CRCH1_CSB_POS) #define TIM_M2_CRCH1_CSB TIM_M2_CRCH1_CSB_MASK #define TIM_M2_CRCH1_CSA_POS 4 #define TIM_M2_CRCH1_CSA_MASK (0x01UL<<TIM_M2_CRCH1_CSA_POS) #define TIM_M2_CRCH1_CSA TIM_M2_CRCH1_CSA_MASK #define TIM_M2_CRCH1_CFB_POS 3 #define TIM_M2_CRCH1_CFB_MASK (0x01UL<<TIM_M2_CRCH1_CFB_POS) #define TIM_M2_CRCH1_CFB TIM_M2_CRCH1_CFB_MASK #define TIM_M2_CRCH1_CRB_POS 2 #define TIM_M2_CRCH1_CRB_MASK (0x01UL<<TIM_M2_CRCH1_CRB_POS) #define TIM_M2_CRCH1_CRB TIM_M2_CRCH1_CRB_MASK //===B通道比较输出刹车电平控制 #define TIM_M2_CRCH1_BKSB_POS 2 #define TIM_M2_CRCH1_BKSB_MASK (0x03UL<<TIM_M2_CRCH1_BKSB_POS) #define TIM_M2_CRCH1_BKSB TIM_M2_CRCH1_BKSB_MASK #define TIM_M2_CRCH1_BKSB_HZ (0x00UL<<TIM_M2_CRCH1_BKSB_POS) #define TIM_M2_CRCH1_BKSB_NONE (0x01UL<<TIM_M2_CRCH1_BKSB_POS) #define TIM_M2_CRCH1_BKSB_LOW (0x02UL<<TIM_M2_CRCH1_BKSB_POS) #define TIM_M2_CRCH1_BKSB_HIGHT (0x03UL<<TIM_M2_CRCH1_BKSB_POS) #define TIM_M2_CRCH1_CFA_POS 1 #define TIM_M2_CRCH1_CFA_MASK (0x01UL<<TIM_M2_CRCH1_CFA_POS) #define TIM_M2_CRCH1_CFA TIM_M2_CRCH1_CFA_MASK #define TIM_M2_CRCH1_CRA_POS 0 #define TIM_M2_CRCH1_CRA_MASK (0x01UL<<TIM_M2_CRCH1_CRA_POS) #define TIM_M2_CRCH1_CRA TIM_M2_CRCH1_CRA_MASK #define TIM_M2_CRCH1_BKSA_POS 0 #define TIM_M2_CRCH1_BKSA_MASK (0x03UL<<TIM_M2_CRCH1_BKSA_POS) #define TIM_M2_CRCH1_BKSA TIM_M2_CRCH1_BKSA_MASK #define TIM_M2_CRCH1_BKSA_HZ (0x00UL<<TIM_M2_CRCH1_BKSA_POS) #define TIM_M2_CRCH1_BKSA_NONE (0x01UL<<TIM_M2_CRCH1_BKSA_POS) #define TIM_M2_CRCH1_BKSA_LOW (0x02UL<<TIM_M2_CRCH1_BKSA_POS) #define TIM_M2_CRCH1_BKSA_HIGHT (0x03UL<<TIM_M2_CRCH1_BKSA_POS) //===通道2控制寄存器 //===捕获比较B软件触发 #define TIM_M2_CRCH2_CCGB_POS 15 #define TIM_M2_CRCH2_CCGB_MASK (0x01UL<<TIM_M2_CRCH2_CCGB_POS) #define TIM_M2_CRCH2_CCGB TIM_M2_CRCH2_CCGB_MASK //===捕获比较A软件触发 #define TIM_M2_CRCH2_CCGA_POS 14 #define TIM_M2_CRCH2_CCGA_MASK (0x01UL<<TIM_M2_CRCH2_CCGA_POS) #define TIM_M2_CRCH2_CCGA TIM_M2_CRCH2_CCGA_MASK //===B比较模式中断 #define TIM_M2_CRCH2_CISB_POS 13 #define TIM_M2_CRCH2_CISB_MASK (0x03UL<<TIM_M2_CRCH2_CISB_POS) #define TIM_M2_CRCH2_CISB TIM_M2_CRCH2_CISB_MASK #define TIM_M2_CRCH2_CISB_EDGE_NONE (0x00UL<<TIM_M2_CRCH2_CISB_POS) #define TIM_M2_CRCH2_CISB_EDGE_RISE (0x01UL<<TIM_M2_CRCH2_CISB_POS) #define TIM_M2_CRCH2_CISB_EDGE_FAIL (0x02UL<<TIM_M2_CRCH2_CISB_POS) #define TIM_M2_CRCH2_CISB_EDGE_ALL (0x03UL<<TIM_M2_CRCH2_CISB_POS) //===B捕获比较触发DMA使能 #define TIM_M2_CRCH2_CDMABEN_POS 11 #define TIM_M2_CRCH2_CDMABEN_MASK (0x01UL<<TIM_M2_CRCH2_CDMABEN_POS) #define TIM_M2_CRCH2_CDMABEN TIM_M2_CRCH2_CDMABEN_MASK //===A捕获比较触发DMA使能 #define TIM_M2_CRCH2_CDMAAEN_POS 10 #define TIM_M2_CRCH2_CDMAAEN_MASK (0x01UL<<TIM_M2_CRCH2_CDMAAEN_POS) #define TIM_M2_CRCH2_CDMAAEN TIM_M2_CRCH2_CDMAAEN_MASK //===B捕获比较触发中断 #define TIM_M2_CRCH2_CIEB_POS 9 #define TIM_M2_CRCH2_CIEB_MASK (0x01UL<<TIM_M2_CRCH2_CIEB_POS) #define TIM_M2_CRCH2_CIEB TIM_M2_CRCH2_CIEB_MASK //===B捕获比较触发中断 #define TIM_M2_CRCH2_CIEA_POS 8 #define TIM_M2_CRCH2_CIEA_MASK (0x01UL<<TIM_M2_CRCH2_CIEA_POS) #define TIM_M2_CRCH2_CIEA TIM_M2_CRCH2_CIEA_MASK //===比较功能,B比较缓存使能控制 #define TIM_M2_CRCH2_BUFEB_POS 7 #define TIM_M2_CRCH2_BUFEB_MASK (0x01UL<<TIM_M2_CRCH2_BUFEB_POS) #define TIM_M2_CRCH2_BUFEB TIM_M2_CRCH2_BUFEB_MASK //===比较功能,B比较缓存使能控制 #define TIM_M2_CRCH2_BUFEA_POS 6 #define TIM_M2_CRCH2_BUFEA_MASK (0x01UL<<TIM_M2_CRCH2_BUFEA_POS) #define TIM_M2_CRCH2_BUFEA TIM_M2_CRCH2_BUFEA_MASK #define TIM_M2_CRCH2_CSB_POS 5 #define TIM_M2_CRCH2_CSB_MASK (0x01UL<<TIM_M2_CRCH2_CSB_POS) #define TIM_M2_CRCH2_CSB TIM_M2_CRCH2_CSB_MASK #define TIM_M2_CRCH2_CSA_POS 4 #define TIM_M2_CRCH2_CSA_MASK (0x01UL<<TIM_M2_CRCH2_CSA_POS) #define TIM_M2_CRCH2_CSA TIM_M2_CRCH2_CSA_MASK #define TIM_M2_CRCH2_CFB_POS 3 #define TIM_M2_CRCH2_CFB_MASK (0x01UL<<TIM_M2_CRCH2_CFB_POS) #define TIM_M2_CRCH2_CFB TIM_M2_CRCH2_CFB_MASK #define TIM_M2_CRCH2_CRB_POS 2 #define TIM_M2_CRCH2_CRB_MASK (0x01UL<<TIM_M2_CRCH2_CRB_POS) #define TIM_M2_CRCH2_CRB TIM_M2_CRCH2_CRB_MASK //===B通道比较输出刹车电平控制 #define TIM_M2_CRCH2_BKSB_POS 2 #define TIM_M2_CRCH2_BKSB_MASK (0x03UL<<TIM_M2_CRCH2_BKSB_POS) #define TIM_M2_CRCH2_BKSB TIM_M2_CRCH2_BKSB_MASK #define TIM_M2_CRCH2_BKSB_HZ (0x00UL<<TIM_M2_CRCH2_BKSB_POS) #define TIM_M2_CRCH2_BKSB_NONE (0x01UL<<TIM_M2_CRCH2_BKSB_POS) #define TIM_M2_CRCH2_BKSB_LOW (0x02UL<<TIM_M2_CRCH2_BKSB_POS) #define TIM_M2_CRCH2_BKSB_HIGHT (0x03UL<<TIM_M2_CRCH2_BKSB_POS) #define TIM_M2_CRCH2_CFA_POS 1 #define TIM_M2_CRCH2_CFA_MASK (0x01UL<<TIM_M2_CRCH2_CFA_POS) #define TIM_M2_CRCH2_CFA TIM_M2_CRCH2_CFA_MASK #define TIM_M2_CRCH2_CRA_POS 0 #define TIM_M2_CRCH2_CRA_MASK (0x01UL<<TIM_M2_CRCH2_CRA_POS) #define TIM_M2_CRCH2_CRA TIM_M2_CRCH2_CRA_MASK #define TIM_M2_CRCH2_BKSA_POS 0 #define TIM_M2_CRCH2_BKSA_MASK (0x03UL<<TIM_M2_CRCH2_BKSA_POS) #define TIM_M2_CRCH2_BKSA TIM_M2_CRCH2_BKSA_MASK #define TIM_M2_CRCH2_BKSA_HZ (0x00UL<<TIM_M2_CRCH2_BKSA_POS) #define TIM_M2_CRCH2_BKSA_NONE (0x01UL<<TIM_M2_CRCH2_BKSA_POS) #define TIM_M2_CRCH2_BKSA_LOW (0x02UL<<TIM_M2_CRCH2_BKSA_POS) #define TIM_M2_CRCH2_BKSA_HIGHT (0x03UL<<TIM_M2_CRCH2_BKSA_POS) //===死区控制寄存器 #define TIM_M2_DTR_VCEN_POS 14 #define TIM_M2_DTR_VCEN_MASK (0x01UL<<TIM_M2_DTR_VCEN_POS) #define TIM_M2_DTR_VCEN TIM_M2_DTR_VCEN_MASK //===Safety刹车控制使能 #define TIM_M2_DTR_SAFETYEN_POS 13 #define TIM_M2_DTR_SAFETYEN_MASK (0x01UL<<TIM_M2_DTR_SAFETYEN_POS) #define TIM_M2_DTR_SAFETYEN TIM_M2_DTR_SAFETYEN_MASK //===PWM输出控制使能 #define TIM_M2_DTR_MOEN_POS 12 #define TIM_M2_DTR_MOEN_MASK (0x01UL<<TIM_M2_DTR_MOEN_POS) #define TIM_M2_DTR_MOEN TIM_M2_DTR_MOEN_MASK //===PWM输出自动控制使能 #define TIM_M2_DTR_AOEN_POS 11 #define TIM_M2_DTR_AOEN_MASK (0x01UL<<TIM_M2_DTR_AOEN_POS) #define TIM_M2_DTR_AOEN TIM_M2_DTR_AOEN_MASK //===刹车控制使能 #define TIM_M2_DTR_BKE_POS 10 #define TIM_M2_DTR_BKE_MASK (0x01UL<<TIM_M2_DTR_BKE_POS) #define TIM_M2_DTR_BKE TIM_M2_DTR_BKE_MASK //===死区控制使能 #define TIM_M2_DTR_DTEN_POS 9 #define TIM_M2_DTR_DTEN_MASK (0x01UL<<TIM_M2_DTR_DTEN_POS) #define TIM_M2_DTR_DTEN TIM_M2_DTR_DTEN_MASK //===刹车选择 #define TIM_M2_DTR_BKSEL_POS 8 #define TIM_M2_DTR_BKSEL_MASK (0x01UL<<TIM_M2_DTR_BKSEL_POS) #define TIM_M2_DTR_BKSEL TIM_M2_DTR_BKSEL_MASK //===死区控制 #define TIM_M2_DTR_TIM_POS 0 #define TIM_M2_DTR_TIM_MASK (0xFFUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM TIM_M2_DTR_TIM_MASK //===死区时间 #define TIM_M2_DTR_TIM_2 (0x00UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_3 (0x01UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_4 (0x02UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_5 (0x03UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_6 (0x04UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_7 (0x05UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_8 (0x06UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_9 (0x07UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_10 (0x08UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_11 (0x09UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_12 (0x0AUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_13 (0x0BUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_14 (0x0CUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_15 (0x0DUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_16 (0x0EUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_17 (0x0FUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_18 (0x10UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_19 (0x11UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_20 (0x12UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_21 (0x13UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_22 (0x14UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_23 (0x15UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_24 (0x16UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_25 (0x17UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_26 (0x18UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_27 (0x19UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_28 (0x1AUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_29 (0x1BUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_30 (0x1CUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_31 (0x1DUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_32 (0x1EUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_33 (0x1FUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_34 (0x20UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_35 (0x21UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_36 (0x22UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_37 (0x23UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_38 (0x24UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_39 (0x25UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_40 (0x26UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_41 (0x27UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_42 (0x28UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_43 (0x29UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_44 (0x2AUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_45 (0x2BUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_46 (0x2CUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_47 (0x2DUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_48 (0x2EUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_49 (0x2FUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_50 (0x30UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_51 (0x31UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_52 (0x32UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_53 (0x33UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_54 (0x34UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_55 (0x35UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_56 (0x36UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_57 (0x37UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_58 (0x38UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_59 (0x39UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_60 (0x3AUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_61 (0x3BUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_62 (0x3CUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_63 (0x3DUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_64 (0x3EUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_65 (0x3FUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_66 (0x40UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_67 (0x41UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_68 (0x42UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_69 (0x43UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_70 (0x44UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_71 (0x45UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_72 (0x46UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_73 (0x47UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_74 (0x48UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_75 (0x49UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_76 (0x4AUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_77 (0x4BUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_78 (0x4CUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_79 (0x4DUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_80 (0x4EUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_81 (0x4FUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_82 (0x50UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_83 (0x51UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_84 (0x52UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_85 (0x53UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_86 (0x54UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_87 (0x55UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_88 (0x56UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_89 (0x57UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_90 (0x58UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_91 (0x59UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_92 (0x5AUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_93 (0x5BUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_94 (0x5CUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_95 (0x5DUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_96 (0x5EUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_97 (0x5FUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_98 (0x60UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_99 (0x61UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_100 (0x62UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_101 (0x63UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_102 (0x64UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_103 (0x65UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_104 (0x66UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_105 (0x67UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_106 (0x68UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_107 (0x69UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_108 (0x6AUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_109 (0x6BUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_110 (0x6CUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_111 (0x6DUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_112 (0x6EUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_113 (0x6FUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_114 (0x70UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_115 (0x71UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_116 (0x72UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_117 (0x73UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_118 (0x74UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_119 (0x75UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_120 (0x76UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_121 (0x77UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_122 (0x78UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_123 (0x79UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_124 (0x7AUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_125 (0x7BUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_126 (0x7CUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_127 (0x7DUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_128 (0x7EUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_129 (0x7FUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_130 (0x80UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_132 (0x81UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_134 (0x82UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_136 (0x83UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_138 (0x84UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_140 (0x85UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_142 (0x86UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_144 (0x87UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_146 (0x88UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_148 (0x89UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_150 (0x8AUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_152 (0x8BUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_154 (0x8CUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_156 (0x8DUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_158 (0x8EUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_160 (0x8FUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_162 (0x90UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_164 (0x91UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_166 (0x92UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_168 (0x93UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_170 (0x94UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_172 (0x95UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_174 (0x96UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_176 (0x97UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_178 (0x98UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_180 (0x99UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_182 (0x9AUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_184 (0x9BUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_186 (0x9CUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_188 (0x9DUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_190 (0x9EUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_192 (0x9FUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_194 (0xA0UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_196 (0xA1UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_198 (0xA2UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_200 (0xA3UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_202 (0xA4UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_204 (0xA5UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_206 (0xA6UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_208 (0xA8UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_210 (0xA9UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_212 (0xAAUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_214 (0xABUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_216 (0xACUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_218 (0xADUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_220 (0xAEUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_222 (0xAFUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_224 (0xB0UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_226 (0xB1UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_228 (0xB2UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_230 (0xB3UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_232 (0xB4UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_234 (0xB5UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_236 (0xB6UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_238 (0xB7UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_240 (0xB8UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_242 (0xB9UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_246 (0xBAUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_248 (0xBBUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_250 (0xBCUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_252 (0xBDUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_254 (0xBEUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_256 (0xBFUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_258 (0xC0UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_266 (0xC1UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_274 (0xC2UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_282 (0xC3UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_290 (0xC4UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_296 (0xC5UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_302 (0xC6UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_308 (0xC7UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_314 (0xC8UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_322 (0xC9UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_330 (0xCAUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_338 (0xCBUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_346 (0xCCUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_354 (0xCDUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_362 (0xCEUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_370 (0xCFUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_378 (0xD0UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_386 (0xD1UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_394 (0xD2UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_402 (0xD3UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_410 (0xD4UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_418 (0xD5UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_426 (0xD6UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_434 (0xD7UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_442 (0xD8UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_450 (0xD9UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_458 (0xDAUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_466 (0xDBUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_474 (0xDCUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_482 (0xDDUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_490 (0xDEUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_498 (0xDFUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_514 (0xE0UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_530 (0xE1UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_546 (0xE2UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_547 (0xE3UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_562 (0xE4UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_578 (0xE5UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_594 (0xE6UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_610 (0xE7UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_642 (0xE8UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_658 (0xE9UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_674 (0xEAUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_690 (0xEBUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_706 (0xECUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_722 (0xEDUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_738 (0xEEUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_754 (0xEFUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_770 (0xF0UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_786 (0xF1UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_802 (0xF2UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_818 (0xF3UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_834 (0xF4UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_850 (0xF5UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_866 (0xF6UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_882 (0xF7UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_898 (0xF8UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_914 (0xF9UL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_930 (0xFAUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_946 (0xFBUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_962 (0xFCUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_978 (0xFDUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_994 (0xFEUL<<TIM_M2_DTR_TIM_POS) #define TIM_M2_DTR_TIM_1010 (0xFFUL<<TIM_M2_DTR_TIM_POS) //===重复周期设置值 #define TIM_M2_RCR_RCR_POS 0 #define TIM_M2_RCR_RCR_MASK (0xFFUL<<TIM_M2_RCR_RCR_POS) #define TIM_M2_RCR_RCR TIM_M2_RCR_RCR_MASK //===通道0比较捕获寄存器 #define TIM_M2_CCR_CCR0A_POS 0 #define TIM_M2_CCR_CCR0A_MASK (0xFFFFUL<<TIM_M2_CCR_CCR0A_POS) #define TIM_M2_CCR_CCR0A TIM_M2_CCR_CCR0A_MASK #define TIM_M2_CCR_CCR0B_POS 0 #define TIM_M2_CCR_CCR0B_MASK (0xFFFFUL<<TIM_M2_CCR_CCR0A_POS) #define TIM_M2_CCR_CCR0B TIM_M2_CCR_CCR0B_MASK //===通道1比较捕获寄存器 #define TIM_M2_CCR_CCR1A_POS 0 #define TIM_M2_CCR_CCR1A_MASK (0xFFFFUL<<TIM_M2_CCR_CCR1A_POS) #define TIM_M2_CCR_CCR1A TIM_M2_CCR_CCR1A_MASK #define TIM_M2_CCR_CCR1B_POS 0 #define TIM_M2_CCR_CCR1B_MASK (0xFFFFUL<<TIM_M2_CCR_CCR1B_POS) #define TIM_M2_CCR_CCR1B TIM_M2_CCR_CCR1B_MASK //===通道2比较捕获寄存器 #define TIM_M2_CCR_CCR2A_POS 0 #define TIM_M2_CCR_CCR2A_MASK (0xFFFFUL<<TIM_M2_CCR_CCR2A_POS) #define TIM_M2_CCR_CCR2A TIM_M2_CCR_CCR2A_MASK #define TIM_M2_CCR_CCR2B_POS 0 #define TIM_M2_CCR_CCR2B_MASK (0xFFFFUL<<TIM_M2_CCR_CCR2B_POS) #define TIM_M2_CCR_CCR2B TIM_M2_CCR_CCR2B_MASK #pragma endregion #pragma region TIM_M3 //===普通定时器 typedef struct { __IO uint32_t ARR; //---重载寄存器 00 __IO uint32_t CNT; //---16位模式计数寄存器 04 uint32_t RESERVED1; //---保留字节 08 __IO uint32_t M23CR; //---控制寄存器 0C __IO uint32_t SR; //---中断标志 10 __IO uint32_t CSR; //---中断标志清除 14 __IO uint32_t MSCR; //---主从模式控制 18 __IO uint32_t FLTR; //---滤波控制 1C __IO uint32_t ADTR; //---ADC触发控制 20 __IO uint32_t CRCH0; //---比较单元0控制寄存器 24 __IO uint32_t CRCH1; //---比较单元1控制寄存器 28 __IO uint32_t CRCH2; //---比较单元2控制寄存器 2C __IO uint32_t DTR; //---死区寄存器 30 __IO uint32_t RCR; //---重复计数寄存器 34 __IO uint32_t ARRDM; //---控制寄存器1 38 __IO uint32_t CCR0A; //---比较0A寄存器 3C __IO uint32_t CCR0B; //---比较0B寄存器 40 __IO uint32_t CCR1A; //---比较1A寄存器 44 __IO uint32_t CCR1B; //---比较1B寄存器 48 __IO uint32_t CCR2A; //---比较2A寄存器 4C __IO uint32_t CCR2B; //---比较2B寄存器 50 } TIM_M3_TypeDef; #define TIM_M3_ARR_ARR_POS 0 #define TIM_M3_ARR_ARR_MASK (0xFFFFUL<<TIM_M3_ARR_ARR_POS) #define TIM_M3_ARR_ARR TIM_M3_ARR_ARR_MASK #define TIM_M3_CNT_CNT_POS 0 #define TIM_M3_CNT_CNT_MASK (0xFFFFUL<<TIM_M3_CNT_CNT_POS) #define TIM_M3_CNT_CNT TIM_M3_CNT_CNT_MASK //===控制寄存器 #define TIM_M3_M23CR_DIR_POS 27 #define TIM_M3_M23CR_DIR_MASK (0x01UL<<TIM_M3_M23CR_DIR_POS) #define TIM_M3_M23CR_DIR TIM_M3_M23CR_DIR_MASK #define TIM_M3_M23CR_DIR_UP (0x00UL<<TIM_M3_M23CR_DIR_POS) #define TIM_M3_M23CR_DIR_DOWN (0x01UL<<TIM_M3_M23CR_DIR_POS) //===软件刹车 #define TIM_M3_M23CR_BG_POS 26 #define TIM_M3_M23CR_BG_MASK (0x01UL<<TIM_M3_M23CR_BG_POS) #define TIM_M3_M23CR_BG TIM_M3_M23CR_BG_MASK #define TIM_M3_M23CR_BG_ENABLE (0x01UL<<TIM_M3_M23CR_BG_POS) #define TIM_M3_M23CR_BG_DISABLE (0x00UL<<TIM_M3_M23CR_BG_POS) //===软件更新 #define TIM_M3_M23CR_UG_POS 25 #define TIM_M3_M23CR_UG_MASK (0x01UL<<TIM_M3_M23CR_UG_POS) #define TIM_M3_M23CR_UG TIM_M3_M23CR_UG_MASK #define TIM_M3_M23CR_UG_ENABLE (0x01UL<<TIM_M3_M23CR_UG_POS) #define TIM_M3_M23CR_UG_DISABLE (0x00UL<<TIM_M3_M23CR_UG_POS) //===软件触发 #define TIM_M3_M23CR_TG_POS 24 #define TIM_M3_M23CR_TG_MASK (0x01UL<<TIM_M3_M23CR_TG_POS) #define TIM_M3_M23CR_TG TIM_M3_M23CR_TG_MASK #define TIM_M3_M23CR_TG_ENABLE (0x01UL<<TIM_M3_M23CR_TG_POS) #define TIM_M3_M23CR_TG_DISABLE (0x00UL<<TIM_M3_M23CR_TG_POS) //===OCREF清除使能 #define TIM_M3_M23CR_OCCE_POS 23 #define TIM_M3_M23CR_OCCE_MASK (0x01UL<<TIM_M3_M23CR_OCCE_POS) #define TIM_M3_M23CR_OCCE TIM_M3_M23CR_OCCE_MASK #define TIM_M3_M23CR_OCCE_ENABLE (0x01UL<<TIM_M3_M23CR_OCCE_POS) #define TIM_M3_M23CR_OCCE_DISABLE (0x00UL<<TIM_M3_M23CR_OCCE_POS) //===A比较模式中断 #define TIM_M3_M23CR_CISA_POS 21 #define TIM_M3_M23CR_CISA_MASK (0x03UL<<TIM_M3_M23CR_CISA_POS) #define TIM_M3_M23CR_CISA TIM_M3_M23CR_CISA_MASK #define TIM_M3_M23CR_CISA_EDGE_NONE (0x00UL<<TIM_M3_M23CR_CISA_POS) #define TIM_M3_M23CR_CISA_EDGE_RISE (0x01UL<<TIM_M3_M23CR_CISA_POS) #define TIM_M3_M23CR_CISA_EDGE_FAIL (0x02UL<<TIM_M3_M23CR_CISA_POS) #define TIM_M3_M23CR_CISA_EDGE_ALL (0x03UL<<TIM_M3_M23CR_CISA_POS) //===刹车中断使能 #define TIM_M3_M23CR_BIE_POS 20 #define TIM_M3_M23CR_BIE_MASK (0x01UL<<TIM_M3_M23CR_BIE_POS) #define TIM_M3_M23CR_BIE TIM_M3_M23CR_BIE_MASK //===触发中断使能 #define TIM_M3_M23CR_TIE_POS 19 #define TIM_M3_M23CR_TIE_MASK (0x01UL<<TIM_M3_M23CR_TIE_POS) #define TIM_M3_M23CR_TIE TIM_M3_M23CR_TIE_MASK //===触发DMA中断使能 #define TIM_M3_M23CR_TDMAIE_POS 18 #define TIM_M3_M23CR_TDMAIE_MASK (0x01UL<<TIM_M3_M23CR_TDMAIE_POS) #define TIM_M3_M23CR_TDMAIE TIM_M3_M23CR_TDMAIE_MASK //===更新源 #define TIM_M3_M23CR_URS_POS 17 #define TIM_M3_M23CR_URS_MASK (0x01UL<<TIM_M3_M23CR_URS_POS) #define TIM_M3_M23CR_URS TIM_M3_M23CR_URS_MASK #define TIM_M3_M23CR_URS_ALL (0x00UL<<TIM_M3_M23CR_URS_POS) #define TIM_M3_M23CR_URS_RISE_OR_FAIL (0x00UL<<TIM_M3_M23CR_URS_POS) //===OCREF清除源选择 #define TIM_M3_M23CR_OCCS_POS 16 #define TIM_M3_M23CR_OCCS_MASK (0x01UL<<TIM_M3_M23CR_OCCS_POS) #define TIM_M3_M23CR_OCCS TIM_M3_M23CR_OCCS_MASK #define TIM_M3_M23CR_OCCS_VC (0x00UL<<TIM_M3_M23CR_OCCS_POS) #define TIM_M3_M23CR_OCCS_ETR (0x01UL<<TIM_M3_M23CR_OCCS_POS) //===PWM互补模式选择 #define TIM_M3_M23CR_CSG_POS 15 #define TIM_M3_M23CR_CSG_MASK (0x01UL<<TIM_M3_M23CR_CSG_POS) #define TIM_M3_M23CR_CSG TIM_M3_M23CR_CSG_MASK #define TIM_M3_M23CR_CSG_COMP (0x00UL<<TIM_M3_M23CR_CSG_POS) #define TIM_M3_M23CR_CSG_CAPT (0x01UL<<TIM_M3_M23CR_CSG_POS) //===触发选择 #define TIM_M3_M23CR_TRIG_POS 14 #define TIM_M3_M23CR_TRIG_MASK (0x01UL<<TIM_M3_M23CR_TRIG_POS) #define TIM_M3_M23CR_TRIG TIM_M3_M23CR_TRIG_MASK #define TIM_M3_M23CR_TRIG_CYCLE (0x00UL<<TIM_M3_M23CR_TRIG_POS) #define TIM_M3_M23CR_TRIG_SINGLE (0x01UL<<TIM_M3_M23CR_TRIG_POS) //===工作模式 #define TIM_M3_M23CR_MODE_POS 12 #define TIM_M3_M23CR_MODE_MASK (0x03UL<<TIM_M3_M23CR_MODE_POS) #define TIM_M3_M23CR_MODE TIM_M3_M23CR_MODE_MASK #define TIM_M3_M23CR_MODE_TIM0 (0x00UL<<TIM_M3_M23CR_MODE_POS) #define TIM_M3_M23CR_MODE_PWC (0x01UL<<TIM_M3_M23CR_MODE_POS) #define TIM_M3_M23CR_MODE_SAWTOOTH (0x02UL<<TIM_M3_M23CR_MODE_POS) #define TIM_M3_M23CR_MODE_TRIANGLE (0x03UL<<TIM_M3_M23CR_MODE_POS) //===更新DMA使能 #define TIM_M3_M23CR_UDMAEN_POS 11 #define TIM_M3_M23CR_UDMAEN_MASK (0x01UL<<TIM_M3_M23CR_UDMAEN_POS) #define TIM_M3_M23CR_UDMAEN TIM_M3_M23CR_UDMAEN_MASK //===更新中断使能 #define TIM_M3_M23CR_UIE_POS 10 #define TIM_M3_M23CR_UIE_MASK (0x01UL<<TIM_M3_M23CR_UIE_POS) #define TIM_M3_M23CR_UIE TIM_M3_M23CR_UIE_MASK //===下降沿捕获使能控制 #define TIM_M3_M23CR_CFG_POS 9 #define TIM_M3_M23CR_CFG_MASK (0x01UL<<TIM_M3_M23CR_CFG_POS) #define TIM_M3_M23CR_CFG TIM_M3_M23CR_CFG_MASK #define TIM_M3_M23CR_CFG_ENABLE (0x01UL<<TIM_M3_M23CR_CFG_POS) #define