//串口 #define UART0_RX_BUFF_LEN (56 * 16) #define UART0_FRAME_MAX_LEN (56) //单帧最长长度 /****************************************** 全局变量 *********************************************/ /*串口缓存全局变量初始化*/ volatile unsigned char g_u8Uart0RxDataMem[UART0_RX_BUFF_LEN] = {0}; //串口0缓存 volatile unsigned short gUart0RxByteNum = 0; //已经接收到的字节数量 volatile unsigned short gUart0RxIndex = 0; //接收循环写入 volatile unsigned short gUart0RxStartIndex = 0; //处理起始位 //串口一个字节一个字节的收 LONG CAudioProcessorDlg::OnCommunication(WPARAM ch, LPARAM port) { unsigned char *pUart0RxDataMem = (unsigned char * )g_u8Uart0RxDataMem; unsigned char u8DataLen = 0; //解析桢字节长度 CString str; str.Format(L"%02X", ch); unsigned char u8Temp[4] = { 0 }; int nRet = 0; int i = 0; int nRealLen = 0; int nRealBeginIndex = 0; unsigned char u8UartParaBuf[UART0_FRAME_MAX_LEN] = {0}; //临时变量,每次处理一帧数据 Unicode_Cstring2char(str, (char*)u8Temp); //转换一下 for (i = 0; i < 4; i++ ) { if (u8Temp[i] >= 'A') { u8Temp[i] = u8Temp[i] - 55; } else { u8Temp[i] = u8Temp[i] - 0x30; } } //按字节接收数据,保证此buf是循环buf g_u8Uart0RxDataMem[gUart0RxIndex % UART0_RX_BUFF_LEN] = (u8Temp[0] << 4) | u8Temp[1]; gUart0RxIndex = (gUart0RxIndex + 1) % UART0_RX_BUFF_LEN; gUart0RxByteNum++; //开始解析数据 while(gUart0RxByteNum) //接收的长度如果大于0 { if(pUart0RxDataMem[gUart0RxStartIndex] == 0x55)//第一个帧头字节正确 { break; } pUart0RxDataMem[gUart0RxStartIndex % UART0_RX_BUFF_LEN] = 0; gUart0RxStartIndex = (gUart0RxStartIndex + 1) % UART0_RX_BUFF_LEN; gUart0RxByteNum--; } if(gUart0RxByteNum >= UART_RX_PROTOCOL_SIZE) //接收到字节数大于14字节 { if (0xAA == pUart0RxDataMem[((gUart0RxStartIndex + 1) % UART0_RX_BUFF_LEN)]) { //取桢长度 u8DataLen = pUart0RxDataMem[((gUart0RxStartIndex + 2) % UART0_RX_BUFF_LEN)]; if((UART_RX_PROTOCOL_SIZE == u8DataLen) || (UART_RX_ExPROTOCOL_SIZE == u8DataLen)) { if(CheckReciveDataCRC(pUart0RxDataMem, u8DataLen)) { //拷贝一帧数据出来 for(i = 0; i < u8DataLen; i++) { //校验通过将数据取出存放到u8UartParaBuf u8UartParaBuf[i] = pUart0RxDataMem[gUart0RxStartIndex]; pUart0RxDataMem[gUart0RxStartIndex] = 0; gUart0RxStartIndex = (gUart0RxStartIndex + 1) % UART0_RX_BUFF_LEN; gUart0RxByteNum--; } u8DataLen = ProcessingProtocolData(u8UartParaBuf, u8DataLen); CommunicationSend((char *)u8UartParaBuf, u8DataLen); } else { pUart0RxDataMem[gUart0RxStartIndex % UART0_RX_BUFF_LEN] = 0; gUart0RxStartIndex = (gUart0RxStartIndex + 1) % UART0_RX_BUFF_LEN; gUart0RxByteNum--; } } else { pUart0RxDataMem[gUart0RxStartIndex % UART0_RX_BUFF_LEN] = 0; gUart0RxStartIndex = (gUart0RxStartIndex + 1) % UART0_RX_BUFF_LEN; gUart0RxByteNum--; } } else { //桢头异常,清除此桢 pUart0RxDataMem[gUart0RxStartIndex % UART0_RX_BUFF_LEN] = 0; gUart0RxStartIndex = (gUart0RxStartIndex + 1) % UART0_RX_BUFF_LEN; gUart0RxByteNum--; } } return 0; }
收藏1 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
等级类勋章
发帖类勋章
时间类勋章
人才类勋章
332
11329
13
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
