[AT32F413] PB3可以设置为输入吗?需要外置上拉电阻吗?怎么试都不行,用过的大神指点下。
2477|16
 楼主| p8s 发表于 2023-11-3 15:48 | 显示全部楼层 |阅读模式
gpio_init_type gpio_init_struct;
  /* enable the led clock */
        crm_periph_clock_enable(CRM_IOMUX_PERIPH_CLOCK, TRUE);
        crm_periph_clock_enable(CRM_GPIOB_PERIPH_CLOCK, TRUE);
  /* configure the led gpio */
  gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
  gpio_init_struct.gpio_out_type  = GPIO_OUTPUT_PUSH_PULL;
  gpio_init_struct.gpio_mode = GPIO_MODE_INPUT;
  gpio_init_struct.gpio_pins = 0xf078;//1111000001111000;//15,14,13,12,,,,6,5,4,3
  gpio_init_struct.gpio_pull = GPIO_PULL_UP;
  gpio_init(GPIOB, &gpio_init_struct);
        gpio_pin_remap_config(SWJTAG_GMUX_010,TRUE);
 楼主| p8s 发表于 2023-11-3 15:52 | 显示全部楼层
原厂程序,改了测试也不行,PB4正常跳变,PB3持续低电平。
#include "at32f413_board.h"
#include "at32f413_clock.h"
/** @addtogroup AT32F413_periph_examples
/** @addtogroup 413_GPIO_swjtag_remap GPIO_swjtag_remap
void swj_dp_config(void);
void gpio_pins_toggle(gpio_type* gpio_x, uint16_t gpio_pin);
  * @brief  configure the gpio of swj-dp.
  * @param  none
  * @retval none
  /* configure pa13 (jtms/swdat), pa14 (jtck/swclk) and pa15 (jtdi) as output push-pull */
//  gpio_init_struct.gpio_pins = GPIO_PINS_13 | GPIO_PINS_14 | GPIO_PINS_15;
  gpio_init_struct.gpio_mode = GPIO_MODE_OUTPUT;
  gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
//  gpio_init(GPIOA, &gpio_init_struct);
  /* configure pb3 (jtdo) and pb4 (jtrst) as output push-pull */
  gpio_init_struct.gpio_pins = GPIO_PINS_1|GPIO_PINS_3 | GPIO_PINS_4;
  * @brief  toggles the specified gpio pin
  * @param  gpiox: where x can be (a..g depending on device used) to select the gpio peripheral
  * @param  gpio_pin: specifies the pins to be toggled.
  * @retval none
  gpio_x->odt ^= gpio_pin;
  * @brief  main function.
  * @param  none
  * @retval none
int main(void)
  system_clock_config();
  at32_board_init();
  crm_periph_clock_enable(CRM_GPIOA_PERIPH_CLOCK, TRUE);
  swj_dp_config();
        gpio_pin_remap_config(SWJTAG_CONF_010, TRUE);
  while(1)
//    if(USER_BUTTON == at32_button_press())
      /* disable the serial wire jtag debug port swj-dp */
//      gpio_pin_remap_config(SWJTAG_CONF_100, TRUE);
      /* turn on led3 */
//      at32_led_off(LED3);
//    /* toggle jtms/swdat pin */
//    gpio_pins_toggle(GPIOA, GPIO_PINS_13);
//    delay_us(200);
//    /* toggle jtck/swclk pin */
//    gpio_pins_toggle(GPIOA, GPIO_PINS_14);
//    delay_us(200);
    /* toggle jtdi pin */
    gpio_pins_toggle(GPIOB, GPIO_PINS_0);
    delay_us(200);
    /* toggle jtdo pin */
    gpio_pins_toggle(GPIOB, GPIO_PINS_3);
    delay_us(200);
    /* toggle jtrst pin */
    gpio_pins_toggle(GPIOB, GPIO_PINS_4);
    delay_us(200);
回忆酱 发表于 2023-11-4 15:13 | 显示全部楼层
试试一次全部禁用jtag的 PA的也是.正常复用完就可以了
albertaabbot 发表于 2023-11-6 22:11 | 显示全部楼层
使用的是官网的开发板吗?这个口是复用的。
mickit 发表于 2023-11-6 22:25 | 显示全部楼层
是led的口吗?
lzbf 发表于 2023-11-7 17:12 | 显示全部楼层
关闭jtag的功能。
dspmana 发表于 2023-11-7 18:15 | 显示全部楼层
需要上拉电阻的。
classroom 发表于 2023-12-8 11:11 | 显示全部楼层
可能是由于在使用SWD调试的时候要取消trace跟踪调试,Pb3端口还是没法正常读取到数据。
earlmax 发表于 2023-12-8 15:56 | 显示全部楼层
一般建议选择10kΩ至100kΩ之间的电阻值。
chenjun89 发表于 2023-12-8 20:01 来自手机 | 显示全部楼层
看一下芯片数据手册这个IO是不是固定某个功能使用的
beacherblack 发表于 2023-12-8 21:00 | 显示全部楼层
在配置PB3为输入模式时,需要设置GPIO的引脚功能寄存器(如GPIOx_AFRL或GPIOx_AFRH,其中x为对应的GPIO端口,如GPIOB),将PB3引脚映射到内部上拉电阻(PUPDD=0)和浮空(PDD=0)模式。
beacherblack 发表于 2023-12-8 22:01 | 显示全部楼层
关闭PB3的输出功能,然后将其设置为输入模式。
mollylawrence 发表于 2023-12-9 09:57 | 显示全部楼层
建议检查PB3端口的连接是否正确
iyoum 发表于 2023-12-9 15:42 | 显示全部楼层
在SWD调试模式
youtome 发表于 2023-12-9 21:14 | 显示全部楼层
是否需要外置上拉电阻,这取决于你的具体应用。
xiaoyaodz 发表于 2023-12-9 21:50 | 显示全部楼层
其他代码或硬件配置错误影响了PB3
pattywu 发表于 2023-12-9 22:30 | 显示全部楼层
我记得与I2C引脚相同的, 上拉电阻好像是没有的.
p8s
17
