[其他ST产品] STM32-LwESP 移植
1453|29
 楼主| 丢丢手绢666 发表于 2024-1-29 20:20 | 显示全部楼层
笔者这里参考 Demo netconn_client_rtos_stm32l496g_discovery,简单的写了个应用。就简简单单的在加入 AP 后与指定的 TCP Server 建立连接,之后发送一个 GET 请求。main.c 如下:
  * @file    Project/STM32F10x_StdPeriph_Template/main.c
  * @author  MCD Application Team
  * @version V3.6.0
  * @date    20-September-2021
  * @brief   Main program body
  * @attention
  * Copyright (c) 2011 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* Includes ------------------------------------------------------------------*/
#include <stdio.h>
#include "stm32f10x.h"
#include "lwesp_opts.h"
#include "FreeRTOS.h"
#include "task.h"
#include "printf.h"
#include "delay.h"
#include "lwesp/lwesp.h"
#include "station_manager.h"
#include "netconn_client.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
lwespr_t lwesp_callback_func(lwesp_evt_t* evt) {
    switch (lwesp_evt_get_type(evt)) {
        case LWESP_EVT_AT_VERSION_NOT_SUPPORTED: {
            lwesp_sw_version_t v_min, v_curr;
            lwesp_get_min_at_fw_version(&v_min);
            lwesp_get_current_at_fw_version(&v_curr);
            printf("Current ESP8266 AT version is not supported by library!\r\n");
            printf("Minimum required AT version is: %d.%d.%d\r\n", (int)v_min.major, (int)v_min.minor, (int)v_min.patch);
            printf("Current AT version is: %d.%d.%d\r\n", (int)v_curr.major, (int)v_curr.minor, (int)v_curr.patch);
            break;
        case LWESP_EVT_INIT_FINISH: {
            printf("Library initialized!\r\n");
            break;
        case LWESP_EVT_RESET_DETECTED: {
            printf("Device reset detected!\r\n");
            break;
        case LWESP_EVT_WIFI_IP_ACQUIRED: {        /* We have IP address and we are fully ready to work */
            if (lwesp_sta_is_joined()) {          /* Check if joined on any network */
                lwesp_sys_thread_create(NULL, "netconn_client", (lwesp_sys_thread_fn)netconn_client_thread, NULL, 512, LWESP_SYS_THREAD_PRIO);
            break;
        case LWESP_EVT_WIFI_CONNECTED: {
            printf("Successfully joined AP\r\n");
            break;
        default:
            break;
    return lwespOK;
void join_ap_test(void *pvParameters)
    /* Initialize ESP with default callback function */
    printf("Initializing LwESP\r\n");
    if (lwesp_init(lwesp_callback_func, 1) != lwespOK) {
        printf("Cannot initialize LwESP!\r\n");
    } else {
        printf("LwESP initialized!\r\n");
     * Continuously try to connect to WIFI network
     * but only in case device is not already connected
    while (1) {
        if (!lwesp_sta_is_joined()) {
             * Connect to access point.
             * Try unlimited time until access point accepts up.
             * Check for station_manager.c to define preferred access points ESP should connect to
            connect_to_preferred_access_point(1);
        vTaskDelay(1000);
    vTaskDelete(NULL);
  * @brief  Configures the nested vectored interrupt controller.
  * @param  None
  * @retval None
void NVIC_Configuration(void)
    /* Configure the NVIC Preemption Priority Bits */
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
    /*!< At this stage the microcontroller clock setting is already configured,
        this is done through SystemInit() function which is called from startup
        file (startup_stm32f10x_xx.s) before to branch to application main.
        To reconfigure the default setting of SystemInit() function, refer to
        system_stm32f10x.c file
    /* Add your application code here
    BaseType_t xReturn = pdPASS;
    NVIC_Configuration();
    debug_uart_init();
    printf("Debug UART output success\r\n");
    xReturn = xTaskCreate(join_ap_test, "join_ap_test", 1024 * 2, NULL, 1, NULL);
    if(pdPASS == xReturn)
        vTaskStartScheduler();
    else
        return -1;
    /* Infinite loop */
    while (1);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
    /* User can add his own implementation to report the file name and line number,
        ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
    /* Infinite loop */
    while (1)
#endif
要运行这个 Demo,还需要 snippets 目录下的几个源文件 station_manager.c, utils.c 和 netconn_client.c。因为 main.c 中调用了这几个源文件中的接口,需要将它们也拷贝到自己的工程中。同时也需要将 snippets/include 中包含到的头文件也添加到自己的工程中,同时不要忘记头文件放置目录也需要添加到 KEIL 的头文件搜索路径中。
Demo 跑起来还需要配置以下参数:
AP 的 SSID 和 PASSWORD
TCP Server 的 IP 地址和连接端口
发送给 TCP Server 的数据
AP 的 SSID 和 PASSWORD 可以在 station_manager.c 中的 ap_list_preferred 中定义:
* List of preferred access points for ESP device
* SSID and password
* ESP will try to scan for access points
* and then compare them with the one on the list below
static const ap_entry_t ap_list_preferred[] = {
    //{ .ssid = "SSID name", .pass = "SSID password" },
    { .ssid = "HUAWEI-tangxiang", .pass = "xxxxxxxx" },
 楼主| 丢丢手绢666 发表于 2024-1-29 20:21 | 显示全部楼层
TCP Server 的 IP 地址和连接端口 可以在 netconn_client.c 中定义:
* \brief           Host and port settings
#define NETCONN_HOST        "106.14.142.xxx"
#define NETCONN_PORT        8001
发送给 TCP Server 的数据 可以在 netconn_client.c 中定义,LwESP 默认在 TCP 连接建立后发送一个 GET 请求。
* \brief           Request header to send on successful connection
static const char
request_header[] = ""
                   "GET / HTTP/1.1\r\n"
                   "Host: " NETCONN_HOST "\r\n"
                   "Connection: close\r\n"
                   "\r\n";
配置完成后,就可以将 STM32 的 USART2 的 TX 和 RX 引脚与 ESP32 相连,同时可以将 STM32 上定义的 RESET 引脚连接到 ESP32 上的 RST 引脚上。等待 STM32 连接上指定的 AP 后就会自动和指定的 TCP Server 建立 TCP 连接,连接成功后就会自动发送一个 GET 请求。
当 STM32 接收到 TCP Server 发送过来的数据时,LwESP 也会通知应用层接收到了多少字节的数据。
 楼主| 丢丢手绢666 发表于 2024-1-29 20:22 | 显示全部楼层
到这里,整个 LwESP 的移植和测试已经全部完成了。其实 LwESP 可以挖掘的功能还有很多,各位读者如果有兴趣可以自行去深入挖掘一下,期待与各位读者的技术交流~~~
