(use-package "FFI")
(default-foreign-language :stdc)
(def-call-out PEA256Init (:name "PEA256Init")
(:return-type boolean)
(:library "D:\\PEA256COM\\x64\\Release\\libpea256x64.dll"))
(def-call-out PEA256Test (:name "PEA256Test")
(def-call-out PEA256Version (:name "PEA256Version")
(:return-type uint32)
(def-call-out PEA256Error (:name "PEA256Error")
(def-call-out PEA256Open (:name "PEA256Open")
(:return-type c-pointer)
(def-call-out PEA256Close (:name "PEA256Close")
(:arguments (handle c-pointer))
(:return-type)
(def-call-out PEA256EncryptUserKey (:name "PEA256EncryptUserKey")
(:arguments (handle c-pointer) (keystr c-string) (keybuff c-string) (keyfile c-string))
(:return-type uint)
(def-call-out PEA256DecryptUserKey (:name "PEA256DecryptUserKey")
(:return-type uint)
(def-call-out PEA256EncryptBytes (:name "PEA256EncryptBytes")
(:arguments (handle c-pointer) (bytes (c-ptr (c-array uchar 4)) :in-out :alloca) (len uint32) (subkey uint32))
(def-call-out PEA256DecryptBytes (:name "PEA256DecryptBytes")
(def-call-out PEA256EncryptBytesEx (:name "PEA256EncryptBytesEx")
(:arguments (handle c-pointer) (inbytes (c-ptr (c-array uchar 4)) :in :alloca) (outbytes (c-ptr (c-array uchar 4)) :in-out :alloca) (len uint32) (subkey uint32))
(def-call-out PEA256DecryptBytesEx (:name "PEA256DecryptBytesEx")
(def-call-out PEA256EncryptArrayEx (:name "PEA256EncryptArrayEx")
(:arguments (handle c-pointer) (inbytes (c-ptr (c-array uchar 4)) :in :alloca) (outbytes (c-ptr (c-array uchar 4)) :in-out :alloca) (index uint32) (len uint32) (subkey uint32))
(def-call-out PEA256DecryptArrayEx (:name "PEA256DecryptArrayEx")
(def-call-out PEA256EncryptBufferEx (:name "PEA256EncryptBufferEx")
(:arguments (handle c-pointer) (inbytes (c-ptr (c-array uchar 4)) :in :alloca) (in_index uint32) (outbytes (c-ptr (c-array uchar 4)) :in-out :alloca) (out_index uint32) (len uint32) (subkey uint32))
(def-call-out PEA256DecryptBufferEx (:name "PEA256DecryptBufferEx")
(if (PEA256Init)
(progn
(format t"PEA256Init成功!!!~%")
(PEA256Test)
(setq version (PEA256Version))
(format t"subkey = ~08X~%" version)
(setq handle (PEA256Open))
(write handle)
(terpri)
(if nil(handle)
(progn
(setf Array (make-array 4 :initial-element 0 :element-type '(unsigned-byte 8)))
(setf ArrayEncrypt (make-array 4 :initial-element 0 :element-type '(unsigned-byte 8)))
(setf ArrayDecrypt (make-array 4 :initial-element 0 :element-type '(unsigned-byte 8)))
(dotimes (i (length Array))
(setf (aref Array i) i)
(setf (aref ArrayEncrypt i) i)
(setq subkey (PEA256EncryptUserKey handle "123" "" ""))
(format t"~%subkey = ~08X" subkey)
(setq subkey (PEA256EncryptBytes handle Array 4 subkey))
;(setq subkey (PEA256EncryptBytes handle Array 4 subkey))
;(setq subkey (PEA256EncryptBytesEx handle ArrayEncrypt ArrayDecrypt 4 subkey))
;(setq subkey (PEA256EncryptArrayEx handle ArrayEncrypt ArrayDecrypt 0 4 subkey))
;(setq subkey (PEA256EncryptBufferEx handle ArrayEncrypt 0 ArrayDecrypt 0 4 subkey))
(format t"~%subkey = ~08X~%" subkey)
(write Array)
(terpri)
(format t" ~02X" (aref Array i))
(setq subkey (PEA256DecryptUserKey handle "123" "" ""))
(setq subkey (PEA256DecryptBytes handle Array 4 subkey))
;(setq subkey (PEA256DecryptBytesEx handle ArrayDecrypt ArrayEncrypt 4 subkey))
;(setq subkey (PEA256DecryptArrayEx handle ArrayDecrypt ArrayEncrypt 0 4 subkey))
;(setq subkey (PEA256DecryptBufferEx handle ArrayDecrypt 0 ArrayEncrypt 0 4 subkey))
(write Array)
(terpri)
(setq subkey (PEA256EncryptUserKey handle "" "0123456789ABCDEF0123456789ABCDEF" ""))
(setq subkey (PEA256DecryptUserKey handle "" "0123456789ABCDEF0123456789ABCDEF" ""))
(setq subkey (PEA256EncryptUserKey handle "" "" "123.PEA.KEY"))
(setq subkey (PEA256DecryptUserKey handle "" "" "123.PEA.KEY"))
(setq subkey (PEA256EncryptUserKey handle "" "" "D:\\libpea256x64\\libpea256x64.dll"))
(setq subkey (PEA256DecryptUserKey handle "" "" "D:\\libpea256x64\\libpea256x64.dll"))
;(write "PEA256Open失败!!!")
(PEA256Close handle)
(format t"~%PEA256Init失败!!!")
(PEA256Error)
(format t"~%Hello World!!!")
