求ESP32通过mqtt和android进行图片传输代码
17613|5
 楼主| macpherson 发表于 2024-11-17 21:33 | 显示全部楼层 |阅读模式
求ESP32通过mqtt和android进行图片传输代码提供apk的编译文件。代码运行成功截图。
提供运行机制说明,自己修改的说明。
3472076282 发表于 2024-11-26 09:32 | 显示全部楼层
ESP32 端代码
首先,确保你已经安装了所需的库,例如 PubSubClient WiFi
#include <WiFi.h>
#include <PubSubClient.h>
// WiFi credentials
const char* ssid = "your_SSID";
const char* password = "your_PASSWORD";
// MQTT Broker
const char* mqtt_server = "broker.hivemq.com";
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
  Serial.begin(115200);
  setup_wifi();
  client.setServer(mqtt_server, 1883);
void setup_wifi() {
  delay(10);
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
void reconnect() {
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    if (client.connect("ESP32Client")) {
      Serial.println("connected");
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      delay(5000);
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
Android 端代码
Android端,你可以使用Paho MQTT库来连接到MQTT Broker并发送/接收消息。以下是一个基本的示例:
1. 添加依赖项到你的 build.gradle 文件:
dependencies {
    implementation 'org.eclipse.paho:org.eclipse.paho.client.mqttv3:1.2.5'
    implementation 'org.eclipse.paho:org.eclipse.paho.android.service:1.1.1'
2. 创建一个服务来处理MQTT连接:
import android.app.Service;
import android.content.Intent;
import android.os.IBinder;
import org.eclipse.paho.android.service.MqttAndroidClient;
import org.eclipse.paho.client.mqttv3.IMqttActionListener;
import org.eclipse.paho.client.mqttv3.IMqttToken;
import org.eclipse.paho.client.mqttv3.MqttCallback;
import org.eclipse.paho.client.mqttv3.MqttMessage;
public class MqttService extends Service {
    private static final String MQTT_BROKER_URL = "tcp://broker.hivemq.com:1883";
    private static final String CLIENT_ID = "AndroidClient";
    private MqttAndroidClient mqttAndroidClient;
    @Override
    public void onCreate() {
        super.onCreate();
        mqttAndroidClient = new MqttAndroidClient(this, MQTT_BROKER_URL, CLIENT_ID);
        mqttAndroidClient.setCallback(new MqttCallback() {
            @Override
            public void connectionLost(Throwable cause) {
                // handle connection loss
            @Override
            public void messageArrived(String topic, MqttMessage message) throws Exception {
                // handle incoming message
            @Override
            public void deliveryComplete(IMqttDeliveryToken token) {
                // handle message delivery complete
    @Override
    public int onStartCommand(Intent intent, int flags, int startId) {
        connectToMqttBroker();
        return START_STICKY;
    private void connectToMqttBroker() {
        try {
            mqttAndroidClient.connect(null, new IMqttActionListener() {
                @Override
                public void onSuccess(IMqttToken asyncActionToken) {
                    // subscribe to a topic or publish a message
                @Override
                public void onFailure(IMqttToken asyncActionToken, Throwable exception) {
                    // handle failure to connect
