| //定时器配置
void RFIDTim_init(void)
    TIM_TimeBaseInitTypeDef TIM_TimeBaseSt;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
    TIM_DeInit(RFID_TIM);
    TIM_TimeBaseSt.TIM_Prescaler = 72-1;    //
    TIM_TimeBaseSt.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseSt.TIM_Period = 1000;
    TIM_TimeBaseSt.TIM_ClockDivision =TIM_CKD_DIV1;
    TIM_TimeBaseInit(RFID_TIM, &TIM_TimeBaseSt);
    TIM_Cmd(RFID_TIM, ENABLE);
    DEBUG("time init ok \n");
//IO及中断配置
void RFID_Exti_Init(void){
    EXTI_InitTypeDef   EXTI_InitStructure;
    GPIO_InitTypeDef   GPIO_InitStructure;
    NVIC_InitTypeDef   NVIC_InitStructure;
    /* Enable GPIOA clock */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    /* Enable AFIO clock */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
    /* Configure PA.00 pin as input floating */
    GPIO_InitStructure.GPIO_Pin = OUT_PIN;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init(OUT_PORT, &GPIO_InitStructure);
    GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource7);//将PA7挂在中断源上
    /* Configure EXTI0 line */
    EXTI_InitStructure.EXTI_Line = EXTI_Line7;
    EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling;
    EXTI_InitStructure.EXTI_LineCmd = ENABLE;
    EXTI_Init(&EXTI_InitStructure);
    EXTI_ClearITPendingBit(EXTI_Line7);
    /* Enable and set EXTI0 Interrupt to the lowest priority */
    NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x00;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x00;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
//RFID初始化
void RFIDInit(void)
    DEBUG("Start Init EM4095 RFID Module\r\n");
    RFIDTim_init();//定时器配置
    RFID_Exti_Init();//IO初始化及中断配置
    DEBUG("finish init EM4095 RFID Module\r\n");
 中断处理函数
// Interrupt bei Flankenwechsel
void EXTI9_5_IRQHandler(void)
    static u8 N = 0;
    if(EXTI_GetITStatus(EXTI_Line7) != RESET)
        if(gFlag == 0x00)
            TT_Buffer[N]= TIM_GetCounter(RFID_TIM); //数组记录计时器计时时间
            TT_voltage[N]=GPIO_ReadInputDataBit(OUT_PORT,OUT_PIN);//数组保存此时IO电平
            TIM_SetCounter(RFID_TIM, 0);//计时器清0
            N++;
            if(N== 1)//cym
               gFlag = 0xFF;
//数据解析
unsigned char Decode(void)
    u16  min,max,avg,i,n;
    min = 0xFF;max = 0xFF;avg = 0xFF;i = 0xFF;n = 0xFF;
    //-------------------- STEP1: 找出 [平均值]
    for(i=1; i<256; i++) //---- 从1开始! 0字节是不可靠数据
        if(TT_Buffer[i]<min)
            min = TT_Buffer[i];
        if(TT_Buffer[i]>max)
            max = TT_Buffer[i];
    //数据过滤
    if(min<100||max>1000)
        //DEBUG("\r\n min: %d max: %d ; |舍弃 ! | \r\n",min,max);
        return 0;
    avg=((min+max)/2);//-----平均值
    n = 0;
    //-------------------- STEP2: 提取原始数据
       for(i=1; i<256; i++) //---- 必须从1开始! 0字节是不可靠数据
        if (TT_Buffer[i]<avg )//(abs((int)TT_Buffer[i] - 245)<=70)
            if (TT_voltage[i]==1)
                Bin_Buffer[n++]=0;
            else
                Bin_Buffer[n++]=1;
        else if (TT_Buffer[i]>avg )//(abs((int)TT_Buffer[i] - 485)<=70)
                Bin_Buffer[n++]=0;
                Bin_Buffer[n++]=0;
            else
                Bin_Buffer[n++]=1;
                Bin_Buffer[n++]=1;
    //-------------------- STEP3: 查找RFID头标志(9个1)
    i = n-128;  //------- 有效起始点!
    while(i--)
        if(FindHeader(i))
            if(FindID(i))
                return 1;
    return 0;
/*=================== 查找RFID 头标志 9个1
//--- 匹配返回:1
//--- 无效返回:0*/
u8 FindHeader(u16 index)
    u8 n;
    if((Bin_Buffer[index]==0)&&(Bin_Buffer[index+1]==1))//cym 1/0
        index++;
        index++;
    else
        return (0);
    for(n=0; n<9; n++)
        if((Bin_Buffer[index]==1)&&(Bin_Buffer[index+1]==0))//cym 0/1
            index = index+2;
        else
            return (0);
    return (1);
将头后的数据解析为实际的卡号数据。
u8 FindID(u16 i)
    u8 n;
    u8 k;
    u8 sum;
    //-------------------- STEP1: 提取RFID有效数据
    if(i)
        for(n=0; n<11; n++)RFID[n] = 0x00; //------ Buffer清零
        i = i+20;  //--- 有效数据流
        for(k=0; k<11; k++)
            for(n=0; n<5; n++)
                RFID[k] = RFID[k]<<1;
                if((Bin_Buffer[i]==1)&&(Bin_Buffer[i+1]==0))//cym 0/1
                    RFID[k] |= 0x01;
                i += 2;
    //---------------------------- STEP2: 校对数据
    //---------------------- X 轴校验
    for(k=0; k<10; k++)
        sum = 0;
        if(RFID[k]&0x01)sum++;
        if(RFID[k]&0x02)sum++;
        if(RFID[k]&0x04)sum++;
        if(RFID[k]&0x08)sum++;
        if(RFID[k]&0x10)sum++;
        if(sum%2) //--- 偶校验出错!
            // MessageBox("X 轴校验出错!");
            return 0;
    //------------------- Y 轴校验
    sum = 0;
    for(k=0; k<11; k++)
        sum ^= RFID[k];
    if(sum&0x1E) //--- 偶校验出错!
        //MessageBox("Y 轴校验出错!");
        return 0;
    //------------------ STEP3: 获取RFID卡号(4个字节32位)
    for(k=0; k<10; k++)
        RFID[k] = RFID[k]>>1; //---去掉校验值
    Vendor  = 0;
    CardIDH = 0;
    CardIDL = 0;
    k = RFID[0]<<4;
    Vendor = k|RFID[1]; //--- 卡版本或供应商信息
    k = RFID[2]<<4;
    k |= RFID[3];
    CardIDH |= k<<8;
    k = RFID[4]<<4;
    k |= RFID[5];
    CardIDH |= k;
    k = RFID[6]<<4;
    k |= RFID[7];
    CardIDL |= k<<8;
    k = RFID[8]<<4;
    k |= RFID[9];
    CardIDL |= k;
    //------------------ STEP4: 显示解码结果
    return 1;
