[活动] APM32F40TIGT6 TINY BOARD+串口通讯和adc采样
747|7
 楼主| emanages 发表于 2023-7-24 07:36 | 显示全部楼层 |阅读模式
有幸能够获得这次测评的机会,由于最近工作上的原因非常的忙,赶进度,此次将进行简单的ADC采样和串口通讯,再串口更具上显示采样值。拿到板子感到整个板子非常大气,如下:
程序主要是配置了ADC和串口的外设,开启滴答定时器。主要程序如下:
adc外设的初始化和中断的开启:
#include "main.h"
#include "hd_adc.h"
#include "apm32f4xx_gpio.h"
#include "apm32f4xx_adc.h"
#include "apm32f4xx_misc.h"
#include "apm32f4xx_rcm.h"
float voltage = 0.0f;
void HD_ADC_Init(void)
    GPIO_Config_T   gpioConfig;
    ADC_Config_T    adcConfig;
    ADC_CommonConfig_T  adcCommonConfig;
    /* Enable GPIOA clock */
    RCM_EnableAHB1PeriphClock(RCM_AHB1_PERIPH_GPIOA);
    /* ADC channel 0 configuration */
    GPIO_ConfigStructInit(&gpioConfig);
    gpioConfig.mode    = GPIO_MODE_AN;
    gpioConfig.pupd    = GPIO_PUPD_NOPULL;
    gpioConfig.pin     = GPIO_PIN_0;
    GPIO_Config(GPIOA, &gpioConfig);
    /* Enable ADC clock */
    RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_ADC1);
    /* ADC configuration */
    ADC_Reset();
    ADC_ConfigStructInit(&adcConfig);
    adcConfig.resolution          = ADC_RESOLUTION_12BIT;
    adcConfig.continuousConvMode  = ENABLE;
    adcConfig.dataAlign           = ADC_DATA_ALIGN_RIGHT;
    adcConfig.extTrigEdge         = ADC_EXT_TRIG_EDGE_NONE;
    adcConfig.scanConvMode        = DISABLE;
    ADC_Config(ADC1, &adcConfig);
    /*Set ADC Clock Prescaler. ADC_Clock = APB2_Clock/4, 84/4=21MHz*/
    adcCommonConfig.prescaler = ADC_PRESCALER_DIV4;
    ADC_CommonConfig(&adcCommonConfig);
    /* ADC channel 10 Convert configuration */
    ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_0, 1, ADC_SAMPLETIME_112CYCLES);
    /* Enable complete conversion interupt */
    ADC_EnableInterrupt(ADC1, ADC_INT_EOC);
    /* NVIC configuration */
    NVIC_EnableIRQRequest(ADC_IRQn, 1, 1);
    /* Enable ADC */
    ADC_Enable(ADC1);
    /* ADC start conversion */
    ADC_SoftwareStartConv(ADC1);
void ADC_Irq_GetData(void)
    uint16_t adcData = 0;
    if (ADC_ReadStatusFlag(ADC1, ADC_FLAG_EOC))
        ADC_ClearStatusFlag(ADC1, ADC_FLAG_EOC);
        adcData = ADC_ReadConversionValue(ADC1);
        voltage = (float)adcData*3.3f/4095.0f;
void ADC_IRQHandler(void)
    ADC_Irq_GetData();
串口的配置:
* @file       usart.c
* @brief
* @version     V1.0.1
* @date        2023-07-13
* @attention
#include "main.h"
#include "hd_usart.h"
#include "Board.h"
void HD_Usart_Init(void)
  USART_Config_T usartConfigStruct;
    /* USART configuration */
    USART_ConfigStructInit(&usartConfigStruct);
    usartConfigStruct.baudRate      = 115200;
    usartConfigStruct.mode          = USART_MODE_TX_RX;
    usartConfigStruct.parity        = USART_PARITY_NONE;
    usartConfigStruct.stopBits      = USART_STOP_BIT_1;
    usartConfigStruct.wordLength    = USART_WORD_LEN_8B;
    usartConfigStruct.hardwareFlow  = USART_HARDWARE_FLOW_NONE;
    /* COM1 init*/
    APM_TINY_COMInit(COM1, &usartConfigStruct);
总体的运行:
uint32_t sys_clock;
int main(void)
    APM_TINY_LEDInit(LED2);
    APM_TINY_LEDInit(LED3);
          APM_TINY_LEDOff(LED2);
          APM_TINY_LEDOn(LED3);
    HD_ADC_Init();
          HD_Usart_Init();
          SysTick_Init();
          sys_clock= RCM_ReadSYSCLKFreq();
    while (1)
                        RUN_BLOCK(1000,GPIOE->ODATA ^= GPIO_PIN_6;);
                        RUN_BLOCK(1000,GPIOE->ODATA ^= GPIO_PIN_5;);
      RUN_BLOCK(1000,printf("ADC采样电压 : %f V\r\n", voltage););
上图可以看出:此时系统时钟168mhz,ADC采样值再3.3v是系统的电源di电压。
串口1s打印一次测试到的经过计算的ADC的值,总体实验显示LED灯1S闪烁一次,串口1s打印一次。
自此,初步测试结束。后期将进行更加详细的测试。
tpgf 发表于 2023-8-12 15:12 | 显示全部楼层
现在的很多评估板上rj45是不是都成了标配了啊
wowu 发表于 2023-8-12 15:29 | 显示全部楼层
请问一下adc采样的精度如何得到验证呢
木木guainv 发表于 2023-8-12 15:48 | 显示全部楼层
12位adc的真正有效值能到小数点后多少位啊
磨砂 发表于 2023-8-12 19:19 | 显示全部楼层
感觉采集上来的电压不是那么稳定呢
xiaoqizi 发表于 2023-8-12 20:01 | 显示全部楼层
这块板子上adc的电压基准用的是什么啊
wakayi 发表于 2023-8-12 21:00 | 显示全部楼层
单片机中的adc采样通常都是使用的单端输入模式是吗
xxrs 发表于 2023-8-13 19:49 | 显示全部楼层
标配
