[AVR单片机] 从今天起全面放弃GCC AVR做IAR AVR菜鸟
13418|47
 楼主| hotpower 发表于 2007-7-19 20:12 | 显示全部楼层
小容量的就不麻烦BootLoader了~~~
空间自身难保呀~~~
龙在天涯 发表于 2007-7-22 16:10 | 显示全部楼层
我一直使用GCC,听大家说我倒是想看看IAR是否和我心意
wapoor 发表于 2007-7-24 22:26 | 显示全部楼层
求教
请问各位,用IAR能设置AVR的熔丝位吗?怎么设置?请多多赐教,谢谢!
main 发表于 2007-7-27 16:09 | 显示全部楼层
几种AVR C语言编译器的比较
http://www.atmanecl.com/ChineseSite/CCCC.htm
huangqi412 发表于 2007-7-27 19:04 | 显示全部楼层
高手给我个pojie的,谢谢
huangqi412@yahoo.com.cn  自己没找到pojie的
brotherwen 发表于 2007-7-30 12:15 | 显示全部楼层
到底是GCC好还是IAR好哦
AIRWILL 发表于 2007-8-1 19:28 | 显示全部楼层
今天
认真把这长帖从头看到尾, 好长, 可是没有收获.
希望看到楼主的测试结果. 期待
xiao 发表于 2007-8-4 22:21 | 显示全部楼层
IAR几种版本的差别,有人用Standard edition么
Standard edition
The standard edition has all features implemented.
Limited edition
The limited edition is a version of IAR Embedded Workbench without a debugger. Limitations:
The IAR C-SPY debugger is not available.
MISRA C is not available.
BaseLine edition information
The BaseLine edition is a special low-priced version of IAR Embedded Workbench. It has limitations both in performance and in the service and support that is provided. Limitations:
The IAR BaseLine C/C++ compiler supports a maximum of 12 Kbytes of generated code.
The runtime library source code is not included.
The IAR Assembler delivered is the full version without any restrictions.
The IAR XLINK Linker will link a maximum of 12 Kbytes of code originating from C or C++ source code, but an unlimited amount of code originating from assembler code.
The IAR BaseLine C-SPY Debugger is the full version without any restrictions.
KickStart edition
The KickStart edition is a special starter-kit/evaluation version of IAR Embedded Workbench with limitations both in code size and in the service and support that is provided. Limitations:
The code limit of IAR KickStart C/C++ compiler is set by the license management system. It will not generate any assembler code output.
The IAR XLINK Linker will link the number of bytes up to the preset code size for the compiler, originating from C or C++ source code, but an unlimited amount of code originating from assembler code.
The IAR KickStart C-SPY Debugger is restricted to the same limit as the compiler.
Evaluation edition
The Evaluation edition is a time-limited evaluation version that you will be able to run for 30 days. Limitations:
Will expire 30 days after generation of the evaluation key.
The runtime library source code is not available.
