[其他ST产品] 演示了如何使用定时器中断以LED的形式展现实验
2326|2
 楼主| 雨果喝水 发表于 2024-2-26 23:28 | 显示全部楼层 |阅读模式
使用STM32CubeIDE和STM32F10x系列的Discovery开发板,演示了如何使用定时器中断以LED的形式展现实验。
  1. #include "main.h"
  2. #include "stm32f1xx_hal.h"
  3. TIM_HandleTypeDef htim2;
  4. void SystemClock_Config(void);
  5. static void MX_GPIO_Init(void);
  6. static void MX_TIM2_Init(void);
  7. int main(void)
  8. {
  9.   HAL_Init();
  10.   SystemClock_Config();
  11.   MX_GPIO_Init();
  12.   MX_TIM2_Init();
  13.   HAL_TIM_Base_Start_IT(&htim2);
  14.   while (1)
  15.   {
  16.     // 主循环中可以执行其他任务
  17.   }
  18. }
  19. void SystemClock_Config(void)
  20. {
  21.   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  22.   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  23.   __HAL_RCC_PWR_CLK_ENABLE();
  24.   __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  25.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  26.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  27.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  28.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  29.   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  30.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  31.   {
  32.     Error_Handler();
  33.   }
  34.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
  35.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  36.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  37.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  38.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  39.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
  40.   {
  41.     Error_Handler();
  42.   }
  43. }
  44. void MX_GPIO_Init(void)
  45. {
  46.   GPIO_InitTypeDef GPIO_InitStruct = {0};
  47.   __HAL_RCC_GPIOC_CLK_ENABLE();
  48.   HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13, GPIO_PIN_RESET);
  49.   GPIO_InitStruct.Pin = GPIO_PIN_13;
  50.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  51.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  52.   HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  53. }
  54. void MX_TIM2_Init(void)
  55. {
  56.   __HAL_RCC_TIM2_CLK_ENABLE();
  57.   htim2.Instance = TIM2;
  58.   htim2.Init.Prescaler = 35999;
  59.   htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  60.   htim2.Init.Period = 999;
  61.   htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  62.   htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  63.   if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
  64.   {
  65.     Error_Handler();
  66.   }
  67.   HAL_NVIC_SetPriority(TIM2_IRQn, 0, 0);
  68.   HAL_NVIC_EnableIRQ(TIM2_IRQn);
  69. }
  70. void TIM2_IRQHandler(void)
  71. {
  72.   HAL_TIM_IRQHandler(&htim2);
  73. }
  74. void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  75. {
  76.   if (htim->Instance == TIM2)
  77.   {
  78.     HAL_GPIO_TogglePin(GPIOC, GPIO_PIN_13); // 切换LED状态
  79.   }
  80. }
  81. void Error_Handler(void)
  82. {
  83.   while (1)
  84.   {
  85.     // 发生错误时的处理代码
  86.   }
  87. }
上述代码配置了STM32F1系列的TIM2定时器,使其每秒触发一次中断。在中断处理函数中,使用HAL库的HAL_GPIO_TogglePin函数来切换PC13引脚的状态,从而实现LED的闪烁效果。
确保在STM32CubeIDE中创建一个新的STM32工程,选择正确的微控制器型号(如STM32F103),并按照上述代码的结构配置时钟、GPIO和定时器。这个例子中使用了PC13引脚,对应Discovery板上的蓝色LED。
21mengnan 发表于 2024-2-29 23:00 | 显示全部楼层
LED的亮和灭是很好的指示标志。
wanduzi 发表于 2024-2-29 23:19 | 显示全部楼层
我也是用LED进行测试。
