[其他ST产品]
演示了如何使用定时器中断以LED的形式展现实验
2098|2
雨果喝水|  楼主 | 2024-2-26 23:28 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
使用STM32CubeIDE和STM32F10x系列的Discovery开发板,演示了如何使用定时器中断以LED的形式展现实验。
#include "main.h"
#include "stm32f1xx_hal.h"
TIM_HandleTypeDef htim2;
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_TIM2_Init(void);
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_TIM2_Init();
  HAL_TIM_Base_Start_IT(&htim2);
  while (1)
    // 主循环中可以执行其他任务
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  __HAL_RCC_GPIOC_CLK_ENABLE();
  HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13, GPIO_PIN_RESET);
  GPIO_InitStruct.Pin = GPIO_PIN_13;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  __HAL_RCC_TIM2_CLK_ENABLE();
  htim2.Instance = TIM2;
  htim2.Init.Prescaler = 35999;
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim2.Init.Period = 999;
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
    Error_Handler();
  HAL_NVIC_SetPriority(TIM2_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(TIM2_IRQn);
void TIM2_IRQHandler(void)
  HAL_TIM_IRQHandler(&htim2);
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  if (htim->Instance == TIM2)
    HAL_GPIO_TogglePin(GPIOC, GPIO_PIN_13); // 切换LED状态
void Error_Handler(void)
  while (1)
    // 发生错误时的处理代码
上述代码配置了STM32F1系列的TIM2定时器,使其每秒触发一次中断。在中断处理函数中,使用HAL库的HAL_GPIO_TogglePin函数来切换PC13引脚的状态,从而实现LED的闪烁效果。
确保在STM32CubeIDE中创建一个新的STM32工程,选择正确的微控制器型号(如STM32F103),并按照上述代码的结构配置时钟、GPIO和定时器。这个例子中使用了PC13引脚,对应Discovery板上的蓝色LED。
