[技术讨论] 全志R128使用RGB LCD移植方法教程
587|0
 楼主| 神棍地海棠 发表于 2023-12-18 17:08 | 显示全部楼层 |阅读模式
这里的示例以百问网的7寸(1024x600)、4寸方屏(480x480)、4寸圆屏RGB(480x480) LCD为例。
[color=var(--c-text-accent)]在新窗口打开[color=var(--c-text-accent)][size=0.85em]#选择方案这里建议用百问网提供的 [color=var(--c-text-accent)]r128-devkit-100ask-rgb在新窗口打开 方案,仓库地址:
  • Gitee: [color=var(--c-text-accent)]https://gitee.com/weidongshan/100ask_r128_demos/tree/master/other/RGB_LCD在新窗口打开
  • GitHub:[color=var(--c-text-accent)]https://github.com/100askTeam/100ask_r128_demos/tree/master/other/RGB_LCD在新窗口打开
方案使用方法,请[color=var(--c-text-accent)]点击这里在新窗口打开查看。
初始化环境变量,选择方案(r128s2_devkit_100ask_rgb_c906与r128s2_devkit_100ask_rgb_m33):
[backcolor=var(--code-bg-color)]100ask@100ask:~/R128-FreeRTOS/SDK$ source envsetup.sh Setup env done!Run lunch_rtos to select project100ask@100ask:~/R128-FreeRTOS/SDK$ lunch_rtoslast=r128s2_devkit_c906You're building on LinuxLunch menu... pick a combo:     1. r128s2_devkit_100ask_rgb_c906     2. r128s2_devkit_100ask_rgb_m33     3. r128s2_devkit_c906     4. r128s2_devkit_m33     5. r128s2_devkit_rgb_c906     6. r128s2_devkit_rgb_m33     7. r128s2_evt_c906     8. r128s2_evt_m33Which would you like? [Default r128s2_devkit_c906]: 1select=1...r128s2/devkit_100ask_rgb_c906'/home/100ask/R128-FreeRTOS/SDK/lichee/rtos/projects/r128s2/devkit_100ask_rgb_c906/defconfig' -> '/home/100ask/R128-FreeRTOS/SDK/lichee/rtos/.config'============================================RTOS_BUILD_TOP=/home/100ask/R128-FreeRTOS/SDKRTOS_TARGET_ARCH=riscvRTOS_TARGET_CHIP=sun20iw2p1RTOS_TARGET_DEVICE=r128s2RTOS_PROJECT_NAME=r128s2_devkit_100ask_rgb_c906============================================Run mrtos_menuconfig to config rtosRun m or mrtos to build rtos
[color=var(--code-ln-color)]
[color=var(--c-text-accent)][size=0.85em]#配置menuconfig
menuconfig具体配置:
[backcolor=var(--code-bg-color)]# 1.打开下面的 DriversDrivers Options  --->    soc related device drivers  --->        PWM devices --->            [* enable pwm driver            [    enable pwm hal APIs test command        TWI Devices  --->            -*- enable twi driver            [    enable twi hal APIs test command        Video support for sunxi  --->                [* DISP Driver Support(sunxi-disp2)            ......# 2. 打开LVGL相关配置System components  --->    thirdparty components  --->        [* Littlevgl-8  --->            --- Littlevgl-8            [*   lvgl examples            [    lvgl g2d test            [*   lvgl-8.1.0 use sunxifb double buffer            [*   lvgl-8.1.0 use sunxifb cache            [    lvgl-8.1.0 use sunxifb g2d            [    lvgl-8.1.0 use sunxifb g2d rotate            [    lvgl-8.1.0 use freetype            [    lvgl-8.1.0 use direct mode
[color=var(--c-text-accent)][size=0.85em]#显示[color=var(--c-text-accent)][size=0.85em]#sys_config.fex配置
修改文件:R128-FreeRTOS/board/r128s2/devkit_rgb/configs/sys_config.fex