TIM_M3_M23CR_CFG_DISABLE (0x00UL<<TIM_M3_M23CR_CFG_POS) //===上升沿捕获使能控制 #define TIM_M3_M23CR_CRG_POS 8 #define TIM_M3_M23CR_CRG_MASK (0x01UL<<TIM_M3_M23CR_CRG_POS) #define TIM_M3_M23CR_CRG TIM_M3_M23CR_CRG_MASK #define TIM_M3_M23CR_CRG_ENABLE (0x01UL<<TIM_M3_M23CR_CRG_POS) #define TIM_M3_M23CR_CRG_DISABLE (0x00UL<<TIM_M3_M23CR_CRG_POS) //===重载缓存使能控制 #define TIM_M3_M23CR_BUFPEN_POS 7 #define TIM_M3_M23CR_BUFPEN_MASK (0x01UL<<TIM_M3_M23CR_BUFPEN_POS) #define TIM_M3_M23CR_BUFPEN TIM_M3_M23CR_BUFPEN_MASK //===时钟分频选择 #define TIM_M3_M23CR_PRS_POS 4 #define TIM_M3_M23CR_PRS_MASK (0x07UL<<TIM_M3_M23CR_PRS_POS) #define TIM_M3_M23CR_PRS TIM_M3_M23CR_PRS_MASK #define TIM_M3_M23CR_PRS_1 (0x00UL<<TIM_M3_M23CR_PRS_POS) #define TIM_M3_M23CR_PRS_2 (0x01UL<<TIM_M3_M23CR_PRS_POS) #define TIM_M3_M23CR_PRS_4 (0x02UL<<TIM_M3_M23CR_PRS_POS) #define TIM_M3_M23CR_PRS_8 (0x03UL<<TIM_M3_M23CR_PRS_POS) #define TIM_M3_M23CR_PRS_16 (0x04UL<<TIM_M3_M23CR_PRS_POS) #define TIM_M3_M23CR_PRS_32 (0x05UL<<TIM_M3_M23CR_PRS_POS) #define TIM_M3_M23CR_PRS_64 (0x06UL<<TIM_M3_M23CR_PRS_POS) #define TIM_M3_M23CR_PRS_256 (0x07UL<<TIM_M3_M23CR_PRS_POS) //===单双点比较控制 #define TIM_M3_M23CR_PWM2S_POS 3 #define TIM_M3_M23CR_PWM2S_MASK (0x01UL<<TIM_M3_M23CR_PWM2S_POS) #define TIM_M3_M23CR_PWM2S TIM_M3_M23CR_PWM2S_MASK #define TIM_M3_M23CR_PWM2S_DOUBLE (0x00UL<<TIM_M3_M23CR_PWM2S_POS) #define TIM_M3_M23CR_PWM2S_SINGLE (0x01UL<<TIM_M3_M23CR_PWM2S_POS) //===计数时钟 #define TIM_M3_M23CR_CT_POS 2 #define TIM_M3_M23CR_CT_MASK (0x01UL<<TIM_M3_M23CR_CT_POS) #define TIM_M3_M23CR_CT TIM_M3_M23CR_CT_MASK #define TIM_M3_M23CR_CT_TCLK (0x00UL<<TIM_M3_M23CR_CT_POS) #define TIM_M3_M23CR_CT_ETR (0x01UL<<TIM_M3_M23CR_CT_POS) //===PWM模式选择 #define TIM_M3_M23CR_COMP_POS 1 #define TIM_M3_M23CR_COMP_MASK (0x01UL<<TIM_M3_M23CR_COMP_POS) #define TIM_M3_M23CR_COMP TIM_M3_M23CR_COMP_MASK #define TIM_M3_M23CR_COMP_PWM_COMP (0x01UL<<TIM_M3_M23CR_COMP_POS) #define TIM_M3_M23CR_COMP_PWM_INDEP (0x00UL<<TIM_M3_M23CR_COMP_POS) //===定时器使能控制 #define TIM_M3_M23CR_EN_POS 0 #define TIM_M3_M23CR_EN_MASK (0x01U<<TIM_M3_M23CR_EN_POS) #define TIM_M3_M23CR_EN TIM_M3_M23CR_EN_MASK //===中断标志寄存器 //===触发中断标志 #define TIM_M3_SR_TIE_POS 15 #define TIM_M3_SR_TIE_MASK (0x01U<<TIM_M3_SR_TIE_POS) #define TIM_M3_SR_TIE TIM_M3_SR_TIE_MASK //===刹车中断标志 #define TIM_M3_SR_BIE_POS 14 #define TIM_M3_SR_BIE_MASK (0x01U<<TIM_M3_SR_BIE_POS) #define TIM_M3_SR_BIE TIM_M3_SR_BIE_MASK //==CH2B捕获丢数据 #define TIM_M3_SR_CH2B_ERROR_POS 13 #define TIM_M3_SR_CH2B_ERROR_MASK (0x01U<<TIM_M3_SR_CH2B_ERROR_POS) #define TIM_M3_SR_CH2B_ERROR TIM_M3_SR_CH2B_ERROR_MASK //==CH1B捕获丢数据 #define TIM_M3_SR_CH1B_ERROR_POS 12 #define TIM_M3_SR_CH1B_ERROR_MASK (0x01U<<TIM_M3_SR_CH1B_ERROR_POS) #define TIM_M3_SR_CH1B_ERROR TIM_M3_SR_CH1B_ERROR_MASK //==CH0B捕获丢数据 #define TIM_M3_SR_CH0B_ERROR_POS 11 #define TIM_M3_SR_CH0B_ERROR_MASK (0x01U<<TIM_M3_SR_CH0B_ERROR_POS) #define TIM_M3_SR_CH0B_ERROR TIM_M3_SR_CH0B_ERROR_MASK //==CH2A捕获丢数据 #define TIM_M3_SR_CH2A_ERROR_POS 10 #define TIM_M3_SR_CH2A_ERROR_MASK (0x01U<<TIM_M3_SR_CH2A_ERROR_POS) #define TIM_M3_SR_CH2A_ERROR TIM_M3_SR_CH2A_ERROR_MASK //==CH1A捕获丢数据 #define TIM_M3_SR_CH1A_ERROR_POS 9 #define TIM_M3_SR_CH1A_ERROR_MASK (0x01U<<TIM_M3_SR_CH1A_ERROR_POS) #define TIM_M3_SR_CH1A_ERROR TIM_M3_SR_CH1A_ERROR_MASK //==CH0A捕获丢数据 #define TIM_M3_SR_CH0A_ERROR_POS 8 #define TIM_M3_SR_CH0A_ERROR_MASK (0x01U<<TIM_M3_SR_CH0A_ERROR_POS) #define TIM_M3_SR_CH0A_ERROR TIM_M3_SR_CH0A_ERROR_MASK //==CH2B捕获/比较中断标志 #define TIM_M3_SR_CH2B_FLAG_POS 7 #define TIM_M3_SR_CH2B_FLAG_MASK (0x01U<<TIM_M3_SR_CH2B_FLAG_POS) #define TIM_M3_SR_CH2B_FLAG TIM_M3_SR_CH2B_FLAG_MASK //==CH1B捕获/比较中断标志 #define TIM_M3_SR_CH1B_FLAG_POS 6 #define TIM_M3_SR_CH1B_FLAG_MASK (0x01U<<TIM_M3_SR_CH1B_FLAG_POS) #define TIM_M3_SR_CH1B_FLAG TIM_M3_SR_CH1B_FLAG_MASK //==CH0B捕获/比较中断标志 #define TIM_M3_SR_CH0B_FLAG_POS 5 #define TIM_M3_SR_CH0B_FLAG_MASK (0x01U<<TIM_M3_SR_CH0B_FLAG_POS) #define TIM_M3_SR_CH0B_FLAG TIM_M3_SR_CH0B_FLAG_MASK //==CH2A捕获/比较中断标志 #define TIM_M3_SR_CH2A_FLAG_POS 4 #define TIM_M3_SR_CH2A_FLAG_MASK (0x01U<<TIM_M3_SR_CH2A_FLAG_POS) #define TIM_M3_SR_CH2A_FLAG TIM_M3_SR_CH2A_FLAG_MASK //==CH1A捕获/比较中断标志 #define TIM_M3_SR_CH1A_FLAG_POS 3 #define TIM_M3_SR_CH1A_FLAG_MASK (0x01U<<TIM_M3_SR_CH1A_FLAG_POS) #define TIM_M3_SR_CH1A_FLAG TIM_M3_SR_CH1A_FLAG_MASK //==CH0A捕获/比较中断标志 #define TIM_M3_SR_CH0A_FLAG_POS 2 #define TIM_M3_SR_CH0A_FLAG_MASK (0x01U<<TIM_M3_SR_CH0A_FLAG_POS) #define TIM_M3_SR_CH0A_FLAG TIM_M3_SR_CH0A_FLAG_MASK //===更新中断标志位 #define TIM_M3_SR_UIE_POS 0 #define TIM_M3_SR_UIE_MASK (0x01U<<TIM_M3_SR_UIE_POS) #define TIM_M3_SR_UIE TIM_M3_SR_UIE_MASK //===清楚标志寄存器 #define TIM_M3_CSR_MASK 0xFFFDUL #define TIM_M3_CSR_TIE_POS 15 #define TIM_M3_CSR_TIE_MASK (0x01U<<TIM_M3_CSR_TIE_POS) #define TIM_M3_CSR_TIE TIM_M3_CSR_TIE_MASK #define TIM_M3_CSR_BIE_POS 14 #define TIM_M3_CSR_BIE_MASK (0x01U<<TIM_M3_CSR_BIE_POS) #define TIM_M3_CSR_BIE TIM_M3_CSR_BIE_MASK #define TIM_M3_CSR_CH2B_ERROR_POS 13 #define TIM_M3_CSR_CH2B_ERROR_MASK (0x01U<<TIM_M3_CSR_CH2B_ERROR_POS) #define TIM_M3_CSR_CH2B_ERROR TIM_M3_CSR_CH2B_ERROR_MASK #define TIM_M3_CSR_CH1B_ERROR_POS 12 #define TIM_M3_CSR_CH1B_ERROR_MASK (0x01U<<TIM_M3_CSR_CH1B_ERROR_POS) #define TIM_M3_CSR_CH1B_ERROR TIM_M3_CSR_CH1B_ERROR_MASK #define TIM_M3_CSR_CH0B_ERROR_POS 11 #define TIM_M3_CSR_CH0B_ERROR_MASK (0x01U<<TIM_M3_CSR_CH0B_ERROR_POS) #define TIM_M3_CSR_CH0B_ERROR TIM_M3_CSR_CH0B_ERROR_MASK #define TIM_M3_CSR_CH2A_ERROR_POS 10 #define TIM_M3_CSR_CH2A_ERROR_MASK (0x01U<<TIM_M3_CSR_CH2A_ERROR_POS) #define TIM_M3_CSR_CH2A_ERROR TIM_M3_CSR_CH2A_ERROR_MASK #define TIM_M3_CSR_CH1A_ERROR_POS 9 #define TIM_M3_CSR_CH1A_ERROR_MASK (0x01U<<TIM_M3_CSR_CH1A_ERROR_POS) #define TIM_M3_CSR_CH1A_ERROR TIM_M3_CSR_CH1A_ERROR_MASK #define TIM_M3_CSR_CH0A_ERROR_POS 8 #define TIM_M3_CSR_CH0A_ERROR_MASK (0x01U<<TIM_M3_CSR_CH0A_ERROR_POS) #define TIM_M3_CSR_CH0A_ERROR TIM_M3_CSR_CH0A_ERROR_MASK #define TIM_M3_CSR_CH2B_FLAG_POS 7 #define TIM_M3_CSR_CH2B_FLAG_MASK (0x01U<<TIM_M3_CSR_CH2B_FLAG_POS) #define TIM_M3_CSR_CH2B_FLAG TIM_M3_CSR_CH2B_FLAG_MASK #define TIM_M3_CSR_CH1B_FLAG_POS 6 #define TIM_M3_CSR_CH1B_FLAG_MASK (0x01U<<TIM_M3_CSR_CH1B_FLAG_POS) #define TIM_M3_CSR_CH1B_FLAG TIM_M3_CSR_CH1B_FLAG_MASK #define TIM_M3_CSR_CH0B_FLAG_POS 5 #define TIM_M3_CSR_CH0B_FLAG_MASK (0x01U<<TIM_M3_CSR_CH0B_FLAG_POS) #define TIM_M3_CSR_CH0B_FLAG TIM_M3_CSR_CH0B_FLAG_MASK #define TIM_M3_CSR_CH2A_FLAG_POS 4 #define TIM_M3_CSR_CH2A_FLAG_MASK (0x01U<<TIM_M3_CSR_CH2A_FLAG_POS) #define TIM_M3_CSR_CH2A_FLAG TIM_M3_CSR_CH2A_FLAG_MASK #define TIM_M3_CSR_CH1A_FLAG_POS 3 #define TIM_M3_CSR_CH1A_FLAG_MASK (0x01U<<TIM_M3_CSR_CH1A_FLAG_POS) #define TIM_M3_CSR_CH1A_FLAG TIM_M3_CSR_CH1A_FLAG_MASK #define TIM_M3_CSR_CH0A_FLAG_POS 2 #define TIM_M3_CSR_CH0A_FLAG_MASK (0x01U<<TIM_M3_CSR_CH0A_FLAG_POS) #define TIM_M3_CSR_CH0A_FLAG TIM_M3_CSR_CH0A_FLAG_MASK #define TIM_M3_CSR_UIE_POS 0 #define TIM_M3_CSR_UIE_MASK (0x01U<<TIM_M3_CSR_UIE_POS) #define TIM_M3_CSR_UIE TIM_M3_CSR_UIE_MASK //===主从模式控制寄存器 //===CH0B输入选择 #define TIM_M3_MSCR_IB0S_POS 12 #define TIM_M3_MSCR_IB0S_MASK (0x01U<<TIM_M3_MSCR_IB0S_POS) #define TIM_M3_MSCR_IB0S TIM_M3_MSCR_IB0S_MASK //===CH0A输入选择 #define TIM_M3_MSCR_IA0S_POS 11 #define TIM_M3_MSCR_IA0S_MASK (0x01U<<TIM_M3_MSCR_IA0S_POS) #define TIM_M3_MSCR_IA0S TIM_M3_MSCR_IA0S_MASK //===从模式选择 #define TIM_M3_MSCR_SMS_POS 8 #define TIM_M3_MSCR_SMS_MASK (0x07U<<TIM_M3_MSCR_SMS_POS) #define TIM_M3_MSCR_SMS TIM_M3_MSCR_SMS_MASK #define TIM_M3_MSCR_SMS_TCLK (0x00U<<TIM_M3_MSCR_SMS_POS) #define TIM_M3_MSCR_SMS_RESET (0x01U<<TIM_M3_MSCR_SMS_POS) #define TIM_M3_MSCR_SMS_TRIG (0x02U<<TIM_M3_MSCR_SMS_POS) #define TIM_M3_MSCR_SMS_ETR (0x03U<<TIM_M3_MSCR_SMS_POS) #define TIM_M3_MSCR_SMS_ENCODE_MODE1 (0x04U<<TIM_M3_MSCR_SMS_POS) #define TIM_M3_MSCR_SMS_ENCODE_MODE2 (0x05U<<TIM_M3_MSCR_SMS_POS) #define TIM_M3_MSCR_SMS_ENCODE_MODE3 (0x06U<<TIM_M3_MSCR_SMS_POS) #define TIM_M3_MSCR_SMS_GATE (0x07U<<TIM_M3_MSCR_SMS_POS) //===触发模式选择 #define TIM_M3_MSCR_TRIG_POS 5 #define TIM_M3_MSCR_TRIG_MASK (0x07U<<TIM_M3_MSCR_TRIG_POS) #define TIM_M3_MSCR_TRIG TIM_M3_MSCR_TRIG_MASK #define TIM_M3_MSCR_TRIG_ETRP (0x00U<<TIM_M3_MSCR_TRIG_POS) #define TIM_M3_MSCR_TRIG_ITR0 (0x01U<<TIM_M3_MSCR_TRIG_POS) #define TIM_M3_MSCR_TRIG_ITR1 (0x02U<<TIM_M3_MSCR_TRIG_POS) #define TIM_M3_MSCR_TRIG_ITR2 (0x03U<<TIM_M3_MSCR_TRIG_POS) #define TIM_M3_MSCR_TRIG_ITR3 (0x04U<<TIM_M3_MSCR_TRIG_POS) #define TIM_M3_MSCR_TRIG_CH0A (0x05U<<TIM_M3_MSCR_TRIG_POS) #define TIM_M3_MSCR_TRIG_CH0AP (0x06U<<TIM_M3_MSCR_TRIG_POS) #define TIM_M3_MSCR_TRIG_CH0BP (0x07U<<TIM_M3_MSCR_TRIG_POS) //===主从模式选择 #define TIM_M3_MSCR_MSM_POS 4 #define TIM_M3_MSCR_MSM_MASK (0x07U<<TIM_M3_MSCR_MSM_POS) #define TIM_M3_MSCR_MSM TIM_M3_MSCR_MSM_MASK //===比较模式下DMA比较触发选择 #define TIM_M3_MSCR_CCDS_POS 3 #define TIM_M3_MSCR_CCDS_MASK (0x07U<<TIM_M3_MSCR_CCDS_POS) #define TIM_M3_MSCR_CCDS TIM_M3_MSCR_CCDS_MASK //===主模式输出选择 #define TIM_M3_MSCR_MMS_POS 0 #define TIM_M3_MSCR_MMS_MASK (0x07UL<<TIM_M3_MSCR_MMS_POS) #define TIM_M3_MSCR_MMS TIM_M3_MSCR_MMS_MASK #define TIM_M3_MSCR_MMS_UG (0x00U<<TIM_M3_MSCR_MMS_POS) #define TIM_M3_MSCR_MMS_EN (0x01U<<TIM_M3_MSCR_MMS_POS) #define TIM_M3_MSCR_MMS_UEV (0x02U<<TIM_M3_MSCR_MMS_POS) #define TIM_M3_MSCR_MMS_CMPSO (0x03U<<TIM_M3_MSCR_MMS_POS) #define TIM_M3_MSCR_MMS_OCREF0A (0x04U<<TIM_M3_MSCR_MMS_POS) #define TIM_M3_MSCR_MMS_OCREF1A (0x05U<<TIM_M3_MSCR_MMS_POS) #define TIM_M3_MSCR_MMS_OCREF2A (0x06U<<TIM_M3_MSCR_MMS_POS) #define TIM_M3_MSCR_MMS_OCREF0B (0x07U<<TIM_M3_MSCR_MMS_POS) //===滤波控制寄存器 //===ETR输入相位 #define TIM_M3_FLTR_ETP_POS 31 #define TIM_M3_FLTR_ETP_MASK (0x01UL<<TIM_M3_FLTR_ETP_POS) #define TIM_M3_FLTR_ETP TIM_M3_FLTR_ETP_MASK //===ETR滤波控制 #define TIM_M3_FLTR_ETR_POS 28 #define TIM_M3_FLTR_ETR_MASK (0x07UL<<TIM_M3_FLTR_ETR_POS) #define TIM_M3_FLTR_ETR TIM_M3_FLTR_ETR_MASK #define TIM_M3_FLTR_ETR_NONE (0x00U<<TIM_M3_FLTR_ETR_POS) #define TIM_M3_FLTR_ETR_PCLK_DIV1 (0x04U<<TIM_M3_FLTR_ETR_POS) #define TIM_M3_FLTR_ETR_PCLK_DIV4 (0x05U<<TIM_M3_FLTR_ETR_POS) #define TIM_M3_FLTR_ETR_PCLK_DIV16 (0x06U<<TIM_M3_FLTR_ETR_POS) #define TIM_M3_FLTR_ETR_PCLK_DIV64 (0x07U<<TIM_M3_FLTR_ETR_POS) //===刹车BK输入相位选择 #define TIM_M3_FLTR_BKP_POS 27 #define TIM_M3_FLTR_BKP_MASK (0x01U<<TIM_M3_FLTR_BKP_POS) #define TIM_M3_FLTR_BKP TIM_M3_FLTR_BKP_MASK //===刹车输入滤波控制 #define TIM_M3_FLTR_BKR_POS 24 #define TIM_M3_FLTR_BKR_MASK (0x07UL<<TIM_M3_FLTR_BKR_POS) #define TIM_M3_FLTR_BKR TIM_M3_FLTR_BKR_MASK #define TIM_M3_FLTR_BKR_NONE (0x00UL<<TIM_M3_FLTR_BKR_POS) #define TIM_M3_FLTR_BKR_PCLK_DIV1 (0x04UL<<TIM_M3_FLTR_BKR_POS) #define TIM_M3_FLTR_BKR_PCLK_DIV4 (0x05UL<<TIM_M3_FLTR_BKR_POS) #define TIM_M3_FLTR_BKR_PCLK_DIV16 (0x06UL<<TIM_M3_FLTR_BKR_POS) #define TIM_M3_FLTR_BKR_PCLK_DIV64 (0x07UL<<TIM_M3_FLTR_BKR_POS) //===CH2B比较输出相位控制 #define TIM_M3_FLTR_CCPB2_POS 23 #define TIM_M3_FLTR_CCPB2_MASK (0x01UL<<TIM_M3_FLTR_CCPB2_POS) #define TIM_M3_FLTR_CCPB2 TIM_M3_FLTR_CCPB2_MASK //==CH2B比较输出控制 #define TIM_M3_FLTR_OCMB2_POS 20 #define TIM_M3_FLTR_OCMB2_MASK (0x07UL<<TIM_M3_FLTR_OCMB2_POS) #define TIM_M3_FLTR_OCMB2 TIM_M3_FLTR_OCMB2_MASK #define TIM_M3_FLTR_OCMB2_FORCE_LOW (0x00UL<<TIM_M3_FLTR_OCMB2_POS) #define TIM_M3_FLTR_OCMB2_FORCE_HIGH (0x01UL<<TIM_M3_FLTR_OCMB2_POS) #define TIM_M3_FLTR_OCMB2_COMP_LOW (0x02UL<<TIM_M3_FLTR_OCMB2_POS) #define TIM_M3_FLTR_OCMB2_COMP_HIGH (0x03UL<<TIM_M3_FLTR_OCMB2_POS) #define TIM_M3_FLTR_OCMB2_COMP_TOGGLE (0x04UL<<TIM_M3_FLTR_OCMB2_POS) #define TIM_M3_FLTR_OCMB2_COMP_KEEP_HIGH (0x05UL<<TIM_M3_FLTR_OCMB2_POS) #define TIM_M3_FLTR_OCMB2_PWM_MODE1 (0x06UL<<TIM_M3_FLTR_OCMB2_POS) #define TIM_M3_FLTR_OCMB2_PWM_MODE2 (0x07UL<<TIM_M3_FLTR_OCMB2_POS) //==CH2B捕获输入滤波控制 #define TIM_M3_FLTR_CH2B_POS 20 #define TIM_M3_FLTR_CH2B_MASK (0x07UL<<TIM_M3_FLTR_CH2B_POS) #define TIM_M3_FLTR_CH2B TIM_M3_FLTR_CH2B_MASK #define TIM_M3_FLTR_CH2B_NONE (0x00U<<TIM_M3_FLTR_CH2B_POS) #define TIM_M3_FLTR_CH2B_PCLK_DIV1 (0x04U<<TIM_M3_FLTR_CH2B_POS) #define TIM_M3_FLTR_CH2B_PCLK_DIV4 (0x05U<<TIM_M3_FLTR_CH2B_POS) #define TIM_M3_FLTR_CH2B_PCLK_DIV16 (0x06U<<TIM_M3_FLTR_CH2B_POS) #define TIM_M3_FLTR_CH2B_PCLK_DIV64 (0x07U<<TIM_M3_FLTR_CH2B_POS) //===CH2A比较输出相位控制 #define TIM_M3_FLTR_CCPA2_POS 19 #define TIM_M3_FLTR_CCPA2_MASK (0x01UL<<TIM_M3_FLTR_CCPA2_POS) #define TIM_M3_FLTR_CCPA2 TIM_M3_FLTR_CCPA2_MASK //==CH2A比较输出控制 #define TIM_M3_FLTR_OCMA2_POS 16 #define TIM_M3_FLTR_OCMA2_MASK (0x07UL<<TIM_M3_FLTR_OCMA2_POS) #define TIM_M3_FLTR_OCMA2 TIM_M3_FLTR_OCMA2_MASK #define TIM_M3_FLTR_OCMA2_FORCE_LOW (0x00UL<<TIM_M3_FLTR_OCMA2_POS) #define TIM_M3_FLTR_OCMA2_FORCE_HIGH (0x01UL<<TIM_M3_FLTR_OCMA2_POS) #define TIM_M3_FLTR_OCMA2_COMP_LOW (0x02UL<<TIM_M3_FLTR_OCMA2_POS) #define TIM_M3_FLTR_OCMA2_COMP_HIGH (0x03UL<<TIM_M3_FLTR_OCMA2_POS) #define TIM_M3_FLTR_OCMA2_COMP_TOGGLE (0x04UL<<TIM_M3_FLTR_OCMA2_POS) #define TIM_M3_FLTR_OCMA2_COMP_KEEP_HIGH (0x05UL<<TIM_M3_FLTR_OCMA2_POS) #define TIM_M3_FLTR_OCMA2_PWM_MODE1 (0x06UL<<TIM_M3_FLTR_OCMA2_POS) #define TIM_M3_FLTR_OCMA2_PWM_MODE2 (0x07UL<<TIM_M3_FLTR_OCMA2_POS) //==CH2A捕获输入滤波控制 #define TIM_M3_FLTR_CH2A_POS 16 #define TIM_M3_FLTR_CH2A_MASK (0x07UL<<TIM_M3_FLTR_CH2A_POS) #define TIM_M3_FLTR_CH2A TIM_M3_FLTR_CH2A_MASK #define TIM_M3_FLTR_CH2A_NONE (0x00UL<<TIM_M3_FLTR_CH2A_POS) #define TIM_M3_FLTR_CH2A_PCLK_DIV1 (0x04UL<<TIM_M3_FLTR_CH2A_POS) #define TIM_M3_FLTR_CH2A_PCLK_DIV4 (0x05UL<<TIM_M3_FLTR_CH2A_POS) #define TIM_M3_FLTR_CH2A_PCLK_DIV16 (0x06UL<<TIM_M3_FLTR_CH2A_POS) #define TIM_M3_FLTR_CH2A_PCLK_DIV64 (0x07UL<<TIM_M3_FLTR_CH2A_POS) //===CH1B比较输出相位控制 #define TIM_M3_FLTR_CCPB1_POS 15 #define TIM_M3_FLTR_CCPB1_MASK (0x01UL<<TIM_M3_FLTR_CCPB1_POS) #define TIM_M3_FLTR_CCPB1 TIM_M3_FLTR_CCPB1_MASK //==CH1B比较输出控制 #define TIM_M3_FLTR_OCMB1_POS 12 #define TIM_M3_FLTR_OCMB1_MASK (0x07UL<<TIM_M3_FLTR_OCMB1_POS) #define TIM_M3_FLTR_OCMB1 TIM_M3_FLTR_OCMB1_MASK #define TIM_M3_FLTR_OCMB1_FORCE_LOW (0x00UL<<TIM_M3_FLTR_OCMB1_POS) #define TIM_M3_FLTR_OCMB1_FORCE_HIGH (0x01UL<<TIM_M3_FLTR_OCMB1_POS) #define TIM_M3_FLTR_OCMB1_COMP_LOW (0x02UL<<TIM_M3_FLTR_OCMB1_POS) #define TIM_M3_FLTR_OCMB1_COMP_HIGH (0x03UL<<TIM_M3_FLTR_OCMB1_POS) #define TIM_M3_FLTR_OCMB1_COMP_TOGGLE (0x04UL<<TIM_M3_FLTR_OCMB1_POS) #define TIM_M3_FLTR_OCMB1_COMP_KEEP_HIGH (0x05UL<<TIM_M3_FLTR_OCMB1_POS) #define TIM_M3_FLTR_OCMB1_PWM_MODE1 (0x06UL<<TIM_M3_FLTR_OCMB1_POS) #define TIM_M3_FLTR_OCMB1_PWM_MODE2 (0x07UL<<TIM_M3_FLTR_OCMB1_POS) //==CH1B捕获输入滤波控制 #define TIM_M3_FLTR_CH1B_POS 12 #define TIM_M3_FLTR_CH1B_MASK (0x07UL<<TIM_M3_FLTR_CH1B_POS) #define TIM_M3_FLTR_CH1B