用1602显示的频率计在protues上就是不出现在啊,谁帮我看看
1972|0
 楼主| chenjiawei7 发表于 2012-5-11 10:38 | 显示全部楼层 |阅读模式
#include <reg52.h>
unsigned char dispbuf[8];
unsigned char temp[8];
unsigned char T0count;
unsigned char timecount;
sbit EN=P2^0;
sbit RS=P2^1;
sbit RW=P2^2;
bit flag;
unsigned long x;
unsigned int num;
unsigned char i;
void delay1ms(unsigned int ms)//延时1毫秒(不够精确的)
unsigned int i,j;
for(i=0;i<ms;i++)
for(j=0;j<100;j++);
void write_command(unsigned char command)//写指令//
delay1ms(1);
RS=0;
RW=0;
EN=0;
P0=command;
delay1ms(1);
EN=1;
delay1ms(1);
EN=0;
void write_data(unsigned char date)//写数据//
delay1ms(1);;
RS=1;
RW=0;
EN=0;
    P0=date;
delay1ms(1);
     EN=1;
     delay1ms(1);
     EN=0;
void init()
EN=0;
write_command(0x38);
write_command(0x0c);
write_command(0x06);
write_command(0x01);
void main(void)
  TMOD=0x15;
  TH0=0;
  TL0=0;
  TH1=(65536-5000)/256;
  TL1=(65536-5000)%256;
  ET0=1;
  ET1=1;
  EA=1;
  init();
  write_command(0x80+0x04);
  TR1=1;
  TR0=1;
  while(1)
     if(flag==1)
         flag=0;
         x=T0count*65536+TH0*256+TL0;
for(i=0;i<8;i++)
             temp[i]=0;
         i=0;
         while(x/10)
             temp[i]=x%10;
             x=x/10;
             i++;
         temp[i]=x;
         for(i=0;i<8;i++)
             dispbuf[i]=temp[i];
         timecount=0;
         T0count=0;
         TH0=0;
         TL0=0;
         TR0=1;
void t0(void) interrupt 1 using 0
  T0count++;
void t1(void) interrupt 3 using 0
  timecount++;
  if(timecount==200)
      TR0=0;
      timecount=0;
      flag=1;
for(num=7;num<=0;num--)
write_data(dispbuf[num]);
delay1ms(1);
