返回列表 发新帖我要提问本帖赏金: 50.00元(功能说明)
[活动] 【APM32F411V Tiny Board测评】+ PlatformIO开发AMP32F411
2070|5
 楼主| 袁胜富 发表于 2024-5-5 20:16 | 显示全部楼层 |阅读模式
#申请原创#[url=home.php?mod=space&uid=760190]@21小跑堂 [/url]
一、安装PlatformIO
1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90
1.安装VSCode,在拓展找到PlatformIO,安装。
920872f152565e2bce750544c1cf57a9
2.安装好后创建工程
203b8156e15362eef02c73b87bde4d7d
0de2cb93b132841e6d614963ccf9085c
STM32F411VET6是没有JSON配置文件的,需要自己制作
860769cfb7af16ef47524b93468c4639
  "build": {
    "core": "stm32",
    "cpu": "cortex-m4",
    "extra_flags": "-DSTM32F411xE -DSTM32F4xx",
    "f_cpu": "120000000L",
    "mcu": "stm32f411vet6",
    "product_line": "STM32F411xE",
    "variant": "STM32F4xx/F411V(C-E)T"
  "debug": {
    "jlink_device": "STM32F411VE",
    "openocd_target": "stm32f4x",
    "svd_path": "STM32F411xx.svd"
  "frameworks": [
    "arduino",
    "cmsis",
    "stm32cube",
    "libopencm3"
  "name": "STM32F411VE (128k RAM. 512k Flash)",
  "upload": {
    "maximum_ram_size": 131072,
    "maximum_size": 524288,
    "protocol": "serial",
    "protocols": [
      "blackmagic",
      "dfu",
      "jlink",
      "serial",
      "stlink",
      "cmsis-dap"
  "url": "https://www.st.com/en/microcontrollers-microprocessors/stm32f411re.html",
  "vendor": "Generic"
支持Arduino开发和DAPLink下载。
还要修改链接脚本,时钟,引脚复用等,下图所示
935537a8eedfc027532e776f8fdc7b71
以上文件均会提供附件。
如果要支持USART3,UART4,UART5需要修改启动文件(startup_stm32f411xe.s)和stm32f411xe.h的中断枚举
b54f591c1d451fad9b71da5b0c8c1f65
2022948e5c91dbd22a5e77c9c21730e7
新建工程完成后,需要配置下载协议为cmsis-dap
d39f9365c394476716469c2a92aa269e
3dc4388e0a55788ae976310f8a903460
二、测试代码 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90 1189b082b95c7ce2920e488569313e90
#include<Arduino.h>
#define     LED2        PE6
#define     LED3        PE5
HardwareSerialSerial1(USART1);
voidsetup() {
  // put your setup code here, to run once:
  pinMode(LED2,OUTPUT);
  pinMode(LED3,OUTPUT);
  Serial1.begin(115200);
voidloop() {
  // put your main code here, to run repeatedly:
  digitalToggle(LED2);
  digitalToggle(LED3);
  Serial1.println("Hello World");
  delay(500);
三、展示
29c6d03f246693e6fe305ed0084300ad
PlatformIO资源.zip
638.7 KB, 下载次数: 1
打赏榜单
Gfan 打赏了 50.00 元 2024-07-17
理由:APM32F411V Tiny测评活动优质测评帖
weifeng90 发表于 2024-5-6 08:07 来自手机 | 显示全部楼层
VS不愧是史上最强开发工具
lilelelele 发表于 2024-9-30 09:06 | 显示全部楼层
这是stm32,不是apm32
 楼主| 袁胜富 发表于 2024-10-6 20:15 | 显示全部楼层
这是stm32,不是apm32
兼容STM32F 411
caigang13 发表于 2024-10-6 21:40 来自手机 | 显示全部楼层
不是极海的芯片吗?怎么成了STM32了?
 楼主| 袁胜富 发表于 2024-10-7 20:12 | 显示全部楼层
