新手关于STM32矩阵键盘问题
2591|4
 楼主| sanjue 发表于 2012-9-4 14:29 | 显示全部楼层 |阅读模式
首先放上代码
struct io_port
GPIO_TypeDef *GPIO_x;
unsigned short GPIO_pin;
static struct io_port key_output[6] = {
{GPIOC, GPIO_Pin_1}, {GPIOC, GPIO_Pin_2},
{GPIOC, GPIO_Pin_3}, {GPIOC, GPIO_Pin_4},
{GPIOC, GPIO_Pin_5}, {GPIOC, GPIO_Pin_6}
static struct io_port key_input[6] = {
{GPIOC, GPIO_Pin_9}, {GPIOC, GPIO_Pin_10},
{GPIOC, GPIO_Pin_11}, {GPIOC, GPIO_Pin_12},
{GPIOC, GPIO_Pin_13}, {GPIOC, GPIO_Pin_14}
unsigned char key[6][6];
void keyboard_init(void)                                   //GPIOC_1-GPIOC_6是输出,全部置1
    unsigned char i;
    for(i = 0; i < 6; i++)
     GPIO_SetBits(key_output.GPIO_x, key_output.GPIO_pin);
void update_key(void)
unsigned char i, j;
for(i = 0; i < 6; i++)                //i是输出口,依次置低电平
  GPIO_ResetBits(key_output.GPIO_x, key_output.GPIO_pin);
  for(j = 0; j < 6; j++)            //j是输入口,当键按下时导通被置为低电平
        //          if(GPIO_ReadInputDataBit(key_input[j].GPIO_x, key_input[j].GPIO_pin) == 0)
        //            delay(10);
               key[j] = 1;
             else
               key[j] = 0;
int key_value(void)
unsigned char keydata;
keyboard_init();
update_key();
      if(key[0][0]) keydata=1;
else if(key[0][1]) keydata=2;
else if(key[0][2]) keydata=3;
else if(key[0][3]) keydata=4;
else if(key[0][4]) keydata=5;
else if(key[0][5]) keydata=6;
else if(key[1][0]) keydata=7;
else if(key[1][1]) keydata=8;
else if(key[1][2]) keydata=9;
else if(key[1][3]) keydata=10;
else if(key[1][4]) keydata=11;
else if(key[1][5]) keydata=12;
else if(key[2][0]) keydata=13;
else if(key[2][1]) keydata=14;
else if(key[2][2]) keydata=15;
else if(key[2][3]) keydata=16;
else if(key[2][4]) keydata=17;
else if(key[2][5]) keydata=18;
else if(key[3][0]) keydata=19;
else if(key[3][1]) keydata=20;
else if(key[3][2]) keydata=21;
else if(key[3][3]) keydata=22;
else if(key[3][4]) keydata=23;
else if(key[3][5]) keydata=24;
else if(key[4][0]) keydata=25;
else if(key[4][1]) keydata=26;
else if(key[4][2]) keydata=27;
else if(key[4][3]) keydata=28;
else if(key[4][4]) keydata=29;
else if(key[4][5]) keydata=30;
else if(key[5][0]) keydata=31;
else if(key[5][1]) keydata=32;
else if(key[5][2]) keydata=33;
else if(key[5][3]) keydata=34;
else if(key[5][4]) keydata=35;
else if(key[5][5]) keydata=36;
else ;
return keydata;
程序如上的时候,按键什么的输出正常,但是因为没有消除抖动,会有小问题。在去掉程序中的斜杠,加上消抖的时候,程序不正常执行了,按下某一个按键之后,就会死掉,求教为什么啊
IJK 发表于 2012-9-4 15:45 | 显示全部楼层
慢慢调试,其实不是很难。
figo20042005 发表于 2012-9-4 20:52 | 显示全部楼层
你的死掉是程序跑飞了?
 楼主| sanjue 发表于 2012-10-10 14:19 | 显示全部楼层
我加上了松手识别,好了,这么久才看到以前发的这个帖子
723737969 发表于 2013-6-12 00:01 | 显示全部楼层
我现在也遇到同样的问题 求解答
