w 将 U 盘(U 盘的格式必须为 FAT32 格式,大小在 32G 以下)插到开发板的 usb 接口,串口打印信息如下所示,U 盘的设备节点是/dev/sdb4。U 盘的设备节点不是固定的,根据实际情况来查看设备节点。
2 输入以下命令挂载 U 盘,可以查看到 U 盘中的文件。注意! 挂载路径要保证是存在的
mount /dev/sdb4 /mnt
cd /mnt
ls
如下图所示:
更多内容可以B站搜索:迅为RK3588开发板
eibo.com/ttarticle/p/show?id=2309405101820778512964
weibo.com/ttarticle/p/show?id=2309405101820623061052
weibo.com/ttarticle/p/show?id=2309405101820446900228
weibo.com/ttarticle/p/show?id=2309405101819885125825
weibo.com/ttarticle/p/show?id=2309405101819717353573
weibo.com/ttarticle/p/show?id=2309405101819713159436
weibo.com/ttarticle/p/show?id=2309405101819675410542
weibo.com/ttarticle/p/show?id=2309405101819637662073
weibo.com/ttarticle/p/show?id=2309405101819599912981
weibo.com/ttarticle/p/show?id=2309405101819423752915
weibo.com/ttarticle/p/show?id=2309405101819406975590
weibo.com/ttarticle/p/show?id=2309405101819398586825
weibo.com/ttarticle/p/show?id=2309405101819201192179
weibo.com/ttarticle/p/show?id=2309405101819146928761
weibo.com/ttarticle/p/show?id=2309405101819084013846
weibo.com/ttarticle/p/show?id=2309405101819033682273
weibo.com/ttarticle/p/show?id=2309405101819012710994
weibo.com/ttarticle/p/show?id=2309405101818987544714
weibo.com/ttarticle/p/show?id=2309405101818949533776
weibo.com/ttarticle/p/show?id=2309405101818928824565
weibo.com/ttarticle/p/show?id=2309405101818895269990
weibo.com/ttarticle/p/show?id=2309405101818840744087
weibo.com/ttarticle/p/show?id=2309405101818802995572
weibo.com/ttarticle/p/show?id=2309405101818790150194
weibo.com/ttarticle/p/show?id=2309405101818782024187
weibo.com/ttarticle/p/show?id=2309405101818727498568
weibo.com/ttarticle/p/show?id=2309405101818668515533
weibo.com/ttarticle/p/show?id=2309405101818597474789
weibo.com/ttarticle/p/show?id=2309405101818597212203
weibo.com/ttarticle/p/show?id=2309405101818547142762
weibo.com/ttarticle/p/show?id=2309405101818240959090
weibo.com/ttarticle/p/show?id=2309405101817842500146
weibo.com/ttarticle/p/show?id=2309405101817620201881
weibo.com/ttarticle/p/show?id=2309405101817569870474
weibo.com/ttarticle/p/show?id=2309405101817557025115
weibo.com/ttarticle/p/show?id=2309405101817523470359
weibo.com/ttarticle/p/show?id=2309405101817494372646
weibo.com/ttarticle/p/show?id=2309405101817469207434
weibo.com/ttarticle/p/show?id=2309405101817439846741
weibo.com/ttarticle/p/show?id=2309405101817410486419
weibo.com/ttarticle/p/show?id=2309405101817389515172
weibo.com/ttarticle/p/show?id=2309405101817355960323
weibo.com/ttarticle/p/show?id=2309405101817339183394
weibo.com/ttarticle/p/show?id=2309405101817297240780
weibo.com/ttarticle/p/show?id=2309405101817288851521
weibo.com/ttarticle/p/show?id=2309405101817251102855
weibo.com/ttarticle/p/show?id=2309405101817200771308
weibo.com/ttarticle/p/show?id=2309405101817192382590
weibo.com/ttarticle/p/show?id=2309405101817150439520
weibo.com/ttarticle/p/show?id=2309405101817095913522
weibo.com/ttarticle/p/show?id=2309405101815493427317
weibo.com/ttarticle/p/show?id=2309405101815443095670
weibo.com/ttarticle/p/show?id=2309405101813925020096
weibo.com/ttarticle/p/show?id=2309405101813878882329
