[AT32WB415] 联合体位域在GPIO中的妙用
3157|0
 楼主| 袁胜富 发表于 2024-6-17 21:30 | 显示全部楼层 |阅读模式
[payamount]1.00[/payamount]
[pay]请在此处填写支付后可见内容[/pay]typedef union
        volatile uint32_t all;
        struct
                volatile uint32_t bit0:1;
                volatile uint32_t bit1:1;
                volatile uint32_t bit2:1;
                volatile uint32_t bit3:1;
                volatile uint32_t bit4:1;
                volatile uint32_t bit5:1;
                volatile uint32_t bit6:1;
                volatile uint32_t bit7:1;
                volatile uint32_t bit8:1;
                volatile uint32_t bit9:1;
                volatile uint32_t bit10:1;
                volatile uint32_t bit11:1;
                volatile uint32_t bit12:1;
                volatile uint32_t bit13:1;
                volatile uint32_t bit14:1;
                volatile uint32_t bit15:1;
                volatile uint32_t :16;//占位,不使用
        }bit;
        struct
                volatile uint32_t bytes0:8;
                volatile uint32_t bytes1:8;
                volatile uint32_t bytes2:8;
                volatile uint32_t bytes3:8;
        }bytes;
}GPIO_Bit_Field_TypeDef;
#define     PA_OUT                                ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x4001080C)))
#define     PAOut(n)                        (PA_OUT->bit.bit##n)
#define     PB_OUT                                ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x40010C0C)))
#define     PBOut(n)                        (PB_OUT->bit.bit##n)
#define     PC_OUT                                ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x4001100C)))
#define     PCOut(n)                        (PC_OUT->bit.bit##n)
#define     PD_OUT                                ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x4001140C)))
#define     PDOut(n)                        (PD_OUT->bit.bit##n)
#define     PE_OUT                                ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x4001180C)))
#define     PEOut(n)                        (PE_OUT->bit.bit##n)
#define     PF_OUT                                ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x40011C0C)))
#define     PFOut(n)                        (PF_OUT->bit.bit##n)
#define     PA_IN                                  ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x40010808)))
#define     PAIn(n)                          (PA_IN->bit.bit##n)
#define     PB_IN                                  ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x40010C08)))
#define     PBIn(n)                          (PB_IN->bit.bit##n)
#define     PC_IN                                  ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x40011008)))
#define     PCIn(n)                          (PC_IN->bit.bit##n)
#define     PD_IN                                  ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x40011408)))
#define     PDIn(n)                          (PD_IN->bit.bit##n)
#define     PE_IN                                  ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x40011808)))
#define     PEIn(n)                          (PE_IN->bit.bit##n)
#define     PF_IN                                  ((GPIO_Bit_Field_TypeDef*)((volatile uint32_t  *)(0x40011C08)))
#define     PFIn(n)                          (PF_IN->bit.bit##n)
#define                                                        LED2                                        PBOut(7)
#define                                                        LED3                                        PBOut(8)
#define                                                        LED4                                        PBOut(9)
__weak void application_entry(void *arg)
    while (1) {
        printf("This is a demo task,please use your task entry!\r\n");
                                LED2 =!LED2;
                                LED3 =!LED3;
                                LED4 =!LED4;
        tos_task_delay(100);