TIM_M3_FLTR_CH1B_MASK #define TIM_M3_FLTR_CH1B_NONE (0x00UL<<TIM_M3_FLTR_CH1B_POS) #define TIM_M3_FLTR_CH1B_PCLK_DIV1 (0x04UL<<TIM_M3_FLTR_CH1B_POS) #define TIM_M3_FLTR_CH1B_PCLK_DIV4 (0x05UL<<TIM_M3_FLTR_CH1B_POS) #define TIM_M3_FLTR_CH1B_PCLK_DIV16 (0x06UL<<TIM_M3_FLTR_CH1B_POS) #define TIM_M3_FLTR_CH1B_PCLK_DIV64 (0x07UL<<TIM_M3_FLTR_CH1B_POS) //===CH1A比较输出相位控制 #define TIM_M3_FLTR_CCPA1_POS 11 #define TIM_M3_FLTR_CCPA1_MASK (0x01UL<<TIM_M3_FLTR_CCPA1_POS) #define TIM_M3_FLTR_CCPA1 TIM_M3_FLTR_CCPA1_MASK //==CH1A比较输出控制 #define TIM_M3_FLTR_OCMA1_POS 8 #define TIM_M3_FLTR_OCMA1_MASK (0x07UL<<TIM_M3_FLTR_OCMA1_POS) #define TIM_M3_FLTR_OCMA1 TIM_M3_FLTR_OCMA1_MASK #define TIM_M3_FLTR_OCMA1_FORCE_LOW (0x00UL<<TIM_M3_FLTR_OCMA1_POS) #define TIM_M3_FLTR_OCMA1_FORCE_HIGH (0x01UL<<TIM_M3_FLTR_OCMA1_POS) #define TIM_M3_FLTR_OCMA1_COMP_LOW (0x02UL<<TIM_M3_FLTR_OCMA1_POS) #define TIM_M3_FLTR_OCMA1_COMP_HIGH (0x03UL<<TIM_M3_FLTR_OCMA1_POS) #define TIM_M3_FLTR_OCMA1_COMP_TOGGLE (0x04UL<<TIM_M3_FLTR_OCMA1_POS) #define TIM_M3_FLTR_OCMA1_COMP_KEEP_HIGH (0x05UL<<TIM_M3_FLTR_OCMA1_POS) #define TIM_M3_FLTR_OCMA1_PWM_MODE1 (0x06UL<<TIM_M3_FLTR_OCMA1_POS) #define TIM_M3_FLTR_OCMA1_PWM_MODE2 (0x07UL<<TIM_M3_FLTR_OCMA1_POS) //==CH1A捕获输入滤波控制 #define TIM_M3_FLTR_CH1A_POS 8 #define TIM_M3_FLTR_CH1A_MASK (0x07UL<<TIM_M3_FLTR_CH1A_POS) #define TIM_M3_FLTR_CH1A TIM_M3_FLTR_CH1A_MASK #define TIM_M3_FLTR_CH1A_NONE (0x00UL<<TIM_M3_FLTR_CH1A_POS) #define TIM_M3_FLTR_CH1A_PCLK_DIV1 (0x04UL<<TIM_M3_FLTR_CH1A_POS) #define TIM_M3_FLTR_CH1A_PCLK_DIV4 (0x05UL<<TIM_M3_FLTR_CH1A_POS) #define TIM_M3_FLTR_CH1A_PCLK_DIV16 (0x06UL<<TIM_M3_FLTR_CH1A_POS) #define TIM_M3_FLTR_CH1A_PCLK_DIV64 (0x07UL<<TIM_M3_FLTR_CH1A_POS) //===CH0B比较输出相位控制 #define TIM_M3_FLTR_CCPB0_POS 7 #define TIM_M3_FLTR_CCPB0_MASK (0x01UL<<TIM_M3_FLTR_CCPB0_POS) #define TIM_M3_FLTR_CCPB0 TIM_M3_FLTR_CCPB0_MASK //==CH0B捕获输入滤波控制 #define TIM_M3_FLTR_OCMB0_POS 4 #define TIM_M3_FLTR_OCMB0_MASK (0x07UL<<TIM_M3_FLTR_OCMB0_POS) #define TIM_M3_FLTR_OCMB0 TIM_M3_FLTR_OCMB0_MASK #define TIM_M3_FLTR_OCMB0_FORCE_LOW (0x00UL<<TIM_M3_FLTR_OCMB0_POS) #define TIM_M3_FLTR_OCMB0_FORCE_HIGH (0x01UL<<TIM_M3_FLTR_OCMB0_POS) #define TIM_M3_FLTR_OCMB0_COMP_LOW (0x02UL<<TIM_M3_FLTR_OCMB0_POS) #define TIM_M3_FLTR_OCMB0_COMP_HIGH (0x03UL<<TIM_M3_FLTR_OCMB0_POS) #define TIM_M3_FLTR_OCMB0_COMP_TOGGLE (0x04UL<<TIM_M3_FLTR_OCMB0_POS) #define TIM_M3_FLTR_OCMB0_COMP_KEEP_HIGH (0x05UL<<TIM_M3_FLTR_OCMB0_POS) #define TIM_M3_FLTR_OCMB0_PWM_MODE1 (0x06UL<<TIM_M3_FLTR_OCMB0_POS) #define TIM_M3_FLTR_OCMB0_PWM_MODE2 (0x07UL<<TIM_M3_FLTR_OCMB0_POS) //==CH0B捕获输入滤波控制 #define TIM_M3_FLTR_CH0B_POS 4 #define TIM_M3_FLTR_CH0B_MASK (0x07UL<<TIM_M3_FLTR_CH0B_POS) #define TIM_M3_FLTR_CH0B TIM_M3_FLTR_CH0B_MASK #define TIM_M3_FLTR_CH0B_NONE (0x00UL<<TIM_M3_FLTR_CH0B_POS) #define TIM_M3_FLTR_CH0B_PCLK_DIV1 (0x04UL<<TIM_M3_FLTR_CH0B_POS) #define TIM_M3_FLTR_CH0B_PCLK_DIV4 (0x05UL<<TIM_M3_FLTR_CH0B_POS) #define TIM_M3_FLTR_CH0B_PCLK_DIV16 (0x06UL<<TIM_M3_FLTR_CH0B_POS) #define TIM_M3_FLTR_CH0B_PCLK_DIV64 (0x07UL<<TIM_M3_FLTR_CH0B_POS) //===CH0A比较输出相位控制 #define TIM_M3_FLTR_CCPA0_POS 3 #define TIM_M3_FLTR_CCPA0_MASK (0x01UL<<TIM_M3_FLTR_CCPA0_POS) #define TIM_M3_FLTR_CCPA0 TIM_M3_FLTR_CCPA0_MASK //==CH0A比较输出控制 #define TIM_M3_FLTR_OCMA0_POS 0 #define TIM_M3_FLTR_OCMA0_MASK (0x07UL<<TIM_M3_FLTR_OCMA0_POS) #define TIM_M3_FLTR_OCMA0 TIM_M3_FLTR_OCMA0_MASK #define TIM_M3_FLTR_OCMA0_FORCE_LOW (0x00UL<<TIM_M3_FLTR_OCMA0_POS) #define TIM_M3_FLTR_OCMA0_FORCE_HIGH (0x01UL<<TIM_M3_FLTR_OCMA0_POS) #define TIM_M3_FLTR_OCMA0_COMP_LOW (0x02UL<<TIM_M3_FLTR_OCMA0_POS) #define TIM_M3_FLTR_OCMA0_COMP_HIGH (0x03UL<<TIM_M3_FLTR_OCMA0_POS) #define TIM_M3_FLTR_OCMA0_COMP_TOGGLE (0x04UL<<TIM_M3_FLTR_OCMA0_POS) #define TIM_M3_FLTR_OCMA0_COMP_KEEP_HIGH (0x05UL<<TIM_M3_FLTR_OCMA0_POS) #define TIM_M3_FLTR_OCMA0_PWM_MODE1 (0x06UL<<TIM_M3_FLTR_OCMA0_POS) #define TIM_M3_FLTR_OCMA0_PWM_MODE2 (0x07UL<<TIM_M3_FLTR_OCMA0_POS) //==CH0A捕获输入滤波控制 #define TIM_M3_FLTR_CH0A_POS 0 #define TIM_M3_FLTR_CH0A_MASK (0x07UL<<TIM_M3_FLTR_CH0A_POS) #define TIM_M3_FLTR_CH0A TIM_M3_FLTR_CH0A_MASK #define TIM_M3_FLTR_CH0A_NONE (0x00UL<<TIM_M3_FLTR_CH0A_POS) #define TIM_M3_FLTR_CH0A_PCLK_DIV1 (0x04UL<<TIM_M3_FLTR_CH0A_POS) #define TIM_M3_FLTR_CH0A_PCLK_DIV4 (0x05UL<<TIM_M3_FLTR_CH0A_POS) #define TIM_M3_FLTR_CH0A_PCLK_DIV16 (0x06UL<<TIM_M3_FLTR_CH0A_POS) #define TIM_M3_FLTR_CH0A_PCLK_DIV64 (0x07UL<<TIM_M3_FLTR_CH0A_POS) //===ADC触发控制寄存器 #define TIM_M3_ADTR_EN_POS 7 #define TIM_M3_ADTR_EN_MASK (0x01UL<<TIM_M3_ADTR_EN_POS) #define TIM_M3_ADTR_EN TIM_M3_ADTR_EN_MASK //===CH2B比较匹配触发adc #define TIM_M3_ADTR_CMB2EN_POS 6 #define TIM_M3_ADTR_CMB2EN_MASK (0x01UL<<TIM_M3_ADTR_CMB2EN_POS) #define TIM_M3_ADTR_CMB2EN TIM_M3_ADTR_CMB2EN_MASK //===CH1B比较匹配触发adc #define TIM_M3_ADTR_CMB1EN_POS 5 #define TIM_M3_ADTR_CMB1EN_MASK (0x01UL<<TIM_M3_ADTR_CMB1EN_POS) #define TIM_M3_ADTR_CMB1EN TIM_M3_ADTR_CMB1EN_MASK //===CH0B比较匹配触发adc #define TIM_M3_ADTR_CMB0EN_POS 4 #define TIM_M3_ADTR_CMB0EN_MASK (0x01UL<<TIM_M3_ADTR_CMB0EN_POS) #define TIM_M3_ADTR_CMB0EN TIM_M3_ADTR_CMB0EN_MASK //===CH2A比较匹配触发adc #define TIM_M3_ADTR_CMA2EN_POS 3 #define TIM_M3_ADTR_CMA2EN_MASK (0x01UL<<TIM_M3_ADTR_CMA2EN_POS) #define TIM_M3_ADTR_CMA2EN TIM_M3_ADTR_CMA2EN_MASK //===CH0A比较匹配触发adc #define TIM_M3_ADTR_CMA1EN_POS 2 #define TIM_M3_ADTR_CMA1EN_MASK (0x01UL<<TIM_M3_ADTR_CMA1EN_POS) #define TIM_M3_ADTR_CMA1EN TIM_M3_ADTR_CMA1EN_MASK //===CH0A比较匹配触发adc #define TIM_M3_ADTR_CMA0EN_POS 1 #define TIM_M3_ADTR_CMA0EN_MASK (0x01UL<<TIM_M3_ADTR_CMA0EN_POS) #define TIM_M3_ADTR_CMA0EN TIM_M3_ADTR_CMA0EN_MASK //===事件更新触发adc #define TIM_M3_ADTR_UEN_POS 0 #define TIM_M3_ADTR_UEN_MASK (0x01UL<<TIM_M3_ADTR_UEN_POS) #define TIM_M3_ADTR_UEN TIM_M3_ADTR_UEN_MASK //===通道0控制寄存器 //===捕获比较B软件触发 #define TIM_M3_CRCH0_CCGB_POS 15 #define TIM_M3_CRCH0_CCGB_MASK (0x01UL<<TIM_M3_CRCH0_CCGB_POS) #define TIM_M3_CRCH0_CCGB TIM_M3_CRCH0_CCGB_MASK //===捕获比较A软件触发 #define TIM_M3_CRCH0_CCGA_POS 14 #define TIM_M3_CRCH0_CCGA_MASK (0x01UL<<TIM_M3_CRCH0_CCGA_POS) #define TIM_M3_CRCH0_CCGA TIM_M3_CRCH0_CCGA_MASK //===B比较模式中断 #define TIM_M3_CRCH0_CISB_POS 13 #define TIM_M3_CRCH0_CISB_MASK (0x03UL<<TIM_M3_CRCH0_CISB_POS) #define TIM_M3_CRCH0_CISB TIM_M3_CRCH0_CISB_MASK #define TIM_M3_CRCH0_CISB_EDGE_NONE (0x00UL<<TIM_M3_CRCH0_CISB_POS) #define TIM_M3_CRCH0_CISB_EDGE_RISE (0x01UL<<TIM_M3_CRCH0_CISB_POS) #define TIM_M3_CRCH0_CISB_EDGE_FAIL (0x02UL<<TIM_M3_CRCH0_CISB_POS) #define TIM_M3_CRCH0_CISB_EDGE_ALL (0x03UL<<TIM_M3_CRCH0_CISB_POS) //===B捕获比较触发DMA使能 #define TIM_M3_CRCH0_CDMABEN_POS 11 #define TIM_M3_CRCH0_CDMABEN_MASK (0x01UL<<TIM_M3_CRCH0_CDMABEN_POS) #define TIM_M3_CRCH0_CDMABEN TIM_M3_CRCH0_CDMABEN_MASK //===A捕获比较触发DMA使能 #define TIM_M3_CRCH0_CDMAAEN_POS 10 #define TIM_M3_CRCH0_CDMAAEN_MASK (0x01UL<<TIM_M3_CRCH0_CDMAAEN_POS) #define TIM_M3_CRCH0_CDMAAEN TIM_M3_CRCH0_CDMAAEN_MASK //===B捕获比较触发中断 #define TIM_M3_CRCH0_CIEB_POS 9 #define TIM_M3_CRCH0_CIEB_MASK (0x01UL<<TIM_M3_CRCH0_CIEB_POS) #define TIM_M3_CRCH0_CIEB TIM_M3_CRCH0_CIEB_MASK //===B捕获比较触发中断 #define TIM_M3_CRCH0_CIEA_POS 8 #define TIM_M3_CRCH0_CIEA_MASK (0x01UL<<TIM_M3_CRCH0_CIEA_POS) #define TIM_M3_CRCH0_CIEA TIM_M3_CRCH0_CIEA_MASK //===比较功能,B比较缓存使能控制 #define TIM_M3_CRCH0_BUFEB_POS 7 #define TIM_M3_CRCH0_BUFEB_MASK (0x01UL<<TIM_M3_CRCH0_BUFEB_POS) #define TIM_M3_CRCH0_BUFEB TIM_M3_CRCH0_BUFEB_MASK //===比较功能,B比较缓存使能控制 #define TIM_M3_CRCH0_BUFEA_POS 6 #define TIM_M3_CRCH0_BUFEA_MASK (0x01UL<<TIM_M3_CRCH0_BUFEA_POS) #define TIM_M3_CRCH0_BUFEA TIM_M3_CRCH0_BUFEA_MASK #define TIM_M3_CRCH0_CSB_POS 5 #define TIM_M3_CRCH0_CSB_MASK (0x01UL<<TIM_M3_CRCH0_CSB_POS) #define TIM_M3_CRCH0_CSB TIM_M3_CRCH0_CSB_MASK #define TIM_M3_CRCH0_CSA_POS 4 #define TIM_M3_CRCH0_CSA_MASK (0x01UL<<TIM_M3_CRCH0_CSA_POS) #define TIM_M3_CRCH0_CSA TIM_M3_CRCH0_CSA_MASK #define TIM_M3_CRCH0_CFB_POS 3 #define TIM_M3_CRCH0_CFB_MASK (0x01UL<<TIM_M3_CRCH0_CFB_POS) #define TIM_M3_CRCH0_CFB TIM_M3_CRCH0_CFB_MASK #define TIM_M3_CRCH0_CRB_POS 2 #define TIM_M3_CRCH0_CRB_MASK (0x01UL<<TIM_M3_CRCH0_CRB_POS) #define TIM_M3_CRCH0_CRB TIM_M3_CRCH0_CRB_MASK //===B通道比较输出刹车电平控制 #define TIM_M3_CRCH0_BKSB_POS 2 #define TIM_M3_CRCH0_BKSB_MASK (0x03UL<<TIM_M3_CRCH0_BKSB_POS) #define TIM_M3_CRCH0_BKSB TIM_M3_CRCH0_BKSB_MASK #define TIM_M3_CRCH0_BKSB_HZ (0x00UL<<TIM_M3_CRCH0_BKSB_POS) #define TIM_M3_CRCH0_BKSB_NONE (0x01UL<<TIM_M3_CRCH0_BKSB_POS) #define TIM_M3_CRCH0_BKSB_LOW (0x02UL<<TIM_M3_CRCH0_BKSB_POS) #define TIM_M3_CRCH0_BKSB_HIGHT (0x03UL<<TIM_M3_CRCH0_BKSB_POS) #define TIM_M3_CRCH0_CFA_POS 1 #define TIM_M3_CRCH0_CFA_MASK (0x01UL<<TIM_M3_CRCH0_CFA_POS) #define TIM_M3_CRCH0_CFA TIM_M3_CRCH0_CFA_MASK #define TIM_M3_CRCH0_CRA_POS 0 #define TIM_M3_CRCH0_CRA_MASK (0x01UL<<TIM_M3_CRCH0_CRA_POS) #define TIM_M3_CRCH0_CRA TIM_M3_CRCH0_CRA_MASK #define TIM_M3_CRCH0_BKSA_POS 0 #define TIM_M3_CRCH0_BKSA_MASK (0x03UL<<TIM_M3_CRCH0_BKSA_POS) #define TIM_M3_CRCH0_BKSA TIM_M3_CRCH0_BKSA_MASK #define TIM_M3_CRCH0_BKSA_HZ (0x00UL<<TIM_M3_CRCH0_BKSA_POS) #define TIM_M3_CRCH0_BKSA_NONE (0x01UL<<TIM_M3_CRCH0_BKSA_POS) #define TIM_M3_CRCH0_BKSA_LOW (0x02UL<<TIM_M3_CRCH0_BKSA_POS) #define TIM_M3_CRCH0_BKSA_HIGHT (0x03UL<<TIM_M3_CRCH0_BKSA_POS) //===通道1控制寄存器 //===捕获比较B软件触发 #define TIM_M3_CRCH1_CCGB_POS 15 #define TIM_M3_CRCH1_CCGB_MASK (0x01UL<<TIM_M3_CRCH1_CCGB_POS) #define TIM_M3_CRCH1_CCGB TIM_M3_CRCH1_CCGB_MASK //===捕获比较A软件触发 #define TIM_M3_CRCH1_CCGA_POS 14 #define TIM_M3_CRCH1_CCGA_MASK (0x01UL<<TIM_M3_CRCH1_CCGA_POS) #define TIM_M3_CRCH1_CCGA TIM_M3_CRCH1_CCGA_MASK //===B比较模式中断 #define TIM_M3_CRCH1_CISB_POS 13 #define TIM_M3_CRCH1_CISB_MASK (0x03UL<<TIM_M3_CRCH1_CISB_POS) #define TIM_M3_CRCH1_CISB TIM_M3_CRCH1_CISB_MASK #define TIM_M3_CRCH1_CISB_EDGE_NONE (0x00UL<<TIM_M3_CRCH1_CISB_POS) #define TIM_M3_CRCH1_CISB_EDGE_RISE (0x01UL<<TIM_M3_CRCH1_CISB_POS) #define TIM_M3_CRCH1_CISB_EDGE_FAIL (0x02UL<<TIM_M3_CRCH1_CISB_POS) #define TIM_M3_CRCH1_CISB_EDGE_ALL (0x03UL<<TIM_M3_CRCH1_CISB_POS) //===B捕获比较触发DMA使能 #define TIM_M3_CRCH1_CDMABEN_POS 11 #define TIM_M3_CRCH1_CDMABEN_MASK (0x01UL<<TIM_M3_CRCH1_CDMABEN_POS) #define TIM_M3_CRCH1_CDMABEN TIM_M3_CRCH1_CDMABEN_MASK //===A捕获比较触发DMA使能 #define TIM_M3_CRCH1_CDMAAEN_POS 10 #define TIM_M3_CRCH1_CDMAAEN_MASK (0x01UL<<TIM_M3_CRCH1_CDMAAEN_POS) #define TIM_M3_CRCH1_CDMAAEN TIM_M3_CRCH1_CDMAAEN_MASK //===B捕获比较触发中断 #define TIM_M3_CRCH1_CIEB_POS 9 #define TIM_M3_CRCH1_CIEB_MASK (0x01UL<<TIM_M3_CRCH1_CIEB_POS) #define TIM_M3_CRCH1_CIEB TIM_M3_CRCH1_CIEB_MASK //===B捕获比较触发中断 #define TIM_M3_CRCH1_CIEA_POS 8 #define TIM_M3_CRCH1_CIEA_MASK (0x01UL<<TIM_M3_CRCH1_CIEA_POS) #define TIM_M3_CRCH1_CIEA TIM_M3_CRCH1_CIEA_MASK //===比较功能,B比较缓存使能控制 #define TIM_M3_CRCH1_BUFEB_POS 7 #define TIM_M3_CRCH1_BUFEB_MASK (0x01UL<<TIM_M3_CRCH1_BUFEB_POS) #define TIM_M3_CRCH1_BUFEB TIM_M3_CRCH1_BUFEB_MASK //===比较功能,B比较缓存使能控制 #define TIM_M3_CRCH1_BUFEA_POS 6 #define TIM_M3_CRCH1_BUFEA_MASK (0x01UL<<TIM_M3_CRCH1_BUFEA_POS) #define TIM_M3_CRCH1_BUFEA TIM_M3_CRCH1_BUFEA_MASK #define TIM_M3_CRCH1_CSB_POS 5 #define TIM_M3_CRCH1_CSB_MASK (0x01UL<<TIM_M3_CRCH1_CSB_POS) #define TIM_M3_CRCH1_CSB TIM_M3_CRCH1_CSB_MASK #define TIM_M3_CRCH1_CSA_POS 4 #define TIM_M3_CRCH1_CSA_MASK (0x01UL<<TIM_M3_CRCH1_CSA_POS) #define TIM_M3_CRCH1_CSA TIM_M3_CRCH1_CSA_MASK #define TIM_M3_CRCH1_CFB_POS 3 #define TIM_M3_CRCH1_CFB_MASK (0x01UL<<TIM_M3_CRCH1_CFB_POS) #define TIM_M3_CRCH1_CFB TIM_M3_CRCH1_CFB_MASK #define TIM_M3_CRCH1_CRB_POS 2 #define TIM_M3_CRCH1_CRB_MASK (0x01UL<<TIM_M3_CRCH1_CRB_POS) #define TIM_M3_CRCH1_CRB TIM_M3_CRCH1_CRB_MASK //===B通道比较输出刹车电平控制 #define TIM_M3_CRCH1_BKSB_POS 2 #define TIM_M3_CRCH1_BKSB_MASK (0x03UL<<TIM_M3_CRCH1_BKSB_POS) #define TIM_M3_CRCH1_BKSB TIM_M3_CRCH1_BKSB_MASK #define TIM_M3_CRCH1_BKSB_HZ (0x00UL<<TIM_M3_CRCH1_BKSB_POS) #define TIM_M3_CRCH1_BKSB_NONE (0x01UL<<TIM_M3_CRCH1_BKSB_POS) #define TIM_M3_CRCH1_BKSB_LOW (0x02UL<<TIM_M3_CRCH1_BKSB_POS) #define TIM_M3_CRCH1_BKSB_HIGHT (0x03UL<<TIM_M3_CRCH1_BKSB_POS) #define TIM_M3_CRCH1_CFA_POS 1 #define TIM_M3_CRCH1_CFA_MASK (0x01UL<<TIM_M3_CRCH1_CFA_POS) #define TIM_M3_CRCH1_CFA TIM_M3_CRCH1_CFA_MASK #define TIM_M3_CRCH1_CRA_POS 0 #define TIM_M3_CRCH1_CRA_MASK (0x01UL<<TIM_M3_CRCH1_CRA_POS) #define TIM_M3_CRCH1_CRA TIM_M3_CRCH1_CRA_MASK #define TIM_M3_CRCH1_BKSA_POS 0 #define TIM_M3_CRCH1_BKSA_MASK (0x03UL<<TIM_M3_CRCH1_BKSA_POS) #define TIM_M3_CRCH1_BKSA TIM_M3_CRCH1_BKSA_MASK #define TIM_M3_CRCH1_BKSA_HZ (0x00UL<<TIM_M3_CRCH1_BKSA_POS) #define TIM_M3_CRCH1_BKSA_NONE (0x01UL<<TIM_M3_CRCH1_BKSA_POS) #define TIM_M3_CRCH1_BKSA_LOW (0x02UL<<TIM_M3_CRCH1_BKSA_POS) #define TIM_M3_CRCH1_BKSA_HIGHT (0x03UL<<TIM_M3_CRCH1_BKSA_POS) //===通道2控制寄存器 //===捕获比较B软件触发 #define TIM_M3_CRCH2_CCGB_POS 15 #define TIM_M3_CRCH2_CCGB_MASK (0x01UL<<TIM_M3_CRCH2_CCGB_POS) #define TIM_M3_CRCH2_CCGB TIM_M3_CRCH2_CCGB_MASK //===捕获比较A软件触发 #define TIM_M3_CRCH2_CCGA_POS 14 #define TIM_M3_CRCH2_CCGA_MASK (0x01UL<<TIM_M3_CRCH2_CCGA_POS) #define TIM_M3_CRCH2_CCGA TIM_M3_CRCH2_CCGA_MASK //===B比较模式中断 #define TIM_M3_CRCH2_CISB_POS 13 #define TIM_M3_CRCH2_CISB_MASK (0x03UL<<TIM_M3_CRCH2_CISB_POS) #define TIM_M3_CRCH2_CISB TIM_M3_CRCH2_CISB_MASK #define TIM_M3_CRCH2_CISB_EDGE_NONE (0x00UL<<TIM_M3_CRCH2_CISB_POS) #define TIM_M3_CRCH2_CISB_EDGE_RISE (0x01UL<<TIM_M3_CRCH2_CISB_POS) #define TIM_M3_CRCH2_CISB_EDGE_FAIL (0x02UL<<TIM_M3_CRCH2_CISB_POS) #define TIM_M3_CRCH2_CISB_EDGE_ALL (0x03UL<<TIM_M3_CRCH2_CISB_POS) //===B捕获比较触发DMA使能 #define TIM_M3_CRCH2_CDMABEN_POS 11 #define TIM_M3_CRCH2_CDMABEN_MASK (0x01UL<<TIM_M3_CRCH2_CDMABEN_POS) #define TIM_M3_CRCH2_CDMABEN TIM_M3_CRCH2_CDMABEN_MASK //===A捕获比较触发DMA使能 #define TIM_M3_CRCH2_CDMAAEN_POS 10 #define TIM_M3_CRCH2_CDMAAEN_MASK (0x01UL<<TIM_M3_CRCH2_CDMAAEN_POS) #define TIM_M3_CRCH2_CDMAAEN TIM_M3_CRCH2_CDMAAEN_MASK //===B捕获比较触发中断 #define TIM_M3_CRCH2_CIEB_POS 9 #define TIM_M3_CRCH2_CIEB_MASK (0x01UL<<TIM_M3_CRCH2_CIEB_POS) #define TIM_M3_CRCH2_CIEB TIM_M3_CRCH2_CIEB_MASK //===B捕获比较触发中断 #define TIM_M3_CRCH2_CIEA_POS 8 #define TIM_M3_CRCH2_CIEA_MASK (0x01UL<<TIM_M3_CRCH2_CIEA_POS) #define TIM_M3_CRCH2_CIEA TIM_M3_CRCH2_CIEA_MASK //===比较功能,B比较缓存使能控制 #define TIM_M3_CRCH2_BUFEB_POS 7 #define TIM_M3_CRCH2_BUFEB_MASK (0x01UL<<TIM_M3_CRCH2_BUFEB_POS) #define TIM_M3_CRCH2_BUFEB TIM_M3_CRCH2_BUFEB_MASK //===比较功能,B比较缓存使能控制 #define TIM_M3_CRCH2_BUFEA_POS 6 #define TIM_M3_CRCH2_BUFEA_MASK (0x01UL<<TIM_M3_CRCH2_BUFEA_POS) #define TIM_M3_CRCH2_BUFEA TIM_M3_CRCH2_BUFEA_MASK #define TIM_M3_CRCH2_CSB_POS 5 #define TIM_M3_CRCH2_CSB_MASK (0x01UL<<TIM_M3_CRCH2_CSB_POS) #define TIM_M3_CRCH2_CSB