[PCB] WiFi7-IPQ9574 and WiFi6 IPQ8072 cpus respectively represent the highest performance in the WiFi phase.
776|0
 楼主| wirelesswifi6 发表于 2024-2-22 10:34 | 显示全部楼层 |阅读模式
What changes do WiFi7 and WiFi6 bring to WiFi technology.
WiFi 7 and WiFi 6 are different evolutionary stages of wireless networking technology, each bringing a series of changes and improvements:
Higher speeds: Each generation of WiFi technology has improved in speed. WiFi 6 offers a higher theoretical maximum speed than WiFi 5 (also known as 802.11ac). WiFi 7 May have further improvements in speed compared to WiFi 6, but the specific speed will vary depending on the specific implementation.
Lower latency: Both WiFi 6 and WiFi 7 aim to reduce latency. This is critical for real-time applications such as online gaming, video conferencing, and iot devices.
Better multi-device performance: WiFi 6 introduces OFDMA (Orthogonal Frequency Division Multiple Access) and MU-MIMO (Multi-User Multiple Input Multiple Output) technologies. The ability to manage communication between multiple devices more efficiently improves the overall performance of the network. WiFi 7 is likely to improve these technologies further, making the network more adaptable to high-volume connected scenarios.
Better coverage and stability: Every generation of WiFi technology has made efforts to improve signal coverage and stability. WiFi 6 and WiFi 7 have introduced some new technologies and algorithms, such as BSS Coloring (Basic service set color labeling), to reduce signal interference, improve coverage and network stability.
Lower energy consumption: With the popularity of iot devices, low energy consumption has become an important consideration. Both WiFi 6 and WiFi 7 aim to provide better performance while reducing power consumption, thereby extending the battery life of devices.
In general, WiFi 7 will further improve the speed, latency, multi-device performance, coverage, stability and energy consumption on the basis of WiFi 6, providing users with a faster, more stable and more intelligent wireless network connection.
Among them, Qualcomm chip is the first choice for many industrial router cpus, its performance is more stable, faster transmission speed, and the current WiFi7 is also listed, compared with WiFi6, they have their own representative chips, let's look at the difference between IPQ9574 and IPQ8072:
The IPQ9574 and IPQ8072 are high-performance Qualcomm Atheros processors commonly used in wireless routers and networking devices. Here are some of the differences:
Processing performance: IPQ9574 tends to have higher processing performance. It typically uses faster cpus and Gpus that can handle larger amounts of data and more complex tasks. In contrast, the IPQ8072's processing performance may be slightly inferior.
WiFi Standard support: Generally speaking, the IPQ9574 will support the newer WiFi standard. For example, it may support WiFi 6E (802.11ax extension), which provides higher speeds and better network performance. The IPQ8072 may only support older WiFi standards, such as WiFi 6 (802.11ax) or WiFi 5 (802.11ac).
Number of network connections: The IPQ9574 tends to support more network connections. This is critical for high-density network environments such as businesses, schools, or busy home networks. The IPQ9574 generally has better multi-user Multiple input Multiple Output (MU-MIMO) support and is able to handle more device connections simultaneously.
Power consumption and heat dissipation: Due to the higher performance of the IPQ9574, it may generate more heat and consume more energy. When designing products, differences in thermal and power management need to be taken into account.
Cost: The IPQ9574 tends to be more expensive because it has higher performance and more advanced features. The IPQ8072 may be better suited for cost-sensitive applications, especially where high performance is required but budgets are limited.