weibo.com/ttarticle/p/show?id=2309405101813627224075
weibo.com/ttarticle/p/show?id=2309405101813593407757
weibo.com/ttarticle/p/show?id=2309405101813585019053
weibo.com/ttarticle/p/show?id=2309405101813555658864
weibo.com/ttarticle/p/show?id=2309405101813425898068
weibo.com/ttarticle/p/show?id=2309405101813417509293
weibo.com/ttarticle/p/show?id=2309405101813417508972
weibo.com/ttarticle/p/show?id=2309405101813396537576
weibo.com/ttarticle/p/show?id=2309405101813341749264
weibo.com/ttarticle/p/show?id=2309405101813333622863
weibo.com/ttarticle/p/show?id=2309405101813312651540
weibo.com/ttarticle/p/show?id=2309405101813274902853
weibo.com/ttarticle/p/show?id=2309405101813270708309
weibo.com/ttarticle/p/show?id=2309405101813211988249
weibo.com/ttarticle/p/show?id=2309405101813195211417
weibo.com/ttarticle/p/show?id=2309405101813178171501
weibo.com/ttarticle/p/show?id=2309405101813149073956
weibo.com/ttarticle/p/show?id=2309405101813144879762
weibo.com/ttarticle/p/show?id=2309405101813144879145
weibo.com/ttarticle/p/show?id=2309405101813085896793
weibo.com/ttarticle/p/show?id=2309405101813064925365
weibo.com/ttarticle/p/show?id=2309405101813044216342
weibo.com/ttarticle/p/show?id=2309405101813027439109
weibo.com/ttarticle/p/show?id=2309405101812989690208
weibo.com/ttarticle/p/show?id=2309405101812972913209
weibo.com/ttarticle/p/show?id=2309405101812914192690
weibo.com/ttarticle/p/show?id=2309405101812880638626
weibo.com/ttarticle/p/show?id=2309405101812876443662
weibo.com/ttarticle/p/show?id=2309405101812838695381
weibo.com/ttarticle/p/show?id=2309405101812830307072
weibo.com/ttarticle/p/show?id=2309405101812704477966
weibo.com/ttarticle/p/show?id=2309405101812687700609
weibo.com/ttarticle/p/show?id=2309405101812683506087
weibo.com/ttarticle/p/show?id=2309405101812683505715
weibo.com/ttarticle/p/show?id=2309405101812624523311
weibo.com/ttarticle/p/show?id=2309405101812608008757
weibo.com/ttarticle/p/show?id=2309405101812557676785
weibo.com/ttarticle/p/show?id=2309405101812549288089
weibo.com/ttarticle/p/show?id=2309405101812528316767
weibo.com/ttarticle/p/show?id=2309405101812515734000
weibo.com/ttarticle/p/show?id=2309405101812511277399
weibo.com/ttarticle/p/show?id=2309405101812486373591
weibo.com/ttarticle/p/show?id=2309405101812473790606
weibo.com/ttarticle/p/show?id=2309405101812461207968
weibo.com/ttarticle/p/show?id=2309405101812460945473
weibo.com/ttarticle/p/show?id=2309405101812444430908
weibo.com/ttarticle/p/show?id=2309405101812431847935
weibo.com/ttarticle/p/show?id=2309405101812431585285
weibo.com/ttarticle/p/show?id=2309405101812427653584
weibo.com/ttarticle/p/show?id=2309405101812406681791
weibo.com/ttarticle/p/show?id=2309405101812406681608
weibo.com/ttarticle/p/show?id=2309405101812394099110
weibo.com/ttarticle/p/show?id=2309405101812377321891
weibo.com/ttarticle/p/show?id=2309405101812373127437
weibo.com/ttarticle/p/show?id=2309405101812372865092
weibo.com/ttarticle/p/show?id=2309405101812368670756
weibo.com/ttarticle/p/show?id=2309405101812351893787
