[综合信息] 国民技术GPIO配置输入模式
830|1
 楼主| wowu 发表于 2025-3-23 14:13 | 显示全部楼层 |阅读模式
废话不多,GPIO配置是在开发单片机常用的。下面就来介绍如何将GPIO配置输入模式。
#define Led1_Pin                  GPIO_PIN_5
#define Led1_Port                  GPIOB
#define Led1_High                 GPIO_WriteBit(Led1_Port, Led1_Pin, Bit_SET)
#define Led1_Low                 GPIO_WriteBit(Led1_Port, Led1_Pin, Bit_RESET)
void OutPut_IO_Init(void)
        GPIO_InitType GPIO_InitStructure;
    GPIO_InitStruct(&GPIO_InitStructure);
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB, ENABLE);
        GPIO_InitStructure.Pin        = Led1_Pin;
        GPIO_InitStructure.GPIO_Current = GPIO_DC_4mA;
        GPIO_InitStructure.GPIO_Pull    = GPIO_No_Pull;
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;
        GPIO_InitPeripheral(Led1_Port, &GPIO_InitStructure);
        Led1_High;
#define Key_Pin                        GPIO_PIN_4
#define Key_Port                GPIOA
#define Read_Key_Port        GPIO_ReadInputDataBit(Key_Port, Key_Pin)
void InPut_IO_Init(void)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA, ENABLE);
        GPIO_InitStructure.Pin            = Key_Pin;
        GPIO_InitStructure.GPIO_Pull      = GPIO_Pull_Up;
    GPIO_InitStructure.GPIO_Mode      = GPIO_Mode_Input;
    GPIO_InitPeripheral(Key_Port, &GPIO_InitStructure);
int main(void)
        InPut_IO_Init();
        OutPut_IO_Init();
        while(1)
                if(Read_Key_Port == Bit_SET)
                        Led1_High;
                else
                        Led1_Low;
原文链接:https://blog.csdn.net/dailin2012/article/details/129726704
szt1993 发表于 2025-7-31 22:44 | 显示全部楼层
GPIO配置输入模式
