关于CY7c68013的问题
2409|3
 楼主| guolingho 发表于 2012-8-2 12:35 | 显示全部楼层 |阅读模式
我用CY7C68013,怎么一执行到FIFORESET就感觉程序跑飞了一样?
就不能继续执行了,我用的是内部时钟。
void Dealy_Moment()
    WORD i;
     for( i = 0x0000; i < 0x7FF; i++ )
      SYNCDELAY;
      SYNCDELAY;
void TD_Init(void)             // Called once at startup
   // set the CPU clock to 48MHz
   CPUCS = ((CPUCS & ~bmCLKSPD) | bmCLKSPD1) ;
   // set the slave FIFO interface to 48MHz
   IFCONFIG |= 0xC3;
  // Registers which require a synchronization delay, see section 15.14
  // FIFORESET        FIFOPINPOLAR
  // INPKTEND         OUTPKTEND
  // EPxBCH:L         REVCTL
  // GPIFTCB3         GPIFTCB2
  // GPIFTCB1         GPIFTCB0
  // EPxFIFOPFH:L     EPxAUTOINLENH:L
  // EPxFIFOCFG       EPxGPIF标志寄存器SEL
  // PINFLAGSxx       EPxFIFOIRQ
  // EPxFIFOIE        GPIFIRQ
  // GPIFIE           GPIFADRH:L
  // UDMACRCH:L       EPxGPIFTRIG
  // GPIFTRIG
  // Note: The pre-REVE EPxGPIFTCH/L register are affected, as well...
  //      ...these have been replaced by GPIFTC[B3:B0] registers
  // default: all endpoints have their VALID bit set
  // default: TYPE1 = 1 and TYPE0 = 0 --> BULK
  // default: EP2 and EP4 DIR bits are 0 (OUT direction)
  // default: EP6 and EP8 DIR bits are 1 (IN direction)
  // default: EP2, EP4, EP6, and EP8 are double buffered
  // we are just using the default values, yes this is not necessary...
    REVCTL = 0x03; // MUST set REVCTL.0 and REVCTL.1 to 1
    SYNCDELAY;
    SYNCDELAY;
    EP2CFG=0xA0;             //需要设定为四缓冲,每个缓冲区大小为512字节
    SYNCDELAY;
    EP4CFG=0x00;
    SYNCDELAY;
    EP6CFG=0xE0;            //in 2缓冲,大小512Byte
    SYNCDELAY;
    EP8CFG=0x00;
    PORTACFG        = 0x00;
    SYNCDELAY;
  OEA                 |=    0x0F;
    SYNCDELAY;
    PA0    =    1;
    SYNCDELAY;        SYNCDELAY;
    PA1 = 1;
    Dealy_Moment();
    SYNCDELAY;
    FIFORESET = 0x80; // Reset the FIFO
    SYNCDELAY;
    FIFORESET = 0x02;
    SYNCDELAY;
    FIFORESET = 0x06;
    SYNCDELAY;
    FIFORESET = 0x00;
    SYNCDELAY;
    PA0    =    0;
    PA1 = 0;
    Dealy_Moment();
  // out endpoints do not come up armed
  // since the defaults are double buffered we must write dummy byte counts twice
  SYNCDELAY;
  EP2BCL = 0x80;                // arm EP2OUT by writing byte count w/skip.
  SYNCDELAY;
  EP2BCL = 0x80;
  SYNCDELAY;
  EP6BCL = 0x80;                // arm EP4OUT by writing byte count w/skip.
  SYNCDELAY;
  EP6BCL = 0x80;
  //小于64字节有效
  //EP6FIFOPFH=0x00; //DEIS PKSTAT  PK2 PK1 PK0 0 PFC9 PFC8
  //EP6FIFOPFL=0x40; //PFC7 PFC6 PFC5 PFC4 PFC3 PFC2 PFC1 PFC0
// handle the case where we were already in AUTO mode...
//    EP2FIFOCFG     = 0x01;            // AUTOOUT=0, WORDWIDE=1
    SYNCDELAY;
    EP6FIFOCFG     = 0x09;            // AUTOIN=1, ZEROLENIN=0, WORDWIDE=1
    SYNCDELAY;
    //IO设置
    //PORTCCFG        =    0x00;
    //PORTECFG        =    0x00;
    //OEC=0x00;
    //OEE=0xff;
    //串口初始化
  // enable dual autopointer feature
  AUTOPTRSETUP |= 0x01;
 楼主| guolingho 发表于 2012-8-2 12:42 | 显示全部楼层
我用PA看波形,发现PA变高后就不变低了,这是怎么回事?
 楼主| guolingho 发表于 2012-8-2 15:56 | 显示全部楼层
没有高手指教一下么?
 楼主| guolingho 发表于 2012-8-9 14:56 | 显示全部楼层
个人签名:偶是初学,初学就是问题多。希望高手多多指教!
35
