[PADS] PADS加过孔
1471|0
 楼主| forgot 发表于 2024-11-7 10:38 | 显示全部楼层 |阅读模式
单击老鼠右键,check “select net”, select the net you want to add via, usually, GND net, the GND is high light. Then right click mouse again, select “ add via”, then you can add vias which are connected to GND net. Freely and put them wherever you want. Remember, if the GND net is hide and set to a special color, no connection for these vias, but they are same color as other pads and trace in GND net.