        } catch (Exception e) {
            e.printStackTrace();
    @Override
    public IBinder onBind(Intent intent) {
        return null;
3. 启动服务:
Intent serviceIntent = new Intent(this, MqttService.class);
startService(serviceIntent);
4. 发布或订阅消息:
    // To publish a message
String topic = "test/topic";
String message = "Hello from Android";
try {
    mqttAndroidClient.publish(topic, message.getBytes(), 0, false);
// To subscribe to a topic
try {
    mqttAndroidClient.subscribe(topic, 0);
图片传输示例
假设你要传输一张图片,可以将图片转换为字节数组并通过MQTT发送。以下是一个简单的例子:
ESP32 端接收图片数据:
void callback(char* topic, byte* payload, unsigned int length) {
  // Assuming the payload is the image data in bytes
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload);
  Serial.println();
Android 端发送图片数据:
Bitmap bitmap = ... // your bitmap image
ByteArrayOutputStream baos = new ByteArrayOutputStream();
bitmap.compress(Bitmap.CompressFormat.JPEG, 100, baos); // bmp is your Bitmap instance
byte[] bytes = baos.toByteArray();
String base64Image = Base64.encodeToString(bytes, Base64.DEFAULT);
try {
    mqttAndroidClient.publish("image/topic", base64Image.getBytes(), 0, false);
以上代码展示了如何在ESP32Android之间通过MQTT进行图片传输的基本方法。根据你的具体需求,你可能需要进一步优化和调整代码。
gaochy1126 发表于 2024-11-30 21:23 | 显示全部楼层
// send_img_aliyun.ino
#include <WiFi.h>
#include <Wire.h>
#include <ArduinoJson.h>
// #include "aliyun_mqtt.h"
#include "aliyunmqtt.h"
#include "esp_camera.h"
#include <SPIFFS.h>
#include "FS.h"                // SD Card ESP32
#include "SD_MMC.h"            // SD Card ESP32
#include "soc/soc.h"           // Disable brownour problems
#include "soc/rtc_cntl_reg.h"  // Disable brownour problems
#include "driver/rtc_io.h"
#include <EEPROM.h>
// 内存存储相关配置
#define EEPROM_SIZE 1
int pictureNumber = 0;
String msg;
int buttonState = 0;
int btnHold = 0;
// #define SENSOR_PIN 10
//以下信息需要自己修改
#define WIFI_SSID "TP-LINK_1760"  //替换自己的WIFI
#define WIFI_PASSWD "987654321"   //替换自己的WIFI密码
// 阿里云物联网 三元组
#define PRODUCT_KEY "k0xxxxxIM"                         //替换自己的PRODUCT_KEY
#define DEVICE_NAME "esp001_001"                       //替换自己的DEVICE_NAME
#define DEVICE_SECRET "589xxxxxxxxxxxxxxxxxxxe0f"  //替换自己的DEVICE_SECRET \
//以下不需修改
#define ALINK_BODY_FORMAT "{\"id\":\"123\",\"version\":\"1.0\",\"method\":\"%s\",\"params\":%s}"
#define ALINK_TOPIC_PROP_POST "/sys/" PRODUCT_KEY "/" DEVICE_NAME "/thing/event/property/post"
#define ALINK_TOPIC_PROP_POSTRSP "/sys/" PRODUCT_KEY "/" DEVICE_NAME "/thing/event/property/post_reply"
#define ALINK_TOPIC_PROP_SET "/sys/" PRODUCT_KEY "/" DEVICE_NAME "/thing/service/property/set"
#define ALINK_METHOD_PROP_POST "thing.event.property.post"
#define ALINK_TOPIC_DEV_INFO "/ota/device/inform/" PRODUCT_KEY "/" DEVICE_NAME ""
#define ALINK_VERSION_FROMA "{\"id\": 123,\"params\": {\"version\": \"%s\"}}"
unsigned long lastMs = 0;
// 测试 初始温度
int i = 15;
PubSubClient mqttClient(espClient);
//CAMERA_MODEL_AI_THINKER类型摄像头的引脚定义
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
static camera_config_t camera_config = {
  .pin_pwdn = PWDN_GPIO_NUM,
