本次使用XR806实现ST7789的屏幕的驱动。 硬件连接本文使用的LCD屏幕的原理图如下,可以确定LCD屏幕的控制引脚接线。 XR806与LCD屏幕的控制引脚分布如下 LCD引脚 XR806引脚
SDA PB4
CS PB6
RST PB5
SCL PB7
DC PB3
实际的连接效果如图所示。 驱动编写ST7789的驱动使用中景园的LCD驱动库,驱动文件包括 - lcd.c
- lcd.h
- lcd_init.c
- lcd_init.h
- lcd_font.h
在XR806的示例程序中GPIO工程的基础上进行移植。在gpio示例文件夹中添加lcd的驱动代码。 移植时要实现对LCD引脚的控制,在lcd_init.h中添加以下代码 #include "driver/chip/hal_gpio.h"#include "kernel/os/os.h"#define LCD_SCLK_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_7, GPIO_PIN_LOW)#define LCD_SCLK_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_7, GPIO_PIN_HIGH)#define LCD_MOSI_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_4, GPIO_PIN_LOW)#define LCD_MOSI_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_4, GPIO_PIN_HIGH)#define LCD_RES_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_5, GPIO_PIN_LOW)#define LCD_RES_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_5, GPIO_PIN_HIGH)#define LCD_DC_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_3, GPIO_PIN_LOW)#define LCD_DC_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_3, GPIO_PIN_HIGH)#define LCD_CS_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_6, GPIO_PIN_LOW)#define LCD_CS_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_6, GPIO_PIN_HIGH)//硬件上没有给出控制接口,这里不做定义#define LCD_BLK_Clr()#define LCD_BLK_Set()在lcd_init.c中添加引脚的初始化函数,并替换延时函数为OS_MSleep,相关的带啊吗如下 #include "lcd_init.h"void LCD_GPIO_Init(void){ GPIO_InitParam param; param.driving = GPIO_DRIVING_LEVEL_1; param.mode = GPIOx_Pn_F1_OUTPUT; param.pull = GPIO_PULL_NONE; HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_3, ¶m); HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_4, ¶m); HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_5, ¶m); HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_6, ¶m); HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_7, ¶m);}void LCD_Init(void){ LCD_GPIO_Init(); LCD_RES_Clr(); OS_MSleep(100);//替换延时函数 LCD_RES_Set(); OS_MSleep(100); //以下代码忽略}在main.c中添加以下代码 #include <stdio.h>#include "kernel/os/os.h"#include "driver/chip/hal_gpio.h"#include "lcd.h"int main(void){ LCD_Init(); OS_MSleep(100); LCD_Fill(0, 0, LCD_W, LCD_H, RED); // LCD_ShowString(4, 0, "XR806 LCD Test", RED, CYAN, 16, 0); LCD_DrawRectangle(0, 0, LCD_W - 1, LCD_H - 1, MAGENTA); LCD_DrawRectangle(1, 1, LCD_W - 2, LCD_H - 2, MAGENTA); while (1) { OS_MSleep(1000); LCD_Fill(0, 0, LCD_W, LCD_H, BLUE); OS_MSleep(1000); LCD_Fill(0, 0, LCD_W, LCD_H, GREEN); OS_MSleep(1000); LCD_Fill(0, 0, LCD_W, LCD_H, YELLOW); OS_MSleep(1000); LCD_Fill(0, 0, LCD_W, LCD_H, LIGHTGREEN); printf("XR806 LCD Test\n"); } return 0;}编译下载后,可以看到屏幕的颜色切换以及串口的数据输出
 总结十分感谢极术社区和全志提供的测评机会,接触到了docker环境开发嵌入式程序的方式。 问题在使用串口下载时遇到了以下问题,目前没有找到解决方法。
