请教各位老师F2812的FIFO问题<br /><br />想完成的任务:上位机发送10个字节给DSP,DSP将接收到的数据存放在数组a[10]里,并将a[10]发送给上位机,再将数组a[10]中数据值加上0x10后发送给上位机。数据接收使用FIFO,数据发送是直接往SciaRegs.SCITXBUF中写值,没有使能发送FIFO功能及发送FIFO中断。<br /><br />程序如下<br /><br />#define ReceBufferLength 10<br />#define SendBufferLength 8<br /><br />Uint16 DataReceived[ReceBufferLength];<br /><br />//--------------------------------------------------<br />interrupt void ISR_SCIRXINTA(void);<br /><br /><br />void InitScia(void)<br />{ <br /> *UART_MODE = 0x44; <br /> EALLOW;<br /> GpioMuxRegs.GPFMUX.all = 0x0030;//设置GPIO为外设方式<br /> EDIS;<br /><br /><br /> SciaRegs.SCICCR.all = 0x0007;<br /> /*-------------------------------------------------------------------------------<br /> // Set SCICTL1.SW Reset 0 to reset the SCI module<br /> -------------------------------------------------------------------------------*/<br /> SciaRegs.SCICTL1.all = 0x0003;<br /> SciaRegs.SCICTL2.all = 0x0002;<br /> <br /> /*-------------------------------------------------------------------------------<br /> // Band Rate = 9600, LSPCLK = 37.5M<br /> // BRR = LSPCLK / (band rate * 8) - 1 = 487(0x01E7H)<br /> -------------------------------------------------------------------------------*/<br /> SciaRegs.SCIHBAUD = 0x0001;<br /> SciaRegs.SCILBAUD = 0x00E7;<br /> <br /> SciaRegs.SCICTL1.all = 0x0023; <br /> <br /> PieCtrl.PIEIER9.bit.INTx1 = 1;//允许接收中断<br /> PieCtrl.PIEIER9.bit.INTx2 = 0;//禁止发送中断<br /> <br />}<br /><br />void InitSciaFIFO(void)<br />{<br /> SciaRegs.SCIFFTX.all = 0xe000;<br /> SciaRegs.SCIFFRX.all = 0x202a;<br /> SciaRegs.SCIFFCT.all = 0x000A; // Set the delay time as 10 clocks<br /> SciaRegs.SCIPRI.all = 0x0010; <br />}<br /><br />interrupt void ISR_SCIRXINTA(void)<br />{<br /><br /> Uint16 i, j;<br /> <br /> for(i = 0; i < ReceBufferLength; i++) // 接收到的数据存入数组<br /> {<br /> DataReceived = SciaRegs.SCIRXBUF.all & Factor_GetData;<br /> } <br /> <br /> for(j = 0; j < ReceBufferLength; j++) // 原值返回<br /> {<br /> SciaRegs.SCITXBUF = DataReceived[j]; <br /> }<br /> <br /> for(j = 0; j < (ReceBufferLength); j++) // 原值加0x10返回<br /> {<br /> SciaRegs.SCITXBUF = DataReceived[j] + 0x10; <br /> }<br /><br /> SciaRegs.SCIFFRX.bit.RXFIFORESET = 0; // Reset the FIFO receive stack<br /> SciaRegs.SCIFFRX.bit.RXFIFORESET = 1; // Enable the FIFO receive operation<br /><br /> PieCtrl.PIEACK.all|= PIEACK_GROUP9;<br />}<br /><br />发送的值是:00 01 02 03 04 05 06 07 08 09<br /><br />理论上应该收到的是:00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 <br /><br />但实际收到的是: 00 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 <br /><br />01 02 03丢失了!<br /><br />我还发现,如果把FIFO深度改为5,则正确,但是如果深度为5时,连续回送20个数据也会有数据丢失。只要回送的数据超过17个,则会有丢失,只有17个数据被送回。<br /><br />请问,小弟的问题出在哪里?这个17是怎么回事?是哪个寄存器设的不对吗?请各位帮忙看看,非常感谢!!!<br /> |
