[技术问答] HC32F4A0系统时钟配置
2554|3
 楼主| 鸵鸟 发表于 2025-1-20 11:00 | 显示全部楼层 |阅读模式
void BSP_SetSysClk(void)
    stc_clock_xtal_init_t stcXtalInit;
    stc_clock_pll_init_t stcPLLHInit;
    stc_pll_clock_freq_t pstcPllClkFreq;
    stc_clock_freq_t pstcClockFreq;
    stc_clock_scale_t clk_freq_cfg;
    /* Config Xtal and enable Xtal */
    stcXtalInit.u8Mode   = CLK_XTAL_MD_OSC;
    stcXtalInit.u8Drv    = CLK_XTAL_DRV_LOW;
    stcXtalInit.u8State  = CLK_XTAL_ON;
    stcXtalInit.u8StableTime = CLK_XTAL_STB_2MS;
    CLK_XtalInit( &stcXtalInit );
    CLK_XtalCmd(ENABLE);
    /* VCO = (8/1)*120 = 960MHz*/
    stcPLLHInit.u8PLLState       = CLK_PLL_ON;
    stcPLLHInit.PLLCFGR          = 0UL;
    stcPLLHInit.PLLCFGR_f.PLLM   = 1UL-1UL;
    stcPLLHInit.PLLCFGR_f.PLLN   = 120UL-1UL;
    stcPLLHInit.PLLCFGR_f.PLLP   = 4UL-1UL;
    stcPLLHInit.PLLCFGR_f.PLLQ   = 4UL-1UL;
    stcPLLHInit.PLLCFGR_f.PLLR   = 4UL-1UL;
    stcPLLHInit.PLLCFGR_f.PLLSRC = CLK_PLL_SRC_XTAL;
    CLK_PLLInit( &stcPLLHInit );
    /* flash read wait cycle setting */
    EFM_REG_Unlock();
    EFM_SetWaitCycle(EFM_WAIT_CYCLE1);
    EFM_REG_Lock();
    CLK_PLLCmd(ENABLE);
    /* Wait MPLL ready. */
    //while (SET != CLK_GetStableStatus(CLK_STB_FLAG_PLL)){}
    CLK_SetSysClockSrc( CLK_SYSCLK_SRC_PLL );
 楼主| 鸵鸟 发表于 2025-1-20 11:01 | 显示全部楼层
HC32F4A0系统时钟配置
为什么所有时钟总线输出频率都是8Mhz,pll设置到底是哪里有问题?
wang6623 发表于 2025-4-30 22:34 | 显示全部楼层
PLL配置需要根据实际应用来调整,例如你可以根据目标系统的时钟需求来设置 PLL倍频因子 和 分频因子。