weibo.com/ttarticle/p/show?id=2309405101812343767519
weibo.com/ttarticle/p/show?id=2309405101812326990476
weibo.com/ttarticle/p/show?id=2309405101812322533491
weibo.com/ttarticle/p/show?id=2309405101812322533420
weibo.com/ttarticle/p/show?id=2309405101812318339122
weibo.com/ttarticle/p/show?id=2309405101812310213029
weibo.com/ttarticle/p/show?id=2309405101812310212761
weibo.com/ttarticle/p/show?id=2309405101812301561865
weibo.com/ttarticle/p/show?id=2309405101812293435940
weibo.com/ttarticle/p/show?id=2309405101812276658326
weibo.com/ttarticle/p/show?id=2309405101812272464087
weibo.com/ttarticle/p/show?id=2309405101826545680439
weibo.com/ttarticle/p/show?id=2309405101826390229017
weibo.com/ttarticle/p/show?id=2309405101826122056269
weibo.com/ttarticle/p/show?id=2309405101825823998017
weibo.com/ttarticle/p/show?id=2309405101825765277983
weibo.com/ttarticle/p/show?id=2309405101825711014096
weibo.com/ttarticle/p/show?id=2309405101825656488323
weibo.com/ttarticle/p/show?id=2309405101825606156760
weibo.com/ttarticle/p/show?id=2309405101825560018948
weibo.com/ttarticle/p/show?id=2309405101825484259459
weibo.com/ttarticle/p/show?id=2309405101825434190031
weibo.com/ttarticle/p/show?id=2309405101825383858542
weibo.com/ttarticle/p/show?id=2309405101825316487481
weibo.com/ttarticle/p/show?id=2309405101825266418188
weibo.com/ttarticle/p/show?id=2309405101825228669545
weibo.com/ttarticle/p/show?id=2309405101825216086203
weibo.com/ttarticle/p/show?id=2309405101825178075153
weibo.com/ttarticle/p/show?id=2309405101825161560644
weibo.com/ttarticle/p/show?id=2309405101825115160929
weibo.com/ttarticle/p/show?id=2309405101825111229110
weibo.com/ttarticle/p/show?id=2309405101824733478987
weibo.com/ttarticle/p/show?id=2309405101824482083033
weibo.com/ttarticle/p/show?id=2309405101824230424995
weibo.com/ttarticle/p/show?id=2309405101824200802308
weibo.com/ttarticle/p/show?id=2309405101824180093237
weibo.com/ttarticle/p/show?id=2309405101824129761730
weibo.com/ttarticle/p/show?id=2309405101824020709710
weibo.com/ttarticle/p/show?id=2309405101823894618475
weibo.com/ttarticle/p/show?id=2309405101823697748644
weibo.com/ttarticle/p/show?id=2309405101823639028075
weibo.com/ttarticle/p/show?id=2309405101823546753772
weibo.com/ttarticle/p/show?id=2309405101823500615950
weibo.com/ttarticle/p/show?id=2309405101823483838972
weibo.com/ttarticle/p/show?id=2309405101823450284631
weibo.com/ttarticle/p/show?id=2309405101823399952612
weibo.com/ttarticle/p/show?id=2309405101823387370166
weibo.com/ttarticle/p/show?id=2309405101823349620890
weibo.com/ttarticle/p/show?id=2309405101823286706717
weibo.com/ttarticle/p/show?id=2309405101823282512295
weibo.com/ttarticle/p/show?id=2309405101823261278301
weibo.com/ttarticle/p/show?id=2309405101823244763796
weibo.com/ttarticle/p/show?id=2309405101823211208886
weibo.com/ttarticle/p/show?id=2309405101823202820260
weibo.com/ttarticle/p/show?id=2309405101823189975321
weibo.com/ttarticle/p/show?id=2309405101823156682961
weibo.com/ttarticle/p/show?id=2309405101823131517536
weibo.com/ttarticle/p/show?id=2309405101823127323278
