[其他]
脉冲镀铜 OMG PC600 ppr 200 填通空 填盲孔 TGV TSV
11734|0
wuxizd|  楼主 | 2024-7-2 13:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AN, ic, IO, TI, 脉冲, pc
特性和优点
1.MC-1200是一种酸性镀铜添加剂系统,专门针对连续生产的脉冲周期性反整流进行了优化;
2.这一过程产生了一种细粒的、韧性的、具有良好分布特征的沉积物,并由两部分组成;
3.MC-1200和周期性反脉冲电镀整流器的组合可以显著缩短电镀时间,同时保持良好的镀铜层厚度分布比;
4.尤其适合纵横比在20:1的印制电路板;
1.MC-1200 is an acid copper plating additive system that has been specifically optimized for use with pulse periodic reverse rectification on a continual production basis;
2.The process produces a fine-grained, ductile deposit with excellent distribution characteristics, and is maintained with two components;
3.The combination of MC-1200 and a periodic reverse pulse plating rectifier can significantly shorten plating times while maintaining excellent copper thickness distribution ratios;
4.Especially suitable for printed circuit boards with an aspect ratio of 20:1;