[backcolor=var(--code-bg-color)][lcd0lcd_used            = 1;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; 7寸屏(1024x600)lcd_driver_name     = "default_lcd"lcd_backlight       = 150lcd_if              = 0lcd_x               = 1024lcd_y               = 600lcd_width           = 150lcd_height          = 94lcd_rb_swap         = 0lcd_dclk_freq       = 48lcd_pwm_used        = 1lcd_pwm_ch          = 7lcd_pwm_freq        = 500000lcd_pwm_pol         = 1lcd_hbp             = 150lcd_ht              = 1344lcd_hspw            = 20lcd_vbp             = 20lcd_vt              = 635lcd_vspw            = 3lcd_lvds_if         = 0lcd_lvds_colordepth = 1lcd_lvds_mode       = 0lcd_frm             = 0lcd_io_phase        = 0x0000lcd_gamma_en        = 0lcd_bright_curve_en = 0lcd_cmap_en         = 0;;;;;; 4寸方屏(480x480);lcd_driver_name     = "default_lcd";lcd_backlight       = 150;lcd_if              = 0;lcd_x               = 480;lcd_y               = 480;lcd_width           = 70;lcd_height          = 70;lcd_rb_swap         = 1;lcd_dclk_freq       = 9;lcd_pwm_used        = 1;lcd_pwm_ch          = 7;lcd_pwm_freq        = 500000;lcd_pwm_pol         = 1;lcd_hbp             = 20;lcd_ht              = 526;lcd_hspw            = 6;lcd_vbp             = 10;lcd_vt              = 510;lcd_vspw            = 4;lcd_lvds_if         = 0;lcd_lvds_colordepth = 1;lcd_lvds_mode       = 0;lcd_frm             = 1;lcd_io_phase        = 0x0000;lcd_gamma_en        = 0;lcd_bright_curve_en = 0;lcd_cmap_en         = 0;;;;;; 4寸圆屏RGB(480*480);lcd_driver_name     = "default_lcd";lcd_backlight       = 200;lcd_if              = 0;lcd_x               = 480;lcd_y               = 480;lcd_width           = 70;lcd_height          = 70;lcd_rb_swap         = 1;lcd_dclk_freq       = 9;lcd_pwm_used        = 1;lcd_pwm_ch          = 7;lcd_pwm_freq        = 2000;lcd_pwm_pol         = 1;lcd_hbp             = 20;lcd_ht              = 526;lcd_hspw            = 6;lcd_vbp             = 10;lcd_vt              = 510;lcd_vspw            = 4;lcd_lvds_if         = 0;lcd_lvds_colordepth = 1;lcd_lvds_mode       = 0;lcd_frm             = 1;lcd_io_phase        = 0x0000;lcd_gamma_en        = 0;lcd_bright_curve_en = 0;lcd_cmap_en         = 0;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;deu_mode            = 0lcdgamma4iep        = 0smart_color         = 0;LCD_D2-LCD_D7lcd_gpio_0               = port:PA00<8><0><3><0>lcd_gpio_1               = port:PA01<8><0><3><0>lcd_gpio_2               = port:PA02<8><0><3><0>lcd_gpio_3               = port:PA03<8><0><3><0>lcd_gpio_4               = port:PA04<8><0><3><0>lcd_gpio_5               = port:PA05<8><0><3><0>;LCD_D10-LCD_D15lcd_gpio_6               = port:PA11<8><0><3><0>lcd_gpio_7               = port:PA10<8><0><3><0>lcd_gpio_8               = port:PA08<8><0><3><0>lcd_gpio_9               = port:PA07<8><0><3><0>lcd_gpio_10              = port:PA06<8><0><3><0>lcd_gpio_11              = port:PA09<8><0><3><0>;LCD_D18-LCD_D23lcd_gpio_12              = port:PA12<8><0><3><0>lcd_gpio_13              = port:PA13<8><0><3><0>lcd_gpio_14              = port:PA14<8><0><3><0>lcd_gpio_15              = port:PA15<8><0><3><0>lcd_gpio_16              = port:PB03<8><0><3><0>lcd_gpio_17              = port:PB02<8><0><3><0>;LCD_VSYNC, LCD_HSYNC, LCD_DCLK, LCD_DElcd_gpio_18              = port:PA18<8><0><3><0>lcd_gpio_19              = port:PA19<8><0><3><0>lcd_gpio_20              = port:PA20<8><0><3><0>lcd_gpio_21              = port:PA21<8><0><3><0>
