[国产单片机]
捕获测量频率问题?
1842|4
hejianguo94|  楼主 | 2012-9-3 20:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用DIP-20封装的stc12c5410AD单片机的P3.7的捕获功能测量频率,通过串口返回到电脑,得到数据始终为零。求解答?
#include<stc12c5410AD.h>
#define uchar unsigned char
sbit LED = P1^7;
unsigned int rate_val = 0;
unsigned long count_1 = 0;
unsigned long count_2 = 0;
unsigned char flag = 0;
unsigned char ov_flag = 0;
unsigned char time_cnt = 0;
bit r_flag = 0;
void PCA_INIT(void)
  CMOD = 0x01;   //  开PCA模块中断,设置空闲模式时关闭PCA计数阵列
  CCAPM0 = 0x11;  //  下降沿捕获使能
  CCON = 0x00;    //  设置初始PCA计数阵列计数初值
  CH = 0;    //
  CL = 0;    // 设置初始PCA计数阵列计数初值
  CCAP0H = 0;  //
  CCAP0L = 0;   //  清各标志位
  CR = 1;
  EPCA_LVD = 1;  // 开中断和低压检测中断位
void TIMER_INIT(void)
  TMOD = 0x21;
  SCON |= 0x50;
  TH0 = (65535 - 50000) / 256;
  TL0 = (65535 - 50000) % 256;
  TH1 = 0xfd;
  TL1 = 0xfd;
  ET0 = 1;
  TR0 = 1;
  TR1 = 1;
  //ES = 1;
  EA = 1;
void UART_send_byte(unsigned char  x)
  TI = 0;
  SBUF = x;
  while(TI == 0);
  TI = 0;
void UART_send_Nbyte(unsigned int  x)
  unsigned char array[2] = 0;
  unsigned char i = 0;
  array[0] = x >> 8;
  array[1] = x & 0xff;
  for(i = 0;i < 2; i++)
   UART_send_byte(array[i]);
void main(void)
  PCA_INIT();
  TIMER_INIT();
  LED = 0;
  while(1)
   if(r_flag)
   r_flag = 0;
   LED = ~LED;
   UART_send_Nbyte(rate_val);
   TR0 = 1;
void TIMER0(void) interrupt 1
  time_cnt ++;
  if(time_cnt == 2)
   time_cnt = 0;
r_flag = 1;
TR0 = 0;
void PCA_ISR(void) interrupt 7    //PCA 中断服务函数
  if(CCF0)
    CCAP0H = CH;  //
    CCAP0L = CL;
if(flag == 0)
   count_1 = ov_flag * 65535 + CCAP0H * 256 + CCAP0L;
   flag ++;
else
   flag = 0;
   count_2 = ov_flag * 65535 + CCAP0H * 256 + CCAP0L;
   rate_val = 12000000 / 12 /(count_2 -count_1);
   CH = 0;
      CL = 0;
      CCAP0H = 0;
      CCAP0L = 0;
   ov_flag = 0;
    CCF0 = 0;
  if(CF)
CF = 0;
ov_flag ++;
谈的元| | 2012-9-3 21:23 | 只看该作者
1.  要证明进入了中断?   在中断中写一变量,自加,然后串口发出,数字变化,证明进入了中断
2. 将进入中断的捕捉值用串口发出,观察是否变化,应该变化
hejianguo94|  楼主 | 2012-9-4 08:38 | 只看该作者
能进入CR计数中断,进不了捕获中断。。。
谈的元| | 2012-9-4 23:09 | 只看该作者
仔细看看捕捉中断的设置
hejianguo94|  楼主 | 2012-9-5 08:56 | 只看该作者
没发现什么错误呀!!
