[AVR单片机] 刚刚接触AVR MEGA,帮俺看看为啥?
1923|0
 楼主| keer_zu 发表于 2007-3-22 16:23 | 显示全部楼层 |阅读模式
AVR, tc, TI, se, IO
为什么进不了中断?
void main(void)
    porta_init();
    TC1_init(1000);
    sei();
    for(;;)
        //delay(100000);
        PORTA ^= 0X00;
        asm("nop");
void TC1_init(int time_ms)                //初始化,可以按毫秒输入定时周期
    TCCR1B |= CLK_8;                      //时钟源8分频
    asm("nop");
    int TCNT_value = Change_time(time_ms);
    TIM16_WriteTCNT1(TCNT_value);         //写16位寄存器
    TIMSK|=(1<<TOIE1);                   //允许T1溢出中断
int Change_time(int i)
    char tcc = TCCR1B |=0x07;
    switch( tcc )
        case CLK_1   : return(CLK_IO_HZ * i);      break;
        case CLK_8   : return(CLK_IO_HZ * i*8);    break;
        case CLK_64  : return(CLK_IO_HZ * i*64);   break;
        case CLK_256 : return(CLK_IO_HZ * i*256);  break;
        case CLK_1024: return(CLK_IO_HZ * i*1024); break;
void porta_init(void)
    DDRA |= 0XFF;
    PORTA = 0XFF;
SIGNAL(SIG_OVERFLOW1)//定时器1中断
    TC1_init(500);
    PORTA ^= 0XFF;
    //sei();
void TIM16_WriteTCNT1( unsigned int i )
     unsigned char sreg;
     sreg = SREG;
    //cli();
    TCNT1 = i;
     SREG = sreg;
