[其它应用] 单片机设计
1608|1
 楼主| tpgf 发表于 2024-11-26 08:13 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include<ds18b20.c>
code unsigned char seven_seg[]= {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char bit_scan[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
unsigned char display_num[8];
unsigned char cp0,cp1;
unsigned int temp_num;
unsigned int temp1,temp2;
sbit le = P1^0;
void display_dat(void)
                display_num[0] = seven_seg[0];
                display_num[1] = seven_seg[8];
                display_num[2] = seven_seg[0];
                display_num[3] = seven_seg[1];
                if((temp_dat & 0xf800)< 0xf800)
                        temp_num = temp_dat & 0x0fff;
                        temp2 = (temp_num & 0x000f) * 0.625;
                        temp1 = temp_num >> 4;
                        display_num[4] = 0xff;
                        display_num[5] = seven_seg[temp1 / 10];
                        display_num[6] = seven_seg[temp1 % 10] & 0x7f;
                        display_num[7] = seven_seg[temp2];
                else
                        temp_num = ~temp_dat + 1;
                        temp2 = (temp_num & 0x000f) * 0.625 + 0.5;;
                        display_num[4] = 0xbf;
void latch(void){le = 1;le = 0;}
void timer0_isr(void) interrupt 1
                  TH0 = (65536 - 2000) / 256;
                        TL0 = (65536 - 2000) % 256;
                        P0 = 0xff;
                        P0 = bit_scan[cp1];latch();P0 = display_num[cp1];
                        cp1++;
                        if(cp1 >= 8)cp1 = 0;
                        cp0++;
void timer0_init(void)
                        TMOD = 0x01;
                        EA = 1;
                        ET0 = 1;
                        TR0 = 1;
void main(void)
                        timer0_init();
                        while(1)
                                display_dat();
                                if(cp0 == 200)
                                        cp0 = 0;
                                        read_temp_da18b20();
unsigned int temp_dat,temp_num;
sbit dq = P1^2;
void delay(unsigned int x){while(x--);}
void ds18b20_init(void)
                unsigned char i = 255;
                dq = 1;
                dq = 0;delay(80);
                dq = 1;
                while(dq & i--);
                delay(20);
void write_ds18b20(unsigned char x)
                unsigned char i;
                for(i = 0;i < 8;i++)
                        dq = 1;
                        dq = 0;
                        dq = (bit)(x & 0x01);
                        delay(10);
                        dq = 1;
                        x = x >> 1;
                delay(8);
unsigned char read_ds18b20(void)
                        unsigned char i,j;
                                dq = 1;
                                dq = 0;
                                j = j >> 1;
                                dq = 1;
                                if(dq)j = j | 0x80;
                                delay(10);
                        return(j);
void read_temp_da18b20(void)
                        unsigned int i,j;
                        ds18b20_init();
                        write_ds18b20(0xcc);
                        write_ds18b20(0x44);
                        ds18b20_init();
                        write_ds18b20(0xbe);
                        i = read_ds18b20();
                        j = read_ds18b20();
                        j = j << 8;
                        temp_dat = i | j;
原文链接:https://blog.csdn.net/Aaa13507646634/article/details/143998793
中国龙芯CDX 发表于 2024-11-27 09:29 | 显示全部楼层
51单片机进行程序设计