TIM_M3_CRCH2_CSB_MASK #define TIM_M3_CRCH2_CSA_POS 4 #define TIM_M3_CRCH2_CSA_MASK (0x01UL<<TIM_M3_CRCH2_CSA_POS) #define TIM_M3_CRCH2_CSA TIM_M3_CRCH2_CSA_MASK #define TIM_M3_CRCH2_CFB_POS 3 #define TIM_M3_CRCH2_CFB_MASK (0x01UL<<TIM_M3_CRCH2_CFB_POS) #define TIM_M3_CRCH2_CFB TIM_M3_CRCH2_CFB_MASK #define TIM_M3_CRCH2_CRB_POS 2 #define TIM_M3_CRCH2_CRB_MASK (0x01UL<<TIM_M3_CRCH2_CRB_POS) #define TIM_M3_CRCH2_CRB TIM_M3_CRCH2_CRB_MASK //===B通道比较输出刹车电平控制 #define TIM_M3_CRCH2_BKSB_POS 2 #define TIM_M3_CRCH2_BKSB_MASK (0x03UL<<TIM_M3_CRCH2_BKSB_POS) #define TIM_M3_CRCH2_BKSB TIM_M3_CRCH2_BKSB_MASK #define TIM_M3_CRCH2_BKSB_HZ (0x00UL<<TIM_M3_CRCH2_BKSB_POS) #define TIM_M3_CRCH2_BKSB_NONE (0x01UL<<TIM_M3_CRCH2_BKSB_POS) #define TIM_M3_CRCH2_BKSB_LOW (0x02UL<<TIM_M3_CRCH2_BKSB_POS) #define TIM_M3_CRCH2_BKSB_HIGHT (0x03UL<<TIM_M3_CRCH2_BKSB_POS) #define TIM_M3_CRCH2_CFA_POS 1 #define TIM_M3_CRCH2_CFA_MASK (0x01UL<<TIM_M3_CRCH2_CFA_POS) #define TIM_M3_CRCH2_CFA TIM_M3_CRCH2_CFA_MASK #define TIM_M3_CRCH2_CRA_POS 0 #define TIM_M3_CRCH2_CRA_MASK (0x01UL<<TIM_M3_CRCH2_CRA_POS) #define TIM_M3_CRCH2_CRA TIM_M3_CRCH2_CRA_MASK #define TIM_M3_CRCH2_BKSA_POS 0 #define TIM_M3_CRCH2_BKSA_MASK (0x03UL<<TIM_M3_CRCH2_BKSA_POS) #define TIM_M3_CRCH2_BKSA TIM_M3_CRCH2_BKSA_MASK #define TIM_M3_CRCH2_BKSA_HZ (0x00UL<<TIM_M3_CRCH2_BKSA_POS) #define TIM_M3_CRCH2_BKSA_NONE (0x01UL<<TIM_M3_CRCH2_BKSA_POS) #define TIM_M3_CRCH2_BKSA_LOW (0x02UL<<TIM_M3_CRCH2_BKSA_POS) #define TIM_M3_CRCH2_BKSA_HIGHT (0x03UL<<TIM_M3_CRCH2_BKSA_POS) //===死区控制寄存器 #define TIM_M3_DTR_VCEN_POS 14 #define TIM_M3_DTR_VCEN_MASK (0x01UL<<TIM_M3_DTR_VCEN_POS) #define TIM_M3_DTR_VCEN TIM_M3_DTR_VCEN_MASK //===Safety刹车控制使能 #define TIM_M3_DTR_SAFETYEN_POS 13 #define TIM_M3_DTR_SAFETYEN_MASK (0x01UL<<TIM_M3_DTR_SAFETYEN_POS) #define TIM_M3_DTR_SAFETYEN TIM_M3_DTR_SAFETYEN_MASK //===PWM输出控制使能 #define TIM_M3_DTR_MOEN_POS 12 #define TIM_M3_DTR_MOEN_MASK (0x01UL<<TIM_M3_DTR_MOEN_POS) #define TIM_M3_DTR_MOEN TIM_M3_DTR_MOEN_MASK //===PWM输出自动控制使能 #define TIM_M3_DTR_AOEN_POS 11 #define TIM_M3_DTR_AOEN_MASK (0x01UL<<TIM_M3_DTR_AOEN_POS) #define TIM_M3_DTR_AOEN TIM_M3_DTR_AOEN_MASK //===刹车控制使能 #define TIM_M3_DTR_BKE_POS 10 #define TIM_M3_DTR_BKE_MASK (0x01UL<<TIM_M3_DTR_BKE_POS) #define TIM_M3_DTR_BKE TIM_M3_DTR_BKE_MASK //===死区控制使能 #define TIM_M3_DTR_DTEN_POS 9 #define TIM_M3_DTR_DTEN_MASK (0x01UL<<TIM_M3_DTR_DTEN_POS) #define TIM_M3_DTR_DTEN TIM_M3_DTR_DTEN_MASK //===刹车选择 #define TIM_M3_DTR_BKSEL_POS 8 #define TIM_M3_DTR_BKSEL_MASK (0x01UL<<TIM_M3_DTR_BKSEL_POS) #define TIM_M3_DTR_BKSEL TIM_M3_DTR_BKSEL_MASK //===死区控制 #define TIM_M3_DTR_TIM_POS 0 #define TIM_M3_DTR_TIM_MASK (0xFFUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM TIM_M3_DTR_TIM_MASK //===死区时间 #define TIM_M3_DTR_TIM_2 (0x00UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_3 (0x01UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_4 (0x02UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_5 (0x03UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_6 (0x04UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_7 (0x05UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_8 (0x06UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_9 (0x07UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_10 (0x08UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_11 (0x09UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_12 (0x0AUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_13 (0x0BUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_14 (0x0CUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_15 (0x0DUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_16 (0x0EUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_17 (0x0FUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_18 (0x10UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_19 (0x11UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_20 (0x12UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_21 (0x13UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_22 (0x14UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_23 (0x15UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_24 (0x16UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_25 (0x17UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_26 (0x18UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_27 (0x19UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_28 (0x1AUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_29 (0x1BUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_30 (0x1CUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_31 (0x1DUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_32 (0x1EUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_33 (0x1FUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_34 (0x20UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_35 (0x21UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_36 (0x22UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_37 (0x23UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_38 (0x24UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_39 (0x25UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_40 (0x26UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_41 (0x27UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_42 (0x28UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_43 (0x29UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_44 (0x2AUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_45 (0x2BUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_46 (0x2CUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_47 (0x2DUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_48 (0x2EUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_49 (0x2FUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_50 (0x30UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_51 (0x31UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_52 (0x32UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_53 (0x33UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_54 (0x34UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_55 (0x35UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_56 (0x36UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_57 (0x37UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_58 (0x38UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_59 (0x39UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_60 (0x3AUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_61 (0x3BUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_62 (0x3CUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_63 (0x3DUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_64 (0x3EUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_65 (0x3FUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_66 (0x40UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_67 (0x41UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_68 (0x42UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_69 (0x43UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_70 (0x44UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_71 (0x45UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_72 (0x46UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_73 (0x47UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_74 (0x48UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_75 (0x49UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_76 (0x4AUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_77 (0x4BUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_78 (0x4CUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_79 (0x4DUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_80 (0x4EUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_81 (0x4FUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_82 (0x50UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_83 (0x51UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_84 (0x52UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_85 (0x53UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_86 (0x54UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_87 (0x55UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_88 (0x56UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_89 (0x57UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_90 (0x58UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_91 (0x59UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_92 (0x5AUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_93 (0x5BUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_94 (0x5CUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_95 (0x5DUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_96 (0x5EUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_97 (0x5FUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_98 (0x60UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_99 (0x61UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_100 (0x62UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_101 (0x63UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_102 (0x64UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_103 (0x65UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_104 (0x66UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_105 (0x67UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_106 (0x68UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_107 (0x69UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_108 (0x6AUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_109 (0x6BUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_110 (0x6CUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_111 (0x6DUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_112 (0x6EUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_113 (0x6FUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_114 (0x70UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_115 (0x71UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_116 (0x72UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_117 (0x73UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_118 (0x74UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_119 (0x75UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_120 (0x76UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_121 (0x77UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_122 (0x78UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_123 (0x79UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_124 (0x7AUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_125 (0x7BUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_126 (0x7CUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_127 (0x7DUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_128 (0x7EUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_129 (0x7FUL<<TIM_M3_DTR_TIM_POS) \ #define TIM_M3_DTR_TIM_130 (0x80UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_132 (0x81UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_134 (0x82UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_136 (0x83UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_138 (0x84UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_140 (0x85UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_142 (0x86UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_144 (0x87UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_146 (0x88UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_148 (0x89UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_150 (0x8AUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_152 (0x8BUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_154 (0x8CUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_156 (0x8DUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_158 (0x8EUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_160 (0x8FUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_162 (0x90UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_164 (0x91UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_166 (0x92UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_168 (0x93UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_170 (0x94UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_172 (0x95UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_174 (0x96UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_176 (0x97UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_178 (0x98UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_180 (0x99UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_182 (0x9AUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_184 (0x9BUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_186 (0x9CUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_188 (0x9DUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_190 (0x9EUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_192 (0x9FUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_194 (0xA0UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_196 (0xA1UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_198 (0xA2UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_200 (0xA3UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_202 (0xA4UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_204 (0xA5UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_206 (0xA6UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_208 (0xA8UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_210 (0xA9UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_212 (0xAAUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_214 (0xABUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_216 (0xACUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_218 (0xADUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_220 (0xAEUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_222 (0xAFUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_224 (0xB0UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_226 (0xB1UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_228 (0xB2UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_230 (0xB3UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_232 (0xB4UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_234 (0xB5UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_236 (0xB6UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_238 (0xB7UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_240 (0xB8UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_242 (0xB9UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_246 (0xBAUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_248 (0xBBUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_250 (0xBCUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_252 (0xBDUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_254 (0xBEUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_256 (0xBFUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_258 (0xC0UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_266 (0xC1UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_274 (0xC2UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_282 (0xC3UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_290 (0xC4UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_296 (0xC5UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_302 (0xC6UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_308 (0xC7UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_314 (0xC8UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_322 (0xC9UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_330 (0xCAUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_338 (0xCBUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_346 (0xCCUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_354 (0xCDUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_362 (0xCEUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_370 (0xCFUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_378 (0xD0UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_386 (0xD1UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_394 (0xD2UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_402 (0xD3UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_410 (0xD4UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_418 (0xD5UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_426 (0xD6UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_434 (0xD7UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_442 (0xD8UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_450 (0xD9UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_458 (0xDAUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_466 (0xDBUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_474 (0xDCUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_482 (0xDDUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_490 (0xDEUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_498 (0xDFUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_514 (0xE0UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_530 (0xE1UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_546 (0xE2UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_547 (0xE3UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_562 (0xE4UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_578 (0xE5UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_594 (0xE6UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_610 (0xE7UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_642 (0xE8UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_658 (0xE9UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_674 (0xEAUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_690 (0xEBUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_706 (0xECUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_722 (0xEDUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_738 (0xEEUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_754 (0xEFUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_770 (0xF0UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_786 (0xF1UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_802 (0xF2UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_818 (0xF3UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_834 (0xF4UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_850 (0xF5UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_866 (0xF6UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_882 (0xF7UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_898 (0xF8UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_914 (0xF9UL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_930 (0xFAUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_946 (0xFBUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_962 (0xFCUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_978 (0xFDUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_994 (0xFEUL<<TIM_M3_DTR_TIM_POS) #define TIM_M3_DTR_TIM_1010 (0xFFUL<<TIM_M3_DTR_TIM_POS) //===重复周期设置值 #define TIM_M3_RCR_RCR_POS 0 #define TIM_M3_RCR_RCR_MASK (0xFFUL<<TIM_M3_RCR_RCR_POS) #define TIM_M3_RCR_RCR TIM_M3_RCR_RCR_MASK //===通道0比较捕获寄存器 #define TIM_M3_CCR_CCR0A_POS 0 #define TIM_M3_CCR_CCR0A_MASK (0xFFFFUL<<TIM_M3_CCR_CCR0A_POS) #define TIM_M3_CCR_CCR0A TIM_M3_CCR_CCR0A_MASK #define TIM_M3_CCR_CCR0B_POS 0 #define TIM_M3_CCR_CCR0B_MASK (0xFFFFUL<<TIM_M3_CCR_CCR0A_POS) #define TIM_M3_CCR_CCR0B TIM_M3_CCR_CCR0B_MASK //===通道1比较捕获寄存器 #define TIM_M3_CCR_CCR1A_POS 0 #define TIM_M3_CCR_CCR1A_MASK (0xFFFFUL<<TIM_M3_CCR_CCR1A_POS) #define TIM_M3_CCR_CCR1A TIM_M3_CCR_CCR1A_MASK #define TIM_M3_CCR_CCR1B_POS 0 #define TIM_M3_CCR_CCR1B_MASK (0xFFFFUL<<TIM_M3_CCR_CCR1B_POS) #define TIM_M3_CCR_CCR1B TIM_M3_CCR_CCR1B_MASK //===通道2比较捕获寄存器 #define TIM_M3_CCR_CCR2A_POS 0 #define TIM_M3_CCR_CCR2A_MASK (0xFFFFUL<<TIM_M3_CCR_CCR2A_POS) #define TIM_M3_CCR_CCR2A TIM_M3_CCR_CCR2A_MASK #define TIM_M3_CCR_CCR2B_POS 0 #define TIM_M3_CCR_CCR2B_MASK (0xFFFFUL<<TIM_M3_CCR_CCR2B_POS) #define TIM_M3_CCR_CCR2B TIM_M3_CCR_CCR2B_MASK #pragma endregion #pragma endregion #pragma region TIMP //===高级定时器 typedef struct { __IO uint32_t CNTER; //---重载寄存器 __IO uint32_t PERAR; //---16位模式计数寄存器 __IO uint32_t PERBR; //---32位模式计数寄存器 uint32_t RESERVED1; //---保留字节 __IO uint32_t GCMAR; //---控制寄存器 __IO uint32_t GCMBR; //---中断标志 __IO uint32_t GCMCR; //---中断标志清除 __IO uint32_t GCMDR; //---中断标志 uint32_t RESERVED2[2]; //---保留字节 __IO uint32_t SCMAR; //---主从模式控制 __IO uint32_t SCMBR; //---滤波控制 uint32_t RESERVED3[4]; //---保留字节 __IO uint32_t DTUAR; //---ADC触发控制 __IO uint32_t DTDAR; //---比较单元0控制寄存器 uint32_t RESERVED4[2]; //---保留字节 __IO uint32_t GCONR; //---比较单元1控制寄存器 __IO uint32_t ICONR; //---比较单元2控制寄存器 __IO uint32_t PCONR; //---死区寄存器 __IO uint32_t BCONR; //---重复计数寄存器 __IO uint32_t DCONT; //---控制寄存器1 __IO uint32_t FCONR; //---比较0A寄存器 __IO uint32_t VPERR; //---比较0B寄存器 __IO uint32_t STFLR; //---比较1A寄存器 __IO uint32_t HSTAR; //---比较1B寄存器 __IO uint32_t HSTPR; //---比较2A寄存器 __IO uint32_t HCELR; //---比较2B寄存器 __IO uint32_t HCPAR; //---比较0A寄存器 __IO uint32_t HCPBR; //---比较0B寄存器 __IO uint32_t HCUPR; //---比较1A寄存器 __IO uint32_t HCDOR; //---比较1B寄存器 uint32_t RESERVED5[28]; //---保留字节 __IO uint32_t SR; //---比较2A寄存器 __IO uint32_t CSR; //---比较2B寄存器 __IO uint32_t CR; //---比较2B寄存器 uint32_t RESERVED6; //---保留字节 __IO uint32_t AOSSR; //---比较1B寄存器 __IO uint32_t AOSCL; //---比较2A寄存器 __IO uint32_t PTBKS; //---比较2B寄存器 __IO uint32_t TTRIG; //---比较0A寄存器 __IO uint32_t ITRIG; //---比较0B寄存器 __IO uint32_t PTBKP; //---比较1A寄存器 uint32_t RESERVED7[179]; //---保留字节 __IO uint32_t SSTAR; //---比较1B寄存器 __IO uint32_t SSTPR; //---比较2A寄存器 __IO uint32_t SCLRR; //---比较2B寄存器 } TIMP_TypeDef; #pragma endregion #pragma region LPTIM //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CNT; //---控制寄存器1 __IO uint32_t ARR; //---控制寄存器1 uint32_t RESERVED; //---保留字节 __IO uint32_t CR; //---控制寄存器1 __IO uint32_t SR; //---控制寄存器1 __IO uint32_t CSR; //---控制寄存器1 } LPTIM_TypeDef; #define LPTIM_ARR_ARR_POS 0 #define LPTIM_ARR_ARR_MASK (0xFFFFUL<<LPTIM_ARR_ARR_POS) #define LPTIM_ARR_ARR LPTIM_ARR_ARR_MASK #define LPTIM_CNT_CNT_POS 0 #define LPTIM_CNT_CNT_MASK (0xFFFFUL<<LPTIM_CNT_CNT_POS) #define LPTIM_CNT_CNT LPTIM_CNT_CNT_MASK //===低功耗定时器控制模式 #define LPTIM_CR_PRS_POS 11 #define LPTIM_CR_PRS_MASK (0x07UL<<LPTIM_CR_PRS_POS) #define LPTIM_CR_PRS LPTIM_CR_PRS_MASK #define LPTIM_CR_PRS_1 (0x00UL<<LPTIM_CR_PRS_POS) #define LPTIM_CR_PRS_2 (0x01UL<<LPTIM_CR_PRS_POS) #define LPTIM_CR_PRS_4 (0x02UL<<LPTIM_CR_PRS_POS) #define LPTIM_CR_PRS_8 (0x03UL<<LPTIM_CR_PRS_POS) #define LPTIM_CR_PRS_16 (0x04UL<<LPTIM_CR_PRS_POS) #define LPTIM_CR_PRS_32 (0x05UL<<LPTIM_CR_PRS_POS) #define LPTIM_CR_PRS_64 (0x06UL<<LPTIM_CR_PRS_POS) #define LPTIM_CR_PRS_256 (0x07UL<<LPTIM_CR_PRS_POS) //===中断使能控制 #define LPTIM_CR_IE_POS 10 #define LPTIM_CR_IE_MASK (0x01UL<<LPTIM_CR_IE_POS) #define LPTIM_CR_IE LPTIM_CR_IE_MASK //===门控端口极性 #define LPTIM_CR_GATEP_POS 9 #define LPTIM_CR_GATEP_MASK (0x01UL<<LPTIM_CR_GATEP_POS) #define LPTIM_CR_GATEP LPTIM_CR_GATEP_MASK //===定时器门控使能 #define LPTIM_CR_GATEN_POS 8 #define LPTIM_CR_GATEN_MASK (0x01UL<<LPTIM_CR_GATEN_POS) #define LPTIM_CR_GATEN LPTIM_CR_GATEN_MASK //===同步标志 #define LPTIM_CR_WT_FLAG_POS 7 #define LPTIM_CR_WT_FLAG_MASK (0x01UL<<LPTIM_CR_WT_FLAG_POS) #define LPTIM_CR_WT_FLAG LPTIM_CR_WT_FLAG_MASK //===时钟选择 #define LPTIM_CR_TCK_SEL_POS 4 #define LPTIM_CR_TCK_SEL_MASK (0x03UL<<LPTIM_CR_TCK_SEL_POS) #define LPTIM_CR_TCK_SEL LPTIM_CR_TCK_SEL_MASK #define LPTIM_CR_TCK_SEL_PCLK (0x00UL<<LPTIM_CR_TCK_SEL_POS) #define LPTIM_CR_TCK_SEL_XTL (0x02UL<<LPTIM_CR_TCK_SEL_POS) #define LPTIM_CR_TCK_SEL_RCL (0x03UL<<LPTIM_CR_TCK_SEL_POS) //===TOG使能控制 #define LPTIM_CR_TOGEN_POS 3 #define LPTIM_CR_TOGEN_MASK (0x01UL<<LPTIM_CR_TOGEN_POS) #define LPTIM_CR_TOGEN LPTIM_CR_TOGEN_MASK //===定时/计数模式选择 #define LPTIM_CR_CT_POS 2 #define LPTIM_CR_CT_MASK (0x01UL<<LPTIM_CR_CT_POS) #define LPTIM_CR_CT LPTIM_CR_CT_MASK //===自由/自动重载模式选择 #define LPTIM_CR_MD_POS 1 #define LPTIM_CR_MD_MASK (0x01UL<<LPTIM_CR_MD_POS) #define LPTIM_CR_MD LPTIM_CR_MD_MASK //===定时器使能 #define LPTIM_CR_EN_POS 0 #define LPTIM_CR_EN_MASK (0x01UL<<LPTIM_CR_EN_POS) #define LPTIM_CR_EN LPTIM_CR_EN_MASK //===中断标志寄存器 #define LPTIM_SR_IE_POS 0 #define LPTIM_SR_IE_MASK (0x01U<<LPTIM_SR_IE_POS) #define LPTIM_SR_IE LPTIM_SR_IE_MASK //===中断标志清除寄存器 #define LPTIM_CSR_IE_POS 0 #define LPTIM_CSR_IE_MASK (0x01U<<LPTIM_SR_IE_POS) #define LPTIM_CSR_IE LPTIM_SR_IE_MASK #pragma endregion #pragma region TRIM //===时钟校准模块 typedef struct { __IO uint32_t CR; //---配置寄存器 __IO uint32_t REFCON; //---参考计数器初值配置寄存器 __IO uint32_t REFCNT; //---参考计数器值 __IO uint32_t CALCNT; //---校准计数器值 __IO uint32_t SR; //---中断标志位寄存器 __IO uint32_t CSR; //---中断标志位清除计数器 __IO uint32_t CALCON; //---校准计数器溢出值配置寄存器 } TRIM_TypeDef; //===待校准/监测时钟选择高位寄存器 #define TRIM_CR_CALCLK_H_POS 8 #define TRIM_CR_CALCLK_H_MASK (0x01UL<<TRIM_CR_CALCLK_H_POS) #define TRIM_CR_CALCLK_H TRIM_CR_CALCLK_H_MASK #define TRIM_CR_CALCLK_L_POS 4 #define TRIM_CR_CALCLK_L_MASK (0x03UL<<TRIM_CR_CALCLK_L_POS) #define TRIM_CR_CALCLK_L TRIM_CR_CALCLK_L_MASK //===校准时钟选择 #define TRIM_CR_CALCLK_MASK ((0x01UL<<TRIM_CR_CALCLK_H_POS)|(0x03UL<<TRIM_CR_CALCLK_L_POS)) #define TRIM_CR_CALCLK_RCH ((0x00UL<<TRIM_CR_CALCLK_H_POS)|(0x00UL<<TRIM_CR_CALCLK_L_POS)) #define TRIM_CR_CALCLK_XTH ((0x00UL<<TRIM_CR_CALCLK_H_POS)|(0x01UL<<TRIM_CR_CALCLK_L_POS)) #define TRIM_CR_CALCLK_RCL ((0x00UL<<TRIM_CR_CALCLK_H_POS)|(0x02UL<<TRIM_CR_CALCLK_L_POS)) #define TRIM_CR_CALCLK_XTL ((0x00UL<<TRIM_CR_CALCLK_H_POS)|(0x03UL<<TRIM_CR_CALCLK_L_POS)) #define TRIM_CR_CALCLK_PLL ((0x01UL<<TRIM_CR_CALCLK_H_POS)|(0x00UL<<TRIM_CR_CALCLK_L_POS)) //===校准中断使能位 #define TRIM_CR_IE_POS 7 #define TRIM_CR_IE_MASK (0x01UL<<TRIM_CR_IE_POS) #define TRIM_CR_IE TRIM_CR_IE_MASK //===监测模式使能位 #define TRIM_CR_EN_POS 6 #define TRIM_CR_EN_MASK (0x01UL<<TRIM_CR_EN_POS) #define TRIM_CR_EN TRIM_CR_EN_MASK //===参考时钟选择 #define TRIM_CR_REFCLK_POS 1 #define TRIM_CR_REFCLK_MASK (0x07UL<<TRIM_CR_REFCLK_POS) #define TRIM_CR_REFCLK TRIM_CR_REFCLK_MASK #define TRIM_CR_REFCLK_RCH (0x00UL<<TRIM_CR_REFCLK_POS) #define TRIM_CR_REFCLK_XTH (0x01UL<<TRIM_CR_REFCLK_POS) #define TRIM_CR_REFCLK_RCL (0x02UL<<TRIM_CR_REFCLK_POS) #define TRIM_CR_REFCLK_XTL (0x03UL<<TRIM_CR_REFCLK_POS) #define TRIM_CR_REFCLK_IRC10K (0x04UL<<TRIM_CR_REFCLK_POS) #define TRIM_CR_REFCLK_EXCLK (0x05UL<<TRIM_CR_REFCLK_POS) //===校准/监测开始寄存器 #define TRIM_CR_START_POS 0 #define TRIM_CR_START_MASK (0x01UL<<TRIM_CR_START_POS) #define TRIM_CR_START TRIM_CR_START_MASK //===PLL失效标注 #define TRIM_SR_PLL_POS 4 #define TRIM_SR_PLL_MASK (0x01UL<<TRIM_SR_PLL_POS) #define TRIM_SR_PLL TRIM_SR_PLL_MASK //===XTH失效标志 #define TRIM_SR_XTH_POS 3 #define TRIM_SR_XTH_MASK (0x01UL<<TRIM_SR_XTH_POS) #define TRIM_SR_XTH TRIM_SR_XTH_MASK //===XTL失效标志 #define TRIM_SR_XTL_POS 2 #define TRIM_SR_XTL_MASK (0x01UL<<TRIM_SR_XTL_POS) #define TRIM_SR_XTL TRIM_SR_XTL_MASK //===校准溢出标志 #define TRIM_SR_CALOF_POS 1 #define TRIM_SR_CALOF_MASK (0x01UL<<TRIM_SR_CALOF_POS) #define TRIM_SR_CALOF TRIM_SR_CALOF_MASK //===参考计数器停止标志 #define TRIM_SR_REFSTOP_POS 0 #define TRIM_SR_REFSTOP_MASK (0x01UL<<TRIM_SR_REFSTOP_POS) #define TRIM_SR_REFSTOP TRIM_SR_REFSTOP_MASK //===清除PLL失效标注 #define TRIM_CSR_PLL_POS 4 #define TRIM_CSR_PLL_MASK (0x01UL<<TRIM_CSR_PLL_POS) #define TRIM_CSR_PLL TRIM_CSR_PLL_MASK //===清除XTH失效标志 #define TRIM_CSR_XTH_POS 3 #define TRIM_CSR_XTH_MASK (0x01UL<<TRIM_CSR_XTH_POS) #define TRIM_CSR_XTH TRIM_CSR_XTH_MASK //===清除XTL失效标志 #define TRIM_CSR_XTL_POS 2 #define TRIM_CSR_XTL_MASK (0x01UL<<TRIM_CSR_XTL_POS) #define TRIM_CSR_XTL TRIM_CSR_XTL_MASK #pragma endregion #pragma region OPA //===运算放大器 typedef struct { __IO uint32_t CR; //---配置寄存器 } OPA_TypeDef; #define OPA_CR_CH4_EN_POS 6 #define OPA_CR_CH4_EN_MASK (0x01UL<<OPA_CR_CH4_EN_POS) #define OPA_CR_CH4_EN OPA_CR_CH4_EN_MASK #define OPA_CR_CH3_EN_POS 5 #define OPA_CR_CH3_EN_MASK (0x01UL<<OPA_CR_CH3_EN_POS) #define OPA_CR_CH3_EN OPA_CR_CH3_EN_MASK #define OPA_CR_CH2_EN_POS 4 #define OPA_CR_CH2_EN_MASK (0x01UL<<OPA_CR_CH2_EN_POS) #define OPA_CR_CH2_EN OPA_CR_CH2_EN_MASK #define OPA_CR_CH1_EN_POS 3 #define OPA_CR_CH1_EN_MASK (0x01UL<<OPA_CR_CH1_EN_POS) #define OPA_CR_CH1_EN OPA_CR_CH1_EN_MASK #define OPA_CR_BUFFER_EN_POS 2 #define OPA_CR_BUFFER_EN_MASK (0x01UL<<OPA_CR_BUFFER_EN_POS) #define OPA_CR_BUFFER_EN OPA_CR_BUFFER_EN_MASK #define OPA_CR_EN_POS 0 #define OPA_CR_EN_MASK (0x01UL<<OPA_CR_EN_POS) #define OPA_CR_EN OPA_CR_EN_MASK #pragma endregion #pragma region PCA //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CCON; //---控制寄存器1 __IO uint32_t CMOD; //---控制寄存器1 __IO uint32_t CNT; //---控制寄存器1 __IO uint32_t CSR; //---控制寄存器1 __IO uint32_t CCAPM0; //---控制寄存器1 __IO uint32_t CCAPM1; //---控制寄存器1 __IO uint32_t CCAPM2; //---控制寄存器1 __IO uint32_t CCAPM3; //---控制寄存器1 __IO uint32_t CCAPM4; //---控制寄存器1 __IO uint32_t CCAP0H; //---控制寄存器1 __IO uint32_t CCAP0L; //---控制寄存器1 __IO uint32_t CCAP1H; //---控制寄存器1 __IO uint32_t CCAP1L; //---控制寄存器1 __IO uint32_t CCAP2H; //---控制寄存器1 __IO uint32_t CCAP2L; //---控制寄存器1 __IO uint32_t