[技术讨论] In depth analysis of alternative SN6507 products
817|0
 楼主| mbgcn 发表于 2025-2-5 15:06 | 显示全部楼层 |阅读模式
The ZCC6507 launched by Wuxi Zhicheng Microelectronics (www.zcc-china.cn) adopts a chip design architecture different from Texas Instruments TI, which is more flexible and has superior performance. The chip cost is much lower than SN6507
1. The output power can reach up to 15W.
2. The input voltage range is wider.
3. Efficiency has increased by 4% compared to SN6507
