帮我看看 新手求救 STC12C5A60S2 AD扫描程序
2279|1
 楼主| pyh0603 发表于 2012-7-22 09:23 | 显示全部楼层 |阅读模式
#include "reg51.h"
#include "intrins.h"
#define FOSC 18432000L
#define BAUD 9600
typedef unsigned char  BYTE;
typedef unsigned int   WORD;
/*Declare SFR associated with the ADC*/
sfr     ADC_CONTR    =0xBC;
//ADC control register
sfr     ADC_RES      =0xBD;
//ADC hight 8-bit result register
sfr     ADC_LOW2     =0xBE;
//ADC low 2-bit rusult register
sfr     P1ASF        =0x9D;  //P1 secondary function control register
/*Define ADC operation const for ADC_CONTR*/
#define ADC_POWER   0x80       //ADC power control bit
#define ADC_FLAG    0x10       //ADC complete flag
#define ADC_START   0x08       //ADC start control bit
#define ADC_SPEEDLL 0x00       //540 clocks
#define ADC_SPEEDL  0x20       //360 clocks
#define ADC_SPEEDH  0x40       //180 clocks
#define ADC_SPEEDLH 0x60       //90  clocks
void InitUart();
void SendData(BYTE dat);
void Delay(WORD n);
void InitADC();
BYTE   ch=0;                   //ADC channel NO.
void main()
InitUart();                //Init UART,use to show ADC result
InitADC();                 //Init ADC sfr
IE=0xa0;                   //Enable ADC interrupt and Open master interrupt switch
                           //Start A/Dconversion
while(1);
/*-------ADC interrupt service routine-------*/
void adc_isr() interrupt 5 using 1
ADC_CONTR&=!ADC_FLAG;      //Clear ADC interrupt flag
SendData(ch);              //Show Channel NO.
SendData(ADC_RES);         //Get ADC high 8-bit result and Send to UART
//if you want show 10-bit result,uncomment next line
//SendData(ADC_LOW2);      //Show ADC low 2-bit result
if(++ch>7)ch=0;            //switch to next channel
ADC_CONTR=ADC_POWER|ADC_SPEEDLL|ADC_START|ch;
/*--------Initial ADC sfr--------*/
void InitADC()
P1ASF=0xff;                //Set all P1 as analog input port
ADC_RES=0;                 //Clear previous result
Delay(2);                  //ADC power-on delay and Start A/D  conversion
/*---------------Initial UART-----------*/
void InitUart()
SCON=0x5a;
TMOD=0x20;
TH1=TL1=-(FOSC/12/32/BAUD);
TR1=1;
Send one byte data to PC
Input:dat(UART data)
output:---------*/
while(!TI);
TI=0;
SBUF=dat;
Software delay funtion
void Delay(WORD n)
WORD x;
while(n--)
x=5000;
while(x--);
#define FOSC 18432000L  是指晶振频率吗?   那后面的L是什么意思啊
ADC_CONTR=ADC_POWER|ADC_SPEEDLL|ADC_START|ch  这个有啥用啊
logokfu 发表于 2012-7-22 10:15 | 显示全部楼层
1、是晶振频率的意思。
2、通过与运算然后将值写入ADC_CONTR寄存器中。
