[PIC®/AVR®/dsPIC®产品] FLASH 读写问题,同一地址,写入后读出来数据不一样
2260|6
 楼主| Tobbie 发表于 2024-12-26 08:58 | 显示全部楼层 |阅读模式
同一地址,写入后读出来数据不一样
* 函数名称:Memory_Check
* 功    能:**检测,防止重复写数据
* 返 回 值:
uint16_t Memory_Check(void)
    uint16_t temp;
    temp=FLASH_ReadWord(0x0020);
    if(temp==0x52)return 0;
    else
        FLASH_WriteWord(dataAddr,Buf,Staus_Cont&0x00ff);//第一次写入档位
        FLASH_WriteWord(0x0020,Buf,0x52&0x00ff);
    return 1;
主函数中初始化先进行**检查
    while(Memory_Check)//**检查,防止每次上电写数据
         if(EUSART2_is_tx_ready())
            EUSART2_Write(FLASH_ReadWord(0x0020));
    while (1)
@qintian0303 :也是不行  发表于 2024-12-27 08:34
换地址试一试呢  发表于 2024-12-26 23:01
 楼主| Tobbie 发表于 2024-12-26 09:03 | 显示全部楼层
 楼主| Tobbie 发表于 2024-12-26 10:08 | 显示全部楼层
uint16_t FLASH_ReadWord(uint16_t flashAddr)
    uint8_t GIEBitValue = INTCONbits.GIE;   // Save interrupt enable
    INTCONbits.GIE = 0;     // Disable interrupts
    NVMADRL = (flashAddr & 0x00FF);
    NVMADRH = ((flashAddr & 0xFF00) >> 8);
    NVMCON1bits.NVMREGS = 0;    // Deselect Configuration space
    NVMCON1bits.RD = 1;      // Initiate Read
    NOP();
    NOP();
    INTCONbits.GIE = GIEBitValue;        // Restore interrupt enable
    return ((uint16_t)((NVMDATH << 8) | NVMDATL));
void FLASH_WriteWord(uint16_t flashAddr, uint16_t *ramBuf, uint16_t word)
    uint16_t blockStartAddr = (uint16_t)(flashAddr & ((END_FLASH-1) ^ (ERASE_FLASH_BLOCKSIZE-1)));
    uint8_t offset = (uint8_t)(flashAddr & (ERASE_FLASH_BLOCKSIZE-1));
    uint8_t i;
    // Entire row will be erased, read and save the existing data
    for (i=0; i<ERASE_FLASH_BLOCKSIZE; i++)
        ramBuf[i] = FLASH_ReadWord((blockStartAddr+i));
    // Write at offset
    ramBuf[offset] = word;
    // Writes ramBuf to current block
    FLASH_WriteBlock(blockStartAddr, ramBuf);
20062516 发表于 2024-12-26 13:54 | 显示全部楼层
FLASH 写之前要擦除
 楼主| Tobbie 发表于 2024-12-26 14:07 | 显示全部楼层
FLASH 写之前要擦除
有做擦除的,在这个void FLASH_WriteWord函数中已经做了block擦除
int8_t FLASH_WriteBlock(uint16_t writeAddr, uint16_t *flashWordArray)
    uint16_t    blockStartAddr  = (uint16_t )(writeAddr & ((END_FLASH-1) ^ (ERASE_FLASH_BLOCKSIZE-1)));
    uint8_t i;
    // Flash write must start at the beginning of a row
    if( writeAddr != blockStartAddr )
        return -1;
    // Block erase sequence
    FLASH_EraseBlock(writeAddr);//擦除block
    // Block write sequence
    NVMCON1bits.WREN = 1;    // Enable wrties
    NVMCON1bits.LWLO = 1;    // Only load write latches
    for (i=0; i<WRITE_FLASH_BLOCKSIZE; i++)
        // Load lower 8 bits of write address
        NVMADRL = (writeAddr & 0xFF);
        // Load upper 6 bits of write address
        NVMADRH = ((writeAddr & 0xFF00) >> 8);
        // Load data in current address
        NVMDATL = flashWordArray;
        NVMDATH = ((flashWordArray & 0xFF00) >> 8);
        if(i == (WRITE_FLASH_BLOCKSIZE-1))
            // Start Flash program memory write
            NVMCON1bits.LWLO = 0;
        NVMCON2 = 0x55;
        NVMCON2 = 0xAA;
        NVMCON1bits.WR = 1;
        NOP();
        NOP();
            writeAddr++;
    NVMCON1bits.WREN = 0;       // Disable writes
    return 0;
