XLINK assigns a segment memory type to each of the segments. In some cases, the individual segments may have the same name as the segment memory type they belong to, for example CODE. Make sure not to confuse the individual segment names with the segment memory types in those cases.
XLINK 为每个内存块指定一个类型,在某些情况下,不同的几个内存块可以有相同的类型,如CODE。在这种情况中,不要混淆块的名和类型。
请教一下,上面是啥意思,为什么以CODE为例子,能给出几个具体的实例吗? |
