[技术讨论] 百问网全志D1h开发板MIPI屏适配
3057|1
 楼主| 神棍地海棠 发表于 2024-7-10 10:29 | 显示全部楼层 |阅读模式
MIPI屏适配
100ASK-D1-H_DualDisplay-DevKit V11
1. 显示适配1.1 修改设备树1.1.1 修改内核设备树
进入目录:
[color=var(--hljs-builtin-name)]cd /home/ubuntu/tina-d1-h/device/config/chips/d1-h/configs/nezha/linux-5.4
修改board.dts:
&lcd0 {        lcd_used            = <1>;        lcd_driver_name     = [color=var(--hljs-string)]"tft08006";        lcd_backlight       = <100>;        lcd_if              = <4>;        lcd_x               = <480>;        lcd_y               = <800>;        lcd_width           = <52>;        lcd_height          = <52>;        lcd_dclk_freq       = <25>;        lcd_pwm_used        = <1>;        lcd_pwm_ch          = <0>;        lcd_pwm_freq        = <1000>;        lcd_pwm_pol         = <0>;        lcd_pwm_max_limit   = <255>;        lcd_hbp             = <10>;        lcd_ht              = <515>;        lcd_hspw            = <5>;        lcd_vbp             = <20>;        lcd_vt              = <830>;        lcd_vspw            = <5>;        lcd_dsi_if          = <0>;        lcd_dsi_lane        = <2>;        lcd_lvds_if         = <0>;        lcd_lvds_colordepth = <0>;        lcd_lvds_mode       = <0>;        lcd_frm             = <0>;        lcd_hv_clk_phase    = <0>;        lcd_hv_sync_polarity= <0>;        lcd_gamma_en        = <0>;        lcd_bright_curve_en = <0>;        lcd_cmap_en         = <0>;        lcd_fsync_en        = <0>;        lcd_fsync_act_time  = <1000>;        lcd_fsync_dis_time  = <1000>;        lcd_fsync_pol       = <0>;        deu_mode            = <0>;        lcdgamma4iep        = <22>;        smart_color         = <90>;        lcd_gpio_0 =  <&pio PG 13 GPIO_ACTIVE_HIGH>;        pinctrl-0 = <&dsi4lane_pins_a>;        pinctrl-1 = <&dsi4lane_pins_b>;};
根据原理图:
[color=var(--tertiary)][color=var(--secondary)]image-1[color=var(--secondary-high)]1178×985 197 KB
可以查看到,mipi屏的pwm通道引脚是PB5,设备树中搜索PB5,发现有I2C设备树节点占用,需要把status位设置为disabled:
[color=var(--tertiary)][color=var(--secondary)]image-2[color=var(--secondary-high)]634×535 64.8 KB
lcd0设备树节点中的pwm通道是pwm0,即把pwm0设备树节点的引脚改为相应的PB5引脚:
1.1.2 修改uboot设备树
进入目录:
修改uboot-board.dts:
&lcd0 {        lcd_used            = <1>;        lcd_driver_name     = [color=var(--hljs-string)]"tft08006";        lcd_backlight       = <100>;        lcd_if              = <4>;        lcd_x               = <480>;        lcd_y               = <800>;        lcd_width           = <52>;        lcd_height          = <52>;        lcd_dclk_freq       = <25>;        lcd_pwm_used        = <1>;        lcd_pwm_ch          = <0>;        lcd_pwm_freq        = <1000>;        lcd_pwm_pol         = <0>;        lcd_pwm_max_limit   = <255>;        lcd_hbp             = <10>;        lcd_ht              = <515>;        lcd_hspw            = <5>;        lcd_vbp             = <20>;        lcd_vt              = <830>;        lcd_vspw            = <5>;        lcd_dsi_if          = <0>;        lcd_dsi_lane        = <2>;        lcd_lvds_if         = <0>;        lcd_lvds_colordepth = <0>;        lcd_lvds_mode       = <0>;        lcd_frm             = <0>;        lcd_hv_clk_phase    = <0>;        lcd_hv_sync_polarity= <0>;                lcd_io_phase        = <0x0000>;                lcd_dsi_te                = <0>;        lcd_gamma_en        = <0>;        lcd_bright_curve_en = <0>;        lcd_cmap_en         = <0>;        lcd_fsync_en        = <0>;        lcd_fsync_act_time  = <1000>;        lcd_fsync_dis_time  = <1000>;        lcd_fsync_pol       = <0>;        deu_mode            = <0>;        lcdgamma4iep        = <22>;        smart_color         = <90>;        lcd_gpio_0 =  <&pio PG 13 GPIO_ACTIVE_HIGH>;        pinctrl-0 = <&dsi4lane_pins_a>;        pinctrl-1 = <&dsi4lane_pins_b>;};1.2 内核配置
修改内核驱动:
进入目录:
~/tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd
在这里[color=var(--tertiary)]100ASK_T113-PRO开发板适配4寸MIPI屏-Tina SDK - Allwinner / T113s3-PRO - 嵌入式开发问答社区可以下载到相应的驱动,替换到TinaSDK里面的tft08006.c和tft08006.h。
并修改如下:
[color=var(--tertiary)][color=var(--secondary)]image-9[color=var(--secondary-high)]1029×452 17.4 KB
执行ckernel,进入内核配置界面:
m kernel_menuconfig
选上屏幕显示驱动TFT08006:
[color=var(--tertiary)][color=var(--secondary)]image-4[color=var(--secondary-high)]2230×1064 221 KB
选上支持显示框架驱动:
[color=var(--tertiary)][color=var(--secondary)]image-5[color=var(--secondary-high)]2222×1083 182 KB
"DISP Driver Support"关乎显示驱动框架的整体启用,而"LCD panels select"则专注于在这个框架下选择和配置具体的LCD面板硬件。前者是基础支持层,后者是具体应用层。
1.3 uboot配置
修改uboot下的驱动:
进入目录:
~/tina-d1-h/lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/lcd
并修改如下:
[color=var(--tertiary)][color=var(--secondary)]image-10[color=var(--secondary-high)]1093×471 17.4 KB
执行cboot,进入uboot配置界面:
make menuconfig
选上屏幕显示驱动:
[color=var(--tertiary)][color=var(--secondary)]image-6[color=var(--secondary-high)]2224×1072 215 KB
选上支持显示框架驱动:
[color=var(--tertiary)][color=var(--secondary)]image-7[color=var(--secondary-high)]2228×1064 184 KB
mipi屏幕显示需要先在uboot阶段初始化。
1.4 显示测试
为了方便测试屏幕显示,可以选上TinaSDK自带的lvgl例程。
执行croot,进入配置界面:
make menuconfig
选上lvgl例程:
[color=var(--tertiary)][color=var(--secondary)]image-8[color=var(--secondary-high)]2223×1062 82.3 KB
编译make,打包pack。
烧录到板子后,执行lv_examples 1:
[color=var(--tertiary)][color=var(--secondary)]image-11[color=var(--secondary-high)]891×516 55.9 KB
2. 触摸适配2.1 修改内核设备树
根据原理图:
[color=var(--tertiary)][color=var(--secondary)]image-12[color=var(--secondary-high)]1213×820 226 KB
可以查看:
TP_INT→PB6;TP_RESET→PB4;DSI_SCL→PB0;DSI_SDA→PB1;
进入:
vi /home/ubuntu/tina-d1-h/device/config/chips/d1-h/configs/nezha/linux-5.4/board.dts
看到PB0、PB1引脚对应的是twi2设备树节点。所以需要在twi2设备树节点中添加触摸屏设备树节点。
