有时无线透传在无法布线时有很方便的效用,不妨试试蓝牙透传,效果如下:
具体是无线数据->串口数据,串口数据->无线数据,目前前者实现了,后者还有些问题未解决,
实现过程如下,基于工程demo/Bluetooth/peripheral_demo改成peripheral_uart_demo,同时目录下peripheral_uart_demo/gcc/defconfig文件里工程名也改成peripheral_uart_demo,然后引入串口读写独立接口即把demo/at_demo下的serial.c、serial.h、serial_debug.h复制到刚才peripheral_uart_demo工程下,由于要无线写以及串口写转无线,所以profile涉及到write_without_rsp和notify,具体配置为:
服务 特征
UUID 12345678-1234-5678-56789abcdef0 12345678-1234-5678-56789abcdef1
Properties Write no response/Notify static struct bt_gatt_attr vnd_attrs[] = { /* Vendor Primary Service Declaration */ BT_GATT_PRIMARY_SERVICE(&vnd_uuid), BT_GATT_CHARACTERISTIC(&vnd_enc_uuid.uuid, BT_GATT_CHRC_WRITE_WITHOUT_RESP | BT_GATT_CHRC_NOTIFY, BT_GATT_PERM_WRITE, NULL, write_without_rsp_vnd, &vnd_value), BT_GATT_CCC(vnd_ccc_notify_changed, BT_GATT_PERM_READ|BT_GATT_PERM_WRITE),};写回调接口为: /**********************vnd_write_cmd_uuid*****************************/static ssize_t write_without_rsp_vnd(struct bt_conn *conn, const struct bt_gatt_attr *attr, const void *buf, uint16_t len, uint16_t offset, uint8_t flags){ uint8_t *value = attr->user_data; /* Write request received. Reject it since this char only accepts * Write Commands. */ if (!(flags & BT_GATT_WRITE_FLAG_CMD)) { return BT_GATT_ERR(BT_ATT_ERR_WRITE_REQ_REJECTED); } if (offset + len > sizeof(vnd_value)) { return BT_GATT_ERR(BT_ATT_ERR_INVALID_OFFSET); } memset(value, 0, sizeof(vnd_value)); memcpy(value + offset, buf, len); serial_write(value + offset, len); *(value + offset + len) = '\0'; printf("\r\nwrite_without_rsp_vnd"); return len;}串口转无线回调(有问题): static void vnd_notify(void){ static uint8_t vnd[MAX_LONG_DATA]; uint16_t len=0; if (!vnd_notif_enabled) return; printf("\r\nnotify\r\n"); serial_read(vnd_notify_value,len); if(len>MAX_LONG_DATA || len==0) return; memcpy(vnd, vnd_notify_value, len); printf("\r\nvnd_notify\r\n"); bt_gatt_notify(NULL, &vnd_svc.attrs[1], vnd, sizeof(vnd));}然后在bt_app_init函数里加入透传口UART1的初始化代码即可: serial_init(SERIAL_UART_ID, 115200, UART_DATA_BITS_8, UART_PARITY_NONE, UART_STOP_BITS_1, 0); serial_start();