  .pin_reset = RESET_GPIO_NUM,
  .pin_xclk = XCLK_GPIO_NUM,
  .pin_sscb_sda = SIOD_GPIO_NUM,
  .pin_sscb_scl = SIOC_GPIO_NUM,
  .pin_d7 = Y9_GPIO_NUM,
  .pin_d6 = Y8_GPIO_NUM,
  .pin_d5 = Y7_GPIO_NUM,
  .pin_d4 = Y6_GPIO_NUM,
  .pin_d3 = Y5_GPIO_NUM,
  .pin_d2 = Y4_GPIO_NUM,
  .pin_d1 = Y3_GPIO_NUM,
  .pin_d0 = Y2_GPIO_NUM,
  .pin_vsync = VSYNC_GPIO_NUM,
  .pin_href = HREF_GPIO_NUM,
  .pin_pclk = PCLK_GPIO_NUM,
  .xclk_freq_hz = 20000000,
  .ledc_timer = LEDC_TIMER_0,
  .ledc_channel = LEDC_CHANNEL_0,
  .pixel_format = PIXFORMAT_JPEG,
  // .frame_size = FRAMESIZE_VGA,
  // FRAMESIZE_UXGA (1600 x 1200)
  // FRAMESIZE_QVGA (320 x 240)
  // FRAMESIZE_CIF (352 x 288)
  // FRAMESIZE_VGA (640 x 480)
  // FRAMESIZE_SVGA (800 x 600)
  // FRAMESIZE_XGA (1024 x 768)
  // FRAMESIZE_SXGA (1280 x 1024)
  .frame_size = FRAMESIZE_QVGA,
  .jpeg_quality = 10,
  // 图像质量(jpeg_quality) 可以是 0 到 63 之间的数字。数字越小意味着质量越高
  .fb_count = 1,
void init_wifi(const char *ssid, const char *password) {
  WiFi.mode(WIFI_STA);
    Serial.println("WiFi does not connect, try again ...");
    delay(500);
  Serial.println("Wifi is connected.");
void mqtt_callback(char *topic, byte *payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  payload[length] = '\0';
  Serial.println((char *)payload);
  if (strstr(topic, ALINK_TOPIC_PROP_SET)) {
    StaticJsonBuffer<100> jsonBuffer;
    JsonObject &root = jsonBuffer.parseObject(payload);
    if (!root.success()) {
      Serial.println("parseObject() failed");
      return;
void mqtt_check_connect() {
  while (!mqttClient.connected())  //
    while (connect_aliyun_mqtt(mqttClient, PRODUCT_KEY, DEVICE_NAME, DEVICE_SECRET)) {
      Serial.println("MQTT connect succeed!");
      //client.subscribe(ALINK_TOPIC_PROP_POSTRSP);
      mqttClient.subscribe(ALINK_TOPIC_PROP_SET);
      Serial.println("subscribe done");
void mqtt_interval_post() {
  //  static int i=0;
  char param[512];
  char jsonBuf[1024];
  sprintf(jsonBuf, "{\"id\":\"1189401707\",\"version\":\"1.0.0\",\"method\":\"%s\",\"params\":{\"img\":\"END\"}}");
  Serial.println(jsonBuf);
  mqttClient.publish(ALINK_TOPIC_PROP_POST, jsonBuf);
  Serial.println("发送结束符");
  delay(1000);
// 摄像头、SD卡与 SPIFFS 初始化
esp_err_t camera_init() {
  //initialize the camera
  esp_err_t err = esp_camera_init(&camera_config);
  if (err != ESP_OK) {
    Serial.println("Camera Init Failed");
    return err;
  sensor_t *s = esp_camera_sensor_get();
  //initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV2640_PID) {
    //        s->set_vflip(s, 1);//flip it back
    //        s->set_brightness(s, 1);//up the blightness just a bit
    //        s->set_contrast(s, 1);
  Serial.println("Camera Init OK!");
  return ESP_OK;
void sd_init(void) {
  //SD card init
  if (!SD_MMC.begin()) {
    Serial.println("Card Mount Failed");
    return;
  uint8_t cardType = SD_MMC.cardType();
  if (cardType == CARD_NONE) {
    Serial.println("No SD_MMC card attached");
    return;
void SPIFFS_init() {
  //初始化SPIFFS
  if (!SPIFFS.begin(true)) {
    Serial.println("An Error has occurred while mounting SPIFFS");