&twi2 {        clock-frequency = <400000>;        pinctrl-0 = <&twi2_pins_a>;        pinctrl-1 = <&twi2_pins_b>;        pinctrl-names = [color=var(--hljs-string)]"default", [color=var(--hljs-string)]"sleep";        dmas = <&dma 45>, <&dma 45>;        dma-names = [color=var(--hljs-string)]"tx", [color=var(--hljs-string)]"rx";        status = [color=var(--hljs-string)]"okay";        ctp@38 {                compatible = [color=var(--hljs-string)]"focaltech,fts";                reg = <0x38>;                status = [color=var(--hljs-string)]"okay";                interrupt-parent = <&pio>;                interrupts = <PB 6 IRQ_TYPE_LEVEL_LOW>;                focaltech,reset-gpio = <&pio PB 4 GPIO_ACTIVE_HIGH>;                focaltech,irq-gpio = <&pio PB 6 IRQ_TYPE_LEVEL_LOW>;                focaltech,max-touch-number = <5>;                focaltech,display-coords = <0 0 480 800>;                focaltech,reg_vdd = <0x0000001f>;                                focaltech,reg_avdd = <0x0000001f>;        };};
如果原来有同样地址为0x38的I2C设备和触摸设备的节点时,可以注释或者删除。
2.2 添加触摸驱动
Tina_SDK自带相应的触摸驱动,只需修改内核配置,把驱动编译进系统。
执行ckernel进入内核目录。
执行m kernel_menuconfig,进入内核配置界面,选上Focaltech Touchscreen :
[color=var(--tertiary)][color=var(--secondary)]image-14[color=var(--secondary-high)]2227×1061 217 KB
执行croot,进入SDK根目录,执行make menuconfig进入配置界面,把触摸驱动模块添加进文件系统中:
[color=var(--tertiary)][color=var(--secondary)]image-15[color=var(--secondary-high)]2226×1060 157 KB
2.3 修改触摸驱动
在测试过程中,发现触摸点(x,y)不对,需要修改驱动程序。
进入目录:
tina-d1-h/lichee/linux-5.4/drivers/input/touchscreen/focaltech_touch
修改:
vim focaltech_core.c
两处修改:
  • 在fts_input_dev_report_a函数中修改,找到相应的位置:
[color=var(--hljs-comment)]#原来的input_report_abs(data->input_dev, ABS_MT_POSITION_X, event->au16_x);input_report_abs(data->input_dev, ABS_MT_POSITION_Y, event->au16_y);[color=var(--hljs-comment)]#修改的input_report_abs(data->input_dev, ABS_MT_POSITION_X, -(event->au16_x - 480));input_report_abs(data->input_dev, ABS_MT_POSITION_Y, -(event->au16_y - 800));
  • 在fts_input_dev_report_b函数中修改,找到相应的位置:
[color=var(--hljs-comment)]#原来的input_report_abs(data->input_dev, ABS_MT_POSITION_X, event->au16_x);input_report_abs(data->input_dev, ABS_MT_POSITION_Y, event->au16_y);[color=var(--hljs-comment)]#修改的input_report_abs(data->input_dev, ABS_MT_POSITION_X, -(event->au16_x - 480));input_report_abs(data->input_dev, ABS_MT_POSITION_Y, -(event->au16_y - 800));2.4 修改lvgl驱动配置文件
如果在lvgl的例程上测试触摸功能,需要进入目录:
[color=var(--hljs-builtin-name)]cd /home/ubuntu/tina-d1-h/package/gui/littlevgl-8/lv_examples/src
修改:
vim lv_drv_conf.h
[color=var(--tertiary)][color=var(--secondary)]image-16[color=var(--secondary-high)]1977×742 119 KB
如果之前配置过lvgl例程,需要进入目录:
[color=var(--hljs-builtin-name)]cd /home/ubuntu/tina-d1-h/out/d1-h-nezha/compile_dir/target
删除lv_examples,再进行编译打包烧录。
开发板上执行lv_examples 0,测试:
jiazzy 发表于 2024-11-25 21:10 | 显示全部楼层
