[技术问答] Cortex-M系列MCU最大亮点是低功耗
1290|2
 楼主| earlmax 发表于 2024-8-15 07:33 | 显示全部楼层 |阅读模式
item
Cortex-M0
Cortex-M0+
Cortex-M3
Cortex-M4
Cortex-M7
Cortex M23
Cortex-M33
Cortex-M35P
Cortex-M52
Cortex-M55
Cortex-M85
CoreMark/MHz
2.33
2.46
3.45
3.54
5.29
2.64
4.1
4.1
4.3
4.4
6.28
DMIPS/MHz*
0.96/1.19/1.91
0.99/1.30/2.58
1.24/1.64/3.49
1.26/1.67/3.65
2.31/3.23/6.78
1.03/1.32/2.67
1.54/2.05/4.48
1.5
1.6
1.69/2.16/5.32
3.13/4.52/8.76
180ULL
(7-track, typical 1.8v, 25°C)
66μW/MHz, 0.11mm2
47.4µW/MHz, 0.098mm2
141µW/MHz, 0.35mm2
151μW/MHz, 0.44mm2
90LP
(7-track, typical 1.2v, 25°C)
12.5μW/MHz, 0.03mm2
9.37µW/MHz, 0.028mm2
31µW/MHz, 0.09mm2
32.82μW/MHz, 0.119mm2
40LP
(9-track, typical 1.1v, 25°C)
5.3μW/MHz, 0.008mm2
3.8µW/MHz, 0.0066mm2
11µW/MHz, 0.02mm2
12.26μW/MHz, 0.028mm2
58.5μW/MHz, 0.105mm2
3.86μW/MHz, 0.0088mm2
12.0μW/MHz, 0.028mm2
40LP
(7-track, typical 0.99V, -40°C)
14.7μW/MHz, 0.091mm2
28HT
(9-track, typical 0.81v, 85°C)
31.8μW/MHz, 0.052mm2
28HT
(7-track, typical 0.81V, 0°C)
9.2μW/MHz, 0.034mm2
28HPC+
(9-track, typical 0.81V, 0°C)
2.26μW/MHz, 0.0037mm2
28HPC+
3.8μW/MHz, 0.014mm2
16FFC
(9-track, typical 0.72V, 0°C)
5.1μW/MHz, 0.021mm2
16FFC
(7-track, typical 0.72v, 85°C)
18.5μW/MHz, 0.028mm2
3.9μW/MHz, 0.008mm2
* 第一个结果遵守了 Dhrystone 文档中所有的“基本规则”,第二个允许函数 inline,而不仅仅是允许的 C 字符串库,而第三个则允许同时(“multi-file”)编译。所有这些都与 Dhrystone 的原始(K和R)v2.1。Arm Compiler 6.17。
呐咯密密 发表于 2024-8-15 14:07 | 显示全部楼层
怎么驴头不对马嘴
又见春光 发表于 2025-8-30 13:55 | 显示全部楼层
Cortex-M 系列 MCU 以低功耗为核心亮点,集成多种睡眠模式,支持外设独立开关,结合高效指令集与唤醒机制,兼顾能效与响应速度。
