分析用户代码
到此,基本启动过程已经分析完。下一步开始分析用户代码,就从main函数开始。
1 程序跳转到main函数后:RCC_GetClocksFreq获取RCC时钟频率;SysTick_Config配置SysTick,在这里打开了SysTick中断,10毫秒一次。Delay(5);延时50毫秒。
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
files before to branch to application main.
To reconfigure the default setting of SystemInit() function,
refer to system_stm32f4xx.c file */
/* SysTick end of count event each 10ms */
RCC_GetClocksFreq(&RCC_Clocks);
SysTick_Config(RCC_Clocks.HCLK_Frequency / 100);
/* Add your application code here */
/* Insert 50 ms delay */
Delay(5);
2 初始化IO就不说了,进入while(1),也就是一个死循环,嵌入式程序,都是一个死循环,否则就跑飞了。
/*初始化LED IO口*/
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOG, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2| GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOG, &GPIO_InitStructure);
/* Infinite loop */
mcu_uart_open(3);
while (1)
GPIO_ResetBits(GPIOG, GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
Delay(100);
GPIO_SetBits(GPIOG, GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
Delay(100);
mcu_uart_test();
TestFun(TestTmp2);
3 在while(1)中调用TestFun函数,这个函数使用两个全局变量,两个局部变量。
/* Private functions ---------------------------------------------------------*/
u32 TestTmp1 = 5;//全局变量,初始化为5
u32 TestTmp2;//全局变量,未初始化
const u32 TestTmp3[10] = {6,7,8,9,10,11,12,13,12,13};
u8 TestFun(u32 x)//函数,带一个参数,并返回一个u8值
u8 test_tmp1 = 4;//局部变量,初始化
u8 test_tmp2;//局部变量,未初始化
static u8 test_tmp3 = 0;//静态局部变量
test_tmp3++;
test_tmp2 = x;
if(test_tmp2> TestTmp1)
test_tmp1 = 10;
else
test_tmp1 = 5;
TestTmp2 +=TestTmp3[test_tmp1];
return test_tmp1;
然后程序就一直在main函数的while循环里面执行。中断呢?对,还有中断。中断中断,就是中断正常的程序执行流程。相关文章:STM32中断系统。我们查看Delay函数,uwTimingDelay不等于0就死等?谁会将uwTimingDelay改为0?
* @brief Inserts a delay time.
* @param nTime: specifies the delay time length, in milliseconds.
* @retval None
void Delay(__IO uint32_t nTime)
uwTimingDelay = nTime;
while(uwTimingDelay != 0);
搜索uwTimingDelay变量,函数TimingDelay_Decrement会将变量一直减到0。
* @brief Decrements the TimingDelay variable.
* @param None
* @retval None
void TimingDelay_Decrement(void)
if (uwTimingDelay != 0x00)
uwTimingDelay--;
这个函数在哪里执行?经查找,在SysTick_Handler函数中运行。谁用这个函数?
* @brief This function handles SysTick Handler.
* @param None
* @retval None
void SysTick_Handler(void)
TimingDelay_Decrement();
经查找,在中断向量表中有这个函数,也即是说这个函数指针保存在中断向量表内。当发生中断时,就会执行这个函数。当然,在进出中断会有保存和恢复现场的操作。这个主要涉及到汇编,暂时不进行分析了。有兴趣自己研究研究。通常,现在我们开发程序不用关心上下文切换了。
__Vectors DCD __initial_sp ; Top of Stack
DCD Reset_Handler ; Reset Handler
DCD NMI_Handler ; NMI Handler
DCD HardFault_Handler ; Hard Fault Handler
DCD MemManage_Handler ; MPU Fault Handler
DCD BusFault_Handler ; Bus Fault Handler
DCD UsageFault_Handler ; Usage Fault Handler
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD SVC_Handler ; SVCall Handler
DCD DebugMon_Handler ; Debug Monitor Handler
DCD 0 ; Reserved
DCD PendSV_Handler ; PendSV Handler
DCD SysTick_Handler ; SysTick Handler
余下问题
1 __main函数是什么函数?是我们在main.c中定义的main函数吗?2 分散加载文件中*(InRoot$$Sections)是什么?3 ZI段,也就是初始化为0的数据段,什么时候初始化?谁初始化?
为什么这几个问题前面留着不说?因为这是同一个问题。顺藤摸瓜!