[color=var(--c-text-accent)][size=0.85em]#LVGL配置
修改文件:SDK/lichee/rtos-components/thirdparty/littlevgl-8/lv_examples/src/lv_conf.h
[backcolor=var(--code-bg-color)]/*Color depth: 1 (1 byte per pixel), 8 (RGB332), 16 (RGB565), 32 (ARGB8888)*/#define LV_COLOR_DEPTH 32  /*这里可以改为16,因为de会自动转换到32位,最终显示还是32位色深*//*Swap the 2 bytes of RGB565 color. Useful if the display has an 8-bit interface (e.g. SPI)*/#define LV_COLOR_16_SWAP 0
[color=var(--c-text-accent)][size=0.85em]#触摸[color=var(--c-text-accent)][size=0.85em]#配置menuconfig
menuconfig具体配置:
[backcolor=var(--code-bg-color)]Drivers Options  --->    other drivers  --->        [* input driver  --->                [*   keyboard driver  --->                [*   touchscreen driver  --->                        [    enable tlsc6x touchscreen driver                        [*   enable gt911 touchscreen driver                        [    enable cst226se touchscreen driver                        [    enable touchscreen drivers APIs test command    soc related device drivers  --->        EFUSE Devices  --->            [* enable efuse driver            [    enable efuse hal APIs test command
[backcolor=var(--code-bg-color)][touchscreentp_used                = 1tp_int                 = port:PA24<1><0><default><default>tp_reset               = port:PA25<1><0><default><default>tp_revert_mode         = 0tp_exchange_flag       = 0;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; 7寸屏(1024x600) GT911tp_max_x               = 1024tp_max_y               = 600tp_addr                = 0x14;;;;;; 4寸方屏(480x480) GT911;tp_max_x               = 480;tp_max_y               = 480;tp_addr                = 0x14;;;;;; 4寸圆屏RGB(480*480);待续...;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;tp_twi_id              = 1
修改文件:SDK/lichee/rtos-components/thirdparty/littlevgl-8/lv_examples/src/lv_drv_conf.h
[backcolor=var(--code-bg-color)]/*------------------------------------------------- * Mouse or touchpad as evdev interface (for Linux based systems) *------------------------------------------------*/#ifndef USE_EVDEV#  define USE_EVDEV           1#endif
[color=var(--c-text-accent)][size=0.85em]#结果
以上配置完成后,编译打包烧录,上电后屏幕背光亮起,屏幕为黑色。
并且可以在 LOG 中看到 [LCD_FB] lcd_fb_probe,line:103: 和 spi_clk_init()1609 [spi1] clk rate auto adjust to 48000000 SPI 初始化的 LOG。
[backcolor=var(--code-bg-color)]disp:[disp_device_attached_and_enable 230attached ok, mgr0<-->dev0disp:[disp_device_attached_and_enable 243type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8[gt911[log PRODUCT_ID=39:31:31:00:60:10[gt911[log verison=00 range_x=0 range_y=0 point_num=0[gt911[log PRODUCT_ID=39:31:31:00:60:10[gt911[log verison=42 range_x=480 range_y=480 point_num=5
通过执行 lv_examples 命令运行LVGL测试demo。
lv_examples 代码位于: SDK/lichee/rtos-components/thirdparty/littlevgl-8/lv_examples/src/lv_main.c