weibo.com/ttarticle/p/show?id=2309405101823106351429
weibo.com/ttarticle/p/show?id=2309405101823093768213
weibo.com/ttarticle/p/show?id=2309405101823081185719
weibo.com/ttarticle/p/show?id=2309405101823056019885
weibo.com/ttarticle/p/show?id=2309405101823039242506
weibo.com/ttarticle/p/show?id=2309405101823030854083
weibo.com/ttarticle/p/show?id=2309405101823018008707
weibo.com/ttarticle/p/show?id=2309405101822984454261
weibo.com/ttarticle/p/show?id=2309405101822934384770
weibo.com/ttarticle/p/show?id=2309405101822934122509
weibo.com/ttarticle/p/show?id=2309405101822921801973
weibo.com/ttarticle/p/show?id=2309405101822921801817
weibo.com/ttarticle/p/show?id=2309405101822917345321
weibo.com/ttarticle/p/show?id=2309405101822884053172
weibo.com/ttarticle/p/show?id=2309405101822871470282
weibo.com/ttarticle/p/show?id=2309405101822867276360
weibo.com/ttarticle/p/show?id=2309405101822858887696
weibo.com/ttarticle/p/show?id=2309405101822862819623
weibo.com/ttarticle/p/show?id=2309405101822837915796
weibo.com/ttarticle/p/show?id=2309405101822825332749
weibo.com/ttarticle/p/show?id=2309405101822825070600
weibo.com/ttarticle/p/show?id=2309405101822816944812
weibo.com/ttarticle/p/show?id=2309405101822812749941
weibo.com/ttarticle/p/show?id=2309405101822766612502
weibo.com/ttarticle/p/show?id=2309405101822762418835
weibo.com/ttarticle/p/show?id=2309405101822758223919
weibo.com/ttarticle/p/show?id=2309405101822754029904
weibo.com/ttarticle/p/show?id=2309405101822737252988
weibo.com/ttarticle/p/show?id=2309405101822741447290
weibo.com/ttarticle/p/show?id=2309405101822712087165
weibo.com/ttarticle/p/show?id=2309405101822699503771
weibo.com/ttarticle/p/show?id=2309405101822691115588
weibo.com/ttarticle/p/show?id=2309405101822690852951
weibo.com/ttarticle/p/show?id=2309405101822686921263
weibo.com/ttarticle/p/show?id=2309405101822682726656
weibo.com/ttarticle/p/show?id=2309405101822682464357
weibo.com/ttarticle/p/show?id=2309405101822644978021
weibo.com/ttarticle/p/show?id=2309405101822632395204
weibo.com/ttarticle/p/show?id=2309405101822628200768
weibo.com/ttarticle/p/show?id=2309405101822624006245
weibo.com/ttarticle/p/show?id=2309405101822624006230
weibo.com/ttarticle/p/show?id=2309405101822619812484
weibo.com/ttarticle/p/show?id=2309405101822607229566
weibo.com/ttarticle/p/show?id=2309405101822590451967
weibo.com/ttarticle/p/show?id=2309405101822569480715
weibo.com/ttarticle/p/show?id=2309405101822565286185
weibo.com/ttarticle/p/show?id=2309405101822561091838
weibo.com/ttarticle/p/show?id=2309405101822556897635
weibo.com/ttarticle/p/show?id=2309405101822548509237
weibo.com/ttarticle/p/show?id=2309405101822540120066
weibo.com/ttarticle/p/show?id=2309405101822523343101
weibo.com/ttarticle/p/show?id=2309405101822514692283
weibo.com/ttarticle/p/show?id=2309405101822510498057
weibo.com/ttarticle/p/show?id=2309405101822498177453
weibo.com/ttarticle/p/show?id=2309405101822502371939
weibo.com/ttarticle/p/show?id=2309405101822502371367
weibo.com/ttarticle/p/show?id=2309405101822489788838
weibo.com/ttarticle/p/show?id=2309405101822472749273