  } else {
    delay(500);
    Serial.println("SPIFFS mounted successfully");
  //Turn-off the 'brownout detector'
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
// 摄像头、SD卡与 SPIFFS 初始化 end
void setup() {
  Serial.println("程序 Start");
  init_wifi(WIFI_SSID, WIFI_PASSWD);
  camera_init();
  sd_init();
  SPIFFS_init();
  mqttClient.setCallback(mqtt_callback);
// the loop function runs over and over again forever
void loop() {
  // 程序开始拍照并保存
  Serial.print("进行拍照\n");
  camera_fb_t *fb = esp_camera_fb_get();
  if (!fb) {
    Serial.print("Camera capture failed");
    return;
  } else {
    EEPROM.begin(EEPROM_SIZE);
    pictureNumber = EEPROM.read(0) + 1;
    // Path where new picture will be saved in SD Card
    String path = "/picture" + String(pictureNumber) + ".jpg";
    fs::FS &fs = SD_MMC;
    Serial.printf("文件名字: %s\n", path.c_str());
    File file = fs.open(path.c_str(), FILE_WRITE);
    if (!file) {
      Serial.println("Failed to open file in writing mode");
    } else {
      file.write(fb->buf, fb->len);  // payload (image), payload length
      Serial.println(fb->len);
      Serial.print("抓拍成功并保存\n");
      Serial.printf("保存路径: %s\n\n", path.c_str());
      EEPROM.write(0, pictureNumber);
      EEPROM.commit();
    String a1 = "{\"id\":\"1189401707\",\"version\":\"1.0.0\",\"method\":\"123\",\"params\":{\"img\":\"";
    String a2;
    String a3 = "\"}}";
    char data[4104];
    // 将图片分为不超过 800 通过 MQTT 发送出去
    for (int i = 0; i < fb->len; i++) {
      sprintf(data, "%02X", *(fb->buf + i));
      a2 += data;
      if (a2.length() == 800) {
        String a4 = a1 + a2;
        String a = a4 + a3;
        char jsonBuf[a.length() + 1];
        for (int i = 0; i < a.length(); i++)
          jsonBuf[i] = a[i];
        jsonBuf[a.length()] = '\0';
        a2 = "", a = "", a4 = "";
        // ms
        delay(200);
    if (a2.length() > 0) {
      String a = a4 + a3;
        jsonBuf[i] = a[i];
     // 将图片分为不超过 800 通过 MQTT 发送出去  end
    char endBuf[100];
    sprintf(endBuf, "{\"id\":\"1189401707\",\"version\":\"1.0.0\",\"method\":\"123\",\"params\":{\"img\":\"END\"}}");
    Serial.println(endBuf);
    mqttClient.publish(ALINK_TOPIC_PROP_POST, endBuf);
  Serial.println("图片发送完成了......");
  delay(1000);
  // 图片发送结束后发送 END
  if (millis() - lastMs >= 10000) {
    lastMs = millis();
    mqtt_check_connect();
    // Post  interval 间隔
    // mqtt_interval_post();
  mqttClient.loop();
  unsigned int WAIT_MS = 2000;
  delay(WAIT_MS);  // ms
  Serial.println(millis() / WAIT_MS);
gaochy1126 发表于 2024-11-30 21:24 | 显示全部楼层
const container = require('rhea');
const crypto = require('crypto');
const fs = require("fs");
// 请根据实际情况修改下面的参数
// host,在物联网平台首页,查看开发配置中查看
var YourHost="iot-06z00xxxxt6xc.amqp.iothub.aliyuncs.com"
// 客户端ID,可自定义,长度不可超过64个字符
var YourClientId="esp32_001"
// 账号的 AccessKey。将鼠标移至账号头像上,然后单击AccessKey管理,获取AccessKey ID和AccessKey Secret。
var YourAccessKeyId="LTAI5tXXXXXXXXXXxLEMGYL2"
var YourAccessKeySecret="6vi2Txxxw9xxxrwig"
// 在对应实例的消息转发 > 服务端订阅 > 消费组列表查看您的消费组ID。
