[AVR单片机] AT90USB
2458|4
 楼主| americ 发表于 2007-5-5 02:53 | 显示全部楼层 |阅读模式
USB, TE, RAM, UG, ip
USB AVR
Devices  Description
AT90USB1286  USB Function Microcontroller.
128-Kbyte self-programming Flash Program Memory, 8-Kbyte SRAM, 4-Kbyte EEPROM, 8 Channel 10-bit A/D-converter. JTAG interface for on-chip-debug. Up to 16 MIPS throughput at 16 MHz. 2.7 - 5.5 Volt operation.
AT90USB1287  USB On-The-Go (OTG) Microcontroller.
AT90USB162  USB Microcontroller.
16-Kbyte self-programming Flash Program Memory, 512-byte SRAM, 512-byte EEPROM. DebugWire interface for on-chip-debug. Up to 16 MIPS throughput at 16 MHz. 2.7 - 5.5 Volt operation.
AT90USB646  USB Function Microcontroller.
64-Kbyte self-programming Flash Program Memory, 4-Kbyte SRAM, 2-Kbyte EEPROM, 8 Channel 10-bit A/D-converter. JTAG interface for on-chip-debug. Up to 16 MIPS throughput at 16 MHz. 2.7 - 5.5 Volt operation.
AT90USB647  USB On-The-Go (OTG) Microcontroller.
AT90USB82  USB Microcontroller.
8-Kbyte self-programming Flash Program Memory, 512-byte SRAM, 512-byte EEPROM. DebugWire interface for on-chip-debug. Up to 16 MIPS throughput at 16 MHz. 2.7 - 5.5 Volt operation.
已经这么久了,这么多款,哪一种 有人批量使用??
可能用在下一个项目中.
双龙 发表于 2007-5-8 01:38 | 显示全部楼层
可能先推AT90USB1287,因为TQFP64封装适合国内的加工工艺
tubie 发表于 2007-5-8 12:20 | 显示全部楼层
多少钱?好买吗?
zsmbj 发表于 2007-5-8 17:38 | 显示全部楼层
82,162是新推出的吧,做一些小的项目不错啊。
不知有没有量产!
tubie 发表于 2007-5-10 12:56 | 显示全部楼层
还是等等看吧,连个供货商都搜不到。