CCAP3H; //---控制寄存器1 __IO uint32_t CCAP3L; //---控制寄存器1 __IO uint32_t CCAP4H; //---控制寄存器1 __IO uint32_t CCAP4L; //---控制寄存器1 __IO uint32_t CCAPO; //---控制寄存器1 __IO uint32_t CCAP0; //---控制寄存器1 __IO uint32_t CCAP1; //---控制寄存器1 __IO uint32_t CCAP2; //---控制寄存器1 __IO uint32_t CCAP3; //---控制寄存器1 __IO uint32_t CCAP4; //---控制寄存器1 __IO uint32_t CARR; //---控制寄存器1 __IO uint32_t EPWM; //---控制寄存器1 } PCA_TypeDef; #pragma endregion #pragma region WDT //===端口通用功能配置寄存器 typedef struct { __IO uint32_t RST; //---控制寄存器1 __IO uint32_t CON; //---控制寄存器1 } WDT_TypeDef; //===端口通用功能配置寄存器 typedef struct { __IO uint32_t RST; //---控制寄存器1 __IO uint32_t CON; //---控制寄存器1 } IWDG_TypeDef; //===WDT中断标志 #define IWDG_CON_INT_FLAG_POS 7 #define IWDG_CON_INT_FLAG_MASK (0x01UL<<IWDG_CON_INT_FLAG_POS) #define IWDG_CON_INT_FLAG IWDG_CON_INT_FLAG_MASK //===WDT溢出后的工作配置 #define IWDG_CON_INT_EN_POS 5 #define IWDG_CON_INT_EN_MASK (0x01UL<<IWDG_CON_INT_EN_POS) #define IWDG_CON_INT_EN IWDG_CON_INT_EN_MASK //===WDT运行标志 #define IWDG_CON_READY_POS 4 #define IWDG_CON_READY_MASK (0x01UL<<IWDG_CON_READY_POS) #define IWDG_CON_READY IWDG_CON_READY_MASK //===WDT定时器的溢出时间配置 #define IWDG_CON_WOV_POS 0 #define IWDG_CON_WOV_MASK (0x0FUL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV IWDG_CON_WOV_MASK //===看门狗溢出时间 #define IWDG_CON_WOV_MS_1P6 (0x00UL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_3P2 (0x01UL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_6P4 (0x02UL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_13 (0x03UL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_26 (0x04UL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_51 (0x05UL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_102 (0x06UL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_205 (0x07UL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_500 (0x08UL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_820 (0x09UL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_1640 (0x0AUL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_3280 (0x0BUL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_6550 (0x0CUL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_13100 (0x0DUL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_26200 (0x0EUL<<IWDG_CON_WOV_POS) #define IWDG_CON_WOV_MS_52400 (0x0FUL<<IWDG_CON_WOV_POS) #pragma endregion #pragma region ADC //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR0; //---控制寄存器1 __IO uint32_t CR1; //---控制寄存器1 08 uint32_t RESERVED1[13]; //---保留字节 __IO uint32_t SQR[3]; //---顺序扫描转换通道配置寄存器 __IO uint32_t JQR; //---插队扫描转换通道配置寄存器 __IO uint32_t SQRDR[16]; //---顺序扫描装换结果配置寄存器 __IO uint32_t JQRDR[4]; //---插队扫描装换结果配置寄存器 __I uint32_t DR; //---转换结果 __I uint32_t DRACC; //---转换累加结果 __IO uint32_t HT; //---比较上阈值 __IO uint32_t LT; //---比较下阈值 __IO uint32_t SR; //---标志寄存器 __IO uint32_t CSR; //---清除标志寄存器 __IO uint32_t EXTRIG0; //---外部触发源0 __IO uint32_t EXTRIG1; //---外部触发源1 __IO uint32_t SGLSTART; //---单次转换开始 __IO uint32_t SQRSTART; //---顺序转换开始 __IO uint32_t JQRSTART; //---插队转换开始 __IO uint32_t ALLSTART; //---全部转换开始 } ADC_TypeDef; //===配置寄存器0 #define ADC_CR0_IE_POS 15 #define ADC_CR0_IE_MASK (0x01UL<<ADC_CR0_IE_POS) #define ADC_CR0_IE ADC_CR0_IE_MASK #define ADC_CR0_INREF_POS 14 #define ADC_CR0_INREF_MASK (0x01UL<<ADC_CR0_INREF_POS) #define ADC_CR0_INREF ADC_CR0_INREF_MASK #define ADC_CR0_SAM_POS 12 #define ADC_CR0_SAM_MASK (0x03UL<<ADC_CR0_SAM_POS) #define ADC_CR0_SAM ADC_CR0_SAM_MASK #define ADC_CR0_SAM_CYCLE_4 (0x00UL<<ADC_CR0_SAM_POS) #define ADC_CR0_SAM_CYCLE_6 (0x01UL<<ADC_CR0_SAM_POS) #define ADC_CR0_SAM_CYCLE_8 (0x02UL<<ADC_CR0_SAM_POS) #define ADC_CR0_SAM_CYCLE_12 (0x03UL<<ADC_CR0_SAM_POS) #define ADC_CR0_BUFFER_POS 11 #define ADC_CR0_BUFFER_MASK (0x01UL<<ADC_CR0_BUFFER_POS) #define ADC_CR0_BUFFER ADC_CR0_BUFFER_MASK #define ADC_CR0_REF_POS 9 #define ADC_CR0_REF_MASK (0x03UL<<ADC_CR0_REF_POS) #define ADC_CR0_REF ADC_CR0_REF_MASK #define ADC_CR0_REF_IN1P5 (0x00UL<<ADC_CR0_REF_POS) #define ADC_CR0_REF_IN2P5 (0x01UL<<ADC_CR0_REF_POS) #define ADC_CR0_REF_EXREF (0x02UL<<ADC_CR0_REF_POS) #define ADC_CR0_REF_AVCC (0x03UL<<ADC_CR0_REF_POS) #define ADC_CR0_CH_POS 4 #define ADC_CR0_CH_MASK (0x1FUL<<ADC_CR0_CH_POS) #define ADC_CR0_CH ADC_CR0_CH_MASK #define ADC_CR0_CH_AIN0 (0x00UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN1 (0x01UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN2 (0x02UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN3 (0x03UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN4 (0x04UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN5 (0x05UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN6 (0x06UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN7 (0x07UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN8 (0x08UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN9 (0x09UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN10 (0x0AUL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN11 (0x0BUL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN12 (0x0CUL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN13 (0x0DUL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN14 (0x0EUL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN15 (0x0FUL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN16 (0x10UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN17 (0x11UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN18 (0x12UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN19 (0x13UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN20 (0x14UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN21 (0x15UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN22 (0x16UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN23 (0x17UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN24 (0x18UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AIN25 (0x19UL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_DAC (0x1AUL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_AVCC_P3 (0x1BUL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_TEMP (0x1CUL<<ADC_CR0_CH_POS) #define ADC_CR0_CH_IN1P2 (0x1DUL<<ADC_CR0_CH_POS) #define ADC_CR0_CLK_POS 2 #define ADC_CR0_CLK_MASK (0x03UL<<ADC_CR0_CLK_POS) #define ADC_CR0_CLK ADC_CR0_CLK_MASK #define ADC_CR0_CLK_DIV1 (0x00UL<<ADC_CR0_CLK_POS) #define ADC_CR0_CLK_DIV2 (0x01UL<<ADC_CR0_CLK_POS) #define ADC_CR0_CLK_DIV4 (0x02UL<<ADC_CR0_CLK_POS) #define ADC_CR0_CLK_DIV8 (0x03UL<<ADC_CR0_CLK_POS) #define ADC_CR0_EN_POS 0 #define ADC_CR0_EN_MASK (0x01UL<<ADC_CR0_EN_POS) #define ADC_CR0_EN ADC_CR0_EN_MASK //===配置寄存器1 #define ADC_CR1_ACC_CLR_POS 15 #define ADC_CR1_ACC_CLR_MASK (0x01UL<<ADC_CR1_ACC_CLR_POS) #define ADC_CR1_ACC_CLR ADC_CR1_ACC_CLR_MASK #define ADC_CR1_REG_CMP_POS 14 #define ADC_CR1_REG_CMP_MASK (0x01UL<<ADC_CR1_REG_CMP_POS) #define ADC_CR1_REG_CMP ADC_CR1_REG_CMP_MASK #define ADC_CR1_HT_CMP_POS 13 #define ADC_CR1_HT_CMP_MASK (0x01UL<<ADC_CR1_HT_CMP_POS) #define ADC_CR1_HT_CMP ADC_CR1_HT_CMP_MASK #define ADC_CR1_LT_CMP_POS 12 #define ADC_CR1_LT_CMP_MASK (0x01UL<<ADC_CR1_LT_CMP_POS) #define ADC_CR1_LT_CMP ADC_CR1_LT_CMP_MASK #define ADC_CR1_ACC_EN_POS 11 #define ADC_CR1_ACC_EN_MASK (0x01UL<<ADC_CR1_ACC_EN_POS) #define ADC_CR1_ACC_EN ADC_CR1_ACC_EN_MASK #define ADC_CR1_MODE_POS 10 #define ADC_CR1_MODE_MASK (0x01UL<<ADC_CR1_MODE_POS) #define ADC_CR1_MODE ADC_CR1_MODE_MASK #define ADC_CR1_DMA_JQR_POS 9 #define ADC_CR1_DMA_JQR_MASK (0x01UL<<ADC_CR1_DMA_JQR_POS) #define ADC_CR1_DMA_JQR ADC_CR1_DMA_JQR_MASK #define ADC_CR1_DMA_SQR_POS 8 #define ADC_CR1_DMA_SQR_MASK (0x01UL<<ADC_CR1_DMA_SQR_POS) #define ADC_CR1_DMA_SQR ADC_CR1_DMA_SQR_MASK #define ADC_CR1_TH_CH_POS 3 #define ADC_CR1_TH_CH_MASK (0x1FUL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH ADC_CR1_TH_CH_MASK #define ADC_CR1_TH_CH_AIN0 (0x00UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN1 (0x01UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN2 (0x02UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN3 (0x03UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN4 (0x04UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN5 (0x05UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN6 (0x06UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN7 (0x07UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN8 (0x08UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN9 (0x09UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN10 (0x0AUL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN11 (0x0BUL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN12 (0x0CUL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN13 (0x0DUL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN14 (0x0EUL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN15 (0x0FUL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN16 (0x10UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN17 (0x11UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN18 (0x12UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN19 (0x13UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN20 (0x14UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN21 (0x15UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN22 (0x16UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN23 (0x17UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN24 (0x18UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN25 (0x19UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN26 (0x11UL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN27 (0x1BUL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN28 (0x1CUL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_TH_CH_AIN29 (0x1DUL<<ADC_CR1_TH_CH_POS) #define ADC_CR1_ALIGN_POS 2 #define ADC_CR1_ALIGN_MASK (0x01UL<<ADC_CR1_ALIGN_POS) #define ADC_CR1_ALIGN ADC_CR1_ALIGN_MASK //===转换通道配置寄存器 #define ADC_SQR_MUX0_MASK (0x1FUL<<0) #define ADC_SQR_MUX0_POS 0 #define ADC_SQR_MUX1_MASK (0x1FUL<<5) #define ADC_SQR_MUX1_POS 5 #define ADC_SQR_MUX2_MASK (0x1FUL<<10) #define ADC_SQR_MUX2_POS 10 #define ADC_SQR_MUX3_MASK (0x1FUL<<15) #define ADC_SQR_MUX3_POS 15 #define ADC_SQR_MUX4_MASK (0x1FUL<<20) #define ADC_SQR_MUX4_POS 20 #define ADC_SQR_MUX5_MASK (0x1FUL<<25) #define ADC_SQR_MUX5_POS 25 #define ADC_SQR_CNT_MASK (0x0FUL<<20) #define ADC_SQR_CNT_POS 20 #define ADC_JQR_MUX0_MASK (0x1FUL<<0) #define ADC_JQR_MUX0_POS 0 #define ADC_JQR_MUX1_MASK (0x1FUL<<5) #define ADC_JQR_MUX1_POS 5 #define ADC_JQR_MUX2_MASK (0x1FUL<<10) #define ADC_JQR_MUX2_POS 10 #define ADC_JQR_MUX3_MASK (0x1FUL<<15) #define ADC_JQR_MUX3_POS 15 #define ADC_JQR_CNT_MASK (0x03UL<<20) #define ADC_JQR_CNT_POS 20 //===ADC转换结果 #define ADC_DR_MASK (0x0FFFUL<<0) #define ADC_DR_ACC_MASK (0xFFFFFUL<<0) //===ADC上下阈值 #define ADC_DR_HT_MASK (0x0FFFUL<<0) #define ADC_DR_LT_ACC_MASK (0x0FFFUL<<0) //===中断标志 #define ADC_SR_JQR_POS 5 #define ADC_SR_JQR_MASK (0x01UL<<ADC_SR_JQR_POS) #define ADC_SR_JQR ADC_SR_JQR_MASK #define ADC_SR_SQR_POS 4 #define ADC_SR_SQR_MASK (0x01UL<<ADC_SR_SQR_POS) #define ADC_SR_SQR ADC_SR_SQR_MASK #define ADC_SR_CMP_POS 3 #define ADC_SR_CMP_MASK (0x01UL<<ADC_SR_CMP_POS) #define ADC_SR_CMP ADC_SR_CMP_MASK #define ADC_SR_HT_POS 2 #define ADC_SR_HT_MASK (0x01UL<<ADC_SR_HT_POS) #define ADC_SR_HT ADC_SR_HT_MASK #define ADC_SR_LT_POS 1 #define ADC_SR_LT_MASK (0x01UL<<ADC_SR_LT_POS) #define ADC_SR_LT ADC_SR_LT_MASK #define ADC_SR_SGL_POS 0 #define ADC_SR_SGL_MASK (0x01UL<<ADC_SR_SGL_POS) #define ADC_SR_SGL ADC_SR_SGL_MASK //===清除中断标志 #define ADC_CSR_JQR_POS 5 #define ADC_CSR_JQR_MASK (0x01UL<<ADC_CSR_JQR_POS) #define ADC_CSR_JQR ADC_CSR_JQR_MASK #define ADC_CSR_SQR_POS 4 #define ADC_CSR_SQR_MASK (0x01UL<<ADC_CSR_SQR_POS) #define ADC_CSR_SQR ADC_CSR_SQR_MASK #define ADC_CSR_CMP_POS 3 #define ADC_CSR_CMP_MASK (0x01UL<<ADC_CSR_CMP_POS) #define ADC_CSR_CMP ADC_CSR_CMP_MASK #define ADC_CSR_HT_POS 2 #define ADC_CSR_HT_MASK (0x01UL<<ADC_CSR_HT_POS) #define ADC_CSR_HT ADC_CSR_HT_MASK #define ADC_CSR_LT_POS 1 #define ADC_CSR_LT_MASK (0x01UL<<ADC_CSR_LT_POS) #define ADC_CSR_LT ADC_CSR_LT_MASK #define ADC_CSR_SGL_POS 0 #define ADC_CSR_SGL_MASK (0x01UL<<ADC_CSR_SGL_POS) #define ADC_CSR_SGL ADC_CSR_SGL_MASK //===单次转换启动 #define ADC_SGL_START_POS 0 #define ADC_SGL_START_MASK (0x01UL<<ADC_SGL_START_POS) #define ADC_SGL_START ADC_SGL_START_MASK //===顺序转换启动 #define ADC_SQR_START_POS 0 #define ADC_SQR_START_MASK (0x01UL<<ADC_SQR_START_POS) #define ADC_SQR_START ADC_SQR_START_MASK //===插队转换启动 #define ADC_JQR_START_POS 0 #define ADC_JQR_START_MASK (0x01UL<<ADC_JQR_START_POS) #define ADC_JQR_START ADC_JQR_START_MASK //===全部转换启动 #define ADC_ALL_START_POS 0 #define ADC_ALL_START_MASK (0x01UL<<ADC_ALL_START_POS) #define ADC_ALL_START ADC_ALL_START_MASK #pragma endregion #pragma region VC //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR; //---控制寄存器1 __IO uint32_t CR0; //---控制寄存器1 __IO uint32_t CR1; //---控制寄存器1 __IO uint32_t OUT0; //---控制寄存器1 __IO uint32_t OUT1; //---控制寄存器1 __IO uint32_t SR; //---控制寄存器1 uint32_t RESERVED[75]; //---保留字节 __IO uint32_t CR2; //---控制寄存器1 __IO uint32_t OUT2; //---控制寄存器1 } VC_TypeDef; #pragma endregion #pragma region BGR //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR; //---配置寄存器 } BGR_TypeDef; //===内部温度传感器使能控制 #define BGR_TS_EN_POS 1 #define BGR_TS_EN_MASK (0x01UL<<BGR_TS_EN_POS) #define BGR_TS_EN BGR_TS_EN_MASK //===BGA使能控制 #define BGR_CR_EN_POS 0 #define BGR_CR_EN_MASK (0x01UL<<BGR_CR_EN_POS) #define BGR_CR_EN BGR_CR_EN_MASK #pragma endregion #pragma region PCNT //===端口通用功能配置寄存器 typedef struct { __IO uint32_t RUN; //---控制寄存器1 __IO uint32_t CTRL; //---控制寄存器1 __IO uint32_t FLT; //---控制寄存器1 __IO uint32_t TOCR; //---控制寄存器1 __IO uint32_t CMD; //---控制寄存器1 __IO uint32_t SR1; //---控制寄存器1 __IO uint32_t CNT; //---控制寄存器1 __IO uint32_t TOP; //---控制寄存器1 __IO uint32_t BUF; //---控制寄存器1 __IO uint32_t SR; //---控制寄存器1 __IO uint32_t CSR; //---控制寄存器1 __IO uint32_t IEN; //---控制寄存器1 __IO uint32_t SR2; //---控制寄存器1 __IO uint32_t DBG; //---控制寄存器1 } PCNT_TypeDef; #pragma endregion #pragma region LCD //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR0; //---控制寄存器1 __IO uint32_t CR1; //---控制寄存器1 __IO uint32_t CSR; //---控制寄存器1 __IO uint32_t P0EN0; //---控制寄存器1 __IO uint32_t P0EN1; //---控制寄存器1 10 uint32_t RESERVED2[11]; //---保留字节 14 18 1C 20 24 28 2C 30 34 38 3C __IO uint32_t RAM0; //---控制寄存器1 __IO uint32_t RAM1; //---控制寄存器1 __IO uint32_t RAM2; //---控制寄存器1 __IO uint32_t RAM3; //---控制寄存器1 __IO uint32_t RAM4; //---控制寄存器1 __IO uint32_t RAM5; //---控制寄存器1 __IO uint32_t RAM6; //---控制寄存器1 __IO uint32_t RAM7; //---控制寄存器1 __IO uint32_t RAM8; //---控制寄存器1 __IO uint32_t RAM9; //---控制寄存器1 __IO uint32_t RAMA; //---控制寄存器1 __IO uint32_t RAMB; //---控制寄存器1 __IO uint32_t RAMC; //---控制寄存器1 __IO uint32_t RAMD; //---控制寄存器1 __IO uint32_t RAME; //---控制寄存器1 __IO uint32_t RAMF; //---控制寄存器1 } LCD_TypeDef; #pragma endregion #pragma region AES //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR; //---控制寄存器 0x00 uint32_t RESERVED[3]; //---保留字节 04 08 0C __IO uint32_t DR[4]; //---数据寄存器 10 14 18 1C __IO uint32_t KEY[8]; //---秘钥寄存器 20 24 28 2C 30 34 38 3C } AES_TypeDef; #define AES_CR_KEYSIZE_POS 3 #define AES_CR_KEYSIZE_MASK (0x03UL<<AES_CR_KEYSIZE_POS) #define AES_CR_KEYSIZE AES_CR_KEYSIZE_MASK #define AES_CR_KEYSIZE_128 (0x00UL<<AES_CR_KEYSIZE_POS) #define AES_CR_KEYSIZE_192 (0x01UL<<AES_CR_KEYSIZE_POS) #define AES_CR_KEYSIZE_256 (0x02UL<<AES_CR_KEYSIZE_POS) #define AES_CR_MODE_POS 1 #define AES_CR_MODE_MASK (0x01UL<<AES_CR_MODE_POS) #define AES_CR_MODE AES_CR_MODE_MASK #define AES_CR_START_POS 0 #define AES_CR_START_MASK (0x01UL<<AES_CR_START_POS) #define AES_CR_START AES_CR_START_MASK #define AES_DR_DATA_POS 0 #define AES_DR_DATA_MASK (0xFFFFFFFFUL<<AES_DR_DATA_POS) #define AES_DR_DATA AES_DR_DATA_MASK #define AES_KEY_KEY_POS 0 #define AES_KEY_KEY_MASK (0xFFFFFFFFUL<<AES_KEY_KEY_POS) #define AES_KEY_KEY AES_KEY_KEY_MASK #pragma endregion #pragma region DAC //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR; //---控制寄存器1 __IO uint32_t SWTR; //---控制寄存器1 __IO uint32_t DHR12R0; //---控制寄存器1 __IO uint32_t DHR12L0; //---控制寄存器1 __IO uint32_t DHR8R0; //---控制寄存器1 10 1C 18 1C 20 24 28 uint32_t RESERVED1[6]; //---保留字节 2C __IO uint32_t DOR; //---控制寄存器1 uint32_t RESERVED2; //---保留字节 __IO uint32_t SR; //---控制寄存器1 __IO uint32_t ETRS; //---控制寄存器1 } DAC_TypeDef; //===DAC参考电压选择 #define DAC_CR_SREF_POS 14 #define DAC_CR_SREF_MASK (0x03UL<<DAC_CR_SREF_POS) #define DAC_CR_SREF DAC_CR_SREF_MASK #define DAC_CR_DMAIE_POS 13 #define DAC_CR_DMAIE_MASK (0x01UL<<DAC_CR_DMAIE_POS) #define DAC_CR_DMAIE DAC_CR_DMAIE_MASK #define DAC_CR_DMAEN_POS 12 #define DAC_CR_DMAEN_MASK (0x01UL<<DAC_CR_DMAIE_POS) #define DAC_CR_DMAEN DAC_CR_DMAIE_MASK #define DAC_CR_WAVE_POS 6 #define DAC_CR_WAVE_MASK (0x03UL<<DAC_CR_DMAIE_POS) #define DAC_CR_WAVE DAC_CR_DMAIE_MASK #define DAC_CR_TRIGSEL_POS 3 #define DAC_CR_TRIGSEL_MASK (0x07UL<<DAC_CR_DMAIE_POS) #define DAC_CR_TRIGSEL DAC_CR_DMAIE_MASK #define DAC_CR_TRIGEN_POS 2 #define DAC_CR_TRIGEN_MASK (0x07UL<<DAC_CR_DMAIE_POS) #define DAC_CR_TRIGEN DAC_CR_DMAIE_MASK #define DAC_CR_BUFFER_POS 1 #define DAC_CR_BUFFER_MASK (0x01UL<<DAC_CR_DMAIE_POS) #define DAC_CR_BUFFER DAC_CR_DMAIE_MASK #define DAC_CR_EN_POS 0 #define DAC_CR_EN_MASK (0x01UL<<DAC_CR_DMAIE_POS) #define DAC_CR_EN DAC_CR_DMAIE_MASK //===端口触发选择 #define DAC_ETRS_TRIGSEL_POS 4 #define DAC_ETRS_TRIGSEL_MASK (0x07UL<<DAC_CR_DMAIE_POS) #define DAC_ETRS_TRIGSEL DAC_CR_DMAIE_MASK #pragma endregion #pragma region LVD //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CR; //---配置寄存器 __IO uint32_t SR; //---状态寄存器 } LVD_TypeDef; //===LVD中断使能控制 #define LVD_CR_IE_POS 15 #define LVD_CR_IE_MASK (0x01UL<<LVD_CR_IE_POS) #define LVD_CR_IE LVD_CR_IE_MASK //===LVD触发方式 #define LVD_CR_HT_POS 14 #define LVD_CR_HT_MASK (0x01UL<<LVD_CR_HT_POS) #define LVD_CR_HT LVD_CR_HT_MASK //===LVD触发方式 #define LVD_CR_RT_POS 13 #define LVD_CR_RT_MASK (0x01UL<<LVD_CR_RT_POS) #define LVD_CR_RT LVD_CR_RT_MASK //===LVD触发方式 #define LVD_CR_FT_POS 12 #define LVD_CR_FT_MASK (0x01UL<<LVD_CR_FT_POS) #define LVD_CR_FT LVD_CR_FT_MASK //===LVD中断触发方式 #define LVD_CR_IRQ_POS 12 #define LVD_CR_IRQ_MASK (0x07UL<<LVD_CR_IRQ_POS) #define LVD_CR_IRQ LVD_CR_IRQ_MASK //===数字滤波时间 #define LVD_CR_FITLER_TIME_POS 9 #define LVD_CR_FITLER_TIME_MASK (0x07UL<<LVD_CR_FITLER_TIME_POS) #define LVD_CR_FITLER_TIME LVD_CR_FITLER_TIME_MASK #define LVD_CR_FITLER_US_7 (0x00UL<<LVD_CR_FITLER_TIME_POS) #define LVD_CR_FITLER_US_14 (0x01UL<<LVD_CR_FITLER_TIME_POS) #define LVD_CR_FITLER_US_28 (0x02UL<<LVD_CR_FITLER_TIME_POS) #define LVD_CR_FITLER_US_112 (0x03UL<<LVD_CR_FITLER_TIME_POS) #define LVD_CR_FITLER_US_450 (0x04UL<<LVD_CR_FITLER_TIME_POS) #define LVD_CR_FITLER_US_1800 (0x05UL<<LVD_CR_FITLER_TIME_POS) #define LVD_CR_FITLER_US_7200 (0x06UL<<LVD_CR_FITLER_TIME_POS) #define LVD_CR_FITLER_US_28800 (0x07UL<<LVD_CR_FITLER_TIME_POS) //===数字滤波使能配置 #define LVD_CR_FITLER_EN_POS 8 #define LVD_CR_FITLER_EN_MASK (0x07UL<<LVD_CR_FITLER_EN_POS) #define LVD_CR_FITLER_EN LVD_CR_FITLER_EN_MASK //===LVD阈值电压选择 #define LVD_CR_LVDS_POS 4 #define LVD_CR_LVDS_MASK (0x0FUL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS LVD_CR_LVDS_MASK #define LVD_CR_LVDS_V_1P8 (0x00UL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_1P9 (0x01UL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_2P0 (0x02UL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_2P1 (0x03UL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_2P2 (0x04UL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_2P3 (0x05UL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_2P4 (0x06UL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_2P5 (0x07UL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_2P6 (0x08UL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_2P7 (0x09UL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_2P8 (0x0AUL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_2P9 (0x0BUL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_3P0 (0x0CUL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_3P1 (0x0DUL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_3P2 (0x0EUL<<LVD_CR_LVDS_POS) #define LVD_CR_LVDS_V_3P3 (0x0FUL<<LVD_CR_LVDS_POS) //===LVD监测来源 #define LVD_CR_SOURCE_POS 2 #define LVD_CR_SOURCE_MASK (0x03UL<<LVD_CR_SOURCE_POS) #define LVD_CR_SOURCE LVD_CR_SOURCE_MASK #define LVD_CR_SOURCE_PB07 (0x03UL<<LVD_CR_SOURCE_POS) #define LVD_CR_SOURCE_PB08 (0x02UL<<LVD_CR_SOURCE_POS) #define LVD_CR_SOURCE_PC13 (0x01UL<<LVD_CR_SOURCE_POS) #define LVD_CR_SOURCE_AVCC (0x00UL<<LVD_CR_SOURCE_POS) //===LVD触发动作选择 #define LVD_CR_ACT_POS 1 #define LVD_CR_ACT_MASK (0x01UL<<LVD_CR_ACT_POS) #define LVD_CR_ACT LVD_CR_ACT_MASK #define LVD_CR_ACT_RESET LVD_CR_ACT #define LVD_CR_ACT_NVIC (~LVD_CR_ACT) //===LVD使能控制 #define LVD_CR_EN_POS 0 #define LVD_CR_EN_MASK (0x01UL<<LVD_CR_EN_POS) #define LVD_CR_EN LVD_CR_EN_MASK //===中断标志 #define LVD_SR_INTF_POS 0 #define LVD_SR_INTF_MASK (0x01UL<<LVD_SR_INTF_POS) #define LVD_SR_INTF LVD_SR_INTF_MASK #pragma endregion #pragma region DMA //===端口通用功能配置寄存器 typedef struct { __IO uint32_t CONF; //---配置寄存器 __IO uint32_t CONFA0; //---状态寄存器 __IO uint32_t CONFB0; //---状态寄存器 __IO uint32_t SRCADR0; //---状态寄存器 __IO uint32_t DSTADR0; //---状态寄存器 __IO uint32_t CONFA1; //---状态寄存器 __IO uint32_t CONFB1; //---状态寄存器 __IO uint32_t SRCADR1; //---状态寄存器 __IO uint32_t DSTADR1; //---状态寄存器 } DMA_TypeDef; #pragma endregion #define FLASH_BASE 0x00000000U #define FLASH_END 0x0001FFFFU #define FLASH_BANK1_END 0x0001FFFFU #define SRAM_BASE 0x20000000U #define SRAM_ENDsss 0x20003FFFU #define PERIPH_BASE 0x40000000U //#define SRAM_BB_BASE 0x22000000U //#define PERIPH_BB_BASE 0x42000000U #define DBGMCU_BASE 0x04002038U #define GPIO_SEL_OFFSET (0x100/4) //===产品身份标识 #define UID_BASE 0x00100E74U //===产品型号 #define PID_BASE 0x00100C60U //===Flash容量 #define FLASH_SIZE_BASE 0x00100C70U //===SRAM容量 #define SRAM_SIZE_BASE 0x00100C74U //===引脚数量 #define PIN_NUM_BASE 0x00100C7AU //===总线基地址 #define APB0PERIPH_BASE PERIPH_BASE #define APB1PERIPH_BASE (PERIPH_BASE + 0x00004000U) #define AHBPERIPH_BASE (PERIPH_BASE + 0x00020000U) //===外设基地址 #define UART0_BASE (APB0PERIPH_BASE + 0x00000000U) #define UART1_BASE (APB0PERIPH_BASE + 0x00000100U) #define LPUART0_BASE (APB0PERIPH_BASE + 0x00000200U) #define I2C0_BASE (APB0PERIPH_BASE + 0x00000400U) #define SPI0_BASE (APB0PERIPH_BASE + 0x00000800U) #define TIM0_BASE (APB0PERIPH_BASE + 0x00000C00U) #define TIM1_BASE (APB0PERIPH_BASE + 0x00000D00U) #define TIM2_BASE (APB0PERIPH_BASE + 0x00000E00U) #define LPTIM0_BASE (APB0PERIPH_BASE + 0x00000F00U) #define LPTIM1_BASE (APB0PERIPH_BASE + 0x00000F40U) #define WDT_BASE (APB0PERIPH_BASE + 0x00000F80U) #define PCA_BASE (APB0PERIPH_BASE + 0x00001000U) #define RTC_BASE (APB0PERIPH_BASE + 0x00001400U) //===时钟校准 #define TRIM_BASE (APB0PERIPH_BASE + 0x00001800U) #define RCC_BASE (APB0PERIPH_BASE + 0x00002000U) #define BGR_BASE (APB0PERIPH_BASE + 0x00002400U) #define ADC0_BASE (APB0PERIPH_BASE + 0x00002404U) #define ADC_BASE (APB0PERIPH_BASE + 0x00002404U) #define VC_BASE (APB0PERIPH_BASE + 0x00002410U) #define OPA_BASE (APB0PERIPH_BASE + 0x00002430U) #define LVD_BASE (APB0PERIPH_BASE + 0x00002428U) #define DAC0_BASE (APB0PERIPH_BASE + 0x00002500U) #define DAC_BASE (APB0PERIPH_BASE + 0x00002500U) #define TIMP4_BASE (APB0PERIPH_BASE + 0x00003000U) #define TIMP5_BASE (APB0PERIPH_BASE + 0x00003400U) #define TIMP6_BASE (APB0PERIPH_BASE + 0x00003800U) #define LPUART1_BASE (APB0PERIPH_BASE + 0x00004000U) #define I2C1_BASE (APB0PERIPH_BASE + 0x00004400U) #define SPI1_BASE (APB0PERIPH_BASE + 0x00004800U) #define RNG_BASE (APB0PERIPH_BASE + 0x00004C00U) #define PCNT_BASE (APB0PERIPH_BASE + 0x00005400U) #define TIM3_BASE (APB0PERIPH_BASE + 0x00005800U) #define LCD_BASE (APB0PERIPH_BASE + 0x00005C00U) #define UART2_BASE (APB0PERIPH_BASE + 0x00006000U) #define UART3_BASE (APB0PERIPH_BASE + 0x00006400U) #define FLASH_CTR_BASE (APB0PERIPH_BASE + 0x00020000U) #define RAM_CTR_BASE (APB0PERIPH_BASE + 0x00020400U) #define CRC_BASE (APB0PERIPH_BASE + 0x00020900U) #define DMAC_BASE (APB0PERIPH_BASE + 0x00021000U) #define AES_BASE (APB0PERIPH_BASE + 0x00021400U) //===端口功能选择寄存器 #define GPIOA_AF_BASE (APB0PERIPH_BASE + 0x00020C00U) #define GPIOB_SEL_BASE (APB0PERIPH_BASE + 0x00020C40U) #define GPIOC_SEL_BASE (APB0PERIPH_BASE + 0x00020C80U) #define GPIOD_SEL_BASE (APB0PERIPH_BASE + 0x00020CC0U) #define GPIOE_SEL_BASE (APB0PERIPH_BASE + 0x00021C00U) #define GPIOF_SEL_BASE (APB0PERIPH_BASE + 0x00021C40U) //===端口特殊功能,辅助功能寄存器 #define GPIO_AF_BASE (APB0PERIPH_BASE + 0x00020F04U) //===端口通用寄存器 #define GPIOA_BASE (APB0PERIPH_BASE + 0x00020D00U) #define GPIOB_BASE (APB0PERIPH_BASE + 0x00020D40U) #define GPIOC_BASE (APB0PERIPH_BASE + 0x00020D80U) #define GPIOD_BASE (APB0PERIPH_BASE + 0x00020DC0U) #define GPIOE_BASE (APB0PERIPH_BASE + 0x00021D00U) #define GPIOF_BASE (APB0PERIPH_BASE + 0x00021D40U) #define GPIOA_AF_BASE (APB0PERIPH_BASE + 0x00020C00U) #define GPIOB_AF_BASE (APB0PERIPH_BASE + 0x00020C40U) #define GPIOC_AF_BASE (APB0PERIPH_BASE + 0x00020C80U) #define GPIOD_AF_BASE (APB0PERIPH_BASE + 0x00020CC0U) #define GPIOE_AF_BASE (APB0PERIPH_BASE + 0x00020CA0U) #define GPIOF_AF_BASE (APB0PERIPH_BASE + 0x00020CC0U) #define GPIO_SUB_BASE (APB0PERIPH_BASE + 0x00020F04U) //===端口中断配置寄存器 #define EXITA_BASE (APB0PERIPH_BASE + 0x00020D30U) #define EXITB_BASE (APB0PERIPH_BASE + 0x00020D70U) #define EXITC_BASE (APB0PERIPH_BASE + 0x00020DB0U) #define EXITD_BASE (APB0PERIPH_BASE + 0x00020DF0U) #define EXITE_BASE (APB0PERIPH_BASE + 0x00021D30U) #define EXITF_BASE (APB0PERIPH_BASE + 0x00021D70U) //===定义端口功能 #define GPIOA ((GPIO_TypeDef *) GPIOA_BASE) #define GPIOB ((GPIO_TypeDef *) GPIOB_BASE) #define GPIOC ((GPIO_TypeDef *) GPIOC_BASE) #define GPIOD ((GPIO_TypeDef *) GPIOD_BASE) #define GPIOE ((GPIO_TypeDef *) GPIOE_BASE) #define GPIOF ((GPIO_TypeDef *) GPIOF_BASE) #define GPIO_SELA ((GPIO_AF_TypeDef *) GPIOA_AF_BASE) #define GPIO_SELB ((GPIO_AF_TypeDef *) GPIOB_AF_BASE) #define GPIO_SELC ((GPIO_AF_TypeDef *) GPIOC_AF_BASE) #define GPIO_SELD ((GPIO_AF_TypeDef *) GPIOD_AF_BASE) #define GPIO_SELE ((GPIO_AF_TypeDef *) GPIOE_AF_BASE) #define GPIO_SELF ((GPIO_AF_TypeDef *) GPIOF_AF_BASE) #define GPIO_SUB ((GPIO_Sub_TypeDef *) GPIO_SUB_BASE) #define EXITA ((EXIT_TypeDef *) EXITA_BASE) #define EXITB ((EXIT_TypeDef *) EXITB_BASE) #define EXITC ((EXIT_TypeDef *) EXITC_BASE) #define EXITD ((EXIT_TypeDef *) EXITD_BASE) #define EXITE ((EXIT_TypeDef *) EXITE_BASE) #define EXITF ((EXIT_TypeDef *) EXITF_BASE) #define RCC ((RCC_TypeDef *) RCC_BASE) #define FLASH ((FLASH_TypeDef *) FLASH_CTR_BASE) #define RAM ((RAM_TypeDef *) RAM_CTR_BASE) #define RNG ((RNG_TypeDef *) RNG_BASE) #define CRC ((CRC_TypeDef *) CRC_BASE) #define RTC ((RTC_TypeDef *) RTC_BASE) #define I2C0 ((I2C_TypeDef *) I2C0_BASE) #define I2C1 ((I2C_TypeDef *) I2C1_BASE) #define SPI0 ((SPI_TypeDef *) SPI0_BASE) #define SPI1 ((SPI_TypeDef *) SPI1_BASE) #define UART0 ((USART_TypeDef *) UART0_BASE) #define UART1 ((USART_TypeDef *) UART1_BASE) #define UART2 ((USART_TypeDef *) UART2_BASE) #define UART3 ((USART_TypeDef *) UART3_BASE) #define LPUART0 ((LPUSART_TypeDef *) LPUART0_BASE) #define LPUART1 ((LPUSART_TypeDef *) LPUART1_BASE) #define LPTIM0 ((LPTIM_TypeDef *) LPTIM0_BASE) #define LPTIM1 ((LPTIM_TypeDef *) LPTIM1_BASE) #define TRIM ((TRIM_TypeDef *) TRIM_BASE) #define TIM0 ((TIM_TypeDef *) TIM0_BASE) #define TIM1 ((TIM_TypeDef *) TIM1_BASE) #define TIM2 ((TIM_TypeDef *) TIM2_BASE) #define TIM3 ((TIM_TypeDef *) TIM3_BASE) #define TIM0_M0 ((TIM_M0_TypeDef *) TIM0_BASE) #define TIM1_M0 ((TIM_M0_TypeDef *) TIM1_BASE) #define TIM2_M0 ((TIM_M0_TypeDef *) TIM2_BASE) #define TIM3_M0 ((TIM_M0_TypeDef *) TIM3_BASE) #define TIM0_M1 ((TIM_M1_TypeDef *) TIM0_BASE) #define TIM1_M1 ((TIM_M1_TypeDef *) TIM1_BASE) #define TIM2_M1 ((TIM_M1_TypeDef *) TIM2_BASE) #define TIM3_M1 ((TIM_M1_TypeDef *) TIM3_BASE) #define TIM0_M2 ((TIM_M2_TypeDef *) TIM0_BASE) #define TIM1_M2 ((TIM_M2_TypeDef *) TIM1_BASE) #define TIM2_M2 ((TIM_M2_TypeDef *) TIM2_BASE) #define TIM3_M2 ((TIM_M2_TypeDef *) TIM3_BASE) #define TIM0_M3 ((TIM_M3_TypeDef *) TIM0_BASE) #define TIM1_M3 ((TIM_M3_TypeDef *) TIM1_BASE) #define TIM2_M3 ((TIM_M3_TypeDef *) TIM2_BASE) #define TIM3_M3 ((TIM_M3_TypeDef *) TIM3_BASE) #define TIMP4 ((TIMP_TypeDef *) TIMP4_BASE) #define TIMP5 ((TIMP_TypeDef *) TIMP5_BASE) #define TIMP6 ((TIMP_TypeDef *) TIMP6_BASE) #define OPA ((OPA_TypeDef *) OPA_BASE) #define PCA ((PCA_TypeDef *) PCA_BASE) #define WDT ((WDT_TypeDef *) WDT_BASE) #define IWDG ((IWDG_TypeDef *) WDT_BASE) #define BGR ((BGR_TypeDef *)BGR_BASE) #define ADC0 ((ADC_TypeDef *) ADC0_BASE) #define ADC ((ADC_TypeDef *) ADC_BASE) #define DAC0 ((DAC_TypeDef *) DAC0_BASE) #define DAC ((DAC_TypeDef *) DAC_BASE) #define VC ((VC_TypeDef *) VC_BASE) #define PCNT ((PCNT_TypeDef *) PCNT_BASE) #define LCD ((LCD_TypeDef *) LCD_BASE) #define AES ((AES_TypeDef *) AES_BASE) #define LVD ((LVD_TypeDef *) LVD_BASE) #define DMA ((DMA_TypeDef *) DMAC_BASE) /// #ifdef __cplusplus } #endif #endif /* HC32L17XA_H */
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
134
1382
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
