求DSP兼职人员
2440|1
行走的月亮|  楼主 | 2007-6-4 23:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
DSP, TI, TE, AN, ST
Dear Sir/Madam:
We are currently seeking a dynamic, self-motivated Top DSP Engineer that will assist with the design and development of a real time embedded DSP systems.
He/ she will be responsible for low level embedded DSP Hardware design and Software design, code and debugging.
If you are interested in this incredible (part time) opportunity, please send:
1) The detail information/resume about you along with the contact information / phone number;
2) Your requirements about the job;
3) Very detail knowledge about TIDSP DM642 including design diagram with “C” Source code to show your experience and skill, which should run CCS and at last including one of them:
A) Interface with Host Bus/PCI/DMA;
B) Audio Codec/Decode;
C) Some program such as Low Pass Filter, Band Pass Filter, Fast Fourier Transform Algorithm to test the DM642 with on chip memory and peripheral component.
D) Real time voice signals, to execute some voice store and loop back program;
After reviewing your responses we will contact you ASAP.
Thanks for your time.
                                                               Mr.Liu
e-mail:csyzcs@yahoo.com.cn
mymaymy| | 2007-6-5 16:03 | 只看该作者
地点都没说。。。
