pms150g电笔.02
710|1
 楼主| 34af9uc 发表于 2023-7-9 09:20 | 显示全部楼层 |阅读模式
/*****************pms150g电笔**********************/
/*****************qq:774145445*********************/
/*****************ID:共同学习stm8******************/
/*****************ide:0.98A4_20230708**************/
//                     pms150g
//                 ______   ______
//             5v-|1-vdd \_/ gnd-8|-gnd      ________
//          led_g-|2-pa7     pa0-7|-jiance--|__10M___|----|    ________
//          led_r-|3-pa6     pa4-6|-bijiao--|__15M___|----|---|__4.7M__|--------220v
//            gnd-|4-pa5_____pa3-5|-feng----|__10R___|--------------------------蜂鸣器
#include        "extern.h"
void        chushihua();                //初始化
led_g                bit                pa.7;
led_r                bit                pa.6;
feng                bit                pa.3;
jiance                bit                pa.0;
bijiao                bit                pa.4;
void        FPPA0 (void)
//.ADJUST_IC        SYSCLK=IHRC/16                //        SYSCLK=1M
//.ADJUST_IC                SYSCLK=ILRC;
.ADJUST_IC        DISABLE;                // No adjust IHRCR, WatchDog Enable
clkmd                =0xf4;                //系统时钟ilrc
clkmd.4                =0;                        //关闭ihrc
chushihua();
byte        a1;
word        a2;
led_r                =1;
led_r                =0;
led_g                =1;
led_g                =0;
a1                =10;
while(a1--)
        a2                =200;
        while(a2 --)
                //if(feng ==1){feng =0;} else{feng =1;}
                pa                ^=1 <<3;                //响蜂鸣器
        feng                =0;
        a2                =100;
        while(a2 --)
                //if(led_g ==1){led_g =0;} else{led_g =1;}
                //pa                ^=1 <<7;                //闪绿灯
                led_g                =1;
                .delay                30;
                led_g                =0;
                .delay                70;
        led_g                =0;
while (1)
stopsys;                //进入掉电模式
if(jiance ==1)
led_r =1;
.delay 500;
led_r =0;
.delay 500;
void        Interrupt (void)
        pushaf;
        if (Intrq.T16)
        {        //        T16 Trig
                //        User can add code
                Intrq.T16        =        0;
        popaf;
void        chushihua()                //初始化
$                led_g                out,low;
$                led_r                out,low;
$                feng                out,low;
$                jiance                in,X_PH, X_PL;                //输入,关闭上拉电阻,关闭下拉电阻
$                bijiao                in,X_PH, X_PL;
padier                =0b1110_1001;                                //pa4数字停用
 楼主| 34af9uc 发表于 2023-7-9 10:13 | 显示全部楼层
必须看住了
319