var YourConsumerGroupId="DEFAULT_GROUP"
// 物联网平台首页实例 ID
var YourIotInstanceId="iot-0600uxtxxsx"
// 存放完整的图片字符串
var imgStr = ""
// 16进制图片转base64
function to_base64(str) {
    var digits = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/";
    var base64_rep = "";
    var cnt = 0;
    var bit_arr = 0;
    var bit_num = 0;
    for (var n = 0; n < str.length; ++n) {
        if (str[n] >= 'A' && str[n] <= 'Z') {
            ascv = str.charCodeAt(n) - 55;
        else if (str[n] >= 'a' && str[n] <= 'z') {
            ascv = str.charCodeAt(n) - 87;
        else {
            ascv = str.charCodeAt(n) - 48;
        bit_arr = (bit_arr << 4) | ascv;
        bit_num += 4;
        if (bit_num >= 6) {
            bit_num -= 6;
            base64_rep += digits[bit_arr >>> bit_num];
            bit_arr &= ~(-1 << bit_num);
    if (bit_num > 0) {
        bit_arr <<= 6 - bit_num;
        base64_rep += digits[bit_arr];
    var padding = base64_rep.length % 4;
    if (padding > 0) {
        for (var n = 0; n < 4 - padding; ++n) {
            base64_rep += "=";
    return base64_rep;
//创建Connection。
var connection = container.connect({
    //接入域名,请参见AMQP客户端接入说明文档。
    'host': YourHost,
    'port': 5671,
    'transport':'tls',
    'reconnect':true,
    'idle_time_out':60000,
    //userName组装方法,请参见AMQP客户端接入说明文档。
    'username':YourClientId+'|authMode=aksign,signMethod=hmacsha1,timestamp=1573489088171,authId='+YourAccessKeyId+',iotInstanceId='+YourIotInstanceId+',consumerGroupId='+YourConsumerGroupId+'|',
    //计算签名,password组装方法,请参见AMQP客户端接入说明文档。
    'password': hmacSha1(YourAccessKeySecret, 'authId='+YourAccessKeyId+'&timestamp=1573489088171'),
//创建Receiver Link
var receiver = connection.open_receiver();
//接收云端推送消息的回调函数。
container.on('message', function (context) {
    var msg = context.message;
    var messageId = msg.message_id;
    var topic = msg.application_properties.topic;
    var content = Buffer.from(msg.body.content).toString();
    // 输出内容。
    console.log(content);
    // 将接收到的mqtt消息中内容转为json
    var imgBody = JSON.parse(content).items.img.value
    console.log('-------')
    // 如果图片没有传输完毕,则拼接图片
    if (imgBody != 'END') {
        imgStr += imgBody
    } else {
        // 如果图片传输完毕,则将图片转为base64
        console.log('imgStr:')
        console.log(to_base64(imgStr))
        // 配置图片保存路径
        var path = './img/' + new Date().getTime() + '.jpg';
        var dataBuffer = new Buffer(to_base64(imgStr), 'base64'); //把base64码转成buffer对象,
        //用fs将图片写入本地文件
        fs.writeFile(path, dataBuffer, function (err) {
            if (err) {
                console.log(err);
            } else {
                console.log('写入成功!');
        // 图片转换完毕后,清空imgStr,准备接受下一张图片
        imgStr = ""
    //发送ACK,注意不要在回调函数有耗时逻辑。
    context.delivery.accept();
//计算password签名。
function hmacSha1(key, context) {
    return Buffer.from(crypto.createHmac('sha1', key).update(context).digest())
        .toString('base64');
gaochy1126 发表于 2024-11-30 21:29 | 显示全部楼层
钓鱼大师 发表于 2025-3-9 16:18 | 显示全部楼层
ESP32和海思芯片比起来,哪个性能或者功能更全面?哪个成本低?
